I’ve been comparing my two Manjaro Gnome installed Services and have been seeing some differences in the Installed services in Systemd. I’ve been combing through the Systemd Wiki and Bugs to try to figure why both laptops do not have these services, so this is where I need a second opinion from the community.
Service Only on the Thinkpad x230 but not on the Thinkpad T430s:
initrd-cleanup.service
initrd-parse-etc.service
initrd-switch-root.service
initrd-udevadm-cleanup-db.service
linux-module-cleanup.service
sysroot.mount
systemd-fsck-root.service
The laptops are similar in:
- From same Intel generation i5 Thinkpad x230 and T430s).
- Updated to the same Manjaro Patch Level and Firmware.
- No Swap file or Partition.
The difference between the laptops:
- Installs image/ISO was from 2 years ago for the x230.
- Install image/ISO was from 3.5 years ago for the T430s
- The harddrives are partitioned differently (see below)
x230 Partition Layout
fdisk -l
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 860
Disklabel type: dos
Disk identifier: 0x6fa4558c
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 2459647 2457600 1.2G 7 HPFS/NTFS/exFAT
/dev/sda2 2459648 667525119 665065472 317.1G 7 HPFS/NTFS/exFAT
/dev/sda4 667525120 976773119 309248000 147.5G 83 Linux
Disk /dev/loop0: 61.2 MiB, 64172032 bytes, 125336 sectors
Disk /dev/loop1: 55.32 MiB, 58007552 bytes, 113296 sectors
Disk /dev/loop2: 61.26 MiB, 64233472 bytes, 125456 sectors
Disk /dev/loop3: 62.09 MiB, 65105920 bytes, 127160 sectors
Disk /dev/loop4: 29.89 MiB, 31342592 bytes, 61216 sectors
Disk /dev/loop5: 161.41 MiB, 169254912 bytes, 330576 sectors
T430 Partition Layout:
sudo fdisk -l
[sudo] password for root:
Disklabel type: dos
/dev/sda1 2048 2459647 2457600 1.2G 7 HPFS/NTFS/exFAT
/dev/sda2 * 2459648 3583999 1124352 549M 7 HPFS/NTFS/exFAT
/dev/sda3 3584000 689942527 686358528 327.3G 7 HPFS/NTFS/exFAT
/dev/sda4 689942528 976773119 286830592 136.8G 5 Extended
/dev/sda5 689944576 976773119 286828544 136.8G 83 Linux
Disk /dev/loop0: 161.41 MiB, 169254912 bytes, 330576 sectors
Disk /dev/loop1: 62.09 MiB, 65105920 bytes, 127160 sectors
Disk /dev/loop2: 29.89 MiB, 31342592 bytes, 61216 sectors
Disk /dev/loop3: 55.32 MiB, 58007552 bytes, 113296 sectors
Disk /dev/loop4: 61.2 MiB, 64172032 bytes, 125336 sectors
Disk /dev/loop5: 61.26 MiB, 64233472 bytes, 125456 sectors
x230 System Configuration:
inxi -Fza
System: Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=85ccbb8b-086b-4c3b-a6c8-a45951356c8e rw apparmor=1 security=apparmor
usbcore.autosuspend=-1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: v: ThinkPad X230 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: serial: <filter> UEFI [Legacy]: LENOVO
Battery: ID-1: BAT0 charge: 34.9 Wh condition: 34.9/57.7 Wh (60%) volts: 12.5/11.1
model: LGC 45N1025 type: Li-ion serial: <filter> status: Full
CPU: Topology: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 3A (58) stepping: 9 microcode: 21 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20763
Speed: 3095 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 3094 2: 3230 3: 2044
4: 2879
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Acer ThinkPad Integrated Camera type: USB driver: uvcvideo bus ID: 1-1.6:4
chip ID: 5986:02d2
Display: x11 server: X.Org 1.20.8 compositor: gnome-shell driver: intel
display ID: :1 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 124 size: 280x160mm (11.0x6.3")
diag: 322mm (12.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.7
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.4.64-1-MANJARO
Network: Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e v: 3.2.6-k
port: 6080 bus ID: 00:19.0 chip ID: 8086:1502
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel
port: efa0 bus ID: 03:00.0 chip ID: 8086:0085
Drives: Local Storage: total: 465.76 GiB used: 59.45 GiB (12.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to get data.
Partition: ID-1: / raw size: 147.46 GiB size: 144.15 GiB (97.75%) used: 59.45 GiB (41.2%)
fs: ext4 block size: 4096 B dev: /dev/sda4
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 48.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 247 Uptime: 3h 46m Memory: 11.41 GiB used: 1.68 GiB (14.7%) Init: systemd
v: 246 Compilers: gcc: 10.2.0 Packages: 1470 pacman: 1453 lib: 411 flatpak: 11
snap: 6 Shell: fish v: 3.1.2 running in: alacritty inxi: 3.1.05
