I have a Dell Inspiron 3437 and the integrated screen is damaged so I put a magnet on the lid switch, so the output will always be on the external monitor (this should´t be a problem I’m just explaining the context).
Every time I login the xfce4-panel seems to be loading but it suddenly it gets blank with nothing to do but Ctrl + Alt + F2
I looked online and, temporally solved it by executing kill -KILL -u myusername
, this is how I could install it , it reverts me to de lighdm login and then it loads normally, i heard about some bugs whit integrated graphics intel and the kernel but on the 5.11 where solved but updating to the 5.11 didn´t solve the problem here.
inxi -Gazy
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a06 class-ID: 0300
Device-2: Realtek Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-1.5:4 chip-ID: 0bda:58c2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: HDMI1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics (HSW GT1) v: 4.5 Mesa 21.0.1
compat-v: 3.0 direct render: Yes
xorg.1.log
[ 1179.202]
X.Org X Server 1.20.10
[ 1179.203] Build Operating System: Linux Manjaro Linux
[ 1179.203] Current Operating System: Linux inspiron3437 5.10.23-1-MANJARO #1 SMP PREEMPT Thu Mar 11 18:47:18 UTC 2021 x86_64
[ 1179.203] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=568c9e81-fccc-4815-96c6-b16e540f3188 rw quiet apparmor=1 security=apparmor resume=UUID=7df29bf3-4c1d-4fdf-8b36-b05fb7c58bc9 udev.log_priority=3
[ 1179.203] Build Date: 16 December 2020 10:33:32PM
[ 1179.203]
[ 1179.203] Current version of pixman: 0.40.0
[ 1179.203] Before reporting problems, check http://wiki.x.org
[ 1179.203] Markers: (--) probed, (**) from config file, (==) default setting,
[ 1179.203] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Apr 9 06:47:17 2021
[ 1179.240] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 1179.240] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 1179.240] (==) No Layout section. Using the first Screen section.
[ 1179.240] (==) No screen section available. Using defaults.
[ 1179.240] (**) |-->Screen "Default Screen Section" (0)
[ 1179.240] (**) | |-->Monitor "<default monitor>"
[ 1179.241] (==) No monitor specified for screen "Default Screen Section".
[ 1179.241] (==) Automatically adding devices
[ 1179.241] (==) Automatically enabling devices
[ 1179.241] (==) Automatically adding GPU devices
[ 1179.241] (==) Automatically binding GPU devices
[ 1179.241] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1179.241] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 1179.241] Entry deleted from font path.
[ 1179.241] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 1179.241] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 1179.241] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 1179.241] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 1179.241] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 1179.241] (II) The server relies on udev to provide the list of input devices.
[ 1179.241] (II) Module ABI versions:
[ 1179.241] X.Org ANSI C Emulation: 0.4
[ 1179.241] X.Org Video Driver: 24.1
[ 1179.241] X.Org XInput driver : 24.1
[ 1179.241] X.Org Server Extension : 10.0
[ 1179.243] (++) using VT number 8
[ 1179.243] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 1179.244] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1179.244] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[ 1179.246] (--) PCI:*(0@0:2:0) 8086:0a06:1028:05f3 rev 11, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 1179.247] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 1179.247] (II) LoadModule: "glx"
[ 1179.269] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1179.273] (II) Module glx: vendor="X.Org Foundation"
[ 1179.273] compiled for 1.20.10, module version = 1.0.0
[ 1179.273] ABI class: X.Org Server Extension, version 10.0
[ 1179.273] (==) Matched intel as autoconfigured driver 0
[ 1179.273] (==) Matched modesetting as autoconfigured driver 1
[ 1179.273] (==) Matched fbdev as autoconfigured driver 2
[ 1179.273] (==) Matched vesa as autoconfigured driver 3
[ 1179.273] (==) Assigned the driver to the xf86ConfigLayout
[ 1179.273] (II) LoadModule: "intel"
[ 1179.274] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 1179.274] (II) Module intel: vendor="X.Org Foundation"
[ 1179.274] compiled for 1.20.10, module version = 2.99.917
[ 1179.275] Module class: X.Org Video Driver
[ 1179.275] ABI class: X.Org Video Driver, version 24.1
[ 1179.275] (II) LoadModule: "modesetting"
[ 1179.275] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 1179.276] (II) Module modesetting: vendor="X.Org Foundation"
[ 1179.276] compiled for 1.20.10, module version = 1.20.10
[ 1179.276] Module class: X.Org Video Driver
[ 1179.276] ABI class: X.Org Video Driver, version 24.1
[ 1179.276] (II) LoadModule: "fbdev"
[ 1179.277] (WW) Warning, couldn't open module fbdev
[ 1179.277] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 1179.277] (II) LoadModule: "vesa"
[ 1179.277] (WW) Warning, couldn't open module vesa
[ 1179.277] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 1179.277] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 1179.278] (II) intel: Driver for Intel(R) HD Graphics
[ 1179.278] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 1179.278] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 1179.278] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 1179.812] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[ 1179.812] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[ 1179.829] (WW) Falling back to old probe method for modesetting
[ 1179.830] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[ 1179.830] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2; using a maximum of 2 threads
[ 1179.830] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 1179.830] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 1179.830] (==) intel(0): RGB weight 888
[ 1179.830] (==) intel(0): Default visual is TrueColor
[ 1179.830] (II) intel(0): Output eDP1 has no monitor section
[ 1179.831] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 1179.831] (II) intel(0): Enabled output eDP1
[ 1179.831] (II) intel(0): Output HDMI1 has no monitor section
[ 1179.831] (II) intel(0): Enabled output HDMI1
[ 1179.831] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 1179.831] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 1179.831] (II) intel(0): Enabled output VIRTUAL1
[ 1179.831] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[ 1179.831] (--) intel(0): Output HDMI1 using initial mode 1366x768 on pipe 1
[ 1179.831] (==) intel(0): TearFree disabled
[ 1179.831] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1179.831] (==) intel(0): DPI set to (96, 96)
[ 1179.831] (II) Loading sub module "dri3"
[ 1179.831] (II) LoadModule: "dri3"
[ 1179.831] (II) Module "dri3" already built-in
[ 1179.831] (II) Loading sub module "dri2"
[ 1179.831] (II) LoadModule: "dri2"
[ 1179.831] (II) Module "dri2" already built-in
[ 1179.831] (II) Loading sub module "present"
[ 1179.831] (II) LoadModule: "present"
[ 1179.831] (II) Module "present" already built-in
[ 1179.831] (II) UnloadModule: "modesetting"
[ 1179.832] (II) Unloading modesetting
[ 1179.832] (II) intel(0): SNA initialized with Haswell (gen7.5, gt1) backend
[ 1179.832] (==) intel(0): Backing store enabled
[ 1179.832] (==) intel(0): Silken mouse disabled
[ 1179.832] (II) intel(0): HW Cursor enabled
[ 1179.832] (==) intel(0): DPMS enabled
[ 1179.832] (==) intel(0): Display hotplug detection enabled
[ 1179.833] (II) intel(0): [DRI2] Setup complete
[ 1179.833] (II) intel(0): [DRI2] DRI driver: i965
[ 1179.833] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 1179.833] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 1179.833] (II) intel(0): hardware support for Present enabled
[ 1179.833] (II) Initializing extension Generic Event Extension
[ 1179.833] (II) Initializing extension SHAPE
[ 1179.833] (II) Initializing extension MIT-SHM
[ 1179.833] (II) Initializing extension XInputExtension
[ 1179.834] (II) Initializing extension XTEST
[ 1179.834] (II) Initializing extension BIG-REQUESTS
[ 1179.834] (II) Initializing extension SYNC
[ 1179.834] (II) Initializing extension XKEYBOARD
[ 1179.835] (II) Initializing extension XC-MISC
[ 1179.835] (II) Initializing extension SECURITY
[ 1179.835] (II) Initializing extension XFIXES
[ 1179.835] (II) Initializing extension RENDER
[ 1179.837] (II) Initializing extension RANDR
[ 1179.837] (II) Initializing extension COMPOSITE
[ 1179.837] (II) Initializing extension DAMAGE
[ 1179.838] (II) Initializing extension MIT-SCREEN-SAVER
[ 1179.838] (II) Initializing extension DOUBLE-BUFFER
[ 1179.838] (II) Initializing extension RECORD
[ 1179.839] (II) Initializing extension DPMS
[ 1179.839] (II) Initializing extension Present
[ 1179.839] (II) Initializing extension DRI3
[ 1179.839] (II) Initializing extension X-Resource
[ 1179.840] (II) Initializing extension XVideo
[ 1179.840] (II) Initializing extension XVideo-MotionCompensation
[ 1179.840] (II) Initializing extension GLX
[ 1179.879] (II) AIGLX: Loaded and initialized i965
[ 1179.879] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 1179.879] (II) Initializing extension XFree86-VidModeExtension
[ 1179.880] (II) Initializing extension XFree86-DGA
[ 1179.880] (II) Initializing extension XFree86-DRI
[ 1179.880] (II) Initializing extension DRI2
[ 1179.886] (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 1179.890] (II) intel(0): switch to mode 1366x768@60.0 on HDMI1 using pipe 1, position (0, 0), rotation normal, reflection none
[ 1179.890] (II) intel(0): Setting screen physical size to 361 x 203
[ 1179.953] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 1179.953] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 1179.953] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 1179.953] (**) Power Button: Applying InputClass "system-keyboard"
[ 1179.953] (II) LoadModule: "libinput"
[ 1179.953] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 1179.955] (II) Module libinput: vendor="X.Org Foundation"
[ 1179.955] compiled for 1.20.8, module version = 0.30.0
[ 1179.955] Module class: X.Org XInput Driver
[ 1179.955] ABI class: X.Org XInput driver, version 24.1
[ 1179.955] (II) Using input driver 'libinput' for 'Power Button'
[ 1179.955] (**) Power Button: always reports core events
[ 1179.955] (**) Option "Device" "/dev/input/event3"
[ 1179.955] (**) Option "_source" "server/udev"
[ 1179.959] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 1179.959] (II) event3 - Power Button: device is a keyboard
[ 1179.959] (II) event3 - Power Button: device removed
[ 1179.979] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 1179.979] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 1179.979] (**) Option "xkb_layout" "us"
[ 1179.979] (**) Option "xkb_variant" "intl"
[ 1180.012] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 1180.012] (II) event3 - Power Button: device is a keyboard
[ 1180.013] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 1180.013] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 1180.013] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 1180.013] (**) Video Bus: Applying InputClass "system-keyboard"
[ 1180.013] (II) Using input driver 'libinput' for 'Video Bus'
[ 1180.013] (**) Video Bus: always reports core events
[ 1180.013] (**) Option "Device" "/dev/input/event9"
[ 1180.013] (**) Option "_source" "server/udev"
[ 1180.015] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 1180.015] (II) event9 - Video Bus: device is a keyboard
[ 1180.015] (II) event9 - Video Bus: device removed
[ 1180.039] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event9"
[ 1180.039] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 1180.039] (**) Option "xkb_layout" "us"
[ 1180.039] (**) Option "xkb_variant" "intl"
[ 1180.041] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 1180.041] (II) event9 - Video Bus: device is a keyboard
[ 1180.042] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 1180.042] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 1180.042] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 1180.042] (**) Power Button: Applying InputClass "system-keyboard"
[ 1180.042] (II) Using input driver 'libinput' for 'Power Button'
[ 1180.042] (**) Power Button: always reports core events
[ 1180.042] (**) Option "Device" "/dev/input/event1"
[ 1180.042] (**) Option "_source" "server/udev"
[ 1180.043] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 1180.043] (II) event1 - Power Button: device is a keyboard
[ 1180.043] (II) event1 - Power Button: device removed
[ 1180.059] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 1180.059] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 1180.059] (**) Option "xkb_layout" "us"
[ 1180.059] (**) Option "xkb_variant" "intl"
[ 1180.061] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 1180.062] (II) event1 - Power Button: device is a keyboard
[ 1180.063] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 1180.063] (II) No input driver specified, ignoring this device.
[ 1180.063] (II) This device may have been added with another device file.
[ 1180.063] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 1180.063] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 1180.063] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 1180.063] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 1180.063] (II) Using input driver 'libinput' for 'Sleep Button'
[ 1180.063] (**) Sleep Button: always reports core events
[ 1180.063] (**) Option "Device" "/dev/input/event2"
[ 1180.063] (**) Option "_source" "server/udev"
[ 1180.065] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 1180.065] (II) event2 - Sleep Button: device is a keyboard
[ 1180.065] (II) event2 - Sleep Button: device removed
[ 1180.079] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 1180.079] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 1180.079] (**) Option "xkb_layout" "us"
[ 1180.079] (**) Option "xkb_variant" "intl"
[ 1180.081] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 1180.081] (II) event2 - Sleep Button: device is a keyboard
[ 1180.081] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 1180.081] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1180.081] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[ 1180.082] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event11)
[ 1180.082] (II) No input driver specified, ignoring this device.
[ 1180.082] (II) This device may have been added with another device file.
[ 1180.083] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event12)
[ 1180.083] (II) No input driver specified, ignoring this device.
[ 1180.083] (II) This device may have been added with another device file.
[ 1180.084] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event13)
[ 1180.084] (II) No input driver specified, ignoring this device.
[ 1180.084] (II) This device may have been added with another device file.
[ 1180.084] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event10)
[ 1180.086] (II) config/udev: Adding input device SEMICCHIP Usb Mouse (/dev/input/event5)
[ 1180.086] (**) SEMICCHIP Usb Mouse: Applying InputClass "evdev pointer catchall"
[ 1180.086] (**) SEMICCHIP Usb Mouse: Applying InputClass "libinput pointer catchall"
[ 1180.086] (II) Using input driver 'libinput' for 'SEMICCHIP Usb Mouse'
[ 1180.086] (**) SEMICCHIP Usb Mouse: always reports core events
[ 1180.086] (**) Option "Device" "/dev/input/event5"
[ 1180.086] (**) Option "_source" "server/udev"
[ 1180.144] (II) event5 - SEMICCHIP Usb Mouse: is tagged by udev as: Mouse
[ 1180.145] (II) event5 - SEMICCHIP Usb Mouse: device is a pointer
[ 1180.145] (II) event5 - SEMICCHIP Usb Mouse: device removed
[ 1180.169] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A2C:0042.0001/input/input6/event5"
[ 1180.169] (II) XINPUT: Adding extended input device "SEMICCHIP Usb Mouse" (type: MOUSE, id 10)
[ 1180.169] (**) Option "AccelerationScheme" "none"
[ 1180.169] (**) SEMICCHIP Usb Mouse: (accel) selected scheme none/0
[ 1180.169] (**) SEMICCHIP Usb Mouse: (accel) acceleration factor: 2.000
[ 1180.169] (**) SEMICCHIP Usb Mouse: (accel) acceleration threshold: 4
[ 1180.229] (II) event5 - SEMICCHIP Usb Mouse: is tagged by udev as: Mouse
[ 1180.229] (II) event5 - SEMICCHIP Usb Mouse: device is a pointer
[ 1180.231] (II) config/udev: Adding input device SEMICCHIP Usb Mouse (/dev/input/mouse0)
[ 1180.231] (II) No input driver specified, ignoring this device.
[ 1180.231] (II) This device may have been added with another device file.
[ 1180.232] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event14)
[ 1180.232] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 1180.232] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 1180.232] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 1180.232] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 1180.232] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 1180.232] (**) Option "Device" "/dev/input/event14"
[ 1180.232] (**) Option "_source" "server/udev"
[ 1180.234] (II) event14 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 1180.234] (II) event14 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 1180.235] (II) event14 - Integrated_Webcam_HD: Integrate: device removed
[ 1180.279] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input15/event14"
[ 1180.279] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 11)
[ 1180.279] (**) Option "xkb_layout" "us"
[ 1180.279] (**) Option "xkb_variant" "intl"
[ 1180.281] (II) event14 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 1180.282] (II) event14 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 1180.283] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 1180.283] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 1180.283] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 1180.283] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 1180.283] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 1180.283] (**) Dell WMI hotkeys: always reports core events
[ 1180.283] (**) Option "Device" "/dev/input/event8"
[ 1180.283] (**) Option "_source" "server/udev"
[ 1180.285] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 1180.285] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 1180.285] (II) event8 - Dell WMI hotkeys: device removed
[ 1180.332] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/PNP0C14:00-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input9/event8"
[ 1180.332] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 12)
[ 1180.332] (**) Option "xkb_layout" "us"
[ 1180.332] (**) Option "xkb_variant" "intl"
[ 1180.334] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 1180.334] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 1180.336] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 1180.336] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 1180.336] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 1180.336] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 1180.336] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 1180.336] (**) AT Translated Set 2 keyboard: always reports core events
[ 1180.336] (**) Option "Device" "/dev/input/event4"
[ 1180.336] (**) Option "_source" "server/udev"
[ 1180.337] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 1180.338] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 1180.339] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 1180.349] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 1180.349] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 1180.350] (**) Option "xkb_layout" "us"
[ 1180.350] (**) Option "xkb_variant" "intl"
[ 1180.352] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 1180.353] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 1180.354] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[ 1180.354] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 1180.354] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 1180.355] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 1180.355] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 1180.355] (**) Option "Device" "/dev/input/event7"
[ 1180.355] (**) Option "_source" "server/udev"
[ 1180.356] (II) event7 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 1180.358] (II) event7 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 1180.358] (II) event7 - SynPS/2 Synaptics TouchPad: device removed
[ 1180.399] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input8/event7"
[ 1180.399] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 14)
[ 1180.400] (**) Option "AccelerationScheme" "none"
[ 1180.400] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 1180.400] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 1180.400] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 1180.402] (II) event7 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 1180.403] (II) event7 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 1180.404] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 1180.404] (II) No input driver specified, ignoring this device.
[ 1180.405] (II) This device may have been added with another device file.
[ 1180.405] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 1180.405] (II) No input driver specified, ignoring this device.
[ 1182.491] (II) intel(0): EDID vendor "CMN", prod id 5234
[ 1182.491] (II) intel(0): Printing DDC gathered Modelines:
[ 1182.491] (II) intel(0): Modeline "1366x768"x0.0 69.30 1366 1414 1446 1466 768 769 773 788 -hsync -vsync (47.3 kHz eP)
[ 1186.607] (II) event5 - SEMICCHIP Usb Mouse: SYN_DROPPED event - some input events have been lost.
[ 1192.461] (II) event3 - Power Button: device removed
[ 1192.465] (II) event9 - Video Bus: device removed
[ 1192.489] (II) event1 - Power Button: device removed
[ 1192.499] (II) event2 - Sleep Button: device removed
[ 1192.512] (II) event5 - SEMICCHIP Usb Mouse: device removed
[ 1192.539] (II) event14 - Integrated_Webcam_HD: Integrate: device removed
[ 1192.566] (II) event8 - Dell WMI hotkeys: device removed
[ 1192.592] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 1192.606] (II) event7 - SynPS/2 Synaptics TouchPad: device removed
[ 1192.640] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 1192.850] (II) UnloadModule: "libinput"
[ 1192.851] (II) UnloadModule: "libinput"
[ 1192.869] (II) Server terminated successfully (0). Closing log file.
xorg.0.log
[ 132.327]
[ 132.327] Build Operating System: Linux Manjaro Linux
[ 132.327] Current Operating System: Linux inspiron3437 5.11.10-1-MANJARO #1 SMP PREEMPT Thu Mar 25 17:14:55 UTC 2021 x86_64
[ 132.327] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=568c9e81-fccc-4815-96c6-b16e540f3188 rw quiet apparmor=1 security=apparmor resume=UUID=7df29bf3-4c1d-4fdf-8b36-b05fb7c58bc9 udev.log_priority=3
[ 132.327] Build Date: 16 December 2020 10:33:32PM
[ 132.327]
[ 132.327] Current version of pixman: 0.40.0
[ 132.327] Before reporting problems, check http://wiki.x.org
[ 132.327] Markers: (--) probed, (**) from config file, (==) default setting,
[ 132.327] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 9 22:39:37 2021
[ 132.328] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 132.328] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 132.328] (==) No Layout section. Using the first Screen section.
[ 132.328] (==) No screen section available. Using defaults.
[ 132.328] (**) |-->Screen "Default Screen Section" (0)
[ 132.328] (**) | |-->Monitor "<default monitor>"
[ 132.328] (==) No monitor specified for screen "Default Screen Section".
[ 132.328] (==) Automatically adding devices
[ 132.328] (==) Automatically enabling devices
[ 132.328] (==) Automatically adding GPU devices
[ 132.328] (==) Automatically binding GPU devices
[ 132.328] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 132.328] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 132.328] Entry deleted from font path.
[ 132.328] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 132.328] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 132.328] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 132.329] (==) FontPath set to:
[ 132.329] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 132.329] (II) The server relies on udev to provide the list of input devices.
[ 132.329] (II) Module ABI versions:
[ 132.329] X.Org ANSI C Emulation: 0.4
[ 132.329] X.Org Video Driver: 24.1
[ 132.329] X.Org XInput driver : 24.1
[ 132.329] X.Org Server Extension : 10.0
[ 132.330] (++) using VT number 7
[ 132.330] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 132.331] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 132.351] (--) PCI:*(0@0:2:0) 8086:0a06:1028:05f3 rev 11, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 132.351] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 132.351] (II) LoadModule: "glx"
[ 132.351] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 132.354] (II) Module glx: vendor="X.Org Foundation"
[ 132.354] compiled for 1.20.10, module version = 1.0.0
[ 132.354] ABI class: X.Org Server Extension, version 10.0
[ 132.354] (==) Matched intel as autoconfigured driver 0
[ 132.354] (==) Matched modesetting as autoconfigured driver 1
[ 132.354] (==) Matched fbdev as autoconfigured driver 2
[ 132.354] (==) Matched vesa as autoconfigured driver 3
[ 132.354] (==) Assigned the driver to the xf86ConfigLayout
[ 132.354] (II) LoadModule: "intel"
[ 132.354] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 132.354] (II) Module intel: vendor="X.Org Foundation"
[ 132.354] compiled for 1.20.10, module version = 2.99.917
[ 132.354] Module class: X.Org Video Driver
[ 132.354] ABI class: X.Org Video Driver, version 24.1
[ 132.354] (II) LoadModule: "modesetting"
[ 132.355] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 132.355] (II) Module modesetting: vendor="X.Org Foundation"
[ 132.355] compiled for 1.20.10, module version = 1.20.10
[ 132.355] Module class: X.Org Video Driver
[ 132.355] ABI class: X.Org Video Driver, version 24.1
[ 132.355] (II) LoadModule: "fbdev"
[ 132.356] (WW) Warning, couldn't open module fbdev
[ 132.356] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 132.356] (II) LoadModule: "vesa"
[ 132.356] (WW) Warning, couldn't open module vesa
[ 132.356] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 132.356] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[ 132.357] (II) intel: Driver for Intel(R) HD Graphics
[ 132.357] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 132.357] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 132.357] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 132.372] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[ 132.372] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[ 132.387] (WW) Falling back to old probe method for modesetting
[ 132.387] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[ 132.387] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2; using a maximum of 2 threads
[ 132.387] (II) intel(0): Creating default Display subsection in Screen section
[ 132.387] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 132.387] (==) intel(0): RGB weight 888
[ 132.387] (==) intel(0): Default visual is TrueColor
[ 132.388] (II) intel(0): Output eDP1 has no monitor section
[ 132.388] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 132.388] (II) intel(0): Enabled output eDP1
[ 132.389] (II) intel(0): Output HDMI1 has no monitor section
[ 132.389] (II) intel(0): Enabled output HDMI1
[ 132.389] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 132.389] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 132.389] (II) intel(0): Enabled output VIRTUAL1
[ 132.389] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[ 132.389] (--) intel(0): Output HDMI1 using initial mode 1366x768 on pipe 1
[ 132.389] (==) intel(0): TearFree disabled
[ 132.389] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 132.389] (==) intel(0): DPI set to (96, 96)
[ 132.389] (II) Loading sub module "dri3"
[ 132.389] (II) LoadModule: "dri3"
[ 132.389] (II) Module "dri3" already built-in
[ 132.389] (II) Loading sub module "dri2"
[ 132.389] (II) LoadModule: "dri2"
[ 132.389] (II) Module "dri2" already built-in
[ 132.389] (II) Loading sub module "present"
[ 132.389] (II) LoadModule: "present"
[ 132.389] (II) Module "present" already built-in
[ 132.389] (II) UnloadModule: "modesetting"
[ 132.389] (II) Unloading modesetting
[ 132.390] (II) intel(0): SNA initialized with Haswell (gen7.5, gt1) backend
[ 132.390] (==) intel(0): Backing store enabled
[ 132.390] (==) intel(0): Silken mouse disabled
[ 132.390] (II) intel(0): HW Cursor enabled
[ 132.390] (==) intel(0): DPMS enabled
[ 132.390] (==) intel(0): Display hotplug detection enabled
[ 132.391] (II) intel(0): [DRI2] Setup complete
[ 132.391] (II) intel(0): [DRI2] DRI driver: i965
[ 132.391] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 132.391] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 132.391] (II) intel(0): hardware support for Present enabled
[ 132.391] (II) Initializing extension Generic Event Extension
[ 132.391] (II) Initializing extension SHAPE
[ 132.391] (II) Initializing extension MIT-SHM
[ 132.391] (II) Initializing extension XInputExtension
[ 132.392] (II) Initializing extension XTEST
[ 132.392] (II) Initializing extension BIG-REQUESTS
[ 132.392] (II) Initializing extension SYNC
[ 132.392] (II) Initializing extension XKEYBOARD
[ 132.393] (II) Initializing extension XC-MISC
[ 132.393] (II) Initializing extension SECURITY
[ 132.393] (II) Initializing extension XFIXES
[ 132.393] (II) Initializing extension RENDER
[ 132.394] (II) Initializing extension RANDR
[ 132.394] (II) Initializing extension COMPOSITE
[ 132.394] (II) Initializing extension DAMAGE
[ 132.395] (II) Initializing extension MIT-SCREEN-SAVER
[ 132.395] (II) Initializing extension DOUBLE-BUFFER
[ 132.395] (II) Initializing extension RECORD
[ 132.395] (II) Initializing extension DPMS
[ 132.396] (II) Initializing extension Present
[ 132.396] (II) Initializing extension DRI3
[ 132.396] (II) Initializing extension X-Resource
[ 132.396] (II) Initializing extension XVideo
[ 132.397] (II) Initializing extension XVideo-MotionCompensation
[ 132.397] (II) Initializing extension GLX
[ 132.416] (II) AIGLX: Loaded and initialized i965
[ 132.416] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 132.416] (II) Initializing extension XFree86-VidModeExtension
[ 132.416] (II) Initializing extension XFree86-DGA
[ 132.416] (II) Initializing extension XFree86-DRI
[ 132.416] (II) Initializing extension DRI2
[ 132.422] (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 132.432] (II) intel(0): switch to mode 1366x768@60.0 on HDMI1 using pipe 1, position (0, 0), rotation normal, reflection none
[ 132.435] (II) intel(0): Setting screen physical size to 361 x 203
[ 132.496] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 132.496] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 132.496] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 132.496] (**) Power Button: Applying InputClass "system-keyboard"
[ 132.496] (II) LoadModule: "libinput"
[ 132.496] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 132.499] (II) Module libinput: vendor="X.Org Foundation"
[ 132.499] compiled for 1.20.8, module version = 0.30.0
[ 132.499] Module class: X.Org XInput Driver
[ 132.499] ABI class: X.Org XInput driver, version 24.1
[ 132.499] (II) Using input driver 'libinput' for 'Power Button'
[ 132.499] (**) Power Button: always reports core events
[ 132.499] (**) Option "Device" "/dev/input/event3"
[ 132.499] (**) Option "_source" "server/udev"
[ 132.502] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 132.502] (II) event3 - Power Button: device is a keyboard
[ 132.502] (II) event3 - Power Button: device removed
[ 132.513] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 132.513] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 132.513] (**) Option "xkb_layout" "us"
[ 132.513] (**) Option "xkb_variant" "intl"
[ 132.558] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 132.558] (II) event3 - Power Button: device is a keyboard
[ 132.561] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 132.561] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 132.561] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 132.561] (**) Video Bus: Applying InputClass "system-keyboard"
[ 132.561] (II) Using input driver 'libinput' for 'Video Bus'
[ 132.561] (**) Video Bus: always reports core events
[ 132.561] (**) Option "Device" "/dev/input/event9"
[ 132.561] (**) Option "_source" "server/udev"
[ 132.563] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 132.563] (II) event9 - Video Bus: device is a keyboard
[ 132.563] (II) event9 - Video Bus: device removed
[ 132.587] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event9"
[ 132.587] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 132.587] (**) Option "xkb_layout" "us"
[ 132.587] (**) Option "xkb_variant" "intl"
[ 132.588] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 132.588] (II) event9 - Video Bus: device is a keyboard
[ 132.590] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 132.590] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 132.590] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 132.590] (**) Power Button: Applying InputClass "system-keyboard"
[ 132.590] (II) Using input driver 'libinput' for 'Power Button'
[ 132.590] (**) Power Button: always reports core events
[ 132.590] (**) Option "Device" "/dev/input/event1"
[ 132.590] (**) Option "_source" "server/udev"
[ 132.592] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 132.592] (II) event1 - Power Button: device is a keyboard
[ 132.592] (II) event1 - Power Button: device removed
[ 132.620] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 132.620] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 132.620] (**) Option "xkb_layout" "us"
[ 132.620] (**) Option "xkb_variant" "intl"
[ 132.623] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 132.623] (II) event1 - Power Button: device is a keyboard
[ 132.624] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 132.624] (II) No input driver specified, ignoring this device.
[ 132.624] (II) This device may have been added with another device file.
[ 132.625] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 132.625] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 132.625] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 132.625] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 132.625] (II) Using input driver 'libinput' for 'Sleep Button'
[ 132.625] (**) Sleep Button: always reports core events
[ 132.625] (**) Option "Device" "/dev/input/event2"
[ 132.625] (**) Option "_source" "server/udev"
[ 132.627] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 132.627] (II) event2 - Sleep Button: device is a keyboard
[ 132.627] (II) event2 - Sleep Button: device removed
[ 132.658] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 132.658] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 132.658] (**) Option "xkb_layout" "us"
[ 132.658] (**) Option "xkb_variant" "intl"
[ 132.659] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 132.659] (II) event2 - Sleep Button: device is a keyboard
[ 132.661] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event11)
[ 132.661] (II) No input driver specified, ignoring this device.
[ 132.661] (II) This device may have been added with another device file.
[ 132.662] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event12)
[ 132.662] (II) No input driver specified, ignoring this device.
[ 132.662] (II) This device may have been added with another device file.
[ 132.662] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event13)
[ 132.663] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event10)
[ 132.663] (II) No input driver specified, ignoring this device.
[ 132.663] (II) This device may have been added with another device file.
[ 132.665] (II) config/udev: Adding input device SEMICCHIP Usb Mouse (/dev/input/event5)
[ 132.665] (**) SEMICCHIP Usb Mouse: Applying InputClass "evdev pointer catchall"
[ 132.665] (**) SEMICCHIP Usb Mouse: Applying InputClass "libinput pointer catchall"
[ 132.665] (II) Using input driver 'libinput' for 'SEMICCHIP Usb Mouse'
[ 132.665] (**) SEMICCHIP Usb Mouse: always reports core events
[ 132.665] (**) Option "Device" "/dev/input/event5"
[ 132.665] (**) Option "_source" "server/udev"
[ 132.723] (II) event5 - SEMICCHIP Usb Mouse: is tagged by udev as: Mouse
[ 132.724] (II) event5 - SEMICCHIP Usb Mouse: device is a pointer
[ 132.724] (II) event5 - SEMICCHIP Usb Mouse: device removed
[ 132.765] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A2C:0042.0001/input/input6/event5"
[ 132.765] (II) XINPUT: Adding extended input device "SEMICCHIP Usb Mouse" (type: MOUSE, id 10)
[ 132.766] (**) Option "AccelerationScheme" "none"
[ 132.766] (**) SEMICCHIP Usb Mouse: (accel) selected scheme none/0
[ 132.766] (**) SEMICCHIP Usb Mouse: (accel) acceleration factor: 2.000
[ 132.766] (**) SEMICCHIP Usb Mouse: (accel) acceleration threshold: 4
[ 132.822] (II) event5 - SEMICCHIP Usb Mouse: is tagged by udev as: Mouse
[ 132.822] (II) event5 - SEMICCHIP Usb Mouse: device is a pointer
[ 132.824] (II) config/udev: Adding input device SEMICCHIP Usb Mouse (/dev/input/mouse0)
[ 132.824] (II) No input driver specified, ignoring this device.
[ 132.824] (II) This device may have been added with another device file.
[ 132.825] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event14)
[ 132.826] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 132.826] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 132.826] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 132.826] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 132.826] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 132.826] (**) Option "Device" "/dev/input/event14"
[ 132.826] (**) Option "_source" "server/udev"
[ 132.828] (II) event14 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 132.828] (II) event14 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 132.828] (II) event14 - Integrated_Webcam_HD: Integrate: device removed
[ 132.887] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input15/event14"
[ 132.887] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 11)
[ 132.887] (**) Option "xkb_layout" "us"
[ 132.887] (**) Option "xkb_variant" "intl"
[ 132.889] (II) event14 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 132.889] (II) event14 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 132.891] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 132.891] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 132.891] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 132.891] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 132.891] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 132.891] (**) Dell WMI hotkeys: always reports core events
[ 132.891] (**) Option "Device" "/dev/input/event8"
[ 132.891] (**) Option "_source" "server/udev"
[ 132.893] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 132.893] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 132.893] (II) event8 - Dell WMI hotkeys: device removed
[ 132.940] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/PNP0C14:00-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input9/event8"
[ 132.940] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 12)
[ 132.940] (**) Option "xkb_layout" "us"
[ 132.940] (**) Option "xkb_variant" "intl"
[ 132.944] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 132.944] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 132.947] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 132.947] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 132.947] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 132.947] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 132.947] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 132.947] (**) AT Translated Set 2 keyboard: always reports core events
[ 132.947] (**) Option "Device" "/dev/input/event4"
[ 132.947] (**) Option "_source" "server/udev"
[ 132.949] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 132.950] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 132.952] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 132.980] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 132.980] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 132.980] (**) Option "xkb_layout" "us"
[ 132.980] (**) Option "xkb_variant" "intl"
[ 132.983] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 132.984] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 132.987] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[ 132.987] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 132.987] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 132.987] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 132.987] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 132.987] (**) Option "Device" "/dev/input/event7"
[ 132.987] (**) Option "_source" "server/udev"
[ 132.990] (II) event7 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 132.992] (II) event7 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 132.992] (II) event7 - SynPS/2 Synaptics TouchPad: device removed
[ 133.047] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input8/event7"
[ 133.047] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 14)
[ 133.049] (**) Option "AccelerationScheme" "none"
[ 133.049] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 133.049] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 133.049] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 133.051] (II) event7 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 133.052] (II) event7 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 133.054] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 133.054] (II) No input driver specified, ignoring this device.
[ 133.054] (II) This device may have been added with another device file.
[ 133.054] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 134.392] (II) intel(0): EDID vendor "CMN", prod id 5234
[ 134.392] (II) intel(0): Printing DDC gathered Modelines:
[ 134.392] (II) intel(0): Modeline "1366x768"x0.0 69.30 1366 1414 1446 1466 768 769 773 788 -hsync -vsync (47.3 kHz eP)
