Hi,
Today, by looking at the journal logs, for curiosity I wanted to check the logs of fsck about the SSD, I executed the following command:
journalctl -u systemd-fsck*
Which spited out:
nov 22 22:18:03 manjaro systemd[1]: Starting File System Check on /dev/disk/by-uuid/0d37cf27-2ff0-4234-a80e-4be323299166...
nov 22 22:18:03 manjaro systemd-fsck[176]: sda1: fsck.ext4 doesn't exist, not checking file system.
nov 22 22:18:03 manjaro systemd[1]: Finished File System Check on /dev/disk/by-uuid/0d37cf27-2ff0-4234-a80e-4be323299166.
nov 22 21:18:04 Probook systemd-fsck[243]: servicedisk: clean, 311/15269888 files, 10415536/61049344 blocks
On the second line complains about the fact that fsck.ext4 doesn’t exist (instead exists: /usr/bin/fsck.ext4), so no file system check has been performed, but on the fourth line states:
The strange fact is not only this contradiction, but also that: dev/disk/by-uuid/0d37cf27-2ff0-4234-a80e-4be323299166 is the main SSD where Manjaro is installed, and servicedisk (UUID 8412b438-5d7b-48bd-bfb1-46666bb7ac64) is the second SSD where I keep my data; by judging from this log seems that only the second SSD has been checked by fsck, is right? And if so, why?
My SSDs in /etc/fstab:
UUID=0d37cf27-2ff0-4234-a80e-4be323299166 / ext4 defaults,noatime,commit=60 0 1
UUID=8412b438-5d7b-48bd-bfb1-46666bb7ac64 /home/dave/mounts/servicedisk/ ext4 defaults,noatime,commit=60 0 2
