Naturally, we’d prefer you didn’t.
It’s not the kernel - it is either the version of e2fsprogs
that was present and used to initially create the file system
or the default settings that where used when creating the file system
The feature that is causing this issue is called: orphan_file
cat /etc/mke2fs.conf
lists the file with the current defaults when a file system is created
That feature is present in Manjaro defaults - but not (yet) in Ubuntu.
Older versions of e2fsprogs
do not know this feature and cannot support it.
That is why disabling the feature on the file system will then enable the older e2fsck program to work.
sudo dumpe2fs /dev/sdaX | grep features
to find out
sudo tune2fs -O ^orphan_file /dev/sdaX
to disable
