I have my system installed using btrfs (if that helps) and up until kernel 6.0 it was fine, I mean it is still fine now and boot into the OS but up until kernel 6.0 there’s no boot log error that says Failed to mount /dev/binderfs
, but after upgrading into kernel 6.1, the boot log always containing the previous message, some caused by /var/log
already defined, I commented out the entry that mount /var/log
on /etc/fstab
and that particular message disappeared next boot, but some are still exists.
After searching through Google, it seems that binderfs is kinda Android thing? Which I’m not sure if I need it because in /etc/fstab
also contains an entry that mount /dev/binderfs
Here’s the full content of /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=95BB-4E97 /boot/efi vfat umask=0077 0 2
UUID=1c0e69fe-b060-48db-a349-cba392a1348b / btrfs subvol=/@,noatime,nodiratime,discard,noautodefrag,compress=zstd:10 0 0
UUID=1c0e69fe-b060-48db-a349-cba392a1348b /home btrfs subvol=/@home,noatime,nodiratime,discard,noautodefrag,compress=zstd:10 0 0
UUID=1c0e69fe-b060-48db-a349-cba392a1348b /var/cache btrfs subvol=/@cache,noatime,nodiratime,discard,noautodefrag,compress=zstd:10 0 0
# Ignored because apparently the generator trying to mount it themselves
# UUID=1c0e69fe-b060-48db-a349-cba392a1348b /var/log btrfs subvol=/@log,noatime,nodiratime,discard,noautodefrag,compress=zstd:15 0 0
#UUID=1e46ce06-1adf-4c6f-a1fa-0d32af9e407b swap swap noatime,nodiratime,discard 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/log tmpfs defaults,noatime,mode=0755 0 0
tmpfs /var/spool tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/tmp tmpfs defaults,noatime,mode=1777 0 0
/dev/zram0 none swap defaults 0 0
binder /dev/binderfs binder nofail 0 0
UUID=f2152f6e-6944-44dd-9e0e-b658b967122e /mnt/tier_3_archive btrfs autodefrag,compress=zstd:10,x-gvfs-name=Tier%203%20%28Archive%29 0 0
UUID=071e64de-e374-428b-8397-cc2034f61b96 /mnt/tier_2_common btrfs autodefrag,compress=zstd:10,x-gvfs-name=Tier%202%20%28Common%29 0 0
UUID=1f079cd8-f00b-42b3-ac38-82ec4cdd2651 /mnt/tier_1_owl btrfs noatime,nodiratime,discard,noautodefrag,compress=zstd:10,x-gvfs-name=Tier%201%20%28Owl%29 0 0
So, I’m thingking, should I remove the binder
file system from fstab
? And what is it exactly? Do I need it? Is the OS need it?
Edit:
Now that I’m reading the file the 2nd time, you might already wondering why’s there two entry that have the same /var/log
mount point? I don’t know either, but apparently it works on kernel pre-6.0
Edit 2:
Here’s the snippet of the dmesg
content containing the error:
[ 4.634277] systemd[1]: Created slice Slice /system/getty.
[ 4.634529] systemd[1]: Created slice Slice /system/modprobe.
[ 4.634739] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 4.634900] systemd[1]: Created slice User and Session Slice.
[ 4.634978] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.635055] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.635196] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.635282] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.635328] systemd[1]: Reached target Login Prompts.
[ 4.635369] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 4.635423] systemd[1]: Reached target Remote File Systems.
[ 4.635465] systemd[1]: Reached target Slice Units.
[ 4.635505] systemd[1]: Reached target Mounting snaps.
[ 4.635543] systemd[1]: Reached target Mounted snaps.
[ 4.635592] systemd[1]: Reached target Local Verity Protected Volumes.
[ 4.635675] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.636096] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.636755] systemd[1]: Listening on Process Core Dump Socket.
[ 4.636885] systemd[1]: Listening on Journal Audit Socket.
[ 4.636983] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.637082] systemd[1]: Listening on Journal Socket.
[ 4.637507] systemd[1]: Listening on udev Control Socket.
[ 4.637593] systemd[1]: Listening on udev Kernel Socket.
[ 4.638105] systemd[1]: Mounting /dev/binderfs...
[ 4.638644] systemd[1]: Mounting Huge Pages File System...
[ 4.639172] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.639716] systemd[1]: Mounting Kernel Debug File System...
[ 4.640255] systemd[1]: Mounting Kernel Trace File System...
[ 4.640959] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.641525] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.642152] systemd[1]: Starting Load Kernel Module configfs...
[ 4.642758] systemd[1]: Starting Load Kernel Module drm...
[ 4.643406] systemd[1]: Starting Load Kernel Module fuse...
[ 4.644840] systemd[1]: Starting Load Kernel Modules...
[ 4.645433] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.645524] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 4.646060] systemd[1]: Starting Coldplug All udev Devices...
[ 4.647014] systemd[1]: dev-binderfs.mount: Mount process exited, code=exited, status=32/n/a
[ 4.647019] systemd[1]: dev-binderfs.mount: Failed with result 'exit-code'.
[ 4.652687] fuse: init (API version 7.37)
[ 4.659559] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.659587] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 4.659636] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 4.659658] sd 5:0:0:0: Attached scsi generic sg3 type 0
[ 4.664535] mc: Linux media interface: v0.10
[ 4.674607] videodev: Linux video capture interface: v2.00
[ 4.676462] v4l2loopback driver version 0.12.7 loaded
[ 4.680746] systemd[1]: Failed to mount /dev/binderfs.
[ 4.681059] systemd[1]: Mounted Huge Pages File System.
[ 4.681156] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.681245] systemd[1]: Mounted Kernel Debug File System.
[ 4.681329] systemd[1]: Mounted Kernel Trace File System.
[ 4.704138] systemd[1]: Finished Create List of Static Device Nodes.
[ 4.704428] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 4.711882] vboxdrv: Found 4 processor cores/threads
[ 4.737440] systemd[1]: Finished Load Kernel Module configfs.
[ 4.737715] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 4.737963] vboxdrv: TSC mode is Invariant, tentative frequency 3599989388 Hz
[ 4.737965] vboxdrv: Successfully loaded version 7.0.4 r154605 (interface 0x00330004)
[ 4.739211] VBoxNetAdp: Successfully started.
[ 4.740637] VBoxNetFlt: Successfully started.
[ 4.749252] device-mapper: uevent: version 1.0.3
[ 4.749350] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 4.754081] systemd[1]: Finished Load Kernel Module drm.
[ 4.756071] BTRFS info (device nvme0n1p2: state M): turning on sync discard
[ 4.756075] BTRFS info (device nvme0n1p2: state M): use zstd compression, level 10
[ 4.757286] usb 1-4: new full-speed USB device number 5 using xhci_hcd
[ 4.762610] zram: Added device: zram0
[ 4.770726] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 4.771377] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 4.787400] systemd[1]: Finished Load Kernel Module fuse.
[ 4.807401] systemd[1]: Finished Load Kernel Modules.
[ 4.840716] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.860727] systemd[1]: Finished Coldplug All udev Devices.
[ 4.877380] systemd[1]: Mounting FUSE Control File System...
[ 4.877921] systemd[1]: Mounting Kernel Configuration File System...
[ 4.877994] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 4.878485] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 4.879012] systemd[1]: Starting Load/Save Random Seed...
[ 4.879570] systemd[1]: Starting Apply Kernel Variables...
[ 4.879661] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 4.880177] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.882077] systemd[1]: Mounted FUSE Control File System.
[ 4.883093] systemd[1]: Mounted Kernel Configuration File System.
[ 4.899270] usb 1-4: New USB device found, idVendor=046d, idProduct=0ac4, bcdDevice= 9.00
[ 4.899273] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.899274] usb 1-4: Product: G535 Wireless Gaming Headset
[ 4.899275] usb 1-4: Manufacturer: Logitech
[ 4.902657] input: Logitech G535 Wireless Gaming Headset Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.3/0003:046D:0AC4.0005/input/input12
[ 4.924152] systemd[1]: Finished Apply Kernel Variables.
[ 4.954081] systemd[1]: Finished Load/Save Random Seed.
[ 4.955151] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 4.957512] hid-generic 0003:046D:0AC4.0005: input,hiddev98,hidraw4: USB HID v1.11 Device [Logitech G535 Wireless Gaming Headset] on usb-0000:00:14.0-4/input3
[ 4.987328] usb 1-3.1: new high-speed USB device number 6 using xhci_hcd
[ 4.990730] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 4.991738] systemd[1]: Reached target Preparation for Local File Systems.
[ 4.992699] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 4.992714] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 5.017461] systemd[1]: Starting Journal Service...
[ 5.018953] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 5.048614] systemd[1]: Started Journal Service.
Here’s the full dmesg
content :
dmesg content
[ 0.000000] microcode: microcode updated early to revision 0xf0, date = 2021-11-12
[ 0.000000] Linux version 6.1.1-1-MANJARO (builduser@fv-az191-932) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT_DYNAMIC Wed Dec 21 23:21:50 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64 root=UUID=1c0e69fe-b060-48db-a349-cba392a1348b rw rootflags=subvol=@ quite apparmor=1 security=apparmor udev.log_priority=3 nvidia-drm.modeset=1 nowatchdog usbcore.autosuspend=-1 sysrq_always_enabled=1 module_blacklist=iTCO_wdt mitigations=off
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 2032
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007d5fcfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007d5fd000-0x000000007ee68fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007ee69000-0x000000007f2edfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007f2ee000-0x000000007f3c0fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007f3c1000-0x000000007fc1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007fc20000-0x000000007fd0dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000007fd0e000-0x000000007fd0efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007fd0f000-0x00000000887fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000008757fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0x7f301000 ACPI=0x7f301000 TPMFinalLog=0x7f36b000 SMBIOS=0x7fa69000 SMBIOS 3.0=0x7fa68000 MEMATTR=0x7a28f018 ESRT=0x780b3518
[ 0.000000] SMBIOS 3.1.1 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z390 Phantom Gaming 4S, BIOS P1.40 12/05/2019
[ 0.000000] tsc: Detected 3600.000 MHz processor
[ 0.000522] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000525] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000531] last_pfn = 0x875800 max_arch_pfn = 0x400000000
[ 0.000623] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001033] last_pfn = 0x7fd0f max_arch_pfn = 0x400000000
[ 0.007532] esrt: Reserving ESRT space from 0x00000000780b3518 to 0x00000000780b3550.
[ 0.007535] e820: update [mem 0x780b3000-0x780b3fff] usable ==> reserved
[ 0.007547] Kernel/User page tables isolation: disabled on command line.
[ 0.007549] Using GB pages for direct mapping
[ 0.007700] Secure boot disabled
[ 0.007700] RAMDISK: [mem 0x2b017000-0x31802fff]
[ 0.007704] ACPI: Early table checksum verification disabled
[ 0.007706] ACPI: RSDP 0x000000007F301000 000024 (v02 ALASKA)
[ 0.007709] ACPI: XSDT 0x000000007F3010B0 0000DC (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007713] ACPI: FACP 0x000000007F342B68 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.007717] ACPI: DSDT 0x000000007F301220 041948 (v02 ALASKA A M I 01072009 INTL 20160527)
[ 0.007719] ACPI: FACS 0x000000007F3C0080 000040
[ 0.007721] ACPI: APIC 0x000000007F342C80 000084 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.007723] ACPI: FPDT 0x000000007F342D08 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007726] ACPI: FIDT 0x000000007F342D50 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007728] ACPI: MCFG 0x000000007F342DF0 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.007730] ACPI: SSDT 0x000000007F342E30 000378 (v01 SataRe SataTabl 00001000 INTL 20160527)
[ 0.007732] ACPI: SSDT 0x000000007F3431A8 001B1C (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.007735] ACPI: AAFT 0x000000007F344CC8 000264 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.007737] ACPI: SSDT 0x000000007F344F30 0031C6 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.007739] ACPI: SSDT 0x000000007F3480F8 00231B (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.007741] ACPI: HPET 0x000000007F34A418 000038 (v01 ALASKA A M I 00000002 01000013)
[ 0.007743] ACPI: SSDT 0x000000007F34A450 002950 (v02 INTEL xh_cfsd4 00000000 INTL 20160527)
[ 0.007746] ACPI: UEFI 0x000000007F34CDA0 000042 (v01 ALASKA A M I 00000002 01000013)
[ 0.007748] ACPI: LPIT 0x000000007F34CDE8 00005C (v01 ALASKA A M I 00000002 01000013)
[ 0.007750] ACPI: SSDT 0x000000007F34CE48 0014E2 (v02 ALASKA TbtTypeC 00000000 INTL 20160527)
[ 0.007752] ACPI: DBGP 0x000000007F34E330 000034 (v01 ALASKA A M I 00000002 01000013)
[ 0.007754] ACPI: DBG2 0x000000007F34E368 000054 (v00 ALASKA A M I 00000002 01000013)
[ 0.007756] ACPI: SSDT 0x000000007F34E3C0 001B67 (v02 ALASKA UsbCTabl 00001000 INTL 20160527)
[ 0.007759] ACPI: SSDT 0x000000007F34FF28 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.007761] ACPI: DMAR 0x000000007F350070 000070 (v01 INTEL EDK2 00000002 01000013)
[ 0.007763] ACPI: BGRT 0x000000007F3500E0 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007765] ACPI: TPM2 0x000000007F350118 000034 (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.007767] ACPI: WSMT 0x000000007F350150 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.007769] ACPI: Reserving FACP table memory at [mem 0x7f342b68-0x7f342c7b]
[ 0.007770] ACPI: Reserving DSDT table memory at [mem 0x7f301220-0x7f342b67]
[ 0.007771] ACPI: Reserving FACS table memory at [mem 0x7f3c0080-0x7f3c00bf]
[ 0.007772] ACPI: Reserving APIC table memory at [mem 0x7f342c80-0x7f342d03]
[ 0.007772] ACPI: Reserving FPDT table memory at [mem 0x7f342d08-0x7f342d4b]
[ 0.007773] ACPI: Reserving FIDT table memory at [mem 0x7f342d50-0x7f342deb]
[ 0.007773] ACPI: Reserving MCFG table memory at [mem 0x7f342df0-0x7f342e2b]
[ 0.007774] ACPI: Reserving SSDT table memory at [mem 0x7f342e30-0x7f3431a7]
[ 0.007774] ACPI: Reserving SSDT table memory at [mem 0x7f3431a8-0x7f344cc3]
[ 0.007775] ACPI: Reserving AAFT table memory at [mem 0x7f344cc8-0x7f344f2b]
[ 0.007776] ACPI: Reserving SSDT table memory at [mem 0x7f344f30-0x7f3480f5]
[ 0.007776] ACPI: Reserving SSDT table memory at [mem 0x7f3480f8-0x7f34a412]
[ 0.007777] ACPI: Reserving HPET table memory at [mem 0x7f34a418-0x7f34a44f]
[ 0.007777] ACPI: Reserving SSDT table memory at [mem 0x7f34a450-0x7f34cd9f]
[ 0.007778] ACPI: Reserving UEFI table memory at [mem 0x7f34cda0-0x7f34cde1]
[ 0.007779] ACPI: Reserving LPIT table memory at [mem 0x7f34cde8-0x7f34ce43]
[ 0.007779] ACPI: Reserving SSDT table memory at [mem 0x7f34ce48-0x7f34e329]
[ 0.007780] ACPI: Reserving DBGP table memory at [mem 0x7f34e330-0x7f34e363]
[ 0.007780] ACPI: Reserving DBG2 table memory at [mem 0x7f34e368-0x7f34e3bb]
[ 0.007781] ACPI: Reserving SSDT table memory at [mem 0x7f34e3c0-0x7f34ff26]
[ 0.007782] ACPI: Reserving SSDT table memory at [mem 0x7f34ff28-0x7f35006b]
[ 0.007782] ACPI: Reserving DMAR table memory at [mem 0x7f350070-0x7f3500df]
[ 0.007783] ACPI: Reserving BGRT table memory at [mem 0x7f3500e0-0x7f350117]
[ 0.007783] ACPI: Reserving TPM2 table memory at [mem 0x7f350118-0x7f35014b]
[ 0.007784] ACPI: Reserving WSMT table memory at [mem 0x7f350150-0x7f350177]
[ 0.007929] No NUMA configuration found
[ 0.007929] Faking a node at [mem 0x0000000000000000-0x00000008757fffff]
[ 0.007932] NODE_DATA(0) allocated [mem 0x8757fb000-0x8757fffff]
[ 0.007971] Zone ranges:
[ 0.007972] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007973] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007974] Normal [mem 0x0000000100000000-0x00000008757fffff]
[ 0.007976] Device empty
[ 0.007976] Movable zone start for each node
[ 0.007977] Early memory node ranges
[ 0.007977] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.007978] node 0: [mem 0x0000000000100000-0x000000007d5fcfff]
[ 0.007979] node 0: [mem 0x000000007ee69000-0x000000007f2edfff]
[ 0.007980] node 0: [mem 0x000000007fd0e000-0x000000007fd0efff]
[ 0.007980] node 0: [mem 0x0000000100000000-0x00000008757fffff]
[ 0.007983] Initmem setup node 0 [mem 0x0000000000001000-0x00000008757fffff]
[ 0.007986] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.008003] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.010497] On node 0, zone DMA32: 6252 pages in unavailable ranges
[ 0.010518] On node 0, zone DMA32: 2592 pages in unavailable ranges
[ 0.047833] On node 0, zone Normal: 753 pages in unavailable ranges
[ 0.047912] On node 0, zone Normal: 10240 pages in unavailable ranges
[ 0.048163] ACPI: PM-Timer IO Port: 0x1808
[ 0.048168] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.048169] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.048170] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.048170] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.048209] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.048211] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.048212] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.048215] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.048216] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.048221] e820: update [mem 0x77f9f000-0x77fdffff] usable ==> reserved
[ 0.048230] TSC deadline timer available
[ 0.048230] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.048242] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.048244] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.048245] PM: hibernation: Registered nosave memory: [mem 0x77f9f000-0x77fdffff]
[ 0.048246] PM: hibernation: Registered nosave memory: [mem 0x780b3000-0x780b3fff]
[ 0.048248] PM: hibernation: Registered nosave memory: [mem 0x7d5fd000-0x7ee68fff]
[ 0.048249] PM: hibernation: Registered nosave memory: [mem 0x7f2ee000-0x7f3c0fff]
[ 0.048249] PM: hibernation: Registered nosave memory: [mem 0x7f3c1000-0x7fc1ffff]
[ 0.048250] PM: hibernation: Registered nosave memory: [mem 0x7fc20000-0x7fd0dfff]
[ 0.048251] PM: hibernation: Registered nosave memory: [mem 0x7fd0f000-0x887fffff]
[ 0.048251] PM: hibernation: Registered nosave memory: [mem 0x88800000-0xdfffffff]
[ 0.048252] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.048252] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.048253] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.048253] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.048254] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.048254] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.048255] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.048255] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
[ 0.048256] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.048256] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.048257] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.048258] [mem 0x88800000-0xdfffffff] available for PCI devices
[ 0.048259] Booting paravirtualized kernel on bare hardware
[ 0.048260] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.052671] setup_percpu: NR_CPUS:320 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.052773] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u524288
[ 0.052778] pcpu-alloc: s221184 r8192 d28672 u524288 alloc=1*2097152
[ 0.052780] pcpu-alloc: [0] 0 1 2 3
[ 0.052795] Fallback order for Node 0: 0
[ 0.052797] Built 1 zonelists, mobility grouping on. Total pages: 8205496
[ 0.052798] Policy zone: Normal
[ 0.052798] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64 root=UUID=1c0e69fe-b060-48db-a349-cba392a1348b rw rootflags=subvol=@ quite apparmor=1 security=apparmor udev.log_priority=3 nvidia-drm.modeset=1 nowatchdog usbcore.autosuspend=-1 sysrq_always_enabled=1 module_blacklist=iTCO_wdt mitigations=off
[ 0.052913] sysrq: sysrq always enabled.
[ 0.052928] Unknown kernel command line parameters "quite BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64", will be passed to user space.
[ 0.052960] random: crng init done
[ 0.054049] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.054594] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.054702] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.054709] software IO TLB: area num 4.
[ 0.113389] Memory: 32505336K/33343620K available (16391K kernel code, 2132K rwdata, 11072K rodata, 2148K init, 3360K bss, 838024K reserved, 0K cma-reserved)
[ 0.113479] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.113490] ftrace: allocating 46412 entries in 182 pages
[ 0.119658] ftrace: allocated 182 pages with 5 groups
[ 0.119711] Dynamic Preempt: full
[ 0.119732] rcu: Preemptible hierarchical RCU implementation.
[ 0.119732] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.119733] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.119734] Trampoline variant of Tasks RCU enabled.
[ 0.119734] Rude variant of Tasks RCU enabled.
[ 0.119734] Tracing variant of Tasks RCU enabled.
[ 0.119735] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.119736] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.123035] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ 0.123282] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.123518] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.123538] Console: colour dummy device 80x25
[ 0.123551] printk: console [tty0] enabled
[ 0.123565] ACPI: Core revision 20220331
[ 0.123860] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.123951] APIC: Switch to symmetric I/O mode setup
[ 0.123952] DMAR: Host address width 39
[ 0.123953] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.123957] DMAR: dmar0: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.123959] DMAR: RMRR base: 0x0000007f6b2000 end: 0x0000007f8fbfff
[ 0.123961] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 0
[ 0.123962] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.123963] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.125426] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.125427] x2apic enabled
[ 0.125452] Switched APIC routing to cluster x2apic.
[ 0.130207] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.143916] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x33e452fbb2f, max_idle_ns: 440795236593 ns
[ 0.143920] Calibrating delay loop (skipped), value calculated using timer frequency.. 7202.00 BogoMIPS (lpj=12000000)
[ 0.143922] pid_max: default: 32768 minimum: 301
[ 0.146039] LSM: Security Framework initializing
[ 0.146048] landlock: Up and running.
[ 0.146049] Yama: becoming mindful.
[ 0.146055] LSM support for eBPF active
[ 0.146071] AppArmor: AppArmor initialized
[ 0.146118] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.146163] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.146340] CPU0: Thermal monitoring enabled (TM1)
[ 0.146374] process: using mwait in idle threads
[ 0.146375] Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
[ 0.146376] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.146380] Spectre V2 : User space: Vulnerable
[ 0.146381] Speculative Store Bypass: Vulnerable
[ 0.146385] SRBDS: Vulnerable
[ 0.161697] Freeing SMP alternatives memory: 36K
[ 0.161896] smpboot: CPU0: Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz (family: 0x6, model: 0x9e, stepping: 0xb)
[ 0.161985] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.161986] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.161995] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.162005] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.162012] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.162029] ... version: 4
[ 0.162029] ... bit width: 48
[ 0.162030] ... generic registers: 8
[ 0.162030] ... value mask: 0000ffffffffffff
[ 0.162031] ... max period: 00007fffffffffff
[ 0.162032] ... fixed-purpose events: 3
[ 0.162032] ... event mask: 00000007000000ff
[ 0.162115] Estimated ratio of average max frequency by base frequency (times 1024): 1024
[ 0.162127] rcu: Hierarchical SRCU implementation.
[ 0.162128] rcu: Max phase no-delay instances is 1000.
[ 0.162552] smp: Bringing up secondary CPUs ...
[ 0.162612] x86: Booting SMP configuration:
[ 0.162613] .... node #0, CPUs: #1 #2 #3
[ 0.164643] smp: Brought up 1 node, 4 CPUs
[ 0.164643] smpboot: Max logical packages: 1
[ 0.164643] smpboot: Total of 4 processors activated (28811.00 BogoMIPS)
[ 0.165388] devtmpfs: initialized
[ 0.165388] x86/mm: Memory block size: 128MB
[ 0.167560] ACPI: PM: Registering ACPI NVS region [mem 0x7f2ee000-0x7f3c0fff] (864256 bytes)
[ 0.167594] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.167599] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.167629] pinctrl core: initialized pinctrl subsystem
[ 0.167855] PM: RTC time: 09:43:09, date: 2023-01-06
[ 0.168140] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.168423] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.168613] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.168807] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.168820] audit: initializing netlink subsys (disabled)
[ 0.168862] audit: type=2000 audit(1672998189.043:1): state=initialized audit_enabled=0 res=1
[ 0.168929] thermal_sys: Registered thermal governor 'fair_share'
[ 0.168930] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.168931] thermal_sys: Registered thermal governor 'step_wise'
[ 0.168931] thermal_sys: Registered thermal governor 'user_space'
[ 0.168932] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.168951] cpuidle: using governor ladder
[ 0.168951] cpuidle: using governor menu
[ 0.168951] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.168951] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.168951] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.168951] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.168951] PCI: Using configuration type 1 for base access
[ 0.168951] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.168951] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.173945] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.173945] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.173945] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.173945] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.174456] ACPI: Added _OSI(Module Device)
[ 0.174456] ACPI: Added _OSI(Processor Device)
[ 0.174456] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.174456] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.235856] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.241185] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.242263] ACPI: Dynamic OEM Table Load:
[ 0.242267] ACPI: SSDT 0xFFFF8B6F014BC800 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.244100] ACPI: Dynamic OEM Table Load:
[ 0.244104] ACPI: SSDT 0xFFFF8B6F014BD800 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.247451] ACPI: Interpreter enabled
[ 0.247484] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.247485] ACPI: Using IOAPIC for interrupt routing
[ 0.247582] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.247583] PCI: Using E820 reservations for host bridge windows
[ 0.248652] ACPI: Enabled 10 GPEs in block 00 to 7F
[ 0.260916] ACPI: PM: Power Resource [USBC]
[ 0.263413] ACPI: PM: Power Resource [V0PR]
[ 0.263767] ACPI: PM: Power Resource [V1PR]
[ 0.264119] ACPI: PM: Power Resource [V2PR]
[ 0.269254] ACPI: PM: Power Resource [WRST]
[ 0.272140] ACPI: PM: Power Resource [PIN]
[ 0.272531] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.272537] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.272627] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ 0.272788] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[ 0.272789] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.273767] PCI host bridge to bus 0000:00
[ 0.273769] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.273771] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.273772] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.273773] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff window]
[ 0.273774] pci_bus 0000:00: root bus resource [mem 0x88800000-0xdfffffff window]
[ 0.273775] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.273776] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.273777] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.273856] pci 0000:00:00.0: [8086:3e1f] type 00 class 0x060000
[ 0.273911] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.273951] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.274522] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[ 0.274540] pci 0000:00:12.0: reg 0x10: [mem 0x4000119000-0x4000119fff 64bit]
[ 0.274686] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.274700] pci 0000:00:14.0: reg 0x10: [mem 0x4000100000-0x400010ffff 64bit]
[ 0.274751] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.276241] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.276257] pci 0000:00:14.2: reg 0x10: [mem 0x4000114000-0x4000115fff 64bit]
[ 0.276267] pci 0000:00:14.2: reg 0x18: [mem 0x4000118000-0x4000118fff 64bit]
[ 0.276373] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.276392] pci 0000:00:16.0: reg 0x10: [mem 0x4000117000-0x4000117fff 64bit]
[ 0.276458] pci 0000:00:16.0: PME# supported from D3hot
[ 0.276894] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[ 0.276905] pci 0000:00:17.0: reg 0x10: [mem 0x8a320000-0x8a321fff]
[ 0.276911] pci 0000:00:17.0: reg 0x14: [mem 0x8a323000-0x8a3230ff]
[ 0.276917] pci 0000:00:17.0: reg 0x18: [io 0x4050-0x4057]
[ 0.276923] pci 0000:00:17.0: reg 0x1c: [io 0x4040-0x4043]
[ 0.276929] pci 0000:00:17.0: reg 0x20: [io 0x4020-0x403f]
[ 0.276935] pci 0000:00:17.0: reg 0x24: [mem 0x8a322000-0x8a3227ff]
[ 0.276968] pci 0000:00:17.0: PME# supported from D3hot
[ 0.277455] pci 0000:00:1b.0: [8086:a343] type 01 class 0x060400
[ 0.277531] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.277555] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[ 0.278202] pci 0000:00:1b.4: [8086:a32c] type 01 class 0x060400
[ 0.278286] pci 0000:00:1b.4: PME# supported from D0 D3hot D3cold
[ 0.278313] pci 0000:00:1b.4: PTM enabled (root), 4ns granularity
[ 0.278958] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.279032] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.279056] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.279725] pci 0000:00:1f.0: [8086:a305] type 00 class 0x060100
[ 0.280101] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[ 0.280131] pci 0000:00:1f.3: reg 0x10: [mem 0x4000110000-0x4000113fff 64bit]
[ 0.280168] pci 0000:00:1f.3: reg 0x20: [mem 0x4000000000-0x40000fffff 64bit]
[ 0.280241] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.283189] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.283212] pci 0000:00:1f.4: reg 0x10: [mem 0x4000116000-0x40001160ff 64bit]
[ 0.283239] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.283472] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.283486] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.283588] pci 0000:00:1f.6: [8086:15bc] type 00 class 0x020000
[ 0.283616] pci 0000:00:1f.6: reg 0x10: [mem 0x8a300000-0x8a31ffff]
[ 0.283757] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.283842] pci 0000:01:00.0: [10de:1f08] type 00 class 0x030000
[ 0.283852] pci 0000:01:00.0: reg 0x10: [mem 0x89000000-0x89ffffff]
[ 0.283861] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.283869] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ 0.283875] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.283880] pci 0000:01:00.0: reg 0x30: [mem 0x8a000000-0x8a07ffff pref]
[ 0.283896] pci 0000:01:00.0: BAR 1: assigned to efifb
[ 0.283900] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.283941] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.283989] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.284076] pci 0000:01:00.1: [10de:10f9] type 00 class 0x040300
[ 0.284085] pci 0000:01:00.1: reg 0x10: [mem 0x8a080000-0x8a083fff]
[ 0.284184] pci 0000:01:00.2: [10de:1ada] type 00 class 0x0c0330
[ 0.284197] pci 0000:01:00.2: reg 0x10: [mem 0xa2000000-0xa203ffff 64bit pref]
[ 0.284210] pci 0000:01:00.2: reg 0x1c: [mem 0xa2040000-0xa204ffff 64bit pref]
[ 0.284256] pci 0000:01:00.2: PME# supported from D0 D3hot
[ 0.284299] pci 0000:01:00.3: [10de:1adb] type 00 class 0x0c8000
[ 0.284308] pci 0000:01:00.3: reg 0x10: [mem 0x8a084000-0x8a084fff]
[ 0.284364] pci 0000:01:00.3: PME# supported from D0 D3hot
[ 0.284420] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.284422] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.284424] pci 0000:00:01.0: bridge window [mem 0x89000000-0x8a0fffff]
[ 0.284426] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa20fffff 64bit pref]
[ 0.284532] pci 0000:02:00.0: [8086:2723] type 00 class 0x028000
[ 0.284556] pci 0000:02:00.0: reg 0x10: [mem 0x8a200000-0x8a203fff 64bit]
[ 0.284679] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.284815] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.284818] pci 0000:00:1b.0: bridge window [mem 0x8a200000-0x8a2fffff]
[ 0.284899] pci 0000:00:1b.4: PCI bridge to [bus 03]
[ 0.284992] pci 0000:04:00.0: [144d:a808] type 00 class 0x010802
[ 0.285012] pci 0000:04:00.0: reg 0x10: [mem 0x8a100000-0x8a103fff 64bit]
[ 0.285263] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.285267] pci 0000:00:1d.0: bridge window [mem 0x8a100000-0x8a1fffff]
[ 0.286337] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.286409] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.286480] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.286550] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.286620] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.286689] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.286759] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.286830] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.292317] iommu: Default domain type: Translated
[ 0.292317] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.292317] SCSI subsystem initialized
[ 0.292317] libata version 3.00 loaded.
[ 0.292317] ACPI: bus type USB registered
[ 0.292317] usbcore: registered new interface driver usbfs
[ 0.292317] usbcore: registered new interface driver hub
[ 0.292317] usbcore: registered new device driver usb
[ 0.292317] pps_core: LinuxPPS API ver. 1 registered
[ 0.292317] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.292317] PTP clock support registered
[ 0.292317] EDAC MC: Ver: 3.0.0
[ 0.292317] Registered efivars operations
[ 0.292317] NetLabel: Initializing
[ 0.292317] NetLabel: domain hash size = 128
[ 0.292317] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.292317] NetLabel: unlabeled traffic allowed by default
[ 0.292317] mctp: management component transport protocol core
[ 0.292317] NET: Registered PF_MCTP protocol family
[ 0.292317] PCI: Using ACPI for IRQ routing
[ 0.335604] PCI: pci_cache_line_size set to 64 bytes
[ 0.335667] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.335668] e820: reserve RAM buffer [mem 0x77f9f000-0x77ffffff]
[ 0.335669] e820: reserve RAM buffer [mem 0x780b3000-0x7bffffff]
[ 0.335670] e820: reserve RAM buffer [mem 0x7d5fd000-0x7fffffff]
[ 0.335671] e820: reserve RAM buffer [mem 0x7f2ee000-0x7fffffff]
[ 0.335672] e820: reserve RAM buffer [mem 0x7fd0f000-0x7fffffff]
[ 0.335672] e820: reserve RAM buffer [mem 0x875800000-0x877ffffff]
[ 0.335681] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.335681] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.335681] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.335681] vgaarb: loaded
[ 0.335681] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.335681] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.338296] clocksource: Switched to clocksource tsc-early
[ 0.338362] VFS: Disk quotas dquot_6.6.0
[ 0.338369] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.338435] AppArmor: AppArmor Filesystem Enabled
[ 0.338452] pnp: PnP ACPI init
[ 0.338719] system 00:00: [io 0x0280-0x028f] has been reserved
[ 0.338722] system 00:00: [io 0x0290-0x029f] has been reserved
[ 0.338723] system 00:00: [io 0x02a0-0x02af] has been reserved
[ 0.338724] system 00:00: [io 0x02b0-0x02bf] has been reserved
[ 0.338855] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.338857] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.338954] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.339112] system 00:03: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.339114] system 00:03: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.339115] system 00:03: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.339117] system 00:03: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.339118] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.339119] system 00:03: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.339120] system 00:03: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.339121] system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.339315] system 00:04: [io 0x1800-0x18fe] could not be reserved
[ 0.339317] system 00:04: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.339318] system 00:04: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.339319] system 00:04: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.339320] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.339321] system 00:04: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.339323] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.339582] system 00:05: [io 0x2000-0x20fe] has been reserved
[ 0.339815] system 00:06: [mem 0xfd6e0000-0xfd6effff] has been reserved
[ 0.339817] system 00:06: [mem 0xfd6d0000-0xfd6dffff] has been reserved
[ 0.339818] system 00:06: [mem 0xfd6b0000-0xfd6bffff] has been reserved
[ 0.339819] system 00:06: [mem 0xfd6a0000-0xfd6affff] has been reserved
[ 0.340585] pnp: PnP ACPI: found 8 devices
[ 0.345705] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.345751] NET: Registered PF_INET protocol family
[ 0.345860] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.348098] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.348133] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.348220] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.348537] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.348720] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.348796] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.348872] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.348937] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.349001] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.349005] NET: Registered PF_XDP protocol family
[ 0.349015] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.349018] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.349020] pci 0000:00:01.0: bridge window [mem 0x89000000-0x8a0fffff]
[ 0.349022] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa20fffff 64bit pref]
[ 0.349025] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.349032] pci 0000:00:1b.0: bridge window [mem 0x8a200000-0x8a2fffff]
[ 0.349037] pci 0000:00:1b.4: PCI bridge to [bus 03]
[ 0.349044] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.349047] pci 0000:00:1d.0: bridge window [mem 0x8a100000-0x8a1fffff]
[ 0.349052] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.349053] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.349054] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.349055] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000effff window]
[ 0.349056] pci_bus 0000:00: resource 8 [mem 0x88800000-0xdfffffff window]
[ 0.349057] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[ 0.349058] pci_bus 0000:00: resource 10 [mem 0xfc800000-0xfe7fffff window]
[ 0.349059] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.349060] pci_bus 0000:01: resource 1 [mem 0x89000000-0x8a0fffff]
[ 0.349061] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa20fffff 64bit pref]
[ 0.349062] pci_bus 0000:02: resource 1 [mem 0x8a200000-0x8a2fffff]
[ 0.349063] pci_bus 0000:04: resource 1 [mem 0x8a100000-0x8a1fffff]
[ 0.349477] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.349523] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[ 0.349721] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[ 0.349755] PCI: CLS 64 bytes, default 64
[ 0.349765] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.349766] software IO TLB: mapped [mem 0x000000007386b000-0x000000007786b000] (64MB)
[ 0.349795] Trying to unpack rootfs image as initramfs...
[ 0.349854] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.349864] sgx: EPC section 0x80200000-0x85f7ffff
[ 0.350432] Initialise system trusted keyrings
[ 0.350439] Key type blacklist registered
[ 0.350461] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[ 0.351267] zbud: loaded
[ 0.351411] integrity: Platform Keyring initialized
[ 0.351414] integrity: Machine keyring initialized
[ 0.357654] Key type asymmetric registered
[ 0.357655] Asymmetric key parser 'x509' registered
[ 0.778891] Freeing initrd memory: 106416K
[ 0.780792] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.780809] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.780829] io scheduler mq-deadline registered
[ 0.780830] io scheduler kyber registered
[ 0.780858] io scheduler bfq registered
[ 0.781549] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.781786] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.781800] ACPI: button: Sleep Button [SLPB]
[ 0.781816] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.781826] ACPI: button: Power Button [PWRB]
[ 0.781840] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.781883] ACPI: button: Power Button [PWRF]
[ 0.782208] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.783193] Non-volatile memory driver v1.3
[ 0.783194] Linux agpgart interface v0.103
[ 0.790141] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.790186] ACPI: bus type drm_connector registered
[ 0.791540] ahci 0000:00:17.0: version 3.0
[ 0.801817] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 0.801820] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part ems deso sadm sds apst
[ 0.851040] scsi host0: ahci
[ 0.851294] scsi host1: ahci
[ 0.851529] scsi host2: ahci
[ 0.851643] scsi host3: ahci
[ 0.851717] scsi host4: ahci
[ 0.851765] scsi host5: ahci
[ 0.851785] ata1: SATA max UDMA/133 abar m2048@0x8a322000 port 0x8a322100 irq 125
[ 0.851787] ata2: SATA max UDMA/133 abar m2048@0x8a322000 port 0x8a322180 irq 125
[ 0.851788] ata3: SATA max UDMA/133 abar m2048@0x8a322000 port 0x8a322200 irq 125
[ 0.851789] ata4: SATA max UDMA/133 abar m2048@0x8a322000 port 0x8a322280 irq 125
[ 0.851791] ata5: SATA max UDMA/133 abar m2048@0x8a322000 port 0x8a322300 irq 125
[ 0.851792] ata6: SATA max UDMA/133 abar m2048@0x8a322000 port 0x8a322380 irq 125
[ 0.851854] usbcore: registered new interface driver usbserial_generic
[ 0.851856] usbserial: USB Serial support registered for generic
[ 0.851938] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.852556] rtc rtc0: invalid alarm value: 2023-01-06T09:43:65
[ 0.852589] rtc_cmos rtc_cmos: registered as rtc0
[ 0.852744] rtc_cmos rtc_cmos: setting system clock to 2023-01-06T09:43:10 UTC (1672998190)
[ 0.852752] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.852812] intel_pstate: Intel P-state driver initializing
[ 0.852916] intel_pstate: Disabling energy efficiency optimization
[ 0.852916] intel_pstate: HWP enabled
[ 0.852930] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.853045] efifb: probing for efifb
[ 0.853053] efifb: framebuffer at 0x90000000, using 34560k, total 34560k
[ 0.853054] efifb: mode is 3840x2160x32, linelength=16384, pages=1
[ 0.853055] efifb: scrolling: redraw
[ 0.853056] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.853079] fbcon: Deferring console take-over
[ 0.853080] fb0: EFI VGA frame buffer device
[ 0.853095] hid: raw HID events driver (C) Jiri Kosina
[ 0.853129] intel_pmc_core INT33A1:00: initialized
[ 0.853188] drop_monitor: Initializing network drop monitor service
[ 0.863762] Initializing XFRM netlink socket
[ 0.863842] NET: Registered PF_INET6 protocol family
[ 0.866754] Segment Routing with IPv6
[ 0.866755] RPL Segment Routing with IPv6
[ 0.866763] In-situ OAM (IOAM) with IPv6
[ 0.866783] NET: Registered PF_PACKET protocol family
[ 0.867176] microcode: sig=0x906eb, pf=0x2, revision=0xf0
[ 0.867206] microcode: Microcode Update Driver: v2.2.
[ 0.867211] IPI shorthand broadcast: enabled
[ 0.867227] sched_clock: Marking stable (866606543, 469861)->(870610375, -3533971)
[ 0.867377] registered taskstats version 1
[ 0.867542] Loading compiled-in X.509 certificates
[ 0.870556] Loaded X.509 cert 'Build time autogenerated kernel key: 5c5acb36a23c86b35d7c1f3b43fac8d124b46bd9'
[ 0.871132] zswap: loaded using pool zstd/z3fold
[ 0.871405] Key type .fscrypt registered
[ 0.871407] Key type fscrypt-provisioning registered
[ 0.871437] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.872071] integrity: Loading X.509 certificate: UEFI:db
[ 0.872096] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.872097] integrity: Loading X.509 certificate: UEFI:db
[ 0.872110] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.874223] PM: Magic number: 7:57:727
[ 0.874242] pci 0000:01:00.2: hash matches
[ 0.874361] RAS: Correctable Errors collector initialized.
[ 1.164505] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.164556] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.164585] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.164612] ata2: SATA link down (SStatus 4 SControl 300)
[ 1.168344] ata1.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.168356] ata1.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.168380] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.168408] ata5: SATA link down (SStatus 4 SControl 300)
[ 1.168918] ata1.00: ATA-10: WDC WD40EZRZ-00GXCB0, 80.00A80, max UDMA/133
[ 1.169417] ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.169429] ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.169661] ata1.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.173477] ata1.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.173489] ata1.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.173557] ata4.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.173569] ata4.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.173908] ata4.00: supports DRM functions and may not be fully accessible
[ 1.173915] ata4.00: ATA-11: Samsung SSD 870 QVO 1TB, SVQ02B6Q, max UDMA/133
[ 1.174550] ata6.00: ATA-9: V-GEN11SM18EG240GB, R0724A0, max UDMA/133
[ 1.174565] ata4.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.174765] ata1.00: configured for UDMA/133
[ 1.175041] scsi 0:0:0:0: Direct-Access ATA WDC WD40EZRZ-00G 0A80 PQ: 0 ANSI: 5
[ 1.176498] ata6.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.176569] sd 0:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 1.176578] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.176664] sd 0:0:0:0: [sda] Write Protect is off
[ 1.176673] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.176838] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.177015] ata4.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 1.177120] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 1.179054] ata4.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.179066] ata4.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.179467] ata4.00: supports DRM functions and may not be fully accessible
[ 1.183534] ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.183546] ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.184626] ata4.00: configured for UDMA/133
[ 1.189838] ata6.00: configured for UDMA/133
[ 1.247720] sda: sda1
[ 1.247991] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.374011] tsc: Refined TSC clocksource calibration: 3599.998 MHz
[ 1.374025] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33e451ab1a6, max_idle_ns: 440795278720 ns
[ 1.374102] clocksource: Switched to clocksource tsc
[ 1.382158] ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.382170] ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.385003] ata3.00: ATA-8: HGST HTS541010A9E680, JA0OA560, max UDMA/133
[ 1.385861] ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.390711] ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 1.390723] ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.393989] ata3.00: configured for UDMA/133
[ 1.394305] scsi 2:0:0:0: Direct-Access ATA HGST HTS541010A9 A560 PQ: 0 ANSI: 5
[ 1.395647] scsi 3:0:0:0: Direct-Access ATA Samsung SSD 870 2B6Q PQ: 0 ANSI: 5
[ 1.395722] sd 2:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.395731] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 1.395819] sd 2:0:0:0: [sdb] Write Protect is off
[ 1.395828] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.395996] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.396152] sd 2:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[ 1.396203] ata4.00: Enabling discard_zeroes_data
[ 1.396236] sd 3:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.396265] sd 3:0:0:0: [sdc] Write Protect is off
[ 1.396272] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 1.396316] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.396372] scsi 5:0:0:0: Direct-Access ATA V-GEN11SM18EG240 4A0 PQ: 0 ANSI: 5
[ 1.396441] sd 3:0:0:0: [sdc] Preferred minimum I/O size 512 bytes
[ 1.396917] ata4.00: Enabling discard_zeroes_data
[ 1.396990] sd 5:0:0:0: [sdd] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 1.397019] sd 5:0:0:0: [sdd] Write Protect is off
[ 1.397025] sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 1.397062] sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.397111] sd 5:0:0:0: [sdd] Preferred minimum I/O size 512 bytes
[ 1.416972] sdc: sdc1
[ 1.418199] sd 3:0:0:0: [sdc] supports TCG Opal
[ 1.418208] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 1.422421] sdd: sdd1 sdd2
[ 1.422743] sd 5:0:0:0: [sdd] Attached SCSI disk
[ 1.476806] sdb: sdb1
[ 1.477021] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 1.479675] Freeing unused decrypted memory: 2036K
[ 1.480530] Freeing unused kernel image (initmem) memory: 2148K
[ 1.490690] Write protecting the kernel read-only data: 30720k
[ 1.492006] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.492532] Freeing unused kernel image (rodata/data gap) memory: 1216K
[ 1.505718] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.505721] rodata_test: all tests were successful
[ 1.505725] Run /init as init process
[ 1.505726] with arguments:
[ 1.505727] /init
[ 1.505728] quite
[ 1.505728] with environment:
[ 1.505729] HOME=/
[ 1.505729] TERM=linux
[ 1.505730] BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
[ 1.547072] fbcon: Taking over console
[ 1.547155] Console: switching to colour frame buffer device 240x67
[ 1.822030] nvidia: loading out-of-tree module taints kernel.
[ 1.822038] nvidia: module license 'NVIDIA' taints kernel.
[ 1.822039] Disabling lock debugging due to kernel taint
[ 1.833717] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.013721] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[ 2.014744] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.061468] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.60.11 Wed Nov 23 23:04:03 UTC 2022
[ 2.083510] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 525.60.11 Wed Nov 23 22:49:17 UTC 2022
[ 2.100027] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 2.204364] nvidia-uvm: Loaded the UVM driver, major device number 236.
[ 2.205922] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.085614] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 3.155825] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 3.155831] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 3.156900] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 3.157075] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 3.157077] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 3.157079] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.160647] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.160651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.160652] usb usb1: Product: xHCI Host Controller
[ 3.160653] usb usb1: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[ 3.160654] usb usb1: SerialNumber: 0000:00:14.0
[ 3.161179] hub 1-0:1.0: USB hub found
[ 3.161195] hub 1-0:1.0: 16 ports detected
[ 3.163327] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 3.163330] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.163332] usb usb2: Product: xHCI Host Controller
[ 3.163333] usb usb2: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[ 3.163333] usb usb2: SerialNumber: 0000:00:14.0
[ 3.163400] hub 2-0:1.0: USB hub found
[ 3.163412] hub 2-0:1.0: 10 ports detected
[ 3.165989] usb: port power management may be unreliable
[ 3.166196] xhci_hcd 0000:01:00.2: xHCI Host Controller
[ 3.166201] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[ 3.166784] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[ 3.166871] xhci_hcd 0000:01:00.2: xHCI Host Controller
[ 3.166873] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[ 3.166874] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.166903] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.166905] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.166906] usb usb3: Product: xHCI Host Controller
[ 3.166907] usb usb3: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[ 3.166908] usb usb3: SerialNumber: 0000:01:00.2
[ 3.167130] hub 3-0:1.0: USB hub found
[ 3.167135] hub 3-0:1.0: 2 ports detected
[ 3.167197] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.167207] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 3.167209] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.167210] usb usb4: Product: xHCI Host Controller
[ 3.167210] usb usb4: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[ 3.167211] usb usb4: SerialNumber: 0000:01:00.2
[ 3.167346] hub 4-0:1.0: USB hub found
[ 3.167352] hub 4-0:1.0: 4 ports detected
[ 3.173108] nvme nvme0: pci function 0000:04:00.0
[ 3.179663] nvme nvme0: missing or invalid SUBNQN field.
[ 3.179691] nvme nvme0: Shutdown timeout set to 8 seconds
[ 3.187520] nvme nvme0: 4/0/0 default/read/poll queues
[ 3.190059] nvme0n1: p1 p2
[ 3.190373] raid6: skipped pq benchmark and selected avx2x4
[ 3.190374] raid6: using avx2x2 recovery algorithm
[ 3.193063] xor: automatically using best checksumming function avx
[ 3.283792] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[ 3.284214] BTRFS: device fsid 1c0e69fe-b060-48db-a349-cba392a1348b devid 1 transid 866842 /dev/nvme0n1p2 scanned by systemd-udevd (167)
[ 3.287341] BTRFS: device label Tier 1 devid 1 transid 121888 /dev/sdc1 scanned by systemd-udevd (161)
[ 3.309586] BTRFS: device label Tier 3 devid 1 transid 16710 /dev/sda1 scanned by systemd-udevd (188)
[ 3.413994] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 3.555881] usb 1-1: New USB device found, idVendor=046d, idProduct=c33f, bcdDevice=31.02
[ 3.555884] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.555885] usb 1-1: Product: G813 RGB MECHANICAL GAMING KEYBOARD
[ 3.555886] usb 1-1: Manufacturer: Logitech
[ 3.555887] usb 1-1: SerialNumber: 047F314B3334
[ 3.561607] input: Logitech G813 RGB MECHANICAL GAMING KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C33F.0001/input/input3
[ 3.617512] hid-generic 0003:046D:C33F.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech G813 RGB MECHANICAL GAMING KEYBOARD] on usb-0000:00:14.0-1/input0
[ 3.618634] input: Logitech G813 RGB MECHANICAL GAMING KEYBOARD Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C33F.0002/input/input4
[ 3.674104] input: Logitech G813 RGB MECHANICAL GAMING KEYBOARD Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C33F.0002/input/input5
[ 3.674324] hid-generic 0003:046D:C33F.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Logitech G813 RGB MECHANICAL GAMING KEYBOARD] on usb-0000:00:14.0-1/input1
[ 3.674344] usbcore: registered new interface driver usbhid
[ 3.674345] usbhid: USB HID core driver
[ 3.718698] usb 2-4: new SuperSpeed USB device number 2 using xhci_hcd
[ 3.774679] BTRFS: device label Tier 2 devid 1 transid 44455 /dev/sdb1 scanned by systemd-udevd (167)
[ 3.805223] BTRFS info (device nvme0n1p2): using crc32c (crc32c-intel) checksum algorithm
[ 3.805229] BTRFS info (device nvme0n1p2): using free space tree
[ 3.819204] usb 2-4: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 3.819207] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.819208] usb 2-4: Product: USB3.0 Hub
[ 3.819209] usb 2-4: Manufacturer: VIA Labs, Inc.
[ 3.820709] hub 2-4:1.0: USB hub found
[ 3.820798] hub 2-4:1.0: 4 ports detected
[ 3.853871] BTRFS info (device nvme0n1p2): enabling ssd optimizations
[ 3.910055] systemd[1]: RTC configured in localtime, applying delta of 420 minutes to system time.
[ 3.938807] systemd[1]: systemd 252.4-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 3.938811] systemd[1]: Detected architecture x86-64.
[ 3.939090] systemd[1]: Hostname set to <aqua>.
[ 3.944002] usb 1-2: new full-speed USB device number 3 using xhci_hcd
[ 4.086123] usb 1-2: New USB device found, idVendor=046d, idProduct=c08b, bcdDevice=27.03
[ 4.086127] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.086129] usb 1-2: Product: G502 HERO Gaming Mouse
[ 4.086130] usb 1-2: Manufacturer: Logitech
[ 4.086131] usb 1-2: SerialNumber: 0D8B39663536
[ 4.088402] input: Logitech G502 HERO Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C08B.0003/input/input8
[ 4.088553] hid-generic 0003:046D:C08B.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech G502 HERO Gaming Mouse] on usb-0000:00:14.0-2/input0
[ 4.089669] input: Logitech G502 HERO Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C08B.0004/input/input9
[ 4.144222] hid-generic 0003:046D:C08B.0004: input,hiddev97,hidraw3: USB HID v1.11 Keyboard [Logitech G502 HERO Gaming Mouse] on usb-0000:00:14.0-2/input1
[ 4.242085] usb 2-4.1: new SuperSpeed USB device number 3 using xhci_hcd
[ 4.342770] usb 2-4.1: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 4.342774] usb 2-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.342775] usb 2-4.1: Product: USB3.0 Hub
[ 4.342776] usb 2-4.1: Manufacturer: VIA Labs, Inc.
[ 4.345142] hub 2-4.1:1.0: USB hub found
[ 4.345380] hub 2-4.1:1.0: 4 ports detected
[ 4.430696] systemd[1]: bpf-lsm: LSM BPF program attached
[ 4.463927] usb 1-3: new high-speed USB device number 4 using xhci_hcd
[ 4.594206] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.610697] usb 1-3: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11
[ 4.610700] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.610702] usb 1-3: Product: USB2.0 Hub
[ 4.610703] usb 1-3: Manufacturer: VIA Labs, Inc.
[ 4.612132] hub 1-3:1.0: USB hub found
[ 4.612836] hub 1-3:1.0: 4 ports detected
[ 4.634277] systemd[1]: Created slice Slice /system/getty.
[ 4.634529] systemd[1]: Created slice Slice /system/modprobe.
[ 4.634739] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 4.634900] systemd[1]: Created slice User and Session Slice.
[ 4.634978] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.635055] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.635196] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.635282] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.635328] systemd[1]: Reached target Login Prompts.
[ 4.635369] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 4.635423] systemd[1]: Reached target Remote File Systems.
[ 4.635465] systemd[1]: Reached target Slice Units.
[ 4.635505] systemd[1]: Reached target Mounting snaps.
[ 4.635543] systemd[1]: Reached target Mounted snaps.
[ 4.635592] systemd[1]: Reached target Local Verity Protected Volumes.
[ 4.635675] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.636096] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.636755] systemd[1]: Listening on Process Core Dump Socket.
[ 4.636885] systemd[1]: Listening on Journal Audit Socket.
[ 4.636983] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.637082] systemd[1]: Listening on Journal Socket.
[ 4.637507] systemd[1]: Listening on udev Control Socket.
[ 4.637593] systemd[1]: Listening on udev Kernel Socket.
[ 4.638105] systemd[1]: Mounting /dev/binderfs...
[ 4.638644] systemd[1]: Mounting Huge Pages File System...
[ 4.639172] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.639716] systemd[1]: Mounting Kernel Debug File System...
[ 4.640255] systemd[1]: Mounting Kernel Trace File System...
[ 4.640959] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.641525] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.642152] systemd[1]: Starting Load Kernel Module configfs...
[ 4.642758] systemd[1]: Starting Load Kernel Module drm...
[ 4.643406] systemd[1]: Starting Load Kernel Module fuse...
[ 4.644840] systemd[1]: Starting Load Kernel Modules...
[ 4.645433] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.645524] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 4.646060] systemd[1]: Starting Coldplug All udev Devices...
[ 4.647014] systemd[1]: dev-binderfs.mount: Mount process exited, code=exited, status=32/n/a
[ 4.647019] systemd[1]: dev-binderfs.mount: Failed with result 'exit-code'.
[ 4.652687] fuse: init (API version 7.37)
[ 4.659559] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.659587] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 4.659636] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 4.659658] sd 5:0:0:0: Attached scsi generic sg3 type 0
[ 4.664535] mc: Linux media interface: v0.10
[ 4.674607] videodev: Linux video capture interface: v2.00
[ 4.676462] v4l2loopback driver version 0.12.7 loaded
[ 4.680746] systemd[1]: Failed to mount /dev/binderfs.
[ 4.681059] systemd[1]: Mounted Huge Pages File System.
[ 4.681156] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.681245] systemd[1]: Mounted Kernel Debug File System.
[ 4.681329] systemd[1]: Mounted Kernel Trace File System.
[ 4.704138] systemd[1]: Finished Create List of Static Device Nodes.
[ 4.704428] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 4.711882] vboxdrv: Found 4 processor cores/threads
[ 4.737440] systemd[1]: Finished Load Kernel Module configfs.
[ 4.737715] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 4.737963] vboxdrv: TSC mode is Invariant, tentative frequency 3599989388 Hz
[ 4.737965] vboxdrv: Successfully loaded version 7.0.4 r154605 (interface 0x00330004)
[ 4.739211] VBoxNetAdp: Successfully started.
[ 4.740637] VBoxNetFlt: Successfully started.
[ 4.749252] device-mapper: uevent: version 1.0.3
[ 4.749350] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 4.754081] systemd[1]: Finished Load Kernel Module drm.
[ 4.756071] BTRFS info (device nvme0n1p2: state M): turning on sync discard
[ 4.756075] BTRFS info (device nvme0n1p2: state M): use zstd compression, level 10
[ 4.757286] usb 1-4: new full-speed USB device number 5 using xhci_hcd
[ 4.762610] zram: Added device: zram0
[ 4.770726] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 4.771377] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 4.787400] systemd[1]: Finished Load Kernel Module fuse.
[ 4.807401] systemd[1]: Finished Load Kernel Modules.
[ 4.840716] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.860727] systemd[1]: Finished Coldplug All udev Devices.
[ 4.877380] systemd[1]: Mounting FUSE Control File System...
[ 4.877921] systemd[1]: Mounting Kernel Configuration File System...
[ 4.877994] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 4.878485] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 4.879012] systemd[1]: Starting Load/Save Random Seed...
[ 4.879570] systemd[1]: Starting Apply Kernel Variables...
[ 4.879661] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 4.880177] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.882077] systemd[1]: Mounted FUSE Control File System.
[ 4.883093] systemd[1]: Mounted Kernel Configuration File System.
[ 4.899270] usb 1-4: New USB device found, idVendor=046d, idProduct=0ac4, bcdDevice= 9.00
[ 4.899273] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.899274] usb 1-4: Product: G535 Wireless Gaming Headset
[ 4.899275] usb 1-4: Manufacturer: Logitech
[ 4.902657] input: Logitech G535 Wireless Gaming Headset Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.3/0003:046D:0AC4.0005/input/input12
[ 4.924152] systemd[1]: Finished Apply Kernel Variables.
[ 4.954081] systemd[1]: Finished Load/Save Random Seed.
[ 4.955151] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 4.957512] hid-generic 0003:046D:0AC4.0005: input,hiddev98,hidraw4: USB HID v1.11 Device [Logitech G535 Wireless Gaming Headset] on usb-0000:00:14.0-4/input3
[ 4.987328] usb 1-3.1: new high-speed USB device number 6 using xhci_hcd
[ 4.990730] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 4.991738] systemd[1]: Reached target Preparation for Local File Systems.
[ 4.992699] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 4.992714] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 5.017461] systemd[1]: Starting Journal Service...
[ 5.018953] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 5.048614] systemd[1]: Started Journal Service.
[ 5.049643] audit: type=1130 audit(1672972994.693:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.060792] audit: type=1130 audit(1672972994.707:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.096399] usb 1-3.1: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11
[ 5.096403] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.096405] usb 1-3.1: Product: USB2.0 Hub
[ 5.096406] usb 1-3.1: Manufacturer: VIA Labs, Inc.
[ 5.097292] hub 1-3.1:1.0: USB hub found
[ 5.097480] hub 1-3.1:1.0: 4 ports detected
[ 5.185169] audit: type=1130 audit(1672972994.830:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-95BB\x2d4E97 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.217295] usb 1-14: new full-speed USB device number 7 using xhci_hcd
[ 5.229046] BTRFS info (device sdc1): using crc32c (crc32c-intel) checksum algorithm
[ 5.229052] BTRFS info (device sdc1): turning on sync discard
[ 5.229055] BTRFS info (device sdc1): use zstd compression, level 10
[ 5.229056] BTRFS info (device sdc1): using free space tree
[ 5.231232] BTRFS info (device sda1): using crc32c (crc32c-intel) checksum algorithm
[ 5.231242] BTRFS info (device sda1): enabling auto defrag
[ 5.231244] BTRFS info (device sda1): use zstd compression, level 10
[ 5.231245] BTRFS info (device sda1): using free space tree
[ 5.234014] BTRFS info (device sdc1): bdev /dev/sdc1 errs: wr 0, rd 0, flush 0, corrupt 1100, gen 0
[ 5.279666] audit: type=1400 audit(1672972994.923:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=427 comm="apparmor_parser"
[ 5.279683] audit: type=1300 audit(1672972994.923:5): arch=c000003e syscall=1 success=yes exit=33625 a0=5 a1=556fbdb13bf0 a2=8359 a3=0 items=0 ppid=426 pid=427 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
[ 5.279690] audit: type=1327 audit(1672972994.923:5): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[ 5.285514] audit: type=1400 audit(1672972994.927:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mariadbd_akonadi" pid=430 comm="apparmor_parser"
[ 5.285520] audit: type=1300 audit(1672972994.927:6): arch=c000003e syscall=1 success=yes exit=39521 a0=5 a1=556fbdc20b30 a2=9a61 a3=0 items=0 ppid=426 pid=430 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
[ 5.285522] audit: type=1327 audit(1672972994.927:6): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[ 5.294071] audit: type=1400 audit(1672972994.933:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=428 comm="apparmor_parser"
[ 5.294121] audit: type=1300 audit(1672972994.933:7): arch=c000003e syscall=1 success=yes exit=30921 a0=5 a1=556fbdb6a510 a2=78c9 a3=0 items=0 ppid=426 pid=428 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
[ 5.294166] audit: type=1327 audit(1672972994.933:7): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[ 5.365204] usb 1-14: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 5.365208] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.447270] usb 1-3.1.1: new full-speed USB device number 8 using xhci_hcd
[ 5.450652] BTRFS info (device sdc1): enabling ssd optimizations
[ 5.499306] EDAC ie31200: No ECC support
[ 5.499336] EDAC ie31200: No ECC support
[ 5.549498] usb 1-3.1.1: New USB device found, idVendor=05e3, idProduct=0606, bcdDevice= 7.02
[ 5.549502] usb 1-3.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.549504] usb 1-3.1.1: Product: USB Hub 2.0
[ 5.549505] usb 1-3.1.1: Manufacturer: ALCOR
[ 5.552186] hub 1-3.1.1:1.0: USB hub found
[ 5.552321] hub 1-3.1.1:1.0: 4 ports detected
[ 5.658042] mousedev: PS/2 mouse device common for all mice
[ 5.667687] BTRFS info (device sdb1): using crc32c (crc32c-intel) checksum algorithm
[ 5.667694] BTRFS info (device sdb1): enabling auto defrag
[ 5.667697] BTRFS info (device sdb1): use zstd compression, level 10
[ 5.667698] BTRFS info (device sdb1): using free space tree
[ 5.770177] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 5.811437] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 5.812788] i2c i2c-6: 2/4 memory slots populated (from DMI)
[ 5.813448] i2c i2c-6: Successfully instantiated SPD at 0x51
[ 5.814259] i2c i2c-6: Successfully instantiated SPD at 0x53
[ 5.837265] usb 1-3.1.1.3: new full-speed USB device number 9 using xhci_hcd
[ 5.877473] e1000e: Intel(R) PRO/1000 Network Driver
[ 5.877475] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 5.877700] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 5.912439] input: PC Speaker as /devices/platform/pcspkr/input/input14
[ 5.915140] spi-nor spi0.0: mx25l12805d (16384 Kbytes)
[ 5.927644] Creating 1 MTD partitions on "0000:00:1f.5":
[ 5.927653] 0x000000000000-0x000001000000 : "BIOS"
[ 5.933330] usb 1-3.1.1.3: New USB device found, idVendor=0c76, idProduct=2020, bcdDevice= 1.00
[ 5.933335] usb 1-3.1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.933336] usb 1-3.1.1.3: Product: 24BIT 192K MODE
[ 5.933337] usb 1-3.1.1.3: Manufacturer: Solid State System Co.,Ltd.
[ 5.933338] usb 1-3.1.1.3: SerialNumber: 010000000000
[ 5.938403] input: Solid State System Co.,Ltd. 24BIT 192K MODE as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1.1/1-3.1.1.3/1-3.1.1.3:1.2/0003:0C76:2020.0006/input/input15
[ 5.980782] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 5.980961] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.981549] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 5.981632] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 5.981637] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 5.983820] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.993978] hid-generic 0003:0C76:2020.0006: input,hidraw5: USB HID v1.00 Device [Solid State System Co.,Ltd. 24BIT 192K MODE] on usb-0000:00:14.0-3.1.1.3/input2
[ 6.037787] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input16
[ 6.037815] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input17
[ 6.037840] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input18
[ 6.037859] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input19
[ 6.039089] zram0: detected capacity change from 0 to 8388608
[ 6.042629] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 6.042631] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 6.042632] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 6.042633] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 6.066442] Adding 4194300k swap on /dev/zram0. Priority:-2 extents:1 across:4194300k SSFS
[ 6.067319] usb 1-3.1.1.4: new full-speed USB device number 10 using xhci_hcd
[ 6.070850] Intel(R) Wireless WiFi driver for Linux
[ 6.070883] snd_hda_codec_realtek hdaudioC1D0: ALCS1200A: SKU not ready 0x00000000
[ 6.070911] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 6.071380] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALCS1200A: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 6.071383] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.071385] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 6.071386] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 6.071387] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 6.071388] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 6.071389] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 6.071390] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 6.079114] cdc_acm 1-4:1.4: ttyACM0: USB ACM device
[ 6.079527] cryptd: max_cpu_qlen set to 1000
[ 6.081334] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[ 6.081345] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 6.081387] ee1004 6-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 6.081411] ee1004 6-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 6.081591] iwlwifi 0000:02:00.0: loaded firmware version 72.daa05125.0 cc-a0-72.ucode op_mode iwlmvm
[ 6.097971] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ 6.105554] usbcore: registered new interface driver cdc_acm
[ 6.105557] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 6.125249] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card1/input20
[ 6.125284] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card1/input21
[ 6.144272] AVX2 version of gcm_enc/dec engaged.
[ 6.144716] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card1/input22
[ 6.144930] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card1/input23
[ 6.144965] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card1/input24
[ 6.157585] AES CTR mode by8 optimization enabled
[ 6.161968] usb 1-3.1.1.4: New USB device found, idVendor=05e3, idProduct=0606, bcdDevice= 7.02
[ 6.161972] usb 1-3.1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.161973] usb 1-3.1.1.4: Product: USB Hub 2.0
[ 6.161974] usb 1-3.1.1.4: Manufacturer: ALCOR
[ 6.164731] hub 1-3.1.1.4:1.0: USB hub found
[ 6.164869] hub 1-3.1.1.4:1.0: 4 ports detected
[ 6.167560] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 70:85:c2:cb:69:c3
[ 6.167566] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ 6.167647] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
[ 6.179577] systemd-journald[295]: Received client request to flush runtime journal.
[ 6.183455] Bluetooth: Core ver 2.22
[ 6.183471] NET: Registered PF_BLUETOOTH protocol family
[ 6.183472] Bluetooth: HCI device and connection manager initialized
[ 6.183474] Bluetooth: HCI socket layer initialized
[ 6.183476] Bluetooth: L2CAP socket layer initialized
[ 6.183478] Bluetooth: SCO socket layer initialized
[ 6.217042] e1000e 0000:00:1f.6 eno1: renamed from eth0
[ 6.235480] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 6.235533] thermal thermal_zone1: failed to read out thermal zone (-61)
[ 6.267379] usb 1-3.1.1.3: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
[ 6.267382] usb 1-3.1.1.3: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
[ 6.267484] usbcore: registered new interface driver snd-usb-audio
[ 6.277843] usbcore: registered new interface driver btusb
[ 6.291158] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[ 6.291189] Bluetooth: hci0: Boot Address: 0x24800
[ 6.291190] Bluetooth: hci0: Firmware Version: 106-39.22
[ 6.291191] Bluetooth: hci0: Firmware already loaded
[ 6.358060] iwlwifi 0000:02:00.0: Detected RF HR B3, rfid=0x10a100
[ 6.423171] iwlwifi 0000:02:00.0: base HW address: 24:41:8c:15:05:18
[ 6.441283] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 6.473700] intel_tcc_cooling: Programmable TCC Offset detected
[ 6.521177] intel_rapl_common: Found RAPL domain package
[ 6.521180] intel_rapl_common: Found RAPL domain core
[ 6.521181] intel_rapl_common: Found RAPL domain dram
[ 8.406643] nct6775: Found NCT6791D or compatible chip at 0x2e:0x290
[ 8.429680] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.429683] Bluetooth: BNEP filters: protocol multicast
[ 8.429686] Bluetooth: BNEP socket layer initialized
[ 8.430638] Bluetooth: MGMT ver 1.22
[ 8.441534] NET: Registered PF_ALG protocol family
[ 8.546951] loop: module loaded
[ 8.548034] loop0: detected capacity change from 0 to 8
[ 8.572936] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 8.645083] NET: Registered PF_QIPCRTR protocol family
[ 10.340640] kauditd_printk_skb: 257 callbacks suppressed
[ 10.340642] audit: type=1130 audit(1672973354.484:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.344940] audit: type=1105 audit(1672973354.491:128): pid=975 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 10.451194] e1000e 0000:00:1f.6 eno1: NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 10.451208] e1000e 0000:00:1f.6 eno1: 10/100 speed: disabling TSO
[ 10.451305] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[ 11.126715] audit: type=1130 audit(1672973355.271:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.129189] audit: type=1334 audit(1672973355.274:130): prog-id=39 op=LOAD
[ 11.129601] audit: type=1334 audit(1672973355.274:131): prog-id=40 op=LOAD
[ 11.191898] audit: type=1130 audit(1672973355.338:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.154966] e1000e 0000:00:1f.6 eno1: NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 12.154969] e1000e 0000:00:1f.6 eno1: 10/100 speed: disabling TSO
[ 13.757748] audit: type=1131 audit(1672973357.904:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.757828] audit: type=1131 audit(1672973362.904:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.541432] audit: type=1100 audit(1672973363.688:135): pid=1012 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="deanrih" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 19.541576] audit: type=1101 audit(1672973363.688:136): pid=1012 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="deanrih" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 19.541852] audit: type=1103 audit(1672973363.688:137): pid=1012 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="deanrih" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 19.541912] audit: type=1006 audit(1672973363.688:138): pid=1012 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 19.541915] audit: type=1300 audit(1672973363.688:138): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffddb2fa0a0 a2=4 a3=7ffddb2f9db4 items=0 ppid=932 pid=1012 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj=unconfined key=(null)
[ 19.541917] audit: type=1327 audit(1672973363.688:138): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746864613933343538302D666538382D346164652D386135652D346231306164316266333833002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 19.594195] audit: type=1130 audit(1672973363.741:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.598777] audit: type=1101 audit(1672973363.744:140): pid=1014 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="deanrih" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.598782] audit: type=1103 audit(1672973363.744:141): pid=1014 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=? acct="deanrih" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 20.378665] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 20.422168] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 20.472949] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 20.517452] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 20.562040] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 20.602333] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 20.658210] overlayfs: "xino" feature enabled using 2 upper inode bits.
[ 21.827961] Bluetooth: RFCOMM TTY layer initialized
[ 21.827966] Bluetooth: RFCOMM socket layer initialized
[ 21.827969] Bluetooth: RFCOMM ver 1.11
[ 23.906199] kauditd_printk_skb: 124 callbacks suppressed
[ 23.906201] audit: type=1400 audit(1672973368.051:264): apparmor="DENIED" operation="open" profile="mariadbd_akonadi" name="/sys/block/" pid=2627 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 23.906847] audit: type=1300 audit(1672973368.051:264): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=55cfe86bab55 a2=90800 a3=0 items=0 ppid=2567 pid=2627 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm="mysqld" exe="/usr/bin/mariadbd" subj=mariadbd_akonadi key=(null)
[ 23.907003] audit: type=1327 audit(1672973368.051:264): proctitle=2F7573722F62696E2F6D7973716C64002D2D64656661756C74732D66696C653D2F686F6D652F6465616E7269682F2E6C6F63616C2F73686172652F616B6F6E6164692F6D7973716C2E636F6E66002D2D646174616469723D2F686F6D652F6465616E7269682F2E6C6F63616C2F73686172652F616B6F6E6164692F64625F6461
[ 25.084782] audit: type=1400 audit(1672973369.231:265): apparmor="DENIED" operation="open" profile="/usr/bin/akonadiserver" name="/var/lib/flatpak/exports/share/mime/mime.cache" pid=2567 comm="NotificationMan" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 25.084868] audit: type=1300 audit(1672973369.231:265): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7f960401e218 a2=80000 a3=0 items=0 ppid=2447 pid=2567 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm="NotificationMan" exe="/usr/bin/akonadiserver" subj=/usr/bin/akonadiserver key=(null)
[ 25.084916] audit: type=1327 audit(1672973369.231:265): proctitle="/usr/bin/akonadiserver"
[ 25.084960] audit: type=1400 audit(1672973369.231:266): apparmor="DENIED" operation="open" profile="/usr/bin/akonadiserver" name="/var/lib/flatpak/exports/share/mime/packages/" pid=2567 comm="NotificationMan" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 25.084997] audit: type=1300 audit(1672973369.231:266): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7f960401e218 a2=90800 a3=0 items=0 ppid=2447 pid=2567 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm="NotificationMan" exe="/usr/bin/akonadiserver" subj=/usr/bin/akonadiserver key=(null)
[ 25.085031] audit: type=1327 audit(1672973369.231:266): proctitle="/usr/bin/akonadiserver"
[ 25.312995] QSGRenderThread[2532]: segfault at 0 ip 00007fd6058d548a sp 00007fd5de8317a0 error 4 in libQt5Quick.so.5.15.7[7fd605724000+2d9000] likely on CPU 3 (core 3, socket 0)
[ 25.313005] Code: 48 8b bb b8 00 00 00 48 8b 07 ff 90 c0 00 00 00 48 8b bb b8 00 00 00 48 8b 07 ff 90 a0 00 00 00 48 8b b3 b8 00 00 00 4c 89 e7 <48> 8b 06 ff 90 c8 00 00 00 48 8b 43 70 48 8b 54 24 28 4c 89 e7 48
[ 29.940989] kauditd_printk_skb: 9 callbacks suppressed
[ 29.940991] audit: type=1131 audit(1672973374.088:276): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 30.010872] audit: type=1131 audit(1672973374.158:277): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.684140] audit: type=1131 audit(1672973382.831:278): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.760684] audit: type=1334 audit(1672973382.908:279): prog-id=0 op=UNLOAD
[ 38.760689] audit: type=1334 audit(1672973382.908:280): prog-id=0 op=UNLOAD
[ 38.760690] audit: type=1334 audit(1672973382.908:281): prog-id=0 op=UNLOAD
[ 38.830819] audit: type=1131 audit(1672973382.978:282): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.854001] audit: type=1334 audit(1672973383.001:283): prog-id=0 op=UNLOAD
[ 38.854005] audit: type=1334 audit(1672973383.001:284): prog-id=0 op=UNLOAD
[ 38.854006] audit: type=1334 audit(1672973383.001:285): prog-id=0 op=UNLOAD
[ 39.952599] firefox[3427]: segfault at d8 ip 00007f7d065608c4 sp 00007ffeb34d67b8 error 4 in libX11.so.6.4.0[7f7d06551000+8b000] likely on CPU 0 (core 0, socket 0)
[ 39.952607] Code: 84 00 00 00 00 00 f3 0f 1e fa 8b 47 1c c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 8b 47 74 c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa <48> 8b 87 d8 00 00 00 c3 0f 1f 40 00 f3 0f 1e fa 48 63 f6 48 c1 e6
[ 39.952634] audit: type=1701 audit(1672973384.098:286): auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=3427 comm="firefox" exe="/usr/lib/firefox-developer-edition/firefox" sig=11 res=1
[ 52.663734] kauditd_printk_skb: 8 callbacks suppressed
[ 52.663736] audit: type=1111 audit(1672973426.667:295): pid=876 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=connection-delete uuid=85c3b80a-238f-4c3f-911f-7933ffad184f name=50726F746F6E2056504E205347233332 pid=2342 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 52.749138] audit: type=1111 audit(1672973426.753:296): pid=876 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=connection-add uuid=8d4edac0-d0cb-40c2-98a4-e0099e308fa2 name="pvpn-ipv6leak-protection" pid=3750 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 52.777103] audit: type=1111 audit(1672973426.780:297): pid=876 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=connection-add uuid=a2fb9b6f-04d2-4523-80c0-d032b466ca66 name=50726F746F6E2056504E205347233332 pid=2342 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 52.793100] audit: type=1130 audit(1672973426.797:298): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.806614] audit: type=1111 audit(1672973426.810:299): pid=876 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=connection-activate uuid=a2fb9b6f-04d2-4523-80c0-d032b466ca66 name=50726F746F6E2056504E205347233332 pid=2342 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 52.820549] tun: Universal TUN/TAP device driver, 1.6
[ 62.820872] audit: type=1131 audit(1672973436.827:300): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 370.996073] usb 2-4: USB disconnect, device number 2
[ 370.996083] usb 2-4.1: USB disconnect, device number 3
[ 371.300655] usb 2-4: new SuperSpeed USB device number 4 using xhci_hcd
[ 371.401389] usb 2-4: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 371.401404] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 371.401410] usb 2-4: Product: USB3.0 Hub
[ 371.401414] usb 2-4: Manufacturer: VIA Labs, Inc.
[ 371.406068] hub 2-4:1.0: USB hub found
[ 371.406262] hub 2-4:1.0: 4 ports detected
[ 371.827500] usb 2-4.1: new SuperSpeed USB device number 5 using xhci_hcd
[ 371.931406] usb 2-4.1: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 371.931418] usb 2-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 371.931424] usb 2-4.1: Product: USB3.0 Hub
[ 371.931428] usb 2-4.1: Manufacturer: VIA Labs, Inc.
[ 371.933805] hub 2-4.1:1.0: USB hub found
[ 371.933956] hub 2-4.1:1.0: 4 ports detected
[ 528.684771] audit: type=1100 audit(1672973902.688:301): pid=4825 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="deanrih" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 528.684866] audit: type=1101 audit(1672973902.688:302): pid=4825 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="deanrih" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 528.685425] audit: type=1110 audit(1672973902.688:303): pid=4825 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 528.687069] audit: type=1105 audit(1672973902.691:304): pid=4825 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 528.704866] audit: type=1106 audit(1672973902.708:305): pid=4825 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 528.704912] audit: type=1104 audit(1672973902.708:306): pid=4825 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 786.562831] audit: type=1100 audit(1672974160.568:307): pid=5544 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="deanrih" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 786.562931] audit: type=1101 audit(1672974160.571:308): pid=5544 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="deanrih" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 786.571557] audit: type=1105 audit(1672974160.578:309): pid=5539 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 936.186542] audit: type=1130 audit(1672974310.195:310): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 936.186557] audit: type=1131 audit(1672974310.195:311): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1769.085475] audit: type=1100 audit(1672975143.097:312): pid=7054 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="deanrih" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1769.085571] audit: type=1101 audit(1672975143.097:313): pid=7054 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="deanrih" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1769.086131] audit: type=1110 audit(1672975143.097:314): pid=7054 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1769.087842] audit: type=1105 audit(1672975143.101:315): pid=7054 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1769.095924] audit: type=1106 audit(1672975143.107:316): pid=7054 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1769.095973] audit: type=1104 audit(1672975143.107:317): pid=7054 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1865.200301] audit: type=1101 audit(1672975239.214:318): pid=7142 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="deanrih" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1865.200916] audit: type=1110 audit(1672975239.214:319): pid=7142 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1865.202833] audit: type=1105 audit(1672975239.218:320): pid=7142 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
