Systemd automount sshfs sftp?
I am trying to setup systemd to automount a sshfs for me.
Using the following guide: SSHFS - ArchWiki
It all seems to be fine, except when i open the folder that’s supposed to have the mount, it just disappears.
Has anyone got this working?
my automount:
    [Unit]
    Description=network mount
    Requires=network-online.target
    After=network-online.service
    [Automount]
    Where=/home/bronson/test3
    TimeoutIdleSec=60
    [Install]
    WantedBy=multi-user.target
my mount
    [Unit]
    Wants=network-online.target
    Before=remote-fs.target
    [Mount]
    What=s@living.lan:/home/s/Bible
    Type=fuse.sshfs
    Options=_netdev,rw,nosuid,allow_other,uid=1000,gid=1000,default_permissions,follow_symlinks,idmap=user,identityfile=/home/bronson/.ssh/id_ed25519
    TimeoutSec=2
    #ForceUnmount=true
    [Install]
    WantedBy=remote-fs.target
Remove the unit dependencies - they are all implied by the _netdev mount option. Adding them may interfere with operation.
[Unit]
#    Requires=network-online.target
#    After=network-online.service
#    Wants=network-online.target
#    Before=remote-fs.target
[Mount]
Type=fuse.sshfs
TimeoutSec=2
#ForceUnmount=true
[Install]
Be sure to ONLY enable the automount unit
You have a 2s timeout for mount - that is too short - it is a network location - give it more time to mount.
Thanks. Ive made the changes, and still having the same issue.
Have you tried mounting on commandline?
sshfs s@living.lan:/home/s/Bible /home/bronson/test3 -o _netdev,rw,nosuid,allow_other,uid=1000,gid=1000,default_permissions,follow_symlinks,idmap=user,identityfile=/home/bronson/.ssh/id_ed25519
What are the message displayed if any?
ok thats a good idea! I get the following error:
fusermount3: option allow_other only allowed if 'user_allow_other' is set in /etc/fuse.conf
so i run as sudo:
The authenticity of host 'living.lan (192.168.1.2)' can't be established.
ED25519 key fingerprint is SHA256:....
This key is not known by any other names.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
ive accepted the key, now ill retry if the mount works
that is also a suggestion on how to address that error - is that option set in /etc/fuse.conf ?
Set it if it is not.
ok so the automount reports the following error:
home-bronson-test.automount: Failed with result 'mount-start-limit-hit'.
and the mount
Nov 23 21:33:07 blaptop systemd[1]: Mounting network mount...
Nov 23 21:33:07 blaptop mount[2135]: read: Connection reset by peer
Nov 23 21:33:07 blaptop systemd[1]: home-bronson-test.mount: Mount process exited, code=exited, status=1/FAILURE
Nov 23 21:33:07 blaptop systemd[1]: home-bronson-test.mount: Failed with result 'exit-code'.
Nov 23 21:33:07 blaptop systemd[1]: Failed to mount network mount.
Nov 23 21:33:08 blaptop systemd[1]: home-bronson-test.mount: Start request repeated too quickly.
Nov 23 21:33:08 blaptop systemd[1]: home-bronson-test.mount: Failed with result 'exit-code'.
Nov 23 21:33:08 blaptop systemd[1]: Failed to mount network mount.
Looks like kde is overloading the automount? Is there a way to work around this?
I think the fusermount issue was more related to not running as root, right? Whe i ran as root and accept the ssl stuff it works fine via command line.
It just the service playing up.
I don’t think so - it’s not what the message implies.
Almost everything can be forced via root …
ok ive modified the fuse.conf so the command works from the terminal without root access fine.
Edit: Ok i have got it working!
my updated units:
    [Unit]
    Description=sshfs network mount
    [Mount]
    Type=fuse.sshfs
    TimeoutSec=30
    [Install]
and
    [Unit]
    [Automount]
    TimeoutIdleSec=0
    [Install]
