Hello,
I dont know if this is a problem:
Feb 11 08:09:40 FBG-Main systemd[346]: /usr/lib/systemd/system-generators/systemd-gpt-auto-generator failed with exit status 1.
Feb 11 08:09:42 FBG-Main kernel: usb 1-7: 1:1: cannot get freq at ep 0x81
Feb 11 08:09:42 FBG-Main kernel: usb 1-7: 2:1: cannot get freq at ep 0x2
Feb 11 08:09:54 FBG-Main systemd[987]: Failed to start Update XDG user dir configuration.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 30 and the job result is failed.
Feb 11 08:14:11 FBG-Main pipewire-media-session[1439]: spa.alsa: The decibel volume range for element 'PCM' (-5006 dB - -6 dB) has negative maximum. Disabling the decibel range.
Feb 11 08:14:11 FBG-Main kernel: usb 1-7: 2:1: cannot get freq at ep 0x2
My PC:
Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF B450M-PLUS GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2409
date: 12/02/2020
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP smt: enabled
arch: Zen 2 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 2357 high: 3593 min/max: 2200/4208 boost: enabled
cores: 1: 3260 2: 2053 3: 2051 4: 2195 5: 2196 6: 2196 7: 3593 8: 2052
9: 2105 10: 2196 11: 2196 12: 2196 bogomips: 86270
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus-ID: 09:00.0 chip-ID: 1002:73ff class-ID: 0300
Device-2: PC-LM1E type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.2:6 chip-ID: 1d6c:0103 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
resolution: 1: 1920x1200~60Hz 2: 1920x1200~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 6600 XT (DIMGREY_CAVEFISH DRM 3.44.0
5.16.5-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Bose Bose USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.1:4 chip-ID: 05a7:1020
class-ID: 0300
Device-4: PC-LM1E type: USB driver: snd-usb-audio,uvcvideo
Device-5: RODE Microphones RØDE NT-USB Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7:5 chip-ID: 19f7:0015
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.45 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 2.06 TiB used: 691.26 GiB (32.8%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 002C temp: 37.9 C
scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: R013 scheme: GPT
ID-1: / size: 557.33 GiB used: 180.17 GiB (32.3%) fs: btrfs
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 25.7 MiB (26.8%) fs: vfat
dev: /dev/nvme0n1p2
ID-3: /home size: 557.33 GiB used: 180.17 GiB (32.3%) fs: btrfs
dev: /dev/nvme0n1p6
ID-4: /home/<filter>/Mount/Data size: 915.79 GiB used: 68.14 GiB (7.4%)
fs: cifs dev: /dev/Data
ID-5: /home/<filter>/Mount/Dateien size: 618.93 GiB
used: 511.06 GiB (82.6%) fs: ntfs dev: /dev/sda1
fs: btrfs dev: /dev/nvme0n1p6
ID-12: /var/cache size: 557.33 GiB used: 180.17 GiB (32.3%) fs: btrfs
dev: /dev/nvme0n1p6
ID-13: /var/log size: 557.33 GiB used: 180.17 GiB (32.3%) fs: btrfs
dev: /dev/nvme0n1p6
ID-1: /dev/nvme0n1p1 size: 529 MiB fs: ntfs
ID-2: /dev/nvme0n1p3 size: 16 MiB fs: <superuser required>
ID-3: /dev/nvme0n1p4 size: 707.99 GiB fs: ntfs
ID-4: /dev/nvme0n1p5 size: 500 MiB fs: vfat
ID-5: /dev/sda2 size: 312.58 GiB fs: btrfs
ID-6: /dev/sdb1 size: 300 MiB fs: vfat
ID-7: /dev/sdb2 size: 223.27 GiB fs: btrfs
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C
mem: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Packages: 1700 pacman: 1653 flatpak: 47
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
2: https://mirror.moson.org/manjaro/stable/$repo/$arch
3: https://manjaro.moson.eu/stable/$repo/$arch
Processes: 386 Uptime: 8h 24m wakeups: 0 Memory: 31.32 GiB
used: 4.16 GiB (13.3%) Init: systemd v: 250 Compilers: gcc: 11.1.0
clang: 13.0.0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
