Thanks guys. I did forgot to add the space before the path. Now it worked for “fah”
michaldybczak alienware-PC ~ sudo grep --recursive -rE '*fah*' /etc/systemd/system
grep: uwaga: * na początku wyrażenia regularnego
/etc/systemd/system/var-lib-snapd-snap-qt551-42.mount:WantedBy=default.target multi-user.target
/etc/systemd/system/var-lib-snapd-snap-gnome\x2d3\x2d38\x2d2004-119.mount:WantedBy=default.target multi-user.target
/etc/systemd/system/var-lib-snapd-snap-qt551-41.mount:WantedBy=default.target multi-user.target
/etc/systemd/system/var-lib-snapd-snap-gtk2\x2dcommon\x2dthemes-13.mount:WantedBy=default.target multi-user.target
/etc/systemd/system/foldingathome.service.d.bak/override.conf:User=fah
/etc/systemd/system/foldingathome.service.d.bak/override.conf:Group=fah
/etc/systemd/system/foldingathome.service.d.bak/override.conf:WorkingDirectory=/var/lib/fah
/etc/systemd/system/foldingathome.service.d.bak/override.conf:ExecStart=/opt/fah/FAHClient --config /var/lib/fah/config.xml --exec-directory=/opt/fah --data-directory=/var/lib/fah
/etc/systemd/system/var-lib-snapd-snap-gnome\x2d3\x2d38\x2d2004-115.mount:WantedBy=default.target multi-user.target
It still adds this warning about * but returns results, so I go with “comodo” through paths again and let you know about the results.
TriMoon
February 20, 2023, 10:31am
22
I fixed my typo in that post above…
michaldybczak:
--recursive -r
Use one, not both because they are the same options. (one is long-option version of the other)
xabbu
February 20, 2023, 10:32am
23
An Alternativ way would be to take a close look to this journal entry. By default you see only the message, but every line contains some meta data.
Make sure the journal command shows only this messages, otherwise it would be hard to read.
For example:
journalctl -b -g Comodo -o verbose
sudo \grep -rE '*Comodo*' /run/systemd
- no results
sudo \grep -rE '*Comodo*' /etc/systemd/system
- no results
- no results
sudo \grep -rE '*Comodo*' /usr/local/lib/systemd
- no such catalog
sudo \grep -rE '*Comodo*' /usr/lib/systemd
- no results
If there are any other paths, let me know.
gave me tons of output. I’m copying below and need to take time to analyze it.
Mon 2023-02-20 10:37:18.432562 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=182b25;b=f50094448b1747a0bd4759a360f602af;m=ebf7fb;t=5f51e68ba895c;x=f11811af80398509]
_TRANSPORT=journal
_UID=1000
_GID=1000
_CAP_EFFECTIVE=0
_AUDIT_SESSION=2
_AUDIT_LOGINUID=1000
_SYSTEMD_OWNER_UID=1000
_SYSTEMD_UNIT=user@1000.service
_SYSTEMD_SLICE=user-1000.slice
_MACHINE_ID=77f35eb0e2dc49c3af0a8418f3437eb4
_HOSTNAME=alienware-PC
_RUNTIME_SCOPE=system
PRIORITY=6
SYSLOG_FACILITY=3
CODE_FILE=src/core/job.c
SYSLOG_IDENTIFIER=systemd
JOB_TYPE=start
_COMM=systemd
_EXE=/usr/lib/systemd/systemd
_CMDLINE=/usr/lib/systemd/systemd --user
_SYSTEMD_CGROUP=/user.slice/user-1000.slice/user@1000.service/init.scope
_SYSTEMD_USER_UNIT=init.scope
_SYSTEMD_USER_SLICE=-.slice
CODE_LINE=581
CODE_FUNC=job_emit_start_message
_PID=934
MESSAGE_ID=7d4958e842da4a758f6c1cdc7b36dcc5
MESSAGE=Starting Comodo Antivirus...
USER_UNIT=app-cav@autostart.service
JOB_ID=98
_BOOT_ID=f50094448b1747a0bd4759a360f602af
TID=934
_SYSTEMD_INVOCATION_ID=53aecee78dda4e2889084b11003a31a3
USER_INVOCATION_ID=3c2b2ed357ee4b25ab1c3ec28d246956
_SOURCE_REALTIME_TIMESTAMP=1676885838432562
Mon 2023-02-20 10:37:18.457228 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=182b3e;b=f50094448b1747a0bd4759a360f602af;m=ec5833;t=5f51e68bae994;x=688ebdcbb9daa13]
_TRANSPORT=journal
_UID=1000
_GID=1000
_CAP_EFFECTIVE=0
_AUDIT_SESSION=2
SYSLOG_FACILITY=3
CODE_LINE=768
CODE_FUNC=job_emit_done_message
JOB_TYPE=start
_COMM=systemd
_PID=934
PRIORITY=3
JOB_ID=98
MESSAGE=Failed to start Comodo Antivirus.
JOB_RESULT=failed
MESSAGE_ID=be02cf6855d2428ba40df7e9d022f03d
TID=934
_SOURCE_REALTIME_TIMESTAMP=1676885838457228
Mon 2023-02-20 11:00:21.508869 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1830a7;b=f50094448b1747a0bd4759a360f602af;m=535c09c1;t=5f51ebb2a9b22;x=2da44e511d78b20a]
PRIORITY=6
_SYSTEMD_SLICE=system.slice
_TRANSPORT=syslog
SYSLOG_FACILITY=3
SYSLOG_IDENTIFIER=dbus-daemon
_UID=81
_GID=81
_COMM=dbus-daemon
_EXE=/usr/bin/dbus-daemon
_CMDLINE=/usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
_CAP_EFFECTIVE=20000000
_SYSTEMD_CGROUP=/system.slice/dbus.service
_SYSTEMD_UNIT=dbus.service
SYSLOG_PID=578
_PID=578
_SYSTEMD_INVOCATION_ID=7471a39447d04f2798ca96525ff6ecae
SYSLOG_TIMESTAMP=Feb 20 11:00:21
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.115' (uid=0 pid=10890 comm="sudo grep --recursive -E *Comodo* /etc/systemd/sys")
_SOURCE_REALTIME_TIMESTAMP=1676887221508869
Mon 2023-02-20 11:00:24.609815 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1830ad;b=f50094448b1747a0bd4759a360f602af;m=538b5ac2;t=5f51ebb59ec23;x=c086b0783b5be6c]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_SYSTEMD_USER_SLICE=app.slice
_TRANSPORT=syslog
PRIORITY=5
_CAP_EFFECTIVE=1ffffffffff
SYSLOG_IDENTIFIER=sudo
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_SYSTEMD_CGROUP=/user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-a4cdbd15a7a04a318cd09aa20fca3c2f.scope
_SYSTEMD_USER_UNIT=app-org.kde.konsole-a4cdbd15a7a04a318cd09aa20fca3c2f.scope
_SYSTEMD_INVOCATION_ID=97d104221c074bcd90876bbade9f7aa2
_PID=10890
_CMDLINE=sudo grep --recursive -E "*Comodo*" /etc/systemd/system
SYSLOG_TIMESTAMP=Feb 20 11:00:24
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /etc/systemd/system
_SOURCE_REALTIME_TIMESTAMP=1676887224609815
Mon 2023-02-20 11:04:58.265905 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1830bb;b=f50094448b1747a0bd4759a360f602af;m=63db03fe;t=5f51ecba9955f;x=630dc5b1c261241d]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:04:58
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.116' (uid=0 pid=10939 comm="sudo grep --recursive -E *Comodo* /usr/local/lib/s")
_SOURCE_REALTIME_TIMESTAMP=1676887498265905
Mon 2023-02-20 11:04:58.266682 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1830c0;b=f50094448b1747a0bd4759a360f602af;m=63db07fa;t=5f51ecba9995b;x=132b03656a691347]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=10939
_CMDLINE=sudo grep --recursive -E "*Comodo*" /usr/local/lib/systemd/system
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /usr/local/lib/systemd/system
_SOURCE_REALTIME_TIMESTAMP=1676887498266682
Mon 2023-02-20 11:05:20.793886 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1830cb;b=f50094448b1747a0bd4759a360f602af;m=6532c3c9;t=5f51ecd015529;x=181ff0ccd6f7b574]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:05:20
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.117' (uid=0 pid=10947 comm="sudo grep --recursive -E *Comodo* /usr/local/etc/s")
_SOURCE_REALTIME_TIMESTAMP=1676887520793886
Mon 2023-02-20 11:05:20.794692 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1830d4;b=f50094448b1747a0bd4759a360f602af;m=6532d402;t=5f51ecd016563;x=99193fa9a090975a]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=10947
_CMDLINE=sudo grep --recursive -E "*Comodo*" /usr/local/etc/systemd/system
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /usr/local/etc/systemd/system
_SOURCE_REALTIME_TIMESTAMP=1676887520794692
Mon 2023-02-20 11:05:33.236323 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1830dd;b=f50094448b1747a0bd4759a360f602af;m=65f09f2c;t=5f51ecdbf308d;x=bc24215c5b3d6213]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:05:33
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.119' (uid=0 pid=10981 comm="sudo grep --recursive -E *Comodo* /usr/lib/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676887533236323
Mon 2023-02-20 11:05:33.237297 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1830e6;b=f50094448b1747a0bd4759a360f602af;m=65f0b602;t=5f51ecdbf4763;x=64597bbdeb10e8b2]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=10981
_CMDLINE=sudo grep --recursive -E "*Comodo*" /usr/lib/systemd/system
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /usr/lib/systemd/system
_SOURCE_REALTIME_TIMESTAMP=1676887533237297
Mon 2023-02-20 11:05:49.267406 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1830ed;b=f50094448b1747a0bd4759a360f602af;m=66e53c94;t=5f51eceb3cdf6;x=d225e33248adbe58]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:05:49
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.120' (uid=0 pid=10988 comm="sudo grep --recursive -E *Comodo* /etc/init.d")
_SOURCE_REALTIME_TIMESTAMP=1676887549267406
Mon 2023-02-20 11:05:49.268364 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1830f1;b=f50094448b1747a0bd4759a360f602af;m=66e54030;t=5f51eceb3d191;x=23e3944938ae2ccf]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=10988
_CMDLINE=sudo grep --recursive -E "*Comodo*" /etc/init.d
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /etc/init.d
_SOURCE_REALTIME_TIMESTAMP=1676887549268364
Mon 2023-02-20 11:05:54.002402 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1830fd;b=f50094448b1747a0bd4759a360f602af;m=672d7c8c;t=5f51ecefc0ded;x=ec7dddf65d2c05d6]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:05:54
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.121' (uid=0 pid=10991 comm="sudo grep --recursive -E *Comodo* /etc/init.d/")
_SOURCE_REALTIME_TIMESTAMP=1676887554002402
Mon 2023-02-20 11:05:54.003263 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=183106;b=f50094448b1747a0bd4759a360f602af;m=672d8d4c;t=5f51ecefc1ead;x=445ab9aadf3f5173]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=10991
_CMDLINE=sudo grep --recursive -E "*Comodo*" /etc/init.d/
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /etc/init.d/
_SOURCE_REALTIME_TIMESTAMP=1676887554003263
Mon 2023-02-20 11:05:59.676640 CET [s=7cc68172d1a24983b6b09ebab5376857;i=18310d;b=f50094448b1747a0bd4759a360f602af;m=6784118b;t=5f51ecf52a2eb;x=ec63ac5f6dccee2b]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:05:59
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.122' (uid=0 pid=10993 comm="sudo grep --recursive -E *Comodo* /usr/lib/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676887559676640
Mon 2023-02-20 11:05:59.677611 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=183111;b=f50094448b1747a0bd4759a360f602af;m=6784155a;t=5f51ecf52a6bb;x=30dfd8913b897769]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=10993
_CMDLINE=sudo grep --recursive -E "*Comodo*" /usr/lib/systemd/system/
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /usr/lib/systemd/system/
_SOURCE_REALTIME_TIMESTAMP=1676887559677611
Mon 2023-02-20 11:06:32.388896 CET [s=7cc68172d1a24983b6b09ebab5376857;i=183121;b=f50094448b1747a0bd4759a360f602af;m=697737ec;t=5f51ed145c94d;x=bfad57160026cc50]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:06:32
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.125' (uid=0 pid=11076 comm="sudo grep --recursive -E *Comodo* /etc/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676887592388896
Mon 2023-02-20 11:06:32.389744 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=18312a;b=f50094448b1747a0bd4759a360f602af;m=69774915;t=5f51ed145da76;x=6bae16f425b09883]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11076
_SOURCE_REALTIME_TIMESTAMP=1676887592389744
Mon 2023-02-20 11:06:51.618452 CET [s=7cc68172d1a24983b6b09ebab5376857;i=183131;b=f50094448b1747a0bd4759a360f602af;m=6a9ca33f;t=5f51ed26b34a0;x=a24cb67b50a6c7d7]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:06:51
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.127' (uid=0 pid=11091 comm="sudo grep --recursive -E *Comodo* /run/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676887611618452
Mon 2023-02-20 11:06:51.619388 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=18313a;b=f50094448b1747a0bd4759a360f602af;m=6a9cb4aa;t=5f51ed26b460b;x=87545a438754f0f1]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11091
_CMDLINE=sudo grep --recursive -E "*Comodo*" /run/systemd
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep --recursive -E *Comodo* /run/systemd
_SOURCE_REALTIME_TIMESTAMP=1676887611619388
Mon 2023-02-20 11:07:11.635391 CET [s=7cc68172d1a24983b6b09ebab5376857;i=183141;b=f50094448b1747a0bd4759a360f602af;m=6bce1271;t=5f51ed39ca3d2;x=5b8824bdc6650e39]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:07:11
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.128' (uid=0 pid=11094 comm="sudo grep --recursive -E *Comodo* /usr/local/lib/s")
_SOURCE_REALTIME_TIMESTAMP=1676887631635391
Mon 2023-02-20 11:07:11.636358 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=183145;b=f50094448b1747a0bd4759a360f602af;m=6bce1629;t=5f51ed39ca78a;x=320df529067ecf81]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11094
_SOURCE_REALTIME_TIMESTAMP=1676887631636358
Mon 2023-02-20 11:21:02.415206 CET [s=7cc68172d1a24983b6b09ebab5376857;i=18318f;b=f50094448b1747a0bd4759a360f602af;m=9d52c46d;t=5f51f052155ce;x=e530bb49109c83b1]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:21:02
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.140' (uid=0 pid=11394 comm="sudo grep -rE *Comodo* /etc/systemd/system")
_SOURCE_REALTIME_TIMESTAMP=1676888462415206
Mon 2023-02-20 11:21:02.416414 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=183198;b=f50094448b1747a0bd4759a360f602af;m=9d52d7da;t=5f51f0521693b;x=d5f09f3a6b03dc83]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11394
_CMDLINE=sudo grep -rE "*Comodo*" /etc/systemd/system
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep -rE *Comodo* /etc/systemd/system
_SOURCE_REALTIME_TIMESTAMP=1676888462416414
Mon 2023-02-20 11:28:34.487277 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1831a0;b=f50094448b1747a0bd4759a360f602af;m=b844d6aa;t=5f51f2013680b;x=619830c4857b5476]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:28:34
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.142' (uid=0 pid=11481 comm="sudo grep -rE *Comodo* /run/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676888914487277
Mon 2023-02-20 11:28:38.186756 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1831ab;b=f50094448b1747a0bd4759a360f602af;m=b87d575d;t=5f51f204be8be;x=c04bc02b255cbcd0]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11481
_CMDLINE=sudo grep -rE "*Comodo*" /run/systemd
SYSLOG_TIMESTAMP=Feb 20 11:28:38
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep -rE *Comodo* /run/systemd
_SOURCE_REALTIME_TIMESTAMP=1676888918186756
Mon 2023-02-20 11:29:56.584040 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1831d2;b=f50094448b1747a0bd4759a360f602af;m=bd29891c;t=5f51f24f81a7c;x=dc916fc6e150b60f]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:29:56
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.145' (uid=0 pid=11493 comm="sudo grep -rE *Comodo* /run/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676888996584040
Mon 2023-02-20 11:29:56.585723 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1831d7;b=f50094448b1747a0bd4759a360f602af;m=bd298fa9;t=5f51f24f8210a;x=4521b70d030bb104]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11493
_SOURCE_REALTIME_TIMESTAMP=1676888996585723
Mon 2023-02-20 11:31:14.520465 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1831e2;b=f50094448b1747a0bd4759a360f602af;m=c1cec065;t=5f51f299d51c6;x=e2d0776697978d3]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:31:14
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.146' (uid=0 pid=11515 comm="sudo grep -rE *Comodo* /etc/systemd/system")
_SOURCE_REALTIME_TIMESTAMP=1676889074520465
Mon 2023-02-20 11:31:14.521800 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1831eb;b=f50094448b1747a0bd4759a360f602af;m=c1ced4e7;t=5f51f299d6648;x=fc2287b0997c5105]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11515
_SOURCE_REALTIME_TIMESTAMP=1676889074521800
Mon 2023-02-20 11:33:59.284240 CET [s=7cc68172d1a24983b6b09ebab5376857;i=1831f2;b=f50094448b1747a0bd4759a360f602af;m=cba0d8ee;t=5f51f336f6a4f;x=9db636c0859d7fa4]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:33:59
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.147' (uid=0 pid=11552 comm="sudo grep -rE *Comodo* /etc/systemd/system")
_SOURCE_REALTIME_TIMESTAMP=1676889239284240
Mon 2023-02-20 11:33:59.285934 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=1831fb;b=f50094448b1747a0bd4759a360f602af;m=cba0f45e;t=5f51f336f85bf;x=6da149e699b40150]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11552
_SOURCE_REALTIME_TIMESTAMP=1676889239285934
Mon 2023-02-20 11:34:23.656805 CET [s=7cc68172d1a24983b6b09ebab5376857;i=183202;b=f50094448b1747a0bd4759a360f602af;m=cd14be2f;t=5f51f34e34f90;x=5c7fd25a1bc1d52c]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:34:23
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.148' (uid=0 pid=11561 comm="sudo grep -rE *Comodo* /usr/local/lib/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676889263656805
Mon 2023-02-20 11:34:23.657739 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=18320b;b=f50094448b1747a0bd4759a360f602af;m=cd14cee3;t=5f51f34e36044;x=d1d0ac615d9e19fc]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11561
_CMDLINE=sudo grep -rE "*Comodo*" /usr/local/lib/systemd
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep -rE *Comodo* /usr/local/lib/systemd
_SOURCE_REALTIME_TIMESTAMP=1676889263657739
Mon 2023-02-20 11:34:53.998384 CET [s=7cc68172d1a24983b6b09ebab5376857;i=183212;b=f50094448b1747a0bd4759a360f602af;m=cee3b801;t=5f51f36b24961;x=3de41c04ec8a995d]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:34:53
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.149' (uid=0 pid=11566 comm="sudo grep -rE *Comodo* /run/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676889293998384
Mon 2023-02-20 11:34:54.001761 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=183216;b=f50094448b1747a0bd4759a360f602af;m=cee3c541;t=5f51f36b256a2;x=159482f4d9e9aab]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11566
_SOURCE_REALTIME_TIMESTAMP=1676889294001761
Mon 2023-02-20 11:36:42.358109 CET [s=7cc68172d1a24983b6b09ebab5376857;i=183222;b=f50094448b1747a0bd4759a360f602af;m=d5592823;t=5f51f3d27b983;x=2b142a8145fd7eca]
PRIORITY=6
_TRANSPORT=syslog
SYSLOG_FACILITY=3
_UID=81
_GID=81
_COMM=dbus-daemon
SYSLOG_PID=578
_PID=578
SYSLOG_TIMESTAMP=Feb 20 11:36:42
MESSAGE=[system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.150' (uid=0 pid=11590 comm="sudo grep -rE *Comodo* /usr/lib/systemd")
_SOURCE_REALTIME_TIMESTAMP=1676889402358109
Mon 2023-02-20 11:36:42.359646 CET [s=c05c74a9b11b47f1aa6b70137304f397;i=183226;b=f50094448b1747a0bd4759a360f602af;m=d5592e09;t=5f51f3d27bf6a;x=f4b437f6e3428a1]
_UID=1000
_GID=1000
_AUDIT_SESSION=2
_TRANSPORT=syslog
PRIORITY=5
_COMM=sudo
_EXE=/usr/bin/sudo
SYSLOG_FACILITY=4
_PID=11590
_CMDLINE=sudo grep -rE "*Comodo*" /usr/lib/systemd
MESSAGE=michaldybczak : TTY=pts/1 ; PWD=/home/michaldybczak ; USER=root ; COMMAND=/usr/bin/grep -rE *Comodo* /usr/lib/systemd
_SOURCE_REALTIME_TIMESTAMP=1676889402359646
xabbu
February 20, 2023, 10:42am
25
We have a winner. But it is special, since it is a user service, not a system service.
systemctl --user status app-cav@autostart.service
Fixed typo in command
sudo systemctl --user status app-cav@autostart.service
Failed to connect to bus: No medium
Grep is not finding anything in /usr/lib/systemd/systemd
. It’s not a file that I can open in text editor.
xabbu
February 20, 2023, 10:49am
27
No sudo
it is for your user. Just,
Yup, I noticed.
xabbu
February 20, 2023, 10:52am
28
It might be in your Home folder (~/.config/systemd/user
) and it will be just app-cav@.service
, without the autostart.
Still can’t see it.
ls /home/michaldybczak/.config/systemd/
user
ls /home/michaldybczak/.config/systemd/user/
default.target.wants
ls /home/michaldybczak/.config/systemd/user/default.target.wants
appimagelauncherd.service
It must be placed somewhere else…
The file appimagelauncherd.service has only:
[Unit]
Description=AppImageLauncher daemon
[Service]
ExecStart=/usr/bin/appimagelauncherd
Restart=on-failure
RestartSec=10
[Install]
xabbu
February 20, 2023, 10:59am
30
The status command will show which file it is.
TriMoon
February 20, 2023, 11:00am
31
XDG autostart files are in ~/.config/autostart/
and /etc/xdg/autostart/
see Desktop Application Autostart Specification
Those files will be automatically converted to systemd units by the generator used for it: systemd-xdg-autostart-generator
Then one of the AppImage programs you have installed is calling it…
xabbu
February 20, 2023, 11:04am
32
Also there are some other folder which might contain the file. @TriMoon link in the second post has a list in “Table 2. Load path when running in user mode (--user
You can also do something like
systemctl --user cat app-cav@autostart.service
to see the complete content of the service file.
xabbu:
app-cav@.service
systemctl status app-cav@.service
Failed to get properties: Unit name app-cav@.service is neither a valid invocation ID nor unit name
In ~/.config/autostart/
I can see:
I wonder about the nexcloud - it isn’t installed at the moment. Should I remove it?
This chromium-service is also a very old autostart - not sure what is it doing or is it doing anything at the moment?
geoclue-demo-agent.desktop - also some old file.
msm_kde_notifier.desktop - also some old file
remmina-applet.desktop - uninstalled, not sure why is it there.
I guess I have some cleaning to do.
Ah, here it is:
ls /etc/xdg/autostart/
at-spi-dbus-bus.desktop kaccess.desktop org.kde.plasmashell.desktop polkit-kde-authentication-agent-1.desktop user-dirs-update-gtk.desktop
baloo_file.desktop klipper.desktop pamac-tray-budgie.desktop powerdevil.desktop warpinator-autostart.desktop
cav.desktop msm_kde_notifier.desktop pamac-tray.desktop print-applet.desktop xapp-sn-watcher.desktop
geoclue-demo-agent.desktop org.gnome.SettingsDaemon.DiskUtilityNotify.desktop pamac-tray-plasma.desktop snapshot-detect.desktop xembedsniproxy.desktop
gmenudbusmenuproxy.desktop org.kde.discover.notifier.desktop pam_kwallet_init.desktop snap-userd-autostart.desktop
gsettings-data-convert.desktop org.kde.kdeconnect.daemon.desktop plasma-hud.desktop touchegg.desktop
Time to delete cav.desktop from /etc/xdg/autostart/
Yeap. The file inside says:
[Desktop Entry]
Type=Application
Name=Comodo Antivirus
Comment=Comodo Antivirus
Exec=/bin/sh /opt/COMODO/load_cav.sh login
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
X-GNOME-Autostart-Delay=6
I guess, it’s time to delete it.
TriMoon
February 20, 2023, 11:08am
37
Calm down, it is normal for people to make mistakes
TriMoon
February 20, 2023, 11:10am
38
I’m glad we found the origin, take care
Thanks to you all @TriMoon and @xabbu !
system
Closed
February 23, 2023, 1:12am
40
