Systemd 240 update breaks graphical login
systemd
gnome
update
xfce
xfce4-gtk3
#1
the latest systemd on unstable broke graphical login i had to revert to make it work again
Xfce4 Unstable (or rather lightdm?); "Unable to contact settings server"
[Unstable Update] 2018-12-14 - Cinnamon, Deepin, QT5, Systemd, KDE-Apps, KDE-Framework, Mesa
[Testing Update i686] 2018-12-19 to 2019-01-15 - Systemd, Kernels, LibreOffice Fresh, Readline
#2
Unstable VM
I got a message after GUI login:
Einstellungsserver kann nicht kontaktiert werden
Failed to connect to socket /tmp/dbus-gZSu5AMyoH: Verbindungsaufbau abgelehnt
then:
Kann keine Verbindung zur Sitzung des Nachrichtenbusses erhalten
Verbindung ist gescheitert: Verbindungsaufbau abgelehnt
Xfce Session is gone…
journalctl -b gives some hints about crashes:
https://filehorst.de/d/cmBcIjwG
#3
I didn’t update systemd on my machine yet. Only packaged it. I’ve to see what the issue might be. Thx for reporting it.
#4
It might be a combination…
I have coredump of xfce4-session and light-locker.
Also have strange new ACPI errors:
Dec 22 09:35:53 Jammin1 kernel: ACPI Error: [_SB_.PCI0.RP05.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170728/dswload2-191)
Dec 22 09:35:53 Jammin1 kernel: ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170728/psobject-252)
Dec 22 09:35:53 Jammin1 kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.RP04.PXSX, AE_NOT_FOUND (20170728/psparse-550)
Dec 22 09:35:53 Jammin1 kernel: ACPI Error: [_SB_.PCI0.RP09.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170728/dswload2-191)
Dec 22 09:35:53 Jammin1 kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.RP08.PXSX, AE_NOT_FOUND (20170728/psparse-550)
Something going on with mdadm:
Dec 22 09:35:53 Jammin1 [407]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sdb5 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [335]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sda5 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [367]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sdb4 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [402]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sdb3 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [378]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sdb6 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [388]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sda2 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [382]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sda6 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [351]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sda4 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [357]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sdb2 --offroot ${DEVLINKS}': Input/output error
Dec 22 09:35:53 Jammin1 [448]: Failed to wait spawned command '/usr/bin/mdadm --incremental --export /dev/sda3 --offroot ${DEVLINKS}': Input/output error
And, a couple of other random entries:
Dec 22 09:35:53 Jammin1 kernel: amdgpu 0000:01:00.0: Invalid PCI ROM header signature: expecting 0xaa55, got 0xffff
Dec 22 09:35:53 Jammin1 kernel: (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
I also downgraded everything (systemd and linux-firmware) and all is well again.
#5
No problem here with kde on unstable
With latest firmware and systemd 240
#6
I just logged in to report this as well.
Updated 12 packages this morning, rebooted this afternoon and no graphical login (error something like ‘can’t find settings manager’ - don’t know exactly, I didn’t write it down).
Used the fantastic ‘Timeshift’ to restore to yesterdays disk image, all was well.
Redid the update with the 8 updates that weren’t to do with systemd, rebooted and all was well again. So proof positive that systemd is the problem (if you ever needed proof of that).
I am on Xfce4 unstable.
Holding systemd updates for now.
#7
Same as @Librewish. " No problem here with kde on unstable With latest firmware and systemd 240"
Did get a few pacman: [ALPM-SCRIPTLET] Failure to communicate with kernel device-mapper driver. etc errors. But I always reboot after getting these errors and go on my merry way with no ill effects.
#8
240.1 is in unstable now.
#9
240.1 is just as bad.
Incidentally the error message is:
Connection Refused
#10
Same for me : 240.1 breaks boot
First symptom : shutdown after update or after switch from stable to unstable takes forever (and then no boot)
#11
Please test v240.1-2 and report back …
#12
I will do when I see it, but not available yet (German mirrors)
Edit. 240.1-2 has just arrived I will try it now.
#13
240.1-2 is bad as well.
Same error.
#14
Hmm, I didn’t had time yet to test. Maybe I’ll update a fresh v18.0.1 version in VB which I’m currently uploading …
#15
I just updated a fresh Gnome v18.0.1 to systemd 240.1-2 without any issues. Seems only old installations may have problems, on which I don’t know why. Did systemd 239.370-1 work? See current issues reported to the Arch-Bugtracker … You may also see the changelog of fedora, which is upstream for systemd. :stuck_out_tongue:
#16
i just changed branch to testing that contains systemd 239.370-2 and it works
#17
Might also be having issues with my X230. I’ll check more tomorrow.
#18
Just updated still no problem works fine
#19
No issues for me on an old KDE VM, after reading this thread I was almost expecting the system to blow up, but alas not.
I’ll update my other VMs then bare metal update on my secondary laptop.
EDIT :
No issues at all for me on any of my unstable systems, all fully encrypted KDE systems, all running linux419 4.19.12-1 with systemd 240.1-2.
Is this a GTK based DE / DM related issue?
Only warning was to do with appstream metadata.
[ALPM] running 'update-appstream-cache.hook'...
[ALPM-SCRIPTLET] The AppStream system cache was updated, but some errors were detected, which might lead to missing metadata. Refer to the verbose log for more information.
#20
No issues for me on Gnome, KDE Plasma and i3 - but i get this on Cinnamon and XFCE
The login screen loads correctly, but then the login fails:
  • On Budgie the login just goes in a loop with no error display.
I can reach the desktop on all of them from TTY2 with the startx command and logged with my user.
No time to check journactl and/or fixes for this. Probably i will be able later this evening.
