System won't boot after Kernel update
Hi,
I’m unable to update to any other Kernel than the currently running 5.15. I hoped that the recent LTS release 6.1 would work, but unfortunately I’m also stuck at reboot here. Could find the following in the Kernel log:
kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
kernel:
kernel: traps: Missing ENDBR: _nv012309rm+0x0/0x10 [nvidia]
kernel: ------------[ cut here ]------------
kernel: kernel BUG at arch/x86/kernel/traps.c:255!
kernel: invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
kernel: CPU: 2 PID: 378 Comm: systemd-modules Tainted: P           OE      6.1.12-1-MANJARO #1 d419fb51ba9431ae2a4575820ea6b5b95f50a34f
kernel: Hardware name: HP OMEN by HP Laptop 17-ck0xxx/88FE, BIOS F.26 01/28/2022
kernel: RIP: 0010:exc_control_protection+0xc2/0xd0
kernel: Code: fa ff 45 31 c9 49 89 d8 b9 09 00 00 00 48 8b 93 80 00 00 00 be fc 00 00 00 48 c7 c7 09 4e 24 87 e8 c3 84 46 ff e9 64 ff ff ff <0f> 0b 66 66 2e 0f 1f 84 00 00 00 00 00 90 66 0f 1f 00 55 53 48 89
kernel: RSP: 0018:ffffaf3140937b48 EFLAGS: 00010002
kernel: RAX: 0000000000000033 RBX: ffffaf3140937b68 RCX: 0000000000000027
kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8a45778a1660
kernel: RBP: 0000000000000003 R08: 0000000000000000 R09: ffffaf31409379e0
kernel: R10: 0000000000000003 R11: ffffffff87acc7e8 R12: 0000000000000000
kernel: R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
kernel: FS:  00007f0a0a45a080(0000) GS:ffff8a4577880000(0000) knlGS:0000000000000000
kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
kernel: CR2: 00007f0a04579000 CR3: 000000010f36e005 CR4: 0000000000f70ee0
kernel: PKRU: 55555554
kernel: Call Trace:
kernel:  <TASK>
kernel:  asm_exc_control_protection+0x26/0x30
kernel: RIP: 0010:_nv012309rm+0x0/0x10 [nvidia]
kernel: Code: 66 2e 0f 1f 84 00 00 00 00 00 48 83 ec 08 e8 f7 d1 1f 00 48 83 c4 08 48 89 c7 e9 bb ff ff ff 66 2e 0f 1f 84 00 00 00 00 00 90 <48> 89 f7 e9 18 08 00 00 0f 1f 84 00 00 00 00 00 48 89 f7 e9 18 08
kernel: RSP: 0018:ffffaf3140937c18 EFLAGS: 00010202
kernel: RAX: ffffffffc3214380 RBX: ffffffffc6277130 RCX: 0000000000000000
kernel: RDX: 00000000000132a2 RSI: 0000000000000010 RDI: ffffffffc6277130
kernel: RBP: ffff8a3e35285fe0 R08: ffffaf3140937ba8 R09: ffffffffc6277170
kernel: R10: ffffffffc6240fb0 R11: 0000000000000000 R12: 0000000000000010
kernel: R13: ffff8a3e35283000 R14: 000055c28f262c00 R15: ffffaf3140937d98
kernel:  ? _nv038466rm+0x20/0x20 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  _nv012307rm+0x24/0xe0 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  _nv038467rm+0xe/0xa0 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  _nv038470rm+0x1d/0x30 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  _nv038472rm+0x2f/0x40 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  _nv017028rm+0x15/0x70 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  _nv000690rm+0x9/0x20 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  ? cdev_add+0x50/0x70
kernel:  rm_init_rm+0x17/0x60 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  nvidia_init_module+0x24e/0x622 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  ? nvidia_init_module+0x622/0x622 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  nvidia_frontend_init_module+0x50/0x94 [nvidia c8d73dd67278aa58c9e9b7568d18a2a7abaf92dd]
kernel:  do_one_initcall+0x5a/0x220
kernel:  do_init_module+0x4a/0x1e0
kernel:  __do_sys_init_module+0x17f/0x1b0
kernel:  do_syscall_64+0x5c/0x90
kernel:  ? syscall_exit_to_user_mode+0x1b/0x40
kernel:  ? do_syscall_64+0x6b/0x90
kernel:  ? exc_page_fault+0x74/0x170
kernel:  entry_SYSCALL_64_after_hwframe+0x63/0xcd
kernel: RIP: 0033:0x7f0a0a721eee
kernel: Code: 48 8b 0d 85 ee 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 52 ee 0c 00 f7 d8 64 89 01 48
kernel: RSP: 002b:00007fff6fe41bd8 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
kernel: RAX: ffffffffffffffda RBX: 000055c28f263310 RCX: 00007f0a0a721eee
kernel: RDX: 000055c28f262c00 RSI: 00000000058e2128 RDI: 00007f09fec97010
kernel: RBP: 000055c28f262c00 R08: 000055c28f263560 R09: 00007fff6fe3dba8
kernel: R10: 0000000000000005 R11: 0000000000000246 R12: 0000000000020000
kernel: R13: 000055c28f263390 R14: 000055c28f263310 R15: 000055c28f2638a0
kernel:  </TASK>
kernel: Modules linked in: mac80211(+) kvm_intel(+) nvidia(POE+) snd_hda_codec_hdmi(+) libarc4 snd_pcm_dmaengine kvm snd_hda_intel i915(+) irqbypass btusb vfat snd_intel_dspcfg crct10dif_pclmul btrtl snd_intel_sd>
kernel:  ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 nvme nvme_core nvme_common usbhid serio_raw atkbd crc32_pclmul libps2 crc32c_intel sdhci_pci vivaldi_fmap sha512_ssse3 cqhci aesni_intel sdhci sp>
kernel: ---[ end trace 0000000000000000 ]---
kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input17
kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input18
kernel: usbcore: registered new interface driver uvcvideo
kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input19
kernel: iwlwifi 0000:2e:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
kernel: i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
kernel: intel_tcc_cooling: Programmable TCC Offset detected
kernel: intel_rapl_common: Found RAPL domain package
kernel: intel_rapl_common: Found RAPL domain core
kernel: intel_rapl_common: Found RAPL domain uncore
kernel: intel_rapl_common: Found RAPL domain psys
systemd[1]: Starting Load/Save RF Kill Switch Status...
systemd[1]: Create System Users was skipped because no trigger condition checks were met.
systemd[1]: systemd-modules-load.service: Main process exited, code=killed, status=11/SEGV
systemd[1]: systemd-modules-load.service: Failed with result 'signal'.
kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input20
kernel: input: ELAN0753:00 04F3:31C2 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0753:00/0018:04F3:31C2.0006/input/input21
kernel: input: ELAN0753:00 04F3:31C2 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0753:00/0018:04F3:31C2.0006/input/input23
kernel: hid-multitouch 0018:04F3:31C2.0006: input,hidraw5: I2C HID v1.00 Mouse [ELAN0753:00 04F3:31C2] on i2c-ELAN0753:00
kernel: typec port0: bound usb3-port4 (ops connector_ops)
kernel: typec port0: bound usb2-port1 (ops connector_ops)
systemd[1]: Failed to start Load Kernel Modules.
Output of mhwd-kernel -li && mhwd -l -li
Currently running: 5.15.94-1-MANJARO (linux515)
   * linux515
   * linux61
> Installed PCI configs:
         network-r8168            2016.04.20                true            PCI
video-hybrid-intel-nvidia-prime            2021.11.04               false            PCI
> 0000:01:00.0 (0300:10de:24dc) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime            2021.11.04               false            PCI
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:2d:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
> 0000:00:02.0 (0300:8086:9a60) Display controller Intel Corporation:
head /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
test -d /sys/firmware/efi && echo efi || echo bios
efi
Thanks in advance.
with update you actually mean switching to a different kernel than the 5.15?
try adding the ibt parameter, since you have nvidia+intel system, and try again booting with the 6.1
Yes, with an update I meant switching to a newer kernel. Your suggestion worked for me, thank you very much for all the efforts you put into the forum. I stumbled upon many answers from you while searching for similar boot issues :+1:
