could it be related to
Freeze when receiving a keypress from a different input device than the last keypress
I got this issue, when using keyboard and mouse with binded keys while gaming.
EDIT:
I resolved my issue. The problem is indeed with mutter. At least in my case. So what i did?
git clone https://aur.archlinux.org/mutter-performance.git
cd mutter-performance
i added to end of the prepare
function in PKGBUILD file following line
sed -i '/case XkbNewKeyboardNotify:/d' src/backends/x11/meta-backend-x11.c
i also removed from makedepends
object glib2-devel
as it is provided by glib2 package and manjaro is behind or something.
and last i ran makepkg -si
and rebooted. that’s it!
Hello!
Sorry about my late reply.
Very busy here.
Thanks! I will give a shot later, if needed.
So, in the Stable Update from 2024-07-01, the problem disappear. mutter
got updated from 46.2-1.0 to
46.2-1.3, and maybe that’s it.
I will keep the thread open, because there is a new stable update here. If the problem don’t come back, I will return and mark as solved.
Anyway, thanks everyone for your time and effort.
Long live to Manjaro!
Hello!
Confirming that in the Stable Update from 2024-07-01 the problem was fixed, and since the 2024-07-16 Stable Update everything just keep working.
So, problem solved.
system
Closed
27 July 2024 00:18
24
