System-wide UI Freeze in KDE Plasma 6
The entire graphical interface periodically freezes without any clear trigger. All UI elements stop responding, except for the mouse cursor, which continues to move. The issue appears randomly during normal system use (approximately once a week). During brief moments when the system “unfreezes”, queued actions execute rapidly, but the freeze returns after ~30 seconds. The problem persists until the system is rebooted.
System Information
  • OS: Manjaro Linux 25.0.10
  • Kernel: 6.12.48-1-MANJARO [64-bit] (actually, the issue persists for several shifts/updates of kernel)
  • Desktop Environment: KDE Plasma 6.3.6
  • Display Server: X11
  • GPU: GeForce RTX 4080
  • NVIDIA Driver: 580.82.09 (proprietary)
I would be grateful for any guidance on identifying the root cause or suggestions for additional logs/debugging steps would be appreciated.
Please provide your system information as described (below) making sure it conforms to forum guidelines for pre-formatted text presentation.
Once that is done, I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
Welcome to the Manjaro community @DmitryInd
Does the issue also occur if you switch to a Plasma Wayland session?
You can change your Plasma session from X11 to Wayland by selecting the session type at the login screen (Wayland is now KDE’s default for Plasma).
If you have set up autologin to skip the password screen, you can change to a Wayland session by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
To see if your current session is running on X11 or Wayland, run the following command in a terminal:
echo $XDG_SESSION_TYPE
For those curious about how Wayland differs from X11:
If switching to Wayland doesn’t fix the issue, then more detailed system information may be required (as was just requested by @soundofthunder )
Here is all the additional information about the system that you may need. Unfortunately, I did not record any logs after the errors occurred. I would appreciate it if you could tell me what to look for the next time an error happens.
Among the known errors that are reported on the Internet, I could not find anything like this that has been published and solved in the last 2 years.
Global information:
$ inxi -zv8
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=acbb09f6-e76f-489b-801b-d733c85bdd32 rw rootflags=subvol=@
    quiet splash resume=UUID=a70a6ddd-7c93-4bf3-8fbc-36a38415567f
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
    wm: kwin_x11 with: kdocker vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: PRO Z790-P WIFI DDR4 (MS-7E06) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.20 date: 09/30/2022
  System RAM: total: 64 GiB available: 62.6 GiB used: 8.8 GiB (14.1%)
  Device-1: Controller0-DIMMA1 type: no module installed
  Device-2: Controller0-DIMMA2 type: DDR4 detail: synchronous size: 32 GiB
    speed: 3600 MT/s volts: curr: 1.35 min: 1.35 max: 1.35 width (bits):
    data: 64 total: 64 manufacturer: Kingston part-no: KF3600C18D4/32GX
    serial: <filter>
  Device-3: Controller1-DIMMB1 type: no module installed
  Device-4: Controller1-DIMMB2 type: DDR4 detail: synchronous size: 32 GiB
    serial: <filter>
  Info: model: 13th Gen Intel Core i5-13600K bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x12F
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 5100 min/max: 800/5100:3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 5100 2: 5100 3: 5100
    4: 5100 5: 5100 6: 5100 7: 5100 8: 5100 9: 5100 10: 5100 11: 5100 12: 5100
    13: 5100 14: 5100 15: 5100 16: 5100 17: 5100 18: 5100 19: 5100 20: 5100
    bogomips: 139820
    de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
    rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Micro-Star MSI
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
    HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0380
  Device-2: NVIDIA AD103 [GeForce RTX 4080] vendor: Palit Microsystems
    driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-08) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-4
    empty: DP-3,DP-5,HDMI-A-5 bus-ID: 01:00.0 chip-ID: 10de:2704
    class-ID: 0300
  Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.3:5
    chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 120 s-size: 542x305mm (21.34x12.01")
    s-diag: 622mm (24.49")
  Monitor-1: DP-4 mapped: DP-2 note: disabled model: Gigabyte G27QC A
    serial: <filter> built: 2022 res: mode: 2560x1440 hz: 165 scale: 100% (1)
    dpi: 108 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.247
    y: 0.671 blue: x: 0.149 y: 0.090 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x720, 1440x576, 1024x768, 1440x480, 800x600, 720x576, 720x480,
    640x480
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
    memory: 15.62 GiB
  API: Vulkan v: 1.4.321 layers: 11 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4080 driver: nvidia v: 580.82.09
    device-ID: 10de:2704 surfaces: N/A device: 1 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 25.2.3-arch1.2
    device-ID: 8086:a780 surfaces: N/A
  Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: NVIDIA vendor: Palit Microsystems driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:22bb class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: SINO WEALTH Bluetooth Keyboard driver: hid-generic,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.1.4:12
    chip-ID: 258a:00e0 class-ID: 0300
  Device-2: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
    class-ID: e001
  Report: ID: hci0 rfk-id: 0 state: up address: N/A
  Local Storage: total: 1.82 TiB used: 1.16 TiB (63.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 46.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
  ID-1: / raw-size: 922.42 GiB size: 1.81 TiB (200.99%) used: 1.16 TiB (63.9%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: acbb09f6-e76f-489b-801b-d733c85bdd32
    used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 3123-A5B3
  ID-3: /home raw-size: 922.42 GiB size: 1.81 TiB (200.99%)
    used: 1.16 TiB (63.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: acbb09f6-e76f-489b-801b-d733c85bdd32
  ID-4: /var/cache raw-size: 922.42 GiB size: 1.81 TiB (200.99%)
  ID-5: /var/log raw-size: 922.42 GiB size: 1.81 TiB (200.99%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 256 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:3 label: swap
    uuid: a70a6ddd-7c93-4bf3-8fbc-36a38415567f
  Device-1: 1-2:2 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7e06 class-ID: 0300
    serial: <filter>
  Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5.3:5 info: Logitech Webcam C930e type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0
  Hub-3: 1-12:4 info: Genesys Logic Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-4: 1-12.1:10 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0801 class-ID: 0900
  Device-1: 1-12.1.3:11 info: A4Tech USB Device type: keyboard,mouse,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 09da:5b22 class-ID: 0300
  Device-2: 1-12.1.4:12 info: SINO WEALTH Bluetooth Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  Hub-5: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-14:9 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-6: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 46 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 2220 pm: pacman pkgs: 2156 libs: 558 tools: pamac,yay pm: flatpak
    pkgs: 64
    1: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    2: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 475
  1: cpu: 4.3% command: steamwebhelper pid: 8093 mem: 502.9 MiB (0.7%)
  2: cpu: 2.7% command: steamwebhelper pid: 8134 mem: 667.5 MiB (1.0%)
  3: cpu: 2.4% command: Xorg pid: 941 mem: 188.4 MiB (0.2%)
  4: cpu: 1.0% command: steam pid: 7841 mem: 253.2 MiB (0.3%)
  5: cpu: 0.7% command: yandex_browser pid: 2222 mem: 690.3 MiB (1.0%)
  Memory top: 5 of 475
  1: mem: 1089.2 MiB (1.6%) command: pamac-manager pid: 11439 cpu: 0.0%
  2: mem: 1076.1 MiB (1.6%) command: plasmashell pid: 1182 cpu: 0.0%
  3: mem: 690.3 MiB (1.0%) command: yandex_browser pid: 2222 cpu: 0.7%
  4: mem: 667.5 MiB (1.0%) command: steamwebhelper pid: 8134 cpu: 2.7%
  5: mem: 579.7 MiB (0.9%) command: thunderbird pid: 1510 cpu: 0.1%
  Processes: 475 Power: uptime: 16h 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
    default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.39
$ LANG=C lscpu
Architecture:                x86_64
  CPU op-mode(s):            32-bit, 64-bit
  Address sizes:             46 bits physical, 48 bits virtual
  Byte Order:                Little Endian
CPU(s):                      20
  On-line CPU(s) list:       0-19
Vendor ID:                   GenuineIntel
  Model name:                13th Gen Intel(R) Core(TM) i5-13600K
    CPU family:              6
    Model:                   183
    Thread(s) per core:      2
    Core(s) per socket:      14
    Socket(s):               1
    Stepping:                1
    CPU(s) scaling MHz:      65%
    CPU max MHz:             5100.0000
    CPU min MHz:             800.0000
    BogoMIPS:                6991.00
    Flags:                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_goo
                             d nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_
                             timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpc
                             id rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req h
                             fi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear serialize pconfig arch_lbr ibt flush_l1d arch_capabilities
Virtualization features:
  Virtualization:            VT-x
Caches (sum of all):
  L1d:                       544 KiB (14 instances)
  L1i:                       704 KiB (14 instances)
  L2:                        20 MiB (8 instances)
  L3:                        24 MiB (1 instance)
NUMA:
  NUMA node(s):              1
  NUMA node0 CPU(s):         0-19
  Gather data sampling:      Not affected
  Indirect target selection: Not affected
  Itlb multihit:             Not affected
  L1tf:                      Not affected
  Mds:                       Not affected
  Meltdown:                  Not affected
  Mmio stale data:           Not affected
  Reg file data sampling:    Mitigation; Clear Register File
  Retbleed:                  Not affected
  Spec rstack overflow:      Not affected
  Spec store bypass:         Mitigation; Speculative Store Bypass disabled via prctl
  Spectre v1:                Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:                Mitigation; Enhanced / Automatic IBRS; IBPB conditional; PBRSB-eIBRS SW sequence; BHI BHI_DIS_S
  Srbds:                     Not affected
  Tsa:                       Not affected
  Tsx async abort:           Not affected
  Vmscape:                   Mitigation; IBPB before exit to userspace
Drivers:
$ mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
          video-nvidia            2025.09.29               false            PCI
Kernels:
$ mhwd-kernel -li
Currently running: 6.12.48-1-MANJARO (linux612)
   * linux61
   * linux612
   * linux66
Manjaro Version:
$ lsb_release -sirc
ManjaroLinux 25.0.10 Zetar
Partitioning
$ lsblk -fa
$ LANG=C sudo parted -l
NAME        FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1
├─nvme0n1p1 vfat   FAT32       3123-A5B3                             273.5M     9% /boot/efi
├─nvme0n1p2 btrfs              acbb09f6-e76f-489b-801b-d733c85bdd32  660.7G    64% /var/log
│        /var/cache
│        /home
└─nvme0n1p5 swap   1     swap  a70a6ddd-7c93-4bf3-8fbc-36a38415567f                [SWAP]
nvme1n1     btrfs              acbb09f6-e76f-489b-801b-d733c85bdd32
Model: Samsung SSD 980 PRO 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name  Flags
 1      2097kB  317MB   315MB   fat32                 boot, esp
 2      317MB   991GB   990GB   btrfs           root
 5      991GB   1000GB  9449MB  linux-swap(v1)        swap
Disk /dev/nvme1n1: 1000GB
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system  Flags
 1      0.00B  1000GB  1000GB  btrfs
PCI Devices
$ lspci -k
00:00.0 Host bridge: Intel Corporation Device a704 (rev 01)
        DeviceName: Onboard - Other
        Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7e06
00:01.0 PCI bridge: Intel Corporation Raptor Lake PCI Express 5.0 Graphics Port (PEG010) (rev 01)
        Kernel driver in use: pcieport
00:02.0 Display controller: Intel Corporation Raptor Lake-S GT1 [UHD Graphics 770] (rev 04)
        DeviceName: Onboard - Video
        Kernel driver in use: i915
        Kernel modules: i915, xe
00:06.0 PCI bridge: Intel Corporation Raptor Lake PCIe 4.0 Graphics Port (rev 01)
00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module (rev 01)
00:0a.0 Signal processing controller: Intel Corporation Raptor Lake Crashlog and Telemetry (rev 01)
        Kernel driver in use: intel_vsec
        Kernel modules: intel_vsec
00:14.0 USB controller: Intel Corporation Raptor Lake USB 3.2 Gen 2x2 (20 Gb/s) XHCI Host Controller (rev 11)
        Kernel driver in use: xhci_hcd
        Kernel modules: mei_me
00:14.2 RAM memory: Intel Corporation Raptor Lake-S PCH Shared SRAM (rev 11)
00:14.3 Network controller: Intel Corporation Raptor Lake-S PCH CNVi WiFi (rev 11)
        DeviceName: Onboard - Ethernet
        Subsystem: Intel Corporation Device 0094
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi
00:16.0 Communication controller: Intel Corporation Raptor Lake CSME HECI #1 (rev 11)
        Kernel driver in use: mei_me
00:17.0 SATA controller: Intel Corporation Raptor Lake SATA AHCI Controller (rev 11)
        DeviceName: Onboard - SATA
        Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation Raptor Lake PCI Express Root Port #1 (rev 11)
00:1c.2 PCI bridge: Intel Corporation Raptor Point-S PCH - PCI Express Root Port 3 (rev 11)
00:1d.0 PCI bridge: Intel Corporation Raptor Lake PCI Express Root Port #9 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Raptor Lake LPC/eSPI Controller (rev 11)
00:1f.3 Audio device: Intel Corporation Raptor Lake High Definition Audio Controller (rev 11)
        DeviceName: Onboard - Sound
        Subsystem: Micro-Star International Co., Ltd. [MSI] Device 9e06
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Raptor Lake-S PCH SMBus Controller (rev 11)
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Raptor Lake SPI (flash) Controller (rev 11)
        Kernel driver in use: intel-spi
        Kernel modules: spi_intel_pci
01:00.0 VGA compatible controller: NVIDIA Corporation AD103 [GeForce RTX 4080] (rev a1)
        Subsystem: Palit Microsystems Inc. Device f296
        Kernel driver in use: nvidia
        Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation Device 22bb (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
        Subsystem: Samsung Electronics Co Ltd SSD 980 PRO
        Kernel driver in use: nvme
        Kernel modules: nvme
04:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03)
        Kernel driver in use: igc
        Kernel modules: igc
05:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
Logs can be generated for the previous boot, and those before it by using appropriate parameters. The following provides all information needed, and probably some you’ll never need:
However, please answer firstly the question posed by @scotty65 in post #3:
And what did you find when searching the forum?
You could use open drivers matching the kernel.
nvidia-driver-assistant
Your cpu may be undervolted - this will cause freezes.
No, I did not try to reproduce the error in the Plasma Wayland session. Currently, I would prefer to stay on display server x11.
Can you please try that, and report back? The result may help to isolate the issue. As might creating a new User account (for diagnostic purposes) to see if the issue persists.
Please don’t ignore a suggestion because it doesn’t suit you. All information you can provide can potentially help to identify the problem.
While searching for my problem, I came across two similar topics:
The error was occurred again today, but this time the system managed to return to normal operation. The following are the systemd logs related to the latest and previous errors.
$ journalctl --system --priority=4 | tail --lines=10
Nov 16 11:32:23 indenbom-ms7e06 kernel: umip_printk: 113 callbacks suppressed
Nov 16 11:34:25 indenbom-ms7e06 kernel: umip_printk: 115 callbacks suppressed
Nov 16 11:36:26 indenbom-ms7e06 kernel: umip_printk: 115 callbacks suppressed
Nov 16 11:38:27 indenbom-ms7e06 kernel: umip_printk: 113 callbacks suppressed
Nov 16 11:40:27 indenbom-ms7e06 kernel: umip_printk: 113 callbacks suppressed
Nov 16 11:42:28 indenbom-ms7e06 kernel: umip_printk: 115 callbacks suppressed
Nov 16 11:42:45 indenbom-ms7e06 kernel: coredump Note size too large: 5375744 (does kernel.core_file_note_size_limit sysctl need adjustment?
Nov 16 11:43:53 indenbom-ms7e06 bluetoothd[750]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Nov 16 12:16:32 indenbom-ms7e06 bluetoothd[750]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Nov 16 22:06:38 indenbom-ms7e06 kernel: BTRFS warning (device nvme0n1p2): to be deleted qgroup 0/1577 has non-zero numbers, rfer 43970519040 rfer_cmpr 43970519040 excl 100093952 excl_cmpr 100093952
$ journalctl --system --boot=-1 --priority=4 | tail --lines=10
Nov 15 13:29:08 indenbom-ms7e06 kernel: xpad 1-9:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
Nov 15 13:35:21 indenbom-ms7e06 kernel: input input33: unable to receive magic message: -32
Nov 15 13:55:40 indenbom-ms7e06 kernel: xpad 1-9:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
Nov 15 14:41:06 indenbom-ms7e06 kernel: input input34: unable to receive magic message: -32
Nov 15 15:41:14 indenbom-ms7e06 kernel: xpad 1-9:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
Nov 15 15:42:09 indenbom-ms7e06 kernel: x86/split lock detection: #AC: CJobMgr::m_Work/532248 took a split_lock trap at address: 0xf3b51c7f
Nov 15 18:00:25 indenbom-ms7e06 kernel: BTRFS warning (device nvme0n1p2): to be deleted qgroup 0/1509 has non-zero numbers, rfer 428988919808 rfer_cmpr 428988919808 excl 21095124992 excl_cmpr 21095124992
As you recommended, I logged into the wayland session and worked on it for about a week. The hanging error occurred again today.
Below are the systemd logs:
$ journalctl --system --priority=4 | tail --lines=30
-- Boot 233be636184943218415badcc0b1b58d --
Nov 24 22:21:10 indenbom-ms7e06 kernel:   #1  #3  #5  #7  #9 #11
Nov 24 22:21:10 indenbom-ms7e06 kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Nov 24 22:21:10 indenbom-ms7e06 kernel: nvidia: loading out-of-tree module taints kernel.
Nov 24 22:21:10 indenbom-ms7e06 kernel: nvidia: module license 'NVIDIA' taints kernel.
Nov 24 22:21:10 indenbom-ms7e06 kernel: Disabling lock debugging due to kernel taint
Nov 24 22:21:10 indenbom-ms7e06 kernel: nvidia: module license taints kernel.
Nov 24 22:21:10 indenbom-ms7e06 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  580.82.09  Fri Aug 29 17:44:50 UTC 2025
Nov 24 22:21:10 indenbom-ms7e06 kernel: usb 1-5.3: 4:1: cannot get freq at ep 0x84
Nov 24 22:21:10 indenbom-ms7e06 kernel: iwlwifi 0000:00:14.3: capa flags index 4 larger than supported by driver
Nov 24 22:21:11 indenbom-ms7e06 systemd-journald[471]: File /var/log/journal/6ad02478fadd4f349717b83073f6d329/system.journal corrupted or uncleanly shut down, renaming and replacing.
Nov 24 22:21:11 indenbom-ms7e06 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Nov 24 22:21:17 indenbom-ms7e06 dbus-broker-launch[738]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 24 22:21:17 indenbom-ms7e06 dbus-broker-launch[738]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 24 22:21:17 indenbom-ms7e06 dbus-broker-launch[893]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 24 22:21:17 indenbom-ms7e06 dbus-broker-launch[893]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 24 22:21:17 indenbom-ms7e06 dbus-broker-launch[893]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 24 22:21:20 indenbom-ms7e06 kernel: platform INT3515:01: deferred probe pending: Serial bus multi instantiate pseudo device driver: Error creating i2c-client, idx 0
Nov 24 22:29:47 indenbom-ms7e06 sddm-greeter-qt6[889]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Nov 24 22:29:47 indenbom-ms7e06 systemd-journald[471]: File /var/log/journal/6ad02478fadd4f349717b83073f6d329/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Nov 24 22:29:50 indenbom-ms7e06 kernel: nvme nvme0: using unchecked data buffer
Nov 24 22:29:50 indenbom-ms7e06 kernel: usb 1-5.3: 4:1: cannot get freq at ep 0x84
Nov 24 22:29:51 indenbom-ms7e06 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 24 22:29:53 indenbom-ms7e06 backlighthelper[1364]: org.kde.powerdevil: no kernel backlight interface found
Nov 24 22:29:58 indenbom-ms7e06 bluetoothd[743]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 24 22:30:03 indenbom-ms7e06 bluetoothd[743]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 24 22:30:08 indenbom-ms7e06 bluetoothd[743]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 24 22:30:13 indenbom-ms7e06 bluetoothd[743]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is downtype or paste code here
your bios is from 2022. if you check your manufacturer you’ll see that there is a actual bios from 2025-08-18. you should update your bios before proceeding. this is always a good first step.
There are maybe work arounds which comes in my mind that could help.
Did you try to switch between TTY (Strg+Alt+F4 ) and back to desktop (Strg+Alt+F1)
or Alt+Shift+F12 to reset hardware acceleration from Desktop?
That could probably cure that UI freeze.
Switch from LTS Kernel 6.12 to LTS Kernel 6.6 could also help, or even try the newest Kernel.
Updating your Bios as Olli suggested should be the last possible option and not the first step!
Updating your Bios can lead to a broken Device, if there is made 1 single mistake,
that includes power outage (which can’t be controlled).
Never update your Bios when its not really important! Only for security issue or system instability which can’t be solved in another way.
Maybe offtopic and idk if this problem is related:
Are you a new Linux User? Then i recommend to stay away from BTRFS as far as possible
and use EXT4 instead. If you not aware how to perfectly maintain and setup your BTRFS Partition.
