System wide stuttering
drivers
hardware
xfce
nvidia
#1
So I have an issue that I am not sure how to fix, I have looked everywhere for a fix and no luck. I am getting a constant sixty fps but it looks like it’s running around thirty, this happens on everything. I have tried using different kernels and drivers. I’m sorry if this post is very vague this is my first post.
Hardware:
  Host: j-pc Kernel: 4.9.142-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.1 Desktop: Xfce 4.13.2git-UNKNOWN tk: Gtk 3.24.1 info: xfce4-panel
  wm: xfwm4 dm: LightDM 1.28.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: TUF Z370-PRO GAMING v: Rev 1.xx
  serial: <filter> UEFI: American Megatrends v: 0215 date: 09/05/2017
  Topology: 6-Core model: Intel Core i5-8600K bits: 64 type: MCP
  arch: Kaby Lake rev: A L2 cache: 9216 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 43212
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800
  3: 3219 4: 3973 5: 1530 6: 800
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com.
  driver: nvidia v: 415.18 bus ID: 01:00.0 chip ID: 10de:1c82
  Display: x11 server: X.Org 1.20.3 driver: nvidia
  resolution: 1920x1080~60Hz, 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 415.18
  direct render: Yes
  Device-1: NVIDIA GP107GL High Definition Audio vendor: eVga.com.
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Device-2: Corsair type: USB driver: hid-generic,snd-usb-audio,usbhid
  bus ID: 1-1:2 chip ID: 1b1c:0a38
  Device-3: C-Media Blue Snowball type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2 chip ID: 0d8c:0005
  serial: <filter>
  Sound Server: ALSA v: k4.9.142-1-MANJARO
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
  port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.73 TiB used: 10.55 GiB (0.4%)
  ID-1: /dev/sda vendor: Western Digital model: WD20EZRZ-00Z5HB0
  size: 1.82 TiB speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
  rev: 0A80 scheme: GPT
  ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08M2NA0
  size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
  rev: 1A01 scheme: GPT
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
  port: f020 bus ID: 00:17.0 chip ID: 8086.2822 rev: N/A
  ID-1: / size: 1.78 TiB used: 10.55 GiB (0.6%) fs: ext4 dev: /dev/sda2
  ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
  Message: No sensors data was found. Is sensors configured?
  Processes: 203 Uptime: 1m Memory: 7.73 GiB used: 1.07 GiB (13.9%)
  Init: systemd v: 239 Compilers: gcc: 8.2.1 clang: 7.0.0 Shell: bash
  v: 4.4.23 running in: xfce4-terminal inxi: 3.0.27
#2
no worries, read through this thread below and it will explain whats needed for others to be able to assist you.
#3
Thank you for being understanding, I updated my post to be more informative with my issue.
#4
also post output of:
cat /var/log/Xorg.0.log* | grep -E "(EE)\|(WW)"
and also, what do you mean by stuttering? a further explanation of how/when/and with what resulting effect may also help. im gonna be getting off in a few, but this will help others understand what the problem is and be able to help you with any luck.
#5
My issue is everything in the os will sometimes skip ahead some frames or even go back some frames. I have force composition pipeline enable as well. It doesn’t seem to do it when force composition pipeline disabled but it’s hard to tell. I cannot upload a video of it because obs does not pick it up. I feel like this is the drivers fault but I cannot seem to fix it.
Here’s the output:
[    16.736]
X.Org X Server 1.20.3
[    16.736] Build Operating System: Linux Arch Linux
[    16.736] Current Operating System: Linux jonathan-pc 4.9.142-1-MANJARO #1 SMP PREEMPT Sat Dec 1 12:03:07 UTC 2018 x86_64
[    16.736] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9-x86_64 root=UUID=45d94fa6-a47a-4a5c-af57-804959ebd507 rw quiet resume=UUID=1263afe2-147c-478a-af5b-f48b13b20ce5
[    16.736] Build Date: 25 October 2018  04:42:32PM
[    16.736]
[    16.736] Current version of pixman: 0.36.0
[    16.736] 	Before reporting problems, check http://wiki.x.org
[    16.736] Markers: (--) probed, (**) from config file, (==) default setting,
[    16.736] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec  5 21:31:37 2018
[    16.772] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    16.772] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    16.813] (==) ServerLayout "Layout0"
[    16.813] (**) |-->Screen "Screen0" (0)
[    16.813] (**) |   |-->Monitor "Monitor0"
[    16.814] (**) |   |-->Device "Device0"
[    16.814] (**) |-->Input Device "Keyboard0"
[    16.814] (**) |-->Input Device "Mouse0"
[    16.814] (==) Automatically adding devices
[    16.814] (==) Automatically enabling devices
[    16.814] (==) Automatically adding GPU devices
[    16.814] (==) Automatically binding GPU devices
[    16.814] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    16.849] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    16.849] 	Entry deleted from font path.
[    16.849] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    16.849] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    16.849] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    16.849] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    16.849] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    16.849] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    16.849] (==) ModulePath set to "/usr/lib/xorg/modules"
[    16.850] (**) Extension "COMPOSITE" is enabled
[    16.850] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    16.850] (WW) Disabling Keyboard0
[    16.850] (WW) Disabling Mouse0
[    16.850] (II) Module ABI versions:
[    16.850] 	X.Org ANSI C Emulation: 0.4
[    16.850] 	X.Org Video Driver: 24.0
[    16.850] 	X.Org XInput driver : 24.1
[    16.850] 	X.Org Server Extension : 10.0
[    16.851] (++) using VT number 7
[    16.851] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    16.852] (II) xfree86: Adding drm device (/dev/dri/card0)
[    16.854] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    16.854] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[    16.856] (--) PCI:*(1@0:0:0) 10de:1c82:3842:6253 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    16.856] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    16.856] (II) LoadModule: "glx"
[    16.868] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[    17.361] (II) Module glx: vendor="NVIDIA Corporation"
[    17.361] 	compiled for 4.0.2, module version = 1.0.0
[    17.361] 	Module class: X.Org Server Extension
[    17.373] (II) NVIDIA GLX Module  415.18  Thu Nov 15 21:39:03 CST 2018
[    17.376] (II) LoadModule: "nvidia"
[    17.400] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    17.457] (II) Module nvidia: vendor="NVIDIA Corporation"
[    17.457] 	compiled for 4.0.2, module version = 1.0.0
[    17.457] 	Module class: X.Org Video Driver
[    17.462] (II) NVIDIA dlloader X Driver  415.18  Thu Nov 15 21:40:36 CST 2018
[    17.462] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    17.473] (II) Loading sub module "fb"
[    17.473] (II) LoadModule: "fb"
[    17.473] (II) Loading /usr/lib/xorg/modules/libfb.so
[    17.486] (II) Module fb: vendor="X.Org Foundation"
[    17.486] 	compiled for 1.20.3, module version = 1.0.0
[    17.486] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    17.486] (II) Loading sub module "wfb"
[    17.486] (II) LoadModule: "wfb"
[    17.486] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    17.496] (II) Module wfb: vendor="X.Org Foundation"
[    17.496] 	compiled for 1.20.3, module version = 1.0.0
[    17.496] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    17.496] (II) Loading sub module "ramdac"
[    17.496] (II) LoadModule: "ramdac"
[    17.496] (II) Module "ramdac" already built-in
[    17.497] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    17.497] (==) NVIDIA(0): RGB weight 888
[    17.497] (==) NVIDIA(0): Default visual is TrueColor
[    17.497] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    17.498] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[    17.498] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[    17.498] (**) NVIDIA(0): Enabling 2D acceleration
[    18.407] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[    18.407] (--) NVIDIA(0):     DFP-0 (boot)
[    18.407] (--) NVIDIA(0):     DFP-1
[    18.407] (--) NVIDIA(0):     DFP-2
[    18.407] (--) NVIDIA(0):     DFP-3
[    18.408] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:1:0:0 (GPU-0)
[    18.408] (--) NVIDIA(0): Memory: 4194304 kBytes
[    18.408] (--) NVIDIA(0): VideoBIOS: 86.07.42.00.50
[    18.408] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    18.423] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): connected
[    18.423] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): Internal TMDS
[    18.423] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): 330.0 MHz maximum pixel clock
[    18.452] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    18.452] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    18.452] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    18.452] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    18.452] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    18.452] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    18.452] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    18.452] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    18.452] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    18.456] (==) NVIDIA(0):
[    18.456] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    18.456] (==) NVIDIA(0):     will be used as the requested mode.
[    18.456] (II) NVIDIA(0): Validated MetaModes:
[    18.456] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[    18.456] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 1080
[    18.458] (--) NVIDIA(0): DPI set to (110, 114); computed from "UseEdidDpi" X config
[    18.458] (--) NVIDIA(0):     option
[    18.459] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[    18.459] (II) NVIDIA:     access.
[    18.460] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    18.460] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    18.460] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    18.460] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    18.460] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    18.460] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    18.460] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    18.460] (II) NVIDIA(0):     Config Options in the README.
[    18.494] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[    18.659] (==) NVIDIA(0): Disabling shared memory pixmaps
[    18.659] (==) NVIDIA(0): Backing store enabled
[    18.659] (==) NVIDIA(0): Silken mouse disabled
[    18.659] (**) NVIDIA(0): DPMS enabled
[    18.673] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[    18.673] (WW) NVIDIA(0): Option "NoLogo" is not used
[    18.673] (II) Loading sub module "dri2"
[    18.673] (II) LoadModule: "dri2"
[    18.673] (II) Module "dri2" already built-in
[    18.673] (II) NVIDIA(0): [DRI2] Setup complete
[    18.673] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    18.674] (II) Initializing extension Generic Event Extension
[    18.674] (II) Initializing extension SHAPE
[    18.675] (II) Initializing extension MIT-SHM
[    18.675] (II) Initializing extension XInputExtension
[    18.675] (II) Initializing extension XTEST
[    18.676] (II) Initializing extension BIG-REQUESTS
[    18.676] (II) Initializing extension SYNC
[    18.676] (II) Initializing extension XKEYBOARD
[    18.677] (II) Initializing extension XC-MISC
[    18.677] (II) Initializing extension SECURITY
[    18.677] (II) Initializing extension XFIXES
[    18.677] (II) Initializing extension RENDER
[    18.678] (II) Initializing extension RANDR
[    18.678] (II) Initializing extension COMPOSITE
[    18.679] (II) Initializing extension DAMAGE
[    18.679] (II) Initializing extension MIT-SCREEN-SAVER
[    18.679] (II) Initializing extension DOUBLE-BUFFER
[    18.679] (II) Initializing extension RECORD
[    18.680] (II) Initializing extension DPMS
[    18.680] (II) Initializing extension Present
[    18.680] (II) Initializing extension DRI3
[    18.680] (II) Initializing extension X-Resource
[    18.681] (II) Initializing extension XVideo
[    18.681] (II) Initializing extension XVideo-MotionCompensation
[    18.681] (II) Initializing extension GLX
[    18.681] (II) Indirect GLX disabled.
[    18.681] (II) Initializing extension XFree86-VidModeExtension
[    18.682] (II) Initializing extension XFree86-DGA
[    18.682] (II) Initializing extension XFree86-DRI
[    18.682] (II) Initializing extension DRI2
[    18.682] (II) Initializing extension NV-GLX
[    18.683] (II) Initializing extension NV-CONTROL
[    18.683] (II) Initializing extension XINERAMA
[    19.069] (II) config/udev: Adding input device Power Button (/dev/input/event7)
[    19.069] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    19.069] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    19.069] (**) Power Button: Applying InputClass "system-keyboard"
[    19.069] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    19.069] (II) LoadModule: "libinput"
[    19.070] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    19.097] (II) Module libinput: vendor="X.Org Foundation"
[    19.097] 	compiled for 1.20.1, module version = 0.28.1
[    19.097] 	Module class: X.Org XInput Driver
[    19.097] 	ABI class: X.Org XInput driver, version 24.1
[    19.097] (II) Using input driver 'libinput' for 'Power Button'
[    19.097] (**) Power Button: always reports core events
[    19.097] (**) Option "Device" "/dev/input/event7"
[    19.097] (**) Option "_source" "server/udev"
[    19.226] (II) event7  - Power Button: is tagged by udev as: Keyboard
[    19.226] (II) event7  - Power Button: device is a keyboard
[    19.226] (II) event7  - Power Button: device removed
[    19.243] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input7/event7"
[    19.243] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    19.243] (**) Option "xkb_model" "pc105"
[    19.243] (**) Option "xkb_layout" "us"
[    19.243] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.266] (II) event7  - Power Button: is tagged by udev as: Keyboard
[    19.266] (II) event7  - Power Button: device is a keyboard
[    19.266] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[    19.266] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    19.266] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    19.266] (**) Power Button: Applying InputClass "system-keyboard"
[    19.266] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    19.266] (II) Using input driver 'libinput' for 'Power Button'
[    19.266] (**) Power Button: always reports core events
[    19.266] (**) Option "Device" "/dev/input/event6"
[    19.266] (**) Option "_source" "server/udev"
[    19.266] (II) event6  - Power Button: is tagged by udev as: Keyboard
[    19.266] (II) event6  - Power Button: device is a keyboard
[    19.266] (II) event6  - Power Button: device removed
[    19.283] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6/event6"
[    19.283] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    19.283] (**) Option "xkb_model" "pc105"
[    19.283] (**) Option "xkb_layout" "us"
[    19.283] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.284] (II) event6  - Power Button: is tagged by udev as: Keyboard
[    19.284] (II) event6  - Power Button: device is a keyboard
[    19.284] (II) config/udev: Adding input device Sleep Button (/dev/input/event5)
[    19.284] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    19.284] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    19.284] (**) Sleep Button: Applying InputClass "system-keyboard"
[    19.284] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    19.284] (II) Using input driver 'libinput' for 'Sleep Button'
[    19.284] (**) Sleep Button: always reports core events
[    19.284] (**) Option "Device" "/dev/input/event5"
[    19.284] (**) Option "_source" "server/udev"
[    19.284] (II) event5  - Sleep Button: is tagged by udev as: Keyboard
[    19.284] (II) event5  - Sleep Button: device is a keyboard
[    19.284] (II) event5  - Sleep Button: device removed
[    19.303] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5/event5"
[    19.303] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[    19.303] (**) Option "xkb_model" "pc105"
[    19.303] (**) Option "xkb_layout" "us"
[    19.303] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.304] (II) event5  - Sleep Button: is tagged by udev as: Keyboard
[    19.304] (II) event5  - Sleep Button: device is a keyboard
[    19.304] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[    19.304] (II) No input driver specified, ignoring this device.
[    19.304] (II) This device may have been added with another device file.
[    19.305] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[    19.305] (II) No input driver specified, ignoring this device.
[    19.305] (II) This device may have been added with another device file.
[    19.305] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[    19.306] (II) config/udev: Adding input device Corsair Corsair HS70 Wireless Gaming Headset (/dev/input/event0)
[    19.306] (**) Corsair Corsair HS70 Wireless Gaming Headset: Applying InputClass "evdev keyboard catchall"
[    19.306] (**) Corsair Corsair HS70 Wireless Gaming Headset: Applying InputClass "libinput keyboard catchall"
[    19.306] (**) Corsair Corsair HS70 Wireless Gaming Headset: Applying InputClass "system-keyboard"
[    19.306] (**) Corsair Corsair HS70 Wireless Gaming Headset: Applying InputClass "Keyboard Defaults"
[    19.306] (II) Using input driver 'libinput' for 'Corsair Corsair HS70 Wireless Gaming Headset'
[    19.306] (**) Corsair Corsair HS70 Wireless Gaming Headset: always reports core events
[    19.306] (**) Option "Device" "/dev/input/event0"
[    19.306] (**) Option "_source" "server/udev"
[    19.307] (II) event0  - Corsair Corsair HS70 Wireless Gaming Headset: is tagged by udev as: Keyboard
[    19.307] (II) event0  - Corsair Corsair HS70 Wireless Gaming Headset: device is a keyboard
[    19.307] (II) event0  - Corsair Corsair HS70 Wireless Gaming Headset: device removed
[    19.356] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.3/0003:1B1C:0A38.0001/input/input0/event0"
[    19.356] (II) XINPUT: Adding extended input device "Corsair Corsair HS70 Wireless Gaming Headset" (type: KEYBOARD, id 9)
[    19.356] (**) Option "xkb_model" "pc105"
[    19.356] (**) Option "xkb_layout" "us"
[    19.356] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.359] (II) event0  - Corsair Corsair HS70 Wireless Gaming Headset: is tagged by udev as: Keyboard
[    19.359] (II) event0  - Corsair Corsair HS70 Wireless Gaming Headset: device is a keyboard
[    19.361] (II) config/udev: Adding input device Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS (/dev/input/event4)
[    19.361] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "evdev keyboard catchall"
[    19.361] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "libinput keyboard catchall"
[    19.361] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "system-keyboard"
[    19.361] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "Keyboard Defaults"
[    19.361] (II) Using input driver 'libinput' for 'Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS'
[    19.361] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: always reports core events
[    19.361] (**) Option "Device" "/dev/input/event4"
[    19.361] (**) Option "_source" "server/udev"
[    19.362] (II) event4  - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: is tagged by udev as: Keyboard
[    19.362] (II) event4  - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device is a keyboard
[    19.362] (II) event4  - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device removed
[    19.386] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.1/1-4.1:1.1/0003:1B1C:1B3B.0006/input/input4/event4"
[    19.386] (II) XINPUT: Adding extended input device "Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS" (type: KEYBOARD, id 10)
[    19.386] (**) Option "xkb_model" "pc105"
[    19.386] (**) Option "xkb_layout" "us"
[    19.386] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.387] (II) event4  - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: is tagged by udev as: Keyboard
[    19.387] (II) event4  - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device is a keyboard
[    19.388] (II) config/udev: Adding input device Corsair Corsair Gaming SCIMITAR PRO RGB Mouse (/dev/input/event9)
[    19.388] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "evdev pointer catchall"
[    19.388] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "libinput pointer catchall"
[    19.388] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming SCIMITAR PRO RGB Mouse'
[    19.388] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: always reports core events
[    19.388] (**) Option "Device" "/dev/input/event9"
[    19.388] (**) Option "_source" "server/udev"
[    19.389] (II) event9  - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: is tagged by udev as: Mouse
[    19.389] (II) event9  - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device is a pointer
[    19.389] (II) event9  - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device removed
[    19.433] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.0/0003:1B1C:1B3E.0008/input/input9/event9"
[    19.433] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming SCIMITAR PRO RGB Mouse" (type: MOUSE, id 11)
[    19.433] (**) Option "AccelerationScheme" "none"
[    19.433] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: (accel) selected scheme none/0
[    19.433] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: (accel) acceleration factor: 2.000
[    19.433] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: (accel) acceleration threshold: 4
[    19.436] (II) event9  - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: is tagged by udev as: Mouse
[    19.436] (II) event9  - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device is a pointer
[    19.438] (II) config/udev: Adding input device Corsair Corsair Gaming SCIMITAR PRO RGB Mouse (/dev/input/mouse0)
[    19.438] (II) No input driver specified, ignoring this device.
[    19.438] (II) This device may have been added with another device file.
[    19.440] (II) config/udev: Adding input device Corsair Corsair Gaming SCIMITAR PRO RGB Mouse (/dev/input/event10)
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "evdev pointer catchall"
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "evdev keyboard catchall"
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "libinput pointer catchall"
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "libinput keyboard catchall"
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "system-keyboard"
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "Keyboard Defaults"
[    19.440] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming SCIMITAR PRO RGB Mouse'
[    19.440] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: always reports core events
[    19.440] (**) Option "Device" "/dev/input/event10"
[    19.440] (**) Option "_source" "server/udev"
[    19.443] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: is tagged by udev as: Keyboard Mouse
[    19.443] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device is a pointer
[    19.443] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device is a keyboard
[    19.443] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device removed
[    19.476] (II) libinput: Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: needs a virtual subdevice
[    19.476] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:1B1C:1B3E.0009/input/input10/event10"
[    19.476] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming SCIMITAR PRO RGB Mouse" (type: MOUSE, id 12)
[    19.477] (**) Option "AccelerationScheme" "none"
[    19.477] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: (accel) selected scheme none/0
[    19.477] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: (accel) acceleration factor: 2.000
[    19.477] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: (accel) acceleration threshold: 4
[    19.480] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: is tagged by udev as: Keyboard Mouse
[    19.480] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device is a pointer
[    19.480] (II) event10 - Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: device is a keyboard
[    19.482] (II) config/udev: Adding input device Corsair Corsair Gaming SCIMITAR PRO RGB Mouse (/dev/input/js0)
[    19.482] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "system-keyboard"
[    19.482] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "Keyboard Defaults"
[    19.482] (II) No input driver specified, ignoring this device.
[    19.482] (II) This device may have been added with another device file.
[    19.483] (II) config/udev: Adding input device Corsair Corsair Gaming SCIMITAR PRO RGB Mouse (/dev/input/mouse1)
[    19.483] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "system-keyboard"
[    19.483] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "Keyboard Defaults"
[    19.483] (II) No input driver specified, ignoring this device.
[    19.483] (II) This device may have been added with another device file.
[    19.485] (II) config/udev: Adding input device BLUE MICROPHONE Blue Snowball  (/dev/input/event1)
[    19.485] (II) No input driver specified, ignoring this device.
[    19.485] (II) This device may have been added with another device file.
[    19.486] (II) config/udev: Adding input device Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard  (/dev/input/event2)
[    19.486] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "evdev keyboard catchall"
[    19.486] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "libinput keyboard catchall"
[    19.486] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "system-keyboard"
[    19.486] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "Keyboard Defaults"
[    19.486] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard '
[    19.486] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : always reports core events
[    19.486] (**) Option "Device" "/dev/input/event2"
[    19.486] (**) Option "_source" "server/udev"
[    19.489] (II) event2  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : is tagged by udev as: Keyboard
[    19.489] (II) event2  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : device is a keyboard
[    19.489] (II) event2  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : device removed
[    19.513] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/usb3/3-2/3-2:1.0/0003:1B1C:1B38.0003/input/input2/event2"
[    19.513] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard " (type: KEYBOARD, id 13)
[    19.513] (**) Option "xkb_model" "pc105"
[    19.513] (**) Option "xkb_layout" "us"
[    19.513] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.516] (II) event2  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : is tagged by udev as: Keyboard
[    19.516] (II) event2  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : device is a keyboard
[    19.518] (II) config/udev: Adding input device Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard  (/dev/input/event3)
[    19.518] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "evdev keyboard catchall"
[    19.518] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "libinput keyboard catchall"
[    19.518] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "system-keyboard"
[    19.518] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "Keyboard Defaults"
[    19.518] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard '
[    19.518] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : always reports core events
[    19.518] (**) Option "Device" "/dev/input/event3"
[    19.518] (**) Option "_source" "server/udev"
[    19.521] (II) event3  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : is tagged by udev as: Keyboard
[    19.521] (II) event3  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : device is a keyboard
[    19.521] (II) event3  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : device removed
[    19.553] (II) libinput: Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : needs a virtual subdevice
[    19.553] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/usb3/3-2/3-2:1.1/0003:1B1C:1B38.0004/input/input3/event3"
[    19.553] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard " (type: MOUSE, id 14)
[    19.553] (**) Option "AccelerationScheme" "none"
[    19.553] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : (accel) selected scheme none/0
[    19.553] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : (accel) acceleration factor: 2.000
[    19.553] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : (accel) acceleration threshold: 4
[    19.556] (II) event3  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : is tagged by udev as: Keyboard
[    19.556] (II) event3  - Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : device is a keyboard
[    19.557] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event11)
[    19.557] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    19.557] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    19.557] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[    19.557] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    19.558] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[    19.558] (**) Eee PC WMI hotkeys: always reports core events
[    19.558] (**) Option "Device" "/dev/input/event11"
[    19.558] (**) Option "_source" "server/udev"
[    19.559] (II) event11 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[    19.559] (II) event11 - Eee PC WMI hotkeys: device is a keyboard
[    19.559] (II) event11 - Eee PC WMI hotkeys: device removed
[    19.606] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input11/event11"
[    19.606] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 15)
[    19.606] (**) Option "xkb_model" "pc105"
[    19.606] (**) Option "xkb_layout" "us"
[    19.606] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.608] (II) event11 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[    19.608] (II) event11 - Eee PC WMI hotkeys: device is a keyboard
[    19.609] (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
[    19.609] (II) No input driver specified, ignoring this device.
[    19.609] (II) This device may have been added with another device file.
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "evdev pointer catchall"
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "evdev keyboard catchall"
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "libinput pointer catchall"
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "libinput keyboard catchall"
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "system-keyboard"
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: Applying InputClass "Keyboard Defaults"
[    19.618] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming SCIMITAR PRO RGB Mouse'
[    19.618] (**) Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: always reports core events
[    19.618] (**) Option "Device" "/dev/input/event10"
[    19.618] (**) Option "_source" "_driver/libinput"
[    19.618] (II) libinput: Corsair Corsair Gaming SCIMITAR PRO RGB Mouse: is a virtual subdevice
[    19.618] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:1B1C:1B3E.0009/input/input10/event10"
[    19.618] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming SCIMITAR PRO RGB Mouse" (type: KEYBOARD, id 16)
[    19.618] (**) Option "xkb_model" "pc105"
[    19.618] (**) Option "xkb_layout" "us"
[    19.618] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.618] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "evdev keyboard catchall"
[    19.618] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "libinput keyboard catchall"
[    19.618] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "system-keyboard"
[    19.618] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : Applying InputClass "Keyboard Defaults"
[    19.618] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard '
[    19.618] (**) Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : always reports core events
[    19.619] (**) Option "Device" "/dev/input/event3"
[    19.619] (**) Option "_source" "_driver/libinput"
[    19.619] (II) libinput: Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard : is a virtual subdevice
[    19.619] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/usb3/3-2/3-2:1.1/0003:1B1C:1B38.0004/input/input3/event3"
[    19.619] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 RGB RAPIDFIRE Keyboard " (type: KEYBOARD, id 17)
[    19.619] (**) Option "xkb_model" "pc105"
[    19.619] (**) Option "xkb_layout" "us"
[    19.619] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    19.649] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    19.649] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    19.649] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    19.678] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    19.678] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    19.678] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    28.113] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): connected
[    28.113] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): Internal TMDS
[    28.113] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): 330.0 MHz maximum pixel clock
[    28.143] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    28.143] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    28.143] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    28.143] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    28.143] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    28.143] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    28.143] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    28.143] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    28.143] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    29.786] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): connected
[    29.786] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): Internal TMDS
[    29.786] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): 330.0 MHz maximum pixel clock
[    29.815] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    29.815] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    29.815] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    29.815] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    29.815] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    29.815] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    29.815] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    29.815] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    29.815] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    44.796] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): connected
[    44.796] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): Internal TMDS
[    44.796] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): 330.0 MHz maximum pixel clock
[    44.826] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    44.826] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    44.826] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    44.826] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    44.826] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    44.826] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    44.826] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    44.826] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    44.826] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    55.371] (EE) libinput bug: Event for missing capability CAP_POINTER on device "Corsair Corsair HS70 Wireless Gaming Headset"
[    69.930] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): connected
[    69.930] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): Internal TMDS
[    69.930] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): 330.0 MHz maximum pixel clock
[    69.963] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[    69.963] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[    69.963] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[    69.963] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    69.963] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    69.963] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    69.963] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    69.963] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    69.963] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   111.815] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): connected
[   111.816] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): Internal TMDS
[   111.816] (--) NVIDIA(GPU-0): AOC 2060W3 (DFP-0): 330.0 MHz maximum pixel clock
[   111.845] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): connected
[   111.845] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): Internal TMDS
[   111.845] (--) NVIDIA(GPU-0): Acer H236HL (DFP-1): 600.0 MHz maximum pixel clock
[   111.845] (--) NVIDIA(GPU-0): DFP-2: disconnected
[   111.845] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[   111.845] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[   111.846] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   111.846] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[   111.846] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   513.070] (II) NVIDIA(0): Setting mode "DPY-0:nvidia-auto-select+1920+0{ForceCompositionPipeline=On},DPY-1:nvidia-auto-select+0+0{ForceCompositionPipeline=On}"
[  2283.967] (EE) client bug: timer event10 debounce: offset negative (-7ms)
[  2283.967] (EE) client bug: timer event10 debounce short: offset negative (-20ms)
[  2346.916] (EE) client bug: timer event10 debounce short: offset negative (-2ms)
[  2351.866] (EE) client bug: timer event10 debounce short: offset negative (-11ms)
[  2366.949] (EE) client bug: timer event10 debounce: offset negative (-0ms)
[  2366.949] (EE) client bug: timer event10 debounce short: offset negative (-13ms)
[  2377.349] (EE) client bug: timer event10 debounce short: offset negative (-0ms)
[  2388.399] (EE) client bug: timer event10 debounce short: offset negative (-7ms)
[  2466.981] (EE) client bug: timer event10 debounce short: offset negative (-0ms)
#6
Might want to try enabling or disabling “Flipping” in Nvidia X Server Settings, as that setting has been known to cause issues:
#7
I have tried that and nothing seems to happen.
#8
Regarding the ACPI outputs in the log, just add to nvidia.conf this line under the Section "Device" :
Option "ConnectToAcpid" "Off"
Make use of Nvidia X Server Settings and set a static config for displays, and add the FCP (not FFCP) parameter, for both your displays, then add those lines too to nvidia.conf as replacement for what you have now.
Always keep a backup and pay attention to the sections!
#9
Thanks for the help! I did as instructed but it’s still doing it. If I need to give out any more information, I can.
#10
Share that config
#11
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 415.18
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "AOC 2060W3"
    HorizSync       30.0 - 83.0
    VertRefresh     50.0 - 76.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 1050 Ti"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-1"
    Option         "metamodes" "DVI-D-0: 1920x1080_60 +1920+0 {ForceCompositionPipeline=On}, HDMI-0: 1920x1080_60 +0+0 {ForceCompositionPipeline=On}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
#12
You truncated the config or is how it is? By default, there are also this entries:
Section "Extensions"
    Option         "Composite" "Enable"
EndSection
Section "ServerFlags"
    Option "IndirectGLX" "On"
EndSection
Section "InputClass"
	Identifier          "Keyboard Defaults"
	MatchIsKeyboard	    "yes"
	Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
You can make use of the
Option "TripleBuffer" "On"
right under the ConnectToAcpid - in some instances it helps.
#13
That’s how the config generated, I have not touched it. I’ll give the triple buffer a go.
#14
Yes, but the original file has more entries … that need to be kept.
#15
Yeah, still nothing. Hm, what would you suggest me do here?
#16
Well … i can’t make an estimation based on descriptions. Stuttering and tearing are clear words but still do not make it clear what the problem is. Does the same on a TEST (new) user? This was present on Live install while using the nonfree drivers?
#17
That’s indeed hard to tell.
So you think it works slightly better with FFCP disabled?
You might try using compton instead of xfwm, from my experience it works much better with nvidia non-free, but I have to say that I haven’t used xfce for at least a year.
#18
This has happened on every single desktop environment I can think of. All the ones I’ve used are KDE, gnome and xfce. I’ve even used different distros and it’s the same. So I’m assuming that it wouldn’t make a difference if I made a new user. I will go check if the live install has the same issues.
#19
I’d have to say it feels the same. I think it’s just the drivers being poo, this doesn’t happen on Windows.
#20
Comparisons with Windows are unhelpful to say the least.
I suggest you try out compton, there are quite a few threads about how to do it.
