System update error (using pamac)
When I execute pamac update command, it shows following error:
$ pamac update
Preparing...
WARNING:fapi:src/tss2-fapi/ifapi_io.c:339:ifapi_io_check_create_dir() Directory /var/lib/tpm2-tss/system/keystore/policy does not exist, creating
ERROR:fapi:src/tss2-fapi/ifapi_helpers.c:1055:create_dirs() mkdir not possible: -1 /var/lib/tpm2-tss/system/keystore/policy
ERROR:fapi:src/tss2-fapi/ifapi_helpers.c:1082:ifapi_create_dirs() ErrorCode (0x0006000b) Create directories for /var/lib/tpm2-tss/system/keystore/policy
ERROR:fapi:src/tss2-fapi/ifapi_io.c:342:ifapi_io_check_create_dir() ErrorCode (0x0006000b) Directory /var/lib/tpm2-tss/system/keystore/policy can't be created.
ERROR:fapi:src/tss2-fapi/ifapi_policy_store.c:115:ifapi_policy_store_initialize() ErrorCode (0x0006000b) Policy directory /var/lib/tpm2-tss/system/keystore/policy can't be created.
ERROR:fapi:src/tss2-fapi/api/Fapi_Initialize.c:218:Fapi_Initialize_Finish() ErrorCode (0x0006000b) Keystore could not be initialized.
WARNING: Listing FAPI token objects failed: "fapi:A parameter has a bad value"
Please see https://github.com/tpm2-software/tpm2-pkcs11/blob/1.9.0/docs/FAPI.md for more details
WARNING: FAPI backend was not initialized.
ERROR:tcti:src/tss2-tcti/tcti-device.c:451:Tss2_Tcti_Device_Init() Failed to open specified TCTI device file /dev/tpmrm0: Permission denied
ERROR:tcti:src/tss2-tcti/tctildr-dl.c:169:tcti_from_file() Could not initialize TCTI file: libtss2-tcti-device.so.0
ERROR:tcti:src/tss2-tcti/tcti-device.c:451:Tss2_Tcti_Device_Init() Failed to open specified TCTI device file /dev/tpm0: Permission denied
WARNING:tcti:src/util/io.c:262:socket_connect() Failed to connect to host 127.0.0.1, port 2321: errno 111: Connection refused
ERROR:tcti:src/tss2-tcti/tcti-swtpm.c:613:Tss2_Tcti_Swtpm_Init() Cannot connect to swtpm TPM socket
ERROR:tcti:src/tss2-tcti/tctildr-dl.c:169:tcti_from_file() Could not initialize TCTI file: libtss2-tcti-swtpm.so.0
ERROR:tcti:src/tss2-tcti/tctildr-dl.c:169:tcti_from_file() Could not initialize TCTI file: libtss2-tcti-mssim.so.0
ERROR:tcti:src/tss2-tcti/tctildr-dl.c:269:tctildr_get_default() No standard TCTI could be loaded
ERROR:tcti:src/tss2-tcti/tctildr.c:430:Tss2_TctiLdr_Initialize_Ex() Failed to instantiate TCTI
ERROR: Could not initialize tpm ctx: 0x5
Refreshing AUR...
Nothing to do.
I tried to search for a solution but couldn’t find anything useful.
What is the reason for this error?
A custom setup using tpm
I haven’t done anything myself. I think this is happening from the last stable update. My DE is Plasma.
No, I agree with @linux-aarhus. Manjaro is not doing that on any setup automatically.
Probably this here is used? GitHub - tpm2-software/tpm2-pkcs11 at 1.9.0
Can you suggest any solution to remove this error?
I searched for tss2 and gnupg depends on a package named tpm2-tss from core repo (inherited from Arch).
My system has it installed (unstable) on v.4.0.1-1 also Plasma - no issues.
I have no idea what causes your issue.
Never used that software and I have no idea what it is doing here. However it seems that it has a connection to gnupg database. pacman/pamac tried to retrieve the keys from the tpm2 and not from the normal database. :man_shrugging:
The issue does not appear on a regular Manjaro Linux installation - so one has to speculate - that you - at some point - knowingly or not - have interacted with the system in a such manner that it became a problem.
Since we don’t know the circumstances - I don’t see how one could suggest anything.
