System unresponsive after removing some kernels
Hi all
Today my system was unusually slow/hanging. I noticed there were 5 kernels installed and thought that may be causing lag, so in the GUI I removed 3 kernels and installed a newer one after that.
When I rebooted the PC, my whole system was unresponsive, meaning after the monitor logo there is nothing on the screen and it just remains like that indefinitely.
I don’t know what kind of mess I’ve made. How can I fix this? I was wondering maybe a chroot -a Timeshift to restore my system. I am hoping I don’t need to do a full reinstall of Manjaro.
I am writing to this forum on a LiveUSB.
Updated: System can’t find GRUB drive:
manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
[manjaro /]#
Can someone please advise?
Perhaps a silly question, but you did run update-grub afterwards, didn’t you?
When you did install a kernel, how did you do that?
Not so important now - in chroot, install one again:
see what is available:
mhwd-kernel -l
choose one and install it:
pacman -Syu linuxXYZ
mkinitcpio -P
to create the initrd
then:
grub-mkconfig -o /boot/grub/grub.cfg
or:
update-grub
That should be it if there is no NVIDIA graphics involved - in that case I’m clueless as to what to do.
No
Only one of the installed kernels is in use at a time. You can see which one with:
uname -a
Then i would suggest using kernel 6.12 (LTS)
After installing a kernel you need to restart to actually use it.
:footprints:
Hi beermad
I did it through the GUI. I thought I could just restart my PC without update-grub.
Hi Nachlese
Great, going to follow your instructions now.
Thank you andreas85. I will select 6.12 LTS.
Thank you Nachlese, following these instructions.
Hi Nachlese
There might have been an error in installing Linux612 but maybe it was resolved:
[manjaro /]# pacman -Syu linux612
 core is up to date
 extra is up to date
 multilib is up to date
warning: linux612-6.12.34-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) linux612-6.12.34-1
Total Installed Size:  144.91 MiB
Net Upgrade Size:        0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                     [######################] 100%
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) checking available disk space                [######################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling linux612                        [######################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.34-1-MANJARO'
  -> Running build hook: [systemd]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
  -> Running build hook: [sd-vconsole]
  -> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing '/bin/sh' for script: /usr/bin/fsck.btrfs
==> WARNING: Possibly missing '/bin/sh' for script: /usr/bin/fsck.xfs
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
(4/5) Updating Kernel initcpios for Nvidia-DRM...
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.13-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.13-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-6.13-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.12-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-rt-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
[manjaro /]#
Hi Nachlese
I have run all the commands in order.
Running update-grubalso gave the error of not finding GRUB drive at the end. Could you please tell me if this output is all good before i leave the liveUSB environment? Thank you so much.
update-grub
done
[manjaro /]#
That is important. Ignore the probe error.
This kernel is EOL. Remove it.
Thank you megavolt.
Would I say pacman -R linux613?
I would do:
mhwd-kernel -r linux613-rt
In general, it uses also pacman, but does additional stuff. It is a helper script.
Thank you.
[manjaro /]# mhwd-kernel -r linux613
Error: Kernel not installed.
Currently running: 6.1.30-1-MANJARO (linux61)
   * linux612
   * linux612-rt
   * linux613-rt
[manjaro /]#
You see what to do?
ah okay
Thank you so much Nachlese, beermad, andreas85 and megavolt.
