System tray randomly disappear on startup
Hi everyone. I hope you all had a good year so far
I have a weird issue, and it starts with “sometimes”…
Sometimes, after logging in, I have no desktop, desktop icon or system tray, usually with an all black wallpaper.
Only the windows that were opened when I last shutdown ; Firefox, dolphin and the konsole.
Adding to the weirdness, alt tab works, super+d also shows my the desktop and get the apps back when pressed again but ctrl+t doesn’t bring up another konsole windows WHILE changing the cursor to indicate one is going to open, just like super+e seems to try to open a dolphin window but nothing happens.
I tried to look up issue but I only get “system tray icon not showing” stuff and the answers are application specific…
Thanks in advance for any help you can provide and happy new year
Jules
Hello and welcome to the Manjaro Community!
It will help people to provide assistance if you provide some system details, e.g.:
inxi -zv8
→ Place 3 backticks ``` on empty lines above and below your pasted output
~or~
→ highlight the pasted text and click the </> button at the top of the reply window.
This presents the terminal output in a scrollable box which improves Forum formatting. :wink:
This way, we’ll know for example if you are using x11 or Wayland, etc. .
All the best for the coming year, and beyond! :smile_cat:
Hi
Thank you for you answer, i’ll do that next time it happens and konsole is opened :slight_smile:
I wonder if the Yakuake drop-down Terminal will still respond? F12 to use it. I believe it’s installed by default on Manjaro KDE.
Otherwise, probably best to just always have a Konsole window open. I do, but that’s because I use it a fair bit. If you can still un-minimize Konsole, even better.
I usually have one open as I have to type “shutdown” in it, the GUI one shuts down linux but not my computer :slight_smile: (i’ll fix that later…) (back in the saddle after years of windows)
Sounds like you have session restore enabled. Try disabling it…I’d guess it fixes both problems, but I may be wrong. Either way it’s worth a try.
System Settings → Startup and Shutdown → Desktop Session → Session Restore → Start with an empty session
See if changing this setting might help (it’s a longshot):
System SettingsSessionDesktop SessionSession Restore:
Change “On login, launch apps that were open” to:
Then reboot.
There was a fairly recent issue KDE Plasma hangs on Shutdown, Restart and Logout that might possibly be related – the above was the workaround.
Hello again
It just happened, I typed inxi -zv8 and nothing happens :
    ~  inxi         ✔
CPU: 8-core AMD Ryzen 7 7800X3D (-MT MCP-) speed/min/max: 2982/545/5050 MHz
Kernel: 6.11.11-1-MANJARO x86_64 Up: 3m Mem: 4.13/61.99 GiB (6.7%)
Storage: 5.46 TiB (33.1% used) Procs: 378 Shell: Zsh inxi: 3.3.37
    ~  inxi -zv8         ✔
(inxi works, just sanity checked it first)
I’ll try what @soundofthunder and @dmt advised, thank you both I didn’t see your replies
