Hello comrades.
After upgrading to latest kernel, a system that I’m supporting won’t go to desktop but get stuck with the following message:
/dev/dev: clean, 49494949/399999999 files, 333333/22222222 blocks
I’ve read similar articles here in the forums and external forums suggesting that the issue has to do with graphic drivers. Before I go shooting in the dark applying other fixes to my environment, I rather have the community look at my logs and point me into the right direction:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=xxxxxxxx-cad2-4f1c-8ab3-xxxxxxxxxxxxxxxx rw quiet apparmor=1
Console: tty 4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 4502 date: 07/13/2021
RAM: total: 31.28 GiB used: 682.2 MiB (2.1%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 86268
Speed: 2797 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2797 2: 2109 3: 2195 4: 2197 5: 2130 6: 2195 7: 2196 8: 2194 9: 2613
10: 2186 11: 2112 12: 2195
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 08:00.0 chip-ID: 10de:128b
class-ID: 0300
Display: server: X.org 1.21.1.1 driver: loaded: nvidia tty: 128x48
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0e0f
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: no
Thank you, all
