System stops / freezes while updating virtualbox
Indeed; I use these things so rarely I forgot. :zany_face:
Above post edited.. :+1:
Edit: Actually, the last checks I’ve done using journalctl I did use the -b option with eg. -1 added, or some other filters.
As far as I see (from entries andtimestamp) journalctl -k provides info from VENTOY-Boot - process. But we would need the one in advance: My process:
  • Boot from SSD, reach the LogIn-Screen;
  • ALT-PRINT-REISUB as the machine freezes after LogIn-Password;
  • Boot from VENTOY …
On my LENOVO ThinkPad there is no PAUSE-key. CTRL-B, FN-CTRL-B or CTRL-P don’t work.
The command will need to be run in chroot otherwise it won’t show anything from the previous startup attempt (probably even if the partition is mounted).
Or, before loginscreen, you hit ctrl alt f4 for example and try to login there and pull the log. Without the usb i mean. At least you will now if it is something with the gui or bigger.
By the way, what i told you in private about the swap partition (for all others - 40gb on the right of root will solve the out of space problem) is also valid even if you repair the system and don’t reinstall. The only thing to consider is you will have to adapt fstab because the uuids will change.
Thank you @BG405 and @Teo
I’ve tried this as described jere
but could not reached the first journalctl (from normal booting), seen only the last journalctl (from VENTOY booting).
Tried this, showed a black screen but keyboard and mouse inactive.
So I tried this:
  • Booted the machine from SSD
  • Took a video from start-screen up to LogIn-screen.
  • Opened the video using AVIDEMUX, run through it picture by picture and made screenshots; filenames Vid01 .. 07 are in order of the boot process. ERROR marks pictures showing red messages; I’m quite sure that I haven’t overlooked any error messages.
Mod edit:- Please avoid posting images – especially if they may be images of text – try to recreate the text in a code fence, instead. In this instance, the images were virtually intelligible, and have been removed.
A lot of missing and damaged stuff too. The kernel module is probably virt box.
I don’t know, i thougt update will fix it. I think now is the moment to make a list of the installed packages and force reinstall everything to fill the missing files. But that will take some space so enlarge the partition first.
There was a tutorial somewhere for the script that dumps all packet names in a list and reinstall them, but i am on the phone now. I think it was in arch wiki. Maybe someone can point to it.
Or, fresh reinstall. As internet traffic time and disk space will be the same anyway, and your home and settings are on a different partition, so it shouldn’t be a problem. But make a list of the custom install packages from chroot first, so that you can reinstall them with one command.
Something like
pacman -Qq > allpackages
Or
pacman -Qk > brokenpackages
@MaMicha
You seem to have multiple issues, few of which can be easily resolved via a forum environment. As @Teo suggests, a fresh Manjaro installation might be the simplest resolution – certainly, the fastest way back to a working machine.
If your /home directory hierarchy is on a separate partition (which is often recommended in the forum) a fresh installation using the manual partitioning method, followed by installing your applications as @Teo also suggests, would have you back to a working system with most of your preferences intact, rather quickly.
If you decide to take that route, and need help with it, I suggest creating a new topic clearly stating what you wish to achieve, and I’m sure members will be glad to assist.
Edit:- Naturally, you would need to download the latest available ISO prepared as a bootable USB, or on a Ventoy USB.
[manjaro@manjaro ~]$ sudo su -
[manjaro ~]# cd /
[manjaro /]# mount /dev/nvme0n1p2 /mnt
[manjaro /]# mount /dev/nvme0n1p1 /mnt/boot/efi
[manjaro /]# manjaro-chroot /mnt /bin/bash
[manjaro /]# cd home
[manjaro ]# pacman -Qk > qq.txt
[manjaro ]# cat qq.txt
7zip: 17 total files, 0 missing files
a52dec: 22 total files, 0 missing files
aalib: 88 total files, 0 missing files
abseil-cpp: 937 total files, 0 missing files
accountsservice: 298 total files, 0 missing files
acl: 103 total files, 0 missing files
acpi: 7 total files, 0 missing files
acpid: 27 total files, 0 missing files
adobe-source-sans-fonts: 37 total files, 0 missing files
adwaita-cursors: 68 total files, 0 missing files
adwaita-fonts: 13 total files, 0 missing files
adwaita-icon-theme: 793 total files, 0 missing files
adwaita-icon-theme-legacy: 2015 total files, 0 missing files
aha: 7 total files, 0 missing files
akonadi: 788 total files, 0 missing files
akonadi-calendar: 393 total files, 0 missing files
akonadi-contacts: 367 total files, 0 missing files
akonadi-import-wizard: 290 total files, 0 missing files
akonadi-mime: 268 total files, 0 missing files
akonadi-search: 239 total files, 0 missing files
akregator: 396 total files, 0 missing files
alsa-card-profiles: 88 total files, 0 missing files
alsa-firmware: 189 total files, 0 missing files
alsa-lib: 160 total files, 0 missing files
alsa-oss: 17 total files, 0 missing files
alsa-plugins: 78 total files, 0 missing files
alsa-topology-conf: 18 total files, 0 missing files
alsa-ucm-conf: 1179 total files, 0 missing files
alsa-utils: 121 total files, 0 missing files
amd-ucode: 17 total files, 0 missing files
aom: 35 total files, 0 missing files
appstream: 1406 total files, 0 missing files
appstream-qt: 44 total files, 0 missing files
archlinux-appstream-data: 3863 total files, 0 missing files
archlinux-java-run: 14 total files, 0 missing files
archlinux-keyring: 16 total files, 0 missing files
argon2: 14 total files, 0 missing files
aria2: 161 total files, 0 missing files
aribb24: 18 total files, 0 missing files
aribb25: 29 total files, 0 missing files
ark: 435 total files, 0 missing files
at-spi2-core: 443 total files, 0 missing files
atkmm: 61 total files, 0 missing files
attica: 106 total files, 0 missing files
attr: 74 total files, 0 missing files
audacious: 237 total files, 0 missing files
audacious-plugins: 416 total files, 0 missing files
audacity: 379 total files, 0 missing files
audacity-docs: 1682 total files, 0 missing files
audio-recorder: 139 total files, 0 missing files
audiocd-kio: 758 total files, 0 missing files
audit: 223 total files, 0 missing files
aurorae: 161 total files, 0 missing files
autoconf: 79 total files, 0 missing files
automake: 140 total files, 0 missing files
avahi: 340 total files, 0 missing files
avidemux-cli: 678 total files, 0 missing files
avidemux-qt: 144 total files, 0 missing files
b43-fwcutter: 7 total files, 0 missing files
babl: 209 total files, 0 missing files
baloo: 758 total files, 0 missing files
baloo-widgets: 205 total files, 0 missing files
base: 0 total files, 0 missing files
base-devel: 0 total files, 0 missing files
bash: 269 total files, 0 missing files
bc: 12 total files, 0 missing files
binutils: 452 total files, 0 missing files
bison: 329 total files, 0 missing files
blas: 11 total files, 0 missing files
bluedevil: 409 total files, 0 missing files
bluez: 37 total files, 0 missing files
bluez-libs: 20 total files, 0 missing files
bluez-qt: 114 total files, 0 missing files
bolt: 29 total files, 0 missing files
boost-libs: 162 total files, 0 missing files
botan: 314 total files, 0 missing files
brave-browser: 480 total files, 0 missing files
breeze: 284 total files, 0 missing files
breeze-cursors: 747 total files, 0 missing files
breeze-gtk: 579 total files, 0 missing files
breeze-icons: 40003 total files, 0 missing files
breeze5: 6 total files, 0 missing files
brotli: 36 total files, 0 missing files
btrfs-progs: 90 total files, 0 missing files
bubblewrap: 13 total files, 0 missing files
bzip2: 28 total files, 0 missing files
c-ares: 189 total files, 0 missing files
ca-certificates: 0 total files, 0 missing files
ca-certificates-mozilla: 5 total files, 0 missing files
ca-certificates-utils: 32 total files, 0 missing files
cabextract: 7 total files, 0 missing files
cairo: 49 total files, 0 missing files
cairomm: 42 total files, 0 missing files
cairomm-1.16: 42 total files, 0 missing files
calendarsupport: 308 total files, 0 missing files
calf: 911 total files, 0 missing files
cblas: 22 total files, 0 missing files
cdparanoia: 18 total files, 0 missing files
cfitsio: 30 total files, 0 missing files
chromaprint: 25 total files, 0 missing files
cifs-utils: 39 total files, 0 missing files
ckbcomp: 7 total files, 0 missing files
clang: 2946 total files, 0 missing files
clinfo: 10 total files, 0 missing files
clucene: 203 total files, 0 missing files
colord-gtk: 9 total files, 0 missing files
colord-gtk-common: 50 total files, 0 missing files
compiler-rt: 154 total files, 0 missing files
composefs: 27 total files, 0 missing files
confuse: 32 total files, 0 missing files
convertlit: 3 total files, 0 missing files
coreutils: 444 total files, 0 missing files
cpio: 94 total files, 0 missing files
cpupower: 63 total files, 0 missing files
cronie: 49 total files, 0 missing files
cryptsetup: 132 total files, 0 missing files
cups: 946 total files, 0 missing files
cups-filters: 84 total files, 0 missing files
cups-pdf: 16 total files, 0 missing files
curl: 569 total files, 0 missing files
darktable: 1294 total files, 0 missing files
dav1d: 26 total files, 0 missing files
db5.3: 50 total files, 0 missing files
dbeaver: 762 total files, 0 missing files
dbus: 95 total files, 0 missing files
dbus-broker: 18 total files, 0 missing files
dbus-broker-units: 7 total files, 0 missing files
dbus-glib: 50 total files, 0 missing files
dbus-units: 0 total files, 0 missing files
dconf: 76 total files, 0 missing files
dcraw: 119 total files, 0 missing files
ddcutil: 32 total files, 0 missing files
debugedit: 13 total files, 0 missing files
default-cursors: 5 total files, 0 missing files
deno: 16 total files, 0 missing files
desktop-file-utils: 19 total files, 0 missing files
device-mapper: 37 total files, 0 missing files
diffutils: 124 total files, 0 missing files
ding-libs: 25 total files, 0 missing files
discount: 44 total files, 0 missing files
djvulibre: 118 total files, 0 missing files
dmidecode: 18 total files, 0 missing files
dmraid: 38 total files, 0 missing files
dnsmasq: 73 total files, 0 missing files
docbook-xml: 165 total files, 0 missing files
docbook-xsl: 2527 total files, 0 missing files
dolphin: 623 total files, 0 missing files
dolphin-plugins: 445 total files, 0 missing files
dosfstools: 39 total files, 0 missing files
double-conversion: 31 total files, 0 missing files
duktape: 17 total files, 0 missing files
e2fsprogs: 209 total files, 0 missing files
easyeffects: 145 total files, 0 missing files
easytag: 361 total files, 0 missing files
ebook-tools: 16 total files, 0 missing files
ecryptfs-utils: 78 total files, 0 missing files
editorconfig-core-c: 33 total files, 0 missing files
efibootmgr: 15 total files, 0 missing files
efivar: 70 total files, 0 missing files
elfutils: 60 total files, 0 missing files
elisa: 200 total files, 0 missing files
enblend-enfuse: 9 total files, 0 missing files
enchant: 34 total files, 0 missing files
eventviews: 201 total files, 0 missing files
exact-audio-copy: 108 total files, 0 missing files
exfatprogs: 31 total files, 0 missing files
exiv2: 133 total files, 0 missing files
expac: 7 total files, 0 missing files
expat: 29 total files, 0 missing files
f2fs-tools: 37 total files, 0 missing files
faac: 25 total files, 0 missing files
faad2: 24 total files, 0 missing files
fakeroot: 46 total files, 0 missing files
fastfetch: 59 total files, 0 missing files
ffcall: 36 total files, 0 missing files
ffmpeg: 286 total files, 0 missing files
ffmpeg4.4: 172 total files, 0 missing files
ffmpegthumbs: 14 total files, 0 missing files
fftw: 85 total files, 0 missing files
fig2dev: 29 total files, 0 missing files
file: 25 total files, 0 missing files
file-roller: 866 total files, 0 missing files
filelight: 289 total files, 0 missing files
filesystem: 132 total files, 0 missing files
filezilla: 934 total files, 0 missing files
findutils: 136 total files, 0 missing files
firefox: 98 total files, 0 missing files
firefox-i18n-de: 6 total files, 0 missing files
flac: 48 total files, 0 missing files
flatpak: 241 total files, 0 missing files
flex: 99 total files, 0 missing files
flickcurl: 95 total files, 0 missing files
fltk1.3: 205 total files, 0 missing files
fluidsynth: 52 total files, 0 missing files
font-manager: 1030 total files, 0 missing files
fontconfig: 375 total files, 0 missing files
foomatic-db: 6519 total files, 0 missing files
foomatic-db-engine: 60 total files, 0 missing files
foomatic-db-gutenprint-ppds: 3614 total files, 0 missing files
foomatic-db-nonfree: 105 total files, 0 missing files
foomatic-db-nonfree-ppds: 149 total files, 0 missing files
foomatic-db-ppds: 6871 total files, 0 missing files
fprintd: 270 total files, 0 missing files
frameworkintegration: 30 total files, 0 missing files
frameworkintegration5: 49 total files, 0 missing files
freeglut: 114 total files, 0 missing files
freeplane: 558 total files, 0 missing files
freetype2: 75 total files, 0 missing files
fribidi: 69 total files, 0 missing files
ftgl: 40 total files, 0 missing files
fuse-common: 2 total files, 0 missing files
fuse2: 36 total files, 0 missing files
fuse3: 28 total files, 0 missing files
fwupd: 330 total files, 0 missing files
fwupd-efi: 7 total files, 0 missing files
fzssh: 23 total files, 0 missing files
gawk: 152 total files, 0 missing files
gc: 81 total files, 0 missing files
gcc: 2852 total files, 0 missing files
gcc-libs: 0 total files, 0 missing files
gcr: 425 total files, 0 missing files
gcr-4: 348 total files, 0 missing files
gd: 37 total files, 0 missing files
gdb: 37 total files, 0 missing files
gdb-common: 100 total files, 0 missing files
gdbm: 81 total files, 0 missing files
gdk-pixbuf2: 368 total files, 0 missing files
gegl: 1023 total files, 0 missing files
gettext: 347 total files, 0 missing files
gexiv2-common: 10 total files, 0 missing files
ghostscript: 369 total files, 0 missing files
giflib: 48 total files, 0 missing files
gimp: 6537 total files, 0 missing files
git: 756 total files, 0 missing files
gjs: 40 total files, 0 missing files
glew: 20 total files, 0 missing files
glib-networking: 232 total files, 0 missing files
glib2: 738 total files, 0 missing files
glibc: 1637 total files, 0 missing files
glibc-locales: 7017 total files, 0 missing files
glibmm: 465 total files, 0 missing files
glibmm-2.68: 464 total files, 0 missing files
glm: 1467 total files, 0 missing files
glslang: 53 total files, 0 missing files
glu: 14 total files, 0 missing files
glycin: 38 total files, 0 missing files
gmic: 47 total files, 0 missing files
gmp: 19 total files, 0 missing files
gnome-themes-extra: 3554 total files, 0 missing files
gnu-netcat: 17 total files, 0 missing files
gnulib-l10n: 120 total files, 0 missing files
gnupg: 254 total files, 0 missing files
gnustep-base: 978 total files, 0 missing files
gnutls: 1357 total files, 0 missing files
gobject-introspection-runtime: 16 total files, 0 missing files
gpart: 11 total files, 0 missing files
gparted: 335 total files, 0 missing files
gperftools: 74 total files, 0 missing files
gpgme: 33 total files, 0 missing files
gpgmepp: 61 total files, 0 missing files
gpm: 36 total files, 0 missing files
grantleetheme: 205 total files, 0 missing files
graphene: 46 total files, 0 missing files
graphicsmagick: 555 total files, 0 missing files
graphite: 22 total files, 0 missing files
graphviz: 452 total files, 0 missing files
grep: 147 total files, 0 missing files
groff: 610 total files, 0 missing files
grub: 1246 total files, 0 missing files
grub-btrfs: 30 total files, 0 missing files
grub-theme-manjaro: 105 total files, 0 missing files
gsettings-desktop-schemas: 233 total files, 0 missing files
gsettings-system-schemas: 8 total files, 0 missing files
gsfonts: 80 total files, 0 missing files
gsl: 293 total files, 0 missing files
gsm: 24 total files, 0 missing files
gspell: 233 total files, 0 missing files
gssdp: 30 total files, 0 missing files
gssproxy: 38 total files, 0 missing files
gst-libav: 4 total files, 0 missing files
gst-plugin-pipewire: 8 total files, 0 missing files
gst-plugin-qml6: 4 total files, 0 missing files
gst-plugins-bad: 67 total files, 0 missing files
gst-plugins-bad-libs: 580 total files, 0 missing files
gst-plugins-base: 10 total files, 0 missing files
gst-plugins-base-libs: 477 total files, 0 missing files
gst-plugins-good: 224 total files, 0 missing files
gst-plugins-ugly: 158 total files, 0 missing files
gstreamer: 348 total files, 0 missing files
gtest: 76 total files, 0 missing files
gtk-update-icon-cache: 14 total files, 0 missing files
gtk3: 1019 total files, 0 missing files
gtk4: 912 total files, 0 missing files
gtkmm-4.0: 730 total files, 0 missing files
gtkmm3: 577 total files, 0 missing files
gtksourceview4: 578 total files, 0 missing files
gts: 39 total files, 0 missing files
guile: 961 total files, 0 missing files
gumbo-parser: 10 total files, 0 missing files
gupnp: 44 total files, 0 missing files
gupnp-igd: 34 total files, 0 missing files
gutenprint: 576 total files, 0 missing files
gvfs: 323 total files, 0 missing files
gwenview: 383 total files, 0 missing files
gzip: 32 total files, 0 missing files
handbrake: 68 total files, 0 missing files
harfbuzz: 85 total files, 0 missing files
harfbuzz-icu: 14 total files, 0 missing files
hdf5: 249 total files, 0 missing files
hdparm: 16 total files, 0 missing files
hibiscus: 177 total files, 0 missing files
hicolor-icon-theme: 711 total files, 0 missing files
hidapi: 28 total files, 0 missing files
highway: 104 total files, 0 missing files
htop: 16 total files, 0 missing files
httrack: 310 total files, 0 missing files
hugin: 675 total files, 0 missing files
hunspell: 277 total files, 0 missing files
hunspell-en_us: 24 total files, 0 missing files
hwdata: 10 total files, 0 missing files
hwinfo: 30 total files, 0 missing files
hwloc: 578 total files, 0 missing files
hyphen: 13 total files, 0 missing files
i2c-tools: 50 total files, 0 missing files
iana-etc: 11 total files, 0 missing files
icoutils: 20 total files, 0 missing files
icu: 286 total files, 0 missing files
id3lib: 33 total files, 0 missing files
iio-sensor-proxy: 18 total files, 0 missing files
ijs: 22 total files, 0 missing files
imagemagick: 801 total files, 0 missing files
imath: 108 total files, 0 missing files
img2pdf: 18 total files, 0 missing files
imlib2: 82 total files, 0 missing files
incidenceeditor: 187 total files, 0 missing files
inetutils: 52 total files, 0 missing files
inkscape: 5130 total files, 0 missing files
install-grub: 9 total files, 0 missing files
intel-ucode: 166 total files, 0 missing files
inxi: 11 total files, 0 missing files
iproute2: 188 total files, 0 missing files
iptables: 268 total files, 0 missing files
iputils: 65 total files, 0 missing files
iso-codes: 1537 total files, 0 missing files
iw: 7 total files, 0 missing files
jack2: 57 total files, 0 missing files
jameica: 121 total files, 0 missing files
jansson: 15 total files, 0 missing files
jasper: 51 total files, 0 missing files
java-environment-common: 23 total files, 0 missing files
java-rhino: 5 total files, 0 missing files
java-runtime-common: 20 total files, 0 missing files
jbig2dec: 15 total files, 0 missing files
jbigkit: 20 total files, 0 missing files
jdk-openjdk: 657 total files, 0 missing files
jdk11-openjdk: 731 total files, 0 missing files
jdk17-openjdk: 722 total files, 0 missing files
jdk21-openjdk: 669 total files, 0 missing files
jemalloc: 23 total files, 0 missing files
jfsutils: 21 total files, 0 missing files
jnetmap: 29 total files, 0 missing files
jq: 25 total files, 0 missing files
js140: 606 total files, 0 missing files
json-c: 34 total files, 0 missing files
json-glib: 225 total files, 0 missing files
jsoncpp: 26 total files, 0 missing files
kaccounts-integration: 228 total files, 0 missing files
kaccounts-providers: 215 total files, 0 missing files
kactivitymanagerd: 237 total files, 0 missing files
kamera: 393 total files, 0 missing files
kamoso: 273 total files, 0 missing files
karchive: 179 total files, 0 missing files
karchive5: 147 total files, 0 missing files
kate: 2548 total files, 0 missing files
kauth: 359 total files, 0 missing files
kauth5: 376 total files, 0 missing files
kbd: 831 total files, 0 missing files
kbookmarks: 309 total files, 0 missing files
kbookmarks5: 310 total files, 0 missing files
kcalc: 341 total files, 0 missing files
kcalendarcore: 168 total files, 0 missing files
kcalutils: 217 total files, 0 missing files
kclock: 231 total files, 0 missing files
kcmutils: 439 total files, 0 missing files
kcodecs: 335 total files, 0 missing files
kcodecs5: 333 total files, 0 missing files
kcolorpicker: 16 total files, 0 missing files
kcolorscheme: 166 total files, 0 missing files
kcompletion: 348 total files, 0 missing files
kcompletion5: 345 total files, 0 missing files
kconfig: 385 total files, 0 missing files
kconfig5: 362 total files, 0 missing files
kconfigwidgets: 481 total files, 0 missing files
kconfigwidgets5: 479 total files, 0 missing files
kcontacts: 292 total files, 0 missing files
kcoreaddons: 459 total files, 0 missing files
kcoreaddons5: 448 total files, 0 missing files
kcrash: 22 total files, 0 missing files
kcrash5: 26 total files, 0 missing files
kdbusaddons: 214 total files, 0 missing files
kdbusaddons5: 200 total files, 0 missing files
kde-cli-tools: 1010 total files, 0 missing files
kde-gtk-config: 26 total files, 0 missing files
kdeclarative: 364 total files, 0 missing files
kdeconnect: 1007 total files, 0 missing files
kdecoration: 199 total files, 0 missing files
kded: 55 total files, 0 missing files
kded5: 24 total files, 0 missing files
kdegraphics-mobipocket: 20 total files, 0 missing files
kdegraphics-thumbnailers: 13 total files, 0 missing files
kdenetwork-filesharing: 254 total files, 0 missing files
kdepim-addons: 1669 total files, 0 missing files
kdeplasma-addons: 2355 total files, 0 missing files
kdesu: 222 total files, 0 missing files
kdiagram: 357 total files, 0 missing files
kdialog: 292 total files, 0 missing files
kdiff3: 399 total files, 0 missing files
kdnssd: 345 total files, 0 missing files
kdoctools: 1572 total files, 0 missing files
kdsoap: 97 total files, 0 missing files
kdsoap-ws-discovery-client: 116 total files, 0 missing files
keditbookmarks: 398 total files, 0 missing files
keyutils: 75 total files, 0 missing files
kfilemetadata: 260 total files, 0 missing files
kfind: 423 total files, 0 missing files
kgamma: 344 total files, 0 missing files
kglobalaccel: 335 total files, 0 missing files
kglobalaccel5: 339 total files, 0 missing files
kglobalacceld: 31 total files, 0 missing files
kguiaddons: 78 total files, 0 missing files
kguiaddons5: 51 total files, 0 missing files
khelpcenter: 783 total files, 0 missing files
kholidays: 277 total files, 0 missing files
ki18n: 439 total files, 0 missing files
ki18n5: 420 total files, 0 missing files
kiconthemes: 325 total files, 0 missing files
kiconthemes5: 306 total files, 0 missing files
kidentitymanagement: 276 total files, 0 missing files
kidletime: 31 total files, 0 missing files
kimageannotator: 50 total files, 0 missing files
kimageformats: 35 total files, 0 missing files
kimap: 314 total files, 0 missing files
kinfocenter: 674 total files, 0 missing files
kio: 1195 total files, 0 missing files
kio-extras: 2279 total files, 0 missing files
kio-fuse: 12 total files, 0 missing files
kio5: 845 total files, 0 missing files
kirigami: 461 total files, 0 missing files
kirigami-addons: 397 total files, 0 missing files
kitemmodels: 49 total files, 0 missing files
kitemmodels5: 54 total files, 0 missing files
kitemviews: 346 total files, 0 missing files
kitemviews5: 345 total files, 0 missing files
kitinerary: 295 total files, 0 missing files
kiwix-desktop: 37 total files, 0 missing files
kjobwidgets: 354 total files, 0 missing files
kjobwidgets5: 347 total files, 0 missing files
kldap: 474 total files, 0 missing files
kmailtransport: 244 total files, 0 missing files
kmbox: 26 total files, 0 missing files
kmenuedit: 403 total files, 0 missing files
kmime: 255 total files, 0 missing files
kmod: 62 total files, 0 missing files
knewstuff: 424 total files, 0 missing files
knighttime: 32 total files, 0 missing files
knotifications: 42 total files, 0 missing files
knotifications5: 351 total files, 0 missing files
knotifyconfig: 328 total files, 0 missing files
konsole: 386 total files, 0 missing files
kontactinterface: 218 total files, 0 missing files
konversation: 497 total files, 0 missing files
kpackage: 254 total files, 0 missing files
kparts: 367 total files, 0 missing files
kpeople: 256 total files, 0 missing files
kpimtextedit: 220 total files, 0 missing files
kpipewire: 190 total files, 0 missing files
kpkpass: 44 total files, 0 missing files
kpty: 332 total files, 0 missing files
kqtquickcharts: 22 total files, 0 missing files
kquickcharts: 37 total files, 0 missing files
kquickimageeditor: 51 total files, 0 missing files
krb5: 205 total files, 0 missing files
krename: 135 total files, 0 missing files
kruler: 356 total files, 0 missing files
krunner: 49 total files, 0 missing files
ksanecore: 148 total files, 0 missing files
kscreen: 373 total files, 0 missing files
kscreenlocker: 346 total files, 0 missing files
kservice: 380 total files, 0 missing files
kservice5: 363 total files, 0 missing files
ksmtp: 188 total files, 0 missing files
ksshaskpass: 175 total files, 0 missing files
kstatusnotifieritem: 158 total files, 0 missing files
ksvg: 36 total files, 0 missing files
ksystemlog: 285 total files, 0 missing files
ksystemstats: 169 total files, 0 missing files
ktextaddons: 1393 total files, 0 missing files
ktexteditor: 358 total files, 0 missing files
ktexttemplate: 78 total files, 0 missing files
ktextwidgets: 344 total files, 0 missing files
ktextwidgets5: 343 total files, 0 missing files
ktnef: 216 total files, 0 missing files
ktouch: 558 total files, 0 missing files
kunitconversion: 228 total files, 0 missing files
kuserfeedback: 276 total files, 0 missing files
kwallet: 348 total files, 0 missing files
kwallet-pam: 12 total files, 0 missing files
kwallet5: 316 total files, 0 missing files
kwalletmanager: 464 total files, 0 missing files
kwayland: 63 total files, 0 missing files
kwayland-integration: 10 total files, 0 missing files
kwayland5: 136 total files, 0 missing files
kweather: 164 total files, 0 missing files
kweathercore: 200 total files, 0 missing files
kwidgetsaddons: 506 total files, 0 missing files
kwidgetsaddons5: 487 total files, 0 missing files
kwin: 2257 total files, 0 missing files
kwin-x11: 1947 total files, 0 missing files
kwindowsystem: 381 total files, 0 missing files
kwindowsystem5: 365 total files, 0 missing files
kwrited: 10 total files, 0 missing files
kxmlgui: 401 total files, 0 missing files
kxmlgui5: 386 total files, 0 missing files
l-smash: 17 total files, 0 missing files
ladspa: 28 total files, 0 missing files
lame: 34 total files, 0 missing files
lapack: 20 total files, 0 missing files
layer-shell-qt: 30 total files, 0 missing files
lcms2: 27 total files, 0 missing files
ldb: 96 total files, 0 missing files
leancrypto: 127 total files, 0 missing files
lensfun: 85 total files, 0 missing files
leocad: 64 total files, 0 missing files
leptonica: 60 total files, 0 missing files
less: 16 total files, 0 missing files
lftp: 75 total files, 0 missing files
lib2geom: 109 total files, 0 missing files
lib32-alsa-lib: 11 total files, 0 missing files
lib32-brotli: 18 total files, 0 missing files
lib32-bzip2: 10 total files, 0 missing files
lib32-curl: 10 total files, 0 missing files
lib32-dbus: 18 total files, 0 missing files
lib32-e2fsprogs: 22 total files, 0 missing files
lib32-expat: 17 total files, 0 missing files
lib32-flac: 21 total files, 0 missing files
lib32-gcc-libs: 49 total files, 0 missing files
lib32-glib2: 43 total files, 0 missing files
lib32-glibc: 333 total files, 0 missing files
lib32-gmp: 14 total files, 0 missing files
lib32-gnutls: 12 total files, 0 missing files
lib32-icu: 37 total files, 0 missing files
lib32-json-c: 16 total files, 0 missing files
lib32-keyutils: 7 total files, 0 missing files
lib32-krb5: 61 total files, 0 missing files
lib32-libasyncns: 7 total files, 0 missing files
lib32-libcanberra: 24 total files, 0 missing files
lib32-libdisplay-info: 11 total files, 0 missing files
lib32-libdrm: 26 total files, 0 missing files
lib32-libelf: 18 total files, 0 missing files
lib32-libffi: 11 total files, 0 missing files
lib32-libgcrypt: 12 total files, 0 missing files
lib32-libglvnd: 30 total files, 0 missing files
lib32-libgpg-error: 7 total files, 0 missing files
lib32-libidn2: 7 total files, 0 missing files
lib32-libldap: 14 total files, 0 missing files
lib32-libltdl: 5 total files, 0 missing files
lib32-libnghttp2: 11 total files, 0 missing files
lib32-libnghttp3: 11 total files, 0 missing files
lib32-libngtcp2: 19 total files, 0 missing files
lib32-libogg: 17 total files, 0 missing files
lib32-libpciaccess: 10 total files, 0 missing files
lib32-libpsl: 10 total files, 0 missing files
lib32-libpulse: 22 total files, 0 missing files
lib32-libsndfile: 19 total files, 0 missing files
lib32-libssh2: 11 total files, 0 missing files
lib32-libtasn1: 7 total files, 0 missing files
lib32-libunistring: 5 total files, 0 missing files
lib32-libva: 27 total files, 0 missing files
lib32-libva-intel-driver: 8 total files, 0 missing files
lib32-libvorbis: 19 total files, 0 missing files
lib32-libx11: 15 total files, 0 missing files
lib32-libxau: 10 total files, 0 missing files
lib32-libxcb: 106 total files, 0 missing files
lib32-libxcrypt: 8 total files, 0 missing files
lib32-libxdmcp: 10 total files, 0 missing files
lib32-libxext: 10 total files, 0 missing files
lib32-libxfixes: 10 total files, 0 missing files
lib32-libxml2: 14 total files, 0 missing files
lib32-libxshmfence: 10 total files, 0 missing files
lib32-libxxf86vm: 10 total files, 0 missing files
lib32-llvm-libs: 0 total files, 0 missing files
lib32-lm_sensors: 6 total files, 0 missing files
lib32-mesa: 0 total files, 0 missing files
lib32-mesa-utils: 9 total files, 0 missing files
lib32-ncurses: 45 total files, 0 missing files
lib32-nettle: 11 total files, 0 missing files
lib32-openssl: 21 total files, 0 missing files
lib32-opus: 11 total files, 0 missing files
lib32-p11-kit: 15 total files, 0 missing files
lib32-pcre2: 0 total files, 0 missing files
lib32-spirv-tools: 0 total files, 0 missing files
lib32-systemd: 0 total files, 0 missing files
lib32-tdb: 7 total files, 0 missing files
lib32-util-linux: 23 total files, 0 missing files
lib32-vulkan-icd-loader: 0 total files, 0 missing files
lib32-vulkan-intel: 0 total files, 0 missing files
lib32-vulkan-mesa-implicit-layers: 0 total files, 0 missing files
lib32-vulkan-nouveau: 0 total files, 0 missing files
lib32-vulkan-radeon: 0 total files, 0 missing files
lib32-wayland: 24 total files, 0 missing files
lib32-xcb-util-keysyms: 10 total files, 0 missing files
lib32-xz: 0 total files, 0 missing files
lib32-zlib: 11 total files, 0 missing files
lib32-zstd: 17 total files, 0 missing files
libabw: 282 total files, 0 missing files
libaccounts-glib: 96 total files, 0 missing files
libaccounts-qt: 36 total files, 0 missing files
libadwaita: 0 total files, 0 missing files
libaec: 21 total files, 0 missing files
libaio: 27 total files, 0 missing files
libao: 72 total files, 0 missing files
libappindicator: 41 total files, 0 missing files
libarchive: 69 total files, 0 missing files
libasan: 9 total files, 0 missing files
libass: 15 total files, 0 missing files
libassuan: 20 total files, 0 missing files
libasyncns: 15 total files, 0 missing files
libatasmart: 19 total files, 0 missing files
libatomic: 13 total files, 0 missing files
libatomic_ops: 93 total files, 0 missing files
libavc1394: 25 total files, 0 missing files
libavif: 28 total files, 0 missing files
libavtp: 23 total files, 0 missing files
libb2: 13 total files, 0 missing files
libblake3: 15 total files, 0 missing files
libblockdev: 69 total files, 0 missing files
libblockdev-crypto: 8 total files, 0 missing files
libblockdev-fs: 22 total files, 0 missing files
libblockdev-loop: 8 total files, 0 missing files
libblockdev-mdraid: 8 total files, 0 missing files
libblockdev-nvme: 8 total files, 0 missing files
libblockdev-part: 8 total files, 0 missing files
libblockdev-smart: 11 total files, 0 missing files
libblockdev-swap: 8 total files, 0 missing files
libbluray: 26 total files, 0 missing files
libbpf: 29 total files, 0 missing files
libbs2b: 20 total files, 0 missing files
libbsd: 285 total files, 0 missing files
libbytesize: 124 total files, 0 missing files
libcaca: 470 total files, 0 missing files
libcanberra: 64 total files, 0 missing files
libcap: 120 total files, 0 missing files
libcap-ng: 56 total files, 0 missing files
libcddb: 21 total files, 0 missing files
libcdio: 87 total files, 0 missing files
libcdio-paranoia: 26 total files, 0 missing files
libcdr: 333 total files, 0 missing files
libcgif: 13 total files, 0 missing files
libcloudproviders: 25 total files, 0 missing files
libcmis: 56 total files, 0 missing files
libcolord: 44 total files, 0 missing files
libcue: 11 total files, 0 missing files
libcups: 30 total files, 0 missing files
libcupsfilters: 66 total files, 0 missing files
libdaemon: 21 total files, 0 missing files
libdatrie: 51 total files, 0 missing files
libdbusmenu-glib: 47 total files, 0 missing files
libdbusmenu-gtk3: 44 total files, 0 missing files
libdbusmenu-qt5: 19 total files, 0 missing files
libdc1394: 140 total files, 0 missing files
libdca: 23 total files, 0 missing files
libde265: 20 total files, 0 missing files
libdecor: 18 total files, 0 missing files
libdeflate: 21 total files, 0 missing files
libdisplay-info: 23 total files, 0 missing files
libdmtx: 16 total files, 0 missing files
libdovi: 14 total files, 0 missing files
libdrm: 92 total files, 0 missing files
libdv: 21 total files, 0 missing files
libdvbpsi: 88 total files, 0 missing files
libdvdcss: 12 total files, 0 missing files
libdvdnav: 21 total files, 0 missing files
libdvdread: 29 total files, 0 missing files
libe-book: 910 total files, 0 missing files
libebml: 45 total files, 0 missing files
libebur128: 13 total files, 0 missing files
libedit: 65 total files, 0 missing files
libei: 26 total files, 0 missing files
libelf: 162 total files, 0 missing files
libepoxy: 20 total files, 0 missing files
libepubgen: 219 total files, 0 missing files
libetonyek: 22 total files, 0 missing files
libevdev: 27 total files, 0 missing files
libevent: 73 total files, 0 missing files
libexif: 121 total files, 0 missing files
libexsid: 9 total files, 0 missing files
libexttextcat: 217 total files, 0 missing files
libfakekey: 10 total files, 0 missing files
libfdk-aac: 19 total files, 0 missing files
libffi: 25 total files, 0 missing files
libfilezilla: 239 total files, 0 missing files
libfontenc: 15 total files, 0 missing files
libfprint: 71 total files, 0 missing files
libfreeaptx: 12 total files, 0 missing files
libfreehand: 0 total files, 0 missing files
libftdi: 57 total files, 0 missing files
libfyaml: 50 total files, 0 missing files
libgcc: 7 total files, 0 missing files
libgcrypt: 27 total files, 0 missing files
libgee: 18 total files, 0 missing files
libgexiv2: 27 total files, 0 missing files
libgfortran: 9 total files, 0 missing files
libgirepository: 80 total files, 0 missing files
libglvnd: 58 total files, 0 missing files
libgme: 10 total files, 0 missing files
libgnomekbd: 277 total files, 0 missing files
libgomp: 11 total files, 0 missing files
libgoom2: 21 total files, 0 missing files
libgpg-error: 100 total files, 0 missing files
libgphoto2: 225 total files, 0 missing files
libgravatar: 187 total files, 0 missing files
libgudev: 46 total files, 0 missing files
libgusb: 37 total files, 0 missing files
libhandy: 156 total files, 0 missing files
libheif: 60 total files, 0 missing files
libhwasan: 9 total files, 0 missing files
libical: 177 total files, 0 missing files
libice: 24 total files, 0 missing files
libid3tag: 15 total files, 0 missing files
libidn: 168 total files, 0 missing files
libidn2: 135 total files, 0 missing files
libiec61883: 18 total files, 0 missing files
libieee1284: 54 total files, 0 missing files
libimagequant: 13 total files, 0 missing files
libimobiledevice: 527 total files, 0 missing files
libimobiledevice-glue: 20 total files, 0 missing files
libinih: 16 total files, 0 missing files
libinput: 77 total files, 0 missing files
libiptcdata: 60 total files, 0 missing files
libisl: 88 total files, 0 missing files
libixion: 46 total files, 0 missing files
libjpeg-turbo: 56 total files, 0 missing files
libjxl: 57 total files, 0 missing files
libkate: 86 total files, 0 missing files
libkcddb: 408 total files, 0 missing files
libkdcraw: 28 total files, 0 missing files
libkdepim: 285 total files, 0 missing files
libkexiv2: 28 total files, 0 missing files
libkgapi: 582 total files, 0 missing files
libkiwix: 35 total files, 0 missing files
libkleo: 416 total files, 0 missing files
libksane: 0 total files, 0 missing files
libksba: 14 total files, 0 missing files
libkscreen: 204 total files, 0 missing files
libksieve: 341 total files, 0 missing files
libksysguard: 937 total files, 0 missing files
liblangtag: 115 total files, 0 missing files
liblc3: 23 total files, 0 missing files
libldac: 15 total files, 0 missing files
libldap: 216 total files, 0 missing files
liblqr: 23 total files, 0 missing files
liblrdf: 20 total files, 0 missing files
liblsan: 9 total files, 0 missing files
libltc: 75 total files, 0 missing files
liblzf: 21 total files, 0 missing files
libmad: 9 total files, 0 missing files
libmakepkg-dropins: 14 total files, 0 missing files
libmalcontent: 23 total files, 0 missing files
libmanette: 26 total files, 0 missing files
libmatio: 47 total files, 0 missing files
libmatroska: 46 total files, 0 missing files
libmbim: 66 total files, 0 missing files
libmd: 143 total files, 0 missing files
libmediainfo: 20 total files, 0 missing files
libmfx: 42 total files, 0 missing files
libmicrodns: 11 total files, 0 missing files
libmicrohttpd: 17 total files, 0 missing files
libmm-glib: 94 total files, 0 missing files
libmms: 14 total files, 0 missing files
libmng: 21 total files, 0 missing files
libmnl: 10 total files, 0 missing files
libmodplug: 17 total files, 0 missing files
libmpc: 12 total files, 0 missing files
libmpcdec: 18 total files, 0 missing files
libmpeg2: 24 total files, 0 missing files
libmspack: 9 total files, 0 missing files
libmspub: 385 total files, 0 missing files
libmtp: 288 total files, 0 missing files
libmusicbrainz5: 128 total files, 0 missing files
libmwaw: 20 total files, 0 missing files
libmypaint: 293 total files, 0 missing files
libmysofa: 25 total files, 0 missing files
libnautilus-extension: 26 total files, 0 missing files
libndp: 15 total files, 0 missing files
libnet: 98 total files, 0 missing files
libnetfilter_conntrack: 19 total files, 0 missing files
libnewt: 243 total files, 0 missing files
libnfnetlink: 12 total files, 0 missing files
libnfs: 0 total files, 0 missing files
libnftnl: 22 total files, 0 missing files
libnghttp2: 15 total files, 0 missing files
libnghttp3: 18 total files, 0 missing files
libngtcp2: 29 total files, 0 missing files
libnice: 77 total files, 0 missing files
libnl: 257 total files, 0 missing files
libnm: 0 total files, 0 missing files
libnma: 16 total files, 0 missing files
libnma-common: 297 total files, 0 missing files
libnma-gtk4: 16 total files, 0 missing files
libnotify: 24 total files, 0 missing files
libnsl: 22 total files, 0 missing files
libntfs-3g: 0 total files, 0 missing files
libnumbertext: 70 total files, 0 missing files
libnvme: 37 total files, 0 missing files
libobjc: 9 total files, 0 missing files
libodfgen: 87 total files, 0 missing files
libogg: 111 total files, 0 missing files
liboggz: 218 total files, 0 missing files
libopenmpt: 43 total files, 0 missing files
liborcus: 130 total files, 0 missing files
libotr: 44 total files, 0 missing files
libp11-kit: 30 total files, 0 missing files
libpagemaker: 192 total files, 0 missing files
libpamac: 340 total files, 0 missing files
libpamac-flatpak-plugin: 5 total files, 0 missing files
libpano13: 54 total files, 0 missing files
libpaper: 29 total files, 0 missing files
libpcap: 123 total files, 0 missing files
libpciaccess: 13 total files, 0 missing files
libpgm: 32 total files, 0 missing files
libphonenumber: 58 total files, 0 missing files
libpipeline: 80 total files, 0 missing files
libpipewire: 358 total files, 0 missing files
libplacebo: 48 total files, 0 missing files
libplasma: 543 total files, 0 missing files
libplist: 38 total files, 0 missing files
libpng: 34 total files, 0 missing files
libportal: 0 total files, 0 missing files
libportal-qt6: 0 total files, 0 missing files
libppd: 37 total files, 0 missing files
libproxy: 26 total files, 0 missing files
libpsl: 38 total files, 0 missing files
libpulse: 99 total files, 0 missing files
libqaccessibilityclient-qt6: 22 total files, 0 missing files
libqalculate: 311 total files, 0 missing files
libqmi: 95 total files, 0 missing files
libqrtr-glib: 21 total files, 0 missing files
libquadmath: 11 total files, 0 missing files
libqxp: 336 total files, 0 missing files
libraqm: 40 total files, 0 missing files
libraw: 39 total files, 0 missing files
libraw1394: 24 total files, 0 missing files
libreoffice-25.2.6: 17674 total files, 0 missing files
libreoffice-still: 0 total files, 0 missing files
libreoffice-still-de: 3050 total files, 0 missing files
libresidfp: 0 total files, 0 missing files
librevenge: 478 total files, 0 missing files
librsvg: 29 total files, 0 missing files
libsamplerate: 40 total files, 0 missing files
libsasl: 54 total files, 0 missing files
libsbsms: 15 total files, 0 missing files
libseccomp: 56 total files, 0 missing files
libsecret: 246 total files, 0 missing files
libshout: 28 total files, 0 missing files
libsidplayfp: 30 total files, 0 missing files
libsigc++: 49 total files, 0 missing files
libsigc++-3.0: 58 total files, 0 missing files
libsigsegv: 7 total files, 0 missing files
libsixel: 27 total files, 0 missing files
libsm: 21 total files, 0 missing files
libsndfile: 61 total files, 0 missing files
libsodium: 90 total files, 0 missing files
libsoup3: 278 total files, 0 missing files
libsoxr: 18 total files, 0 missing files
libspectre: 17 total files, 0 missing files
libspiro: 15 total files, 0 missing files
libsrtp: 16 total files, 0 missing files
libssc: 63 total files, 0 missing files
libssh: 23 total files, 0 missing files
libssh2: 203 total files, 0 missing files
libstaroffice: 18 total files, 0 missing files
libstdc++: 16 total files, 0 missing files
libstemmer: 11 total files, 0 missing files
libsynctex: 13 total files, 0 missing files
libsysprof-capture: 24 total files, 0 missing files
libtasn1: 83 total files, 0 missing files
libtatsu: 11 total files, 0 missing files
libteam: 35 total files, 0 missing files
libthai: 87 total files, 0 missing files
libtheora: 151 total files, 0 missing files
libtiff: 46 total files, 0 missing files
libtiger: 11 total files, 0 missing files
libtirpc: 91 total files, 0 missing files
libtommath: 9 total files, 0 missing files
libtool: 79 total files, 0 missing files
libtpms: 49 total files, 0 missing files
libtraceevent: 169 total files, 0 missing files
libtracefs: 236 total files, 0 missing files
libtsan: 9 total files, 0 missing files
libubsan: 9 total files, 0 missing files
libunibreak: 19 total files, 0 missing files
libunistring: 58 total files, 0 missing files
libunwind: 78 total files, 0 missing files
libupnp: 64 total files, 0 missing files
liburcu: 0 total files, 0 missing files
liburing: 256 total files, 0 missing files
libusb: 16 total files, 0 missing files
libusb-compat: 11 total files, 0 missing files
libusbmuxd: 18 total files, 0 missing files
libutempter: 20 total files, 0 missing files
libva: 69 total files, 0 missing files
libvdpau: 21 total files, 0 missing files
libverto: 19 total files, 0 missing files
libvips: 100 total files, 0 missing files
libvisio: 710 total files, 0 missing files
libvlc: 120 total files, 0 missing files
libvncserver: 26 total files, 0 missing files
libvorbis: 26 total files, 0 missing files
libvpl: 41 total files, 0 missing files
libvpx: 28 total files, 0 missing files
libwacom: 868 total files, 0 missing files
libwbclient: 10 total files, 0 missing files
libwebp: 52 total files, 0 missing files
libwireplumber: 61 total files, 0 missing files
libwmf: 79 total files, 0 missing files
libwpd: 1339 total files, 0 missing files
libwpg: 152 total files, 0 missing files
libwps: 19 total files, 0 missing files
libx11: 1252 total files, 0 missing files
libx86emu: 11 total files, 0 missing files
libxau: 25 total files, 0 missing files
libxaw: 143 total files, 0 missing files
libxcb: 2460 total files, 0 missing files
libxcomposite: 29 total files, 0 missing files
libxcrypt: 24 total files, 0 missing files
libxcursor: 77 total files, 0 missing files
libxcvt: 20 total files, 0 missing files
libxdamage: 15 total files, 0 missing files
libxdmcp: 17 total files, 0 missing files
libxext: 100 total files, 0 missing files
libxfixes: 18 total files, 0 missing files
libxfont2: 15 total files, 0 missing files
libxft: 96 total files, 0 missing files
libxi: 97 total files, 0 missing files
libxinerama: 23 total files, 0 missing files
libxkbcommon: 50 total files, 0 missing files
libxkbcommon-x11: 21 total files, 0 missing files
libxkbfile: 20 total files, 0 missing files
libxklavier: 41 total files, 0 missing files
libxml2: 84 total files, 0 missing files
libxml2-legacy: 66 total files, 0 missing files
libxmlb: 76 total files, 0 missing files
libxmu: 45 total files, 0 missing files
libxpm: 63 total files, 0 missing files
libxpresent: 26 total files, 0 missing files
libxrandr: 32 total files, 0 missing files
libxrender: 18 total files, 0 missing files
libxshmfence: 14 total files, 0 missing files
libxslt: 65 total files, 0 missing files
libxss: 29 total files, 0 missing files
libxt: 340 total files, 0 missing files
libxtst: 33 total files, 0 missing files
libxv: 43 total files, 0 missing files
libxvmc: 23 total files, 0 missing files
libxxf86vm: 40 total files, 0 missing files
libyaml: 13 total files, 0 missing files
libyuv: 36 total files, 0 missing files
libzen: 52 total files, 0 missing files
libzim: 32 total files, 0 missing files
libzip: 169 total files, 0 missing files
libzmf: 261 total files, 0 missing files
licenses: 113 total files, 0 missing files
lilv: 21 total files, 0 missing files
linux-api-headers: 1079 total files, 0 missing files
linux-firmware-amdgpu: 0 total files, 0 missing files
linux-firmware-atheros: 0 total files, 0 missing files
linux-firmware-broadcom: 0 total files, 0 missing files
linux-firmware-cirrus: 0 total files, 0 missing files
linux-firmware-intel: 0 total files, 0 missing files
linux-firmware-mediatek: 0 total files, 0 missing files
linux-firmware-meta: 0 total files, 0 missing files
linux-firmware-nvidia: 0 total files, 0 missing files
linux-firmware-other: 0 total files, 0 missing files
linux-firmware-radeon: 0 total files, 0 missing files
linux-firmware-realtek: 0 total files, 0 missing files
linux-firmware-whence: 0 total files, 0 missing files
linux612: 0 total files, 0 missing files
linux612-virtualbox-host-modules: 10 total files, 0 missing files
linux618: 7658 total files, 0 missing files
linux618-virtualbox-host-modules: 0 total files, 0 missing files
linux66: 0 total files, 0 missing files
linux66-virtualbox-host-modules: 0 total files, 0 missing files
lirc: 486 total files, 0 missing files
litehtml: 84 total files, 0 missing files
live-media: 239 total files, 0 missing files
llvm: 0 total files, 0 missing files
llvm-libs: 16 total files, 0 missing files
llvm21: 2630 total files, 0 missing files
llvm21-libs: 13 total files, 0 missing files
lm_sensors: 52 total files, 0 missing files
lmdb: 22 total files, 0 missing files
logrotate: 19 total files, 0 missing files
lpsolve: 35 total files, 0 missing files
lsb-release: 7 total files, 0 missing files
lsof: 17 total files, 0 missing files
lsp-plugins-lv2: 205 total files, 0 missing files
lua: 48 total files, 0 missing files
lua51: 40 total files, 0 missing files
lua54: 45 total files, 0 missing files
luajit: 50 total files, 0 missing files
luit: 0 total files, 0 missing files
lv2: 288 total files, 0 missing files
lvm2: 0 total files, 0 missing files
lz4: 23 total files, 0 missing files
lzo: 35 total files, 0 missing files
m4: 93 total files, 0 missing files
mailcap: 13 total files, 0 missing files
mailcommon: 305 total files, 0 missing files
mailimporter: 322 total files, 0 missing files
make: 105 total files, 0 missing files
man-db: 501 total files, 0 missing files
man-pages: 4293 total files, 0 missing files
manjaro-alsa: 0 total files, 0 missing files
manjaro-application-utility: 0 total files, 0 missing files
manjaro-base-skel: 0 total files, 0 missing files
manjaro-browser-settings: 36 total files, 0 missing files
manjaro-gstreamer: 0 total files, 0 missing files
manjaro-hello: 0 total files, 0 missing files
manjaro-icons: 0 total files, 0 missing files
manjaro-kde-settings: 0 total files, 0 missing files
manjaro-keyring: 7 total files, 0 missing files
manjaro-modem: 0 total files, 0 missing files
manjaro-pipewire: 7 total files, 0 missing files
manjaro-printer: 0 total files, 0 missing files
manjaro-release: 0 total files, 0 missing files
manjaro-settings-manager: 0 total files, 0 missing files
manjaro-settings-manager-knotifier: 0 total files, 0 missing files
manjaro-system: 0 total files, 0 missing files
manjaro-zsh-config: 91 total files, 0 missing files
mariadb: 0 total files, 0 missing files
mariadb-clients: 0 total files, 0 missing files
mariadb-libs: 0 total files, 0 missing files
markdownpart: 0 total files, 0 missing files
md4c: 27 total files, 0 missing files
mda.lv2: 96 total files, 0 missing files
mdadm: 41 total files, 0 missing files
media-player-info: 268 total files, 0 missing files
mediainfo: 7 total files, 0 missing files
mediainfo-gui: 32 total files, 0 missing files
meld: 0 total files, 0 missing files
memtest86+: 6 total files, 0 missing files
memtest86+-efi: 6 total files, 0 missing files
mesa: 127 total files, 0 missing files
mesa-utils: 22 total files, 0 missing files
messagelib: 1267 total files, 0 missing files
mhwd: 0 total files, 0 missing files
mhwd-amdgpu: 7 total files, 0 missing files
mhwd-ati: 6 total files, 0 missing files
mhwd-db: 0 total files, 0 missing files
mhwd-nvidia: 0 total files, 0 missing files
mhwd-nvidia-390xx: 0 total files, 0 missing files
mhwd-nvidia-470xx: 0 total files, 0 missing files
mhwd-nvidia-580xx: 0 total files, 0 missing files
micro: 20 total files, 0 missing files
milou: 238 total files, 0 missing files
minizip: 18 total files, 0 missing files
mjpegtools: 164 total files, 0 missing files
mkinitcpio: 103 total files, 0 missing files
mkinitcpio-busybox: 4 total files, 0 missing files
mkinitcpio-openswap: 13 total files, 0 missing files
mobile-broadband-provider-info: 8 total files, 0 missing files
modemmanager: 239 total files, 0 missing files
modemmanager-qt: 66 total files, 0 missing files
mp3val: 7 total files, 0 missing files
mpdecimal: 26 total files, 0 missing files
mpfr: 30 total files, 0 missing files
mpg123: 38 total files, 0 missing files
mpv: 86 total files, 0 missing files
mtdev: 17 total files, 0 missing files
mtools: 78 total files, 0 missing files
mtpfs: 3 total files, 0 missing files
mujs: 0 total files, 0 missing files
mypaint-brushes: 412 total files, 0 missing files
mypaint-brushes1: 373 total files, 0 missing files
nano: 189 total files, 0 missing files
nano-syntax-highlighting: 136 total files, 0 missing files
ncurses: 3967 total files, 0 missing files
neon: 282 total files, 0 missing files
net-snmp: 692 total files, 0 missing files
netpbm: 1263 total files, 0 missing files
nettle: 92 total files, 0 missing files
networkmanager: 368 total files, 0 missing files
networkmanager-l2tp: 202 total files, 0 missing files
networkmanager-openconnect: 178 total files, 0 missing files
networkmanager-openvpn: 193 total files, 0 missing files
networkmanager-qt: 173 total files, 0 missing files
networkmanager-vpn-plugin-l2tp: 17 total files, 0 missing files
networkmanager-vpn-plugin-openconnect: 14 total files, 0 missing files
networkmanager-vpn-plugin-openvpn: 16 total files, 0 missing files
networkmanager-vpn-plugin-vpnc: 12 total files, 0 missing files
networkmanager-vpnc: 193 total files, 0 missing files
nfs-utils: 124 total files, 0 missing files
nfsidmap: 26 total files, 0 missing files
nftables: 65 total files, 0 missing files
nilfs-utils: 50 total files, 0 missing files
nlohmann-json: 72 total files, 0 missing files
noto-fonts: 639 total files, 0 missing files
noto-fonts-cjk: 21 total files, 0 missing files
noto-fonts-emoji: 8 total files, 0 missing files
npth: 17 total files, 0 missing files
nspr: 71 total files, 0 missing files
nss: 139 total files, 0 missing files
nss-mdns: 8 total files, 0 missing files
ntfs-3g: 15 total files, 0 missing files
ntp: 305 total files, 0 missing files
ntsync-autoload: 8 total files, 0 missing files
numactl: 31 total files, 0 missing files
numlockx: 7 total files, 0 missing files
nvidia-driver-assistant: 19 total files, 0 missing files
oath-toolkit: 229 total files, 0 missing files
ocean-sound-theme: 83 total files, 0 missing files
ocl-icd: 26 total files, 0 missing files
okular: 1683 total files, 0 missing files
onetbb: 207 total files, 0 missing files
oniguruma: 33 total files, 0 missing files
openal: 44 total files, 0 missing files
openconnect: 190 total files, 0 missing files
opencore-amr: 27 total files, 0 missing files
opencv: 914 total files, 0 missing files
openexr: 230 total files, 0 missing files
openh264: 20 total files, 0 missing files
openjpeg2: 521 total files, 0 missing files
openjph: 32 total files, 0 missing files
openmp: 47 total files, 0 missing files
openssh: 89 total files, 0 missing files
openssl: 6754 total files, 0 missing files
openvpn: 86 total files, 0 missing files
openxr: 45 total files, 0 missing files
opus: 21 total files, 0 missing files
opusfile: 23 total files, 0 missing files
orc: 66 total files, 0 missing files
os-prober: 47 total files, 0 missing files
osm-gps-map: 52 total files, 0 missing files
ostree: 175 total files, 0 missing files
p11-kit: 249 total files, 0 missing files
pacman: 426 total files, 0 missing files
pacman-contrib: 62 total files, 0 missing files
pacman-mirrors: 0 total files, 0 missing files
pam: 605 total files, 0 missing files
pamac-cli: 22 total files, 0 missing files
pamac-gtk3: 52 total files, 0 missing files
pamac-tray-icon-plasma: 7 total files, 0 missing files
pambase: 8 total files, 0 missing files
pango: 86 total files, 0 missing files
pangomm: 73 total files, 0 missing files
pangomm-2.48: 74 total files, 0 missing files
papirus-icon-theme: 103433 total files, 0 missing files
parted: 131 total files, 0 missing files
passim: 92 total files, 0 missing files
patch: 7 total files, 0 missing files
pavucontrol: 187 total files, 0 missing files
pciutils: 29 total files, 0 missing files
pcre: 211 total files, 0 missing files
pcre2: 257 total files, 0 missing files
pcsclite: 54 total files, 0 missing files
pdfarranger: 189 total files, 0 missing files
pdfio: 40 total files, 0 missing files
perl: 3227 total files, 0 missing files
perl-alien-build: 197 total files, 0 missing files
perl-alien-libxml2: 24 total files, 0 missing files
perl-capture-tiny: 9 total files, 0 missing files
perl-class-inspector: 12 total files, 0 missing files
perl-clone: 13 total files, 0 missing files
perl-dbi: 143 total files, 0 missing files
perl-encode-locale: 9 total files, 0 missing files
perl-error: 11 total files, 0 missing files
perl-ffi-checklib: 9 total files, 0 missing files
perl-file-basedir: 13 total files, 0 missing files
perl-file-chdir: 9 total files, 0 missing files
perl-file-desktopentry: 9 total files, 0 missing files
perl-file-listing: 9 total files, 0 missing files
perl-file-mimeinfo: 24 total files, 0 missing files
perl-file-sharedir: 19 total files, 0 missing files
perl-file-which: 9 total files, 0 missing files
perl-html-parser: 27 total files, 0 missing files
perl-html-tagset: 9 total files, 0 missing files
perl-http-cookiejar: 12 total files, 0 missing files
perl-http-cookies: 14 total files, 0 missing files
perl-http-daemon: 9 total files, 0 missing files
perl-http-date: 9 total files, 0 missing files
perl-http-message: 27 total files, 0 missing files
perl-http-negotiate: 9 total files, 0 missing files
perl-image-exiftool: 504 total files, 0 missing files
perl-io-html: 9 total files, 0 missing files
perl-ipc-system-simple: 10 total files, 0 missing files
perl-libwww: 55 total files, 0 missing files
perl-lwp-mediatypes: 10 total files, 0 missing files
perl-mailtools: 41 total files, 0 missing files
perl-mime-base32: 9 total files, 0 missing files
perl-net-http: 16 total files, 0 missing files
perl-path-tiny: 9 total files, 0 missing files
perl-timedate: 94 total files, 0 missing files
perl-try-tiny: 12 total files, 0 missing files
perl-uri: 95 total files, 0 missing files
perl-www-robotrules: 14 total files, 0 missing files
perl-xml-libxml: 66 total files, 0 missing files
perl-xml-namespacesupport: 9 total files, 0 missing files
perl-xml-parser: 59 total files, 0 missing files
perl-xml-sax: 35 total files, 0 missing files
perl-xml-sax-base: 14 total files, 0 missing files
perl-xml-writer: 12 total files, 0 missing files
phonon-qt6: 477 total files, 0 missing files
phonon-qt6-vlc: 170 total files, 0 missing files
pimcommon: 305 total files, 0 missing files
pinentry: 16 total files, 0 missing files
pipewire: 248 total files, 0 missing files
pipewire-alsa: 12 total files, 0 missing files
pipewire-audio: 82 total files, 0 missing files
pipewire-pulse: 70 total files, 0 missing files
pipewire-session-manager: 0 total files, 0 missing files
pixman: 15 total files, 0 missing files
pkcs11-helper: 35 total files, 0 missing files
pkgconf: 50 total files, 0 missing files
plasma-activities: 46 total files, 0 missing files
plasma-activities-stats: 36 total files, 0 missing files
plasma-browser-integration: 247 total files, 0 missing files
plasma-desktop: 4753 total files, 0 missing files
plasma-integration: 173 total files, 0 missing files
plasma-nm: 1230 total files, 0 missing files
plasma-pa: 323 total files, 0 missing files
plasma-systemmonitor: 339 total files, 0 missing files
plasma-thunderbolt: 210 total files, 0 missing files
plasma-workspace: 6786 total files, 0 missing files
plasma-workspace-wallpapers: 412 total files, 0 missing files
plasma-x11-session: 4 total files, 0 missing files
plasma5support: 749 total files, 0 missing files
plasma6-themes-breath: 0 total files, 0 missing files
plasma6-themes-breath-migration: 0 total files, 0 missing files
playonlinux: 592 total files, 0 missing files
plotutils: 76 total files, 0 missing files
plymouth: 522 total files, 0 missing files
plymouth-kcm: 180 total files, 0 missing files
plymouth-theme-manjaro: 131 total files, 0 missing files
podofo: 160 total files, 0 missing files
polkit: 238 total files, 0 missing files
polkit-kde-agent: 217 total files, 0 missing files
polkit-qt5: 59 total files, 0 missing files
polkit-qt6: 59 total files, 0 missing files
poppler: 171 total files, 0 missing files
poppler-data: 524 total files, 0 missing files
poppler-glib: 90 total files, 0 missing files
poppler-qt6: 27 total files, 0 missing files
popt: 126 total files, 0 missing files
portaudio: 43 total files, 0 missing files
portmidi: 25 total files, 0 missing files
portsmf: 21 total files, 0 missing files
postgresql: 3212 total files, 0 missing files
postgresql-libs: 276 total files, 0 missing files
postgresql-old-upgrade: 2525 total files, 0 missing files
potrace: 18 total files, 0 missing files
povray: 3347 total files, 0 missing files
power-profiles-daemon: 28 total files, 0 missing files
powerdevil: 756 total files, 0 missing files
powertop: 44 total files, 0 missing files
ppp: 91 total files, 0 missing files
print-manager: 358 total files, 0 missing files
prison: 58 total files, 0 missing files
procps-ng: 242 total files, 0 missing files
projectm: 4265 total files, 0 missing files
protobuf: 404 total files, 0 missing files
protobuf-c: 21 total files, 0 missing files
psmisc: 196 total files, 0 missing files
pstoedit: 47 total files, 0 missing files
pugixml: 20 total files, 0 missing files
pulseaudio-qt: 60 total files, 0 missing files
purpose: 879 total files, 0 missing files
pyside6: 485 total files, 0 missing files
python: 3198 total files, 0 missing files
python-appdirs: 19 total files, 0 missing files
python-attrs: 87 total files, 0 missing files
python-autocommand: 31 total files, 0 missing files
python-beautifulsoup4: 65 total files, 0 missing files
python-cachecontrol: 58 total files, 0 missing files
python-cairo: 21 total files, 0 missing files
python-certifi: 36 total files, 0 missing files
python-cffi: 85 total files, 0 missing files
python-chardet: 273 total files, 0 missing files
python-charset-normalizer: 59 total files, 0 missing files
python-cryptography: 320 total files, 0 missing files
python-cssselect: 27 total files, 0 missing files
python-dateutil: 79 total files, 0 missing files
python-dbus: 73 total files, 0 missing files
python-docopt: 17 total files, 0 missing files
python-filelock: 88 total files, 0 missing files
python-gobject: 98 total files, 0 missing files
python-idna: 0 total files, 0 missing files
python-jaraco.collections: 22 total files, 0 missing files
python-jaraco.context: 22 total files, 0 missing files
python-jaraco.functools: 23 total files, 0 missing files
python-jaraco.text: 37 total files, 0 missing files
python-lockfile: 35 total files, 0 missing files
python-lxml: 179 total files, 0 missing files
python-more-itertools: 29 total files, 0 missing files
python-mpv: 20 total files, 0 missing files
python-msgpack: 26 total files, 0 missing files
python-natsort: 60 total files, 0 missing files
python-npyscreen: 211 total files, 0 missing files
python-numpy: 1907 total files, 0 missing files
python-packaging: 89 total files, 0 missing files
python-pikepdf: 300 total files, 0 missing files
python-pillow: 349 total files, 0 missing files
python-pip: 1458 total files, 0 missing files
python-platformdirs: 54 total files, 0 missing files
python-pycparser: 39 total files, 0 missing files
python-pycups: 10 total files, 0 missing files
python-pygments: 1158 total files, 0 missing files
python-pyqt5: 886 total files, 0 missing files
python-pyqt5-sip: 13 total files, 0 missing files
python-pyqt6: 1040 total files, 0 missing files
python-pyqt6-sip: 17 total files, 0 missing files
python-pyserial: 82 total files, 0 missing files
python-pysmbc: 18 total files, 0 missing files
python-pytz: 28 total files, 0 missing files
python-reportlab: 542 total files, 0 missing files
python-requests: 72 total files, 0 missing files
python-setproctitle: 22 total files, 0 missing files
python-setuptools: 467 total files, 0 missing files
python-six: 19 total files, 0 missing files
python-soupsieve: 38 total files, 0 missing files
python-standard-pipes: 16 total files, 0 missing files
python-tinycss2: 46 total files, 0 missing files
python-typing_extensions: 18 total files, 0 missing files
python-urllib3: 0 total files, 0 missing files
python-webencodings: 25 total files, 0 missing files
python-wheel: 66 total files, 0 missing files
python-wxpython: 951 total files, 0 missing files
python-yaml: 78 total files, 0 missing files
python-zstandard: 26 total files, 0 missing files
qca-qt6: 51 total files, 0 missing files
qcoro: 164 total files, 0 missing files
qgpgme: 121 total files, 0 missing files
qmmp: 193 total files, 0 missing files
qpdf: 108 total files, 0 missing files
qqc2-breeze-style: 110 total files, 0 missing files
qqc2-desktop-style: 218 total files, 0 missing files
qrencode: 15 total files, 0 missing files
qt5-base: 3862 total files, 0 missing files
qt5-declarative: 1057 total files, 0 missing files
qt5-multimedia: 375 total files, 0 missing files
qt5-speech: 50 total files, 0 missing files
qt5-svg: 56 total files, 0 missing files
qt5-tools: 382 total files, 0 missing files
qt5-translations: 351 total files, 0 missing files
qt5-wayland: 398 total files, 0 missing files
qt5-x11extras: 31 total files, 0 missing files
qt6-5compat: 165 total files, 0 missing files
qt6-base: 5102 total files, 0 missing files
qt6-charts: 442 total files, 0 missing files
qt6-connectivity: 251 total files, 0 missing files
qt6-declarative: 5512 total files, 0 missing files
qt6-graphs: 344 total files, 0 missing files
qt6-imageformats: 73 total files, 0 missing files
qt6-location: 262 total files, 0 missing files
qt6-multimedia: 500 total files, 0 missing files
qt6-multimedia-ffmpeg: 107 total files, 0 missing files
qt6-positioning: 213 total files, 0 missing files
qt6-quick3d: 1435 total files, 0 missing files
qt6-quicktimeline: 135 total files, 0 missing files
qt6-scxml: 330 total files, 0 missing files
qt6-sensors: 250 total files, 0 missing files
qt6-shadertools: 80 total files, 0 missing files
qt6-speech: 115 total files, 0 missing files
qt6-svg: 137 total files, 0 missing files
qt6-tools: 610 total files, 0 missing files
qt6-translations: 316 total files, 0 missing files
qt6-virtualkeyboard: 447 total files, 0 missing files
qt6-webchannel: 128 total files, 0 missing files
qt6-webengine: 618 total files, 0 missing files
qt6-websockets: 98 total files, 0 missing files
qtkeychain-qt6: 32 total files, 0 missing files
raptor: 128 total files, 0 missing files
rasqal: 81 total files, 0 missing files
rav1e: 17 total files, 0 missing files
rawtherapee: 669 total files, 0 missing files
re2: 23 total files, 0 missing files
readline: 60 total files, 0 missing files
redland: 100 total files, 0 missing files
ripgrep: 24 total files, 0 missing files
ripgrep-all: 6 total files, 0 missing files
rnnoise: 18 total files, 0 missing files
rpcbind: 24 total files, 0 missing files
rssguard: 123 total files, 0 missing files
rsync: 49 total files, 0 missing files
rtkit: 28 total files, 0 missing files
rtmpdump: 25 total files, 0 missing files
rubberband: 24 total files, 0 missing files
run-parts: 31 total files, 0 missing files
s-nail: 16 total files, 0 missing files
samba: 1199 total files, 0 missing files
sane: 688 total files, 0 missing files
sbc: 14 total files, 0 missing files
sbctl: 33 total files, 0 missing files
scour: 32 total files, 0 missing files
sddm: 251 total files, 0 missing files
sddm-breath-theme: 17 total files, 0 missing files
sddm-kcm: 192 total files, 0 missing files
sdl12-compat: 52 total files, 0 missing files
sdl2-compat: 126 total files, 0 missing files
sdl3: 113 total files, 0 missing files
sdl_image: 14 total files, 0 missing files
sed: 136 total files, 0 missing files
serd: 28 total files, 0 missing files
shaderc: 22 total files, 0 missing files
shadow: 534 total files, 0 missing files
shared-mime-info: 255 total files, 0 missing files
shiboken6: 72 total files, 0 missing files
signon-kwallet-extension: 5 total files, 0 missing files
signon-plugin-oauth2: 10 total files, 0 missing files
signon-ui: 10 total files, 0 missing files
signond: 122 total files, 0 missing files
simplescreenrecorder: 127 total files, 0 missing files
skanlite: 291 total files, 0 missing files
slang: 182 total files, 0 missing files
smartmontools: 46 total files, 0 missing files
smbclient: 234 total files, 0 missing files
snappy: 22 total files, 0 missing files
sndio: 69 total files, 0 missing files
socat: 14 total files, 0 missing files
sof-firmware: 766 total files, 0 missing files
solid: 257 total files, 0 missing files
solid5: 273 total files, 0 missing files
songrec: 92 total files, 0 missing files
sonnet: 379 total files, 0 missing files
sonnet5: 377 total files, 0 missing files
sord: 30 total files, 0 missing files
sound-theme-freedesktop: 44 total files, 0 missing files
soundtouch: 26 total files, 0 missing files
source-highlight: 434 total files, 0 missing files
sox: 49 total files, 0 missing files
spandsp: 157 total files, 0 missing files
spectacle: 308 total files, 0 missing files
speex: 32 total files, 0 missing files
speexdsp: 22 total files, 0 missing files
spirv-tools: 59 total files, 0 missing files
sqlite: 31 total files, 0 missing files
sratom: 19 total files, 0 missing files
srt: 21 total files, 0 missing files
sshfs: 9 total files, 0 missing files
stoken: 33 total files, 0 missing files
sudo: 243 total files, 0 missing files
suil: 26 total files, 0 missing files
suitesparse: 198 total files, 0 missing files
svt-av1: 29 total files, 0 missing files
syndication: 88 total files, 0 missing files
syntax-highlighting: 781 total files, 0 missing files
sysfsutils: 17 total files, 0 missing files
system-config-printer: 491 total files, 0 missing files
systemd: 1921 total files, 0 missing files
systemd-libs: 922 total files, 0 missing files
systemd-sysvcompat: 0 total files, 0 missing files
systemsettings: 373 total files, 0 missing files
taglib: 154 total files, 0 missing files
talloc: 23 total files, 0 missing files
tar: 135 total files, 0 missing files
tcl: 1183 total files, 0 missing files
tdb: 25 total files, 0 missing files
tenacity: 308 total files, 0 missing files
terminus-font: 311 total files, 0 missing files
tesseract: 75 total files, 0 missing files
tesseract-data-deu: 4 total files, 0 missing files
tesseract-data-osd: 4 total files, 0 missing files
tevent: 13 total files, 0 missing files
texinfo: 705 total files, 0 missing files
texlive-basic: 2676 total files, 0 missing files
texlive-bin: 323 total files, 0 missing files
texlive-plaingeneric: 10963 total files, 0 missing files
texlive-pstricks: 883 total files, 0 missing files
thin-provisioning-tools: 0 total files, 0 missing files
threadweaver: 84 total files, 0 missing files
thunderbird: 95 total files, 0 missing files
thunderbird-i18n-de: 5 total files, 0 missing files
tigervnc: 172 total files, 0 missing files
timeshift: 283 total files, 0 missing files
timeshift-autosnap-manjaro: 12 total files, 0 missing files
tinysparql: 279 total files, 0 missing files
tinyxml2: 19 total files, 0 missing files
tpm2-tss: 308 total files, 0 missing files
tslib: 74 total files, 0 missing files
ttf-bitstream-vera: 17 total files, 0 missing files
ttf-dejavu: 56 total files, 0 missing files
ttf-droid: 42 total files, 14 missing files
ttf-hack: 14 total files, 0 missing files
ttf-hack-nerd: 19 total files, 0 missing files
ttf-inconsolata: 87 total files, 0 missing files
ttf-indic-otf: 36 total files, 0 missing files
ttf-liberation: 19 total files, 0 missing files
ttf-meslo-nerd-font-powerlevel10k: 8 total files, 0 missing files
tvbrowser: 99 total files, 0 missing files
twolame: 24 total files, 0 missing files
tzdata: 1887 total files, 0 missing files
uchardet: 22 total files, 0 missing files
udev-usb-sync: 14 total files, 0 missing files
udftools: 33 total files, 0 missing files
udiskie: 135 total files, 0 missing files
udisks2: 281 total files, 0 missing files
unarchiver: 13 total files, 0 missing files
unzip: 18 total files, 0 missing files
update-grub: 7 total files, 0 missing files
upower: 115 total files, 0 missing files
usb_modeswitch: 538 total files, 0 missing files
usbutils: 27 total files, 0 missing files
util-linux: 1680 total files, 0 missing files
util-linux-libs: 81 total files, 0 missing files
v4l-utils: 809 total files, 0 missing files
vamp-plugin-sdk: 53 total files, 0 missing files
vapoursynth: 69 total files, 0 missing files
vde2: 94 total files, 0 missing files
verdict: 23 total files, 0 missing files
vid.stab: 27 total files, 0 missing files
vigra: 257 total files, 0 missing files
vim: 214 total files, 0 missing files
vim-runtime: 2556 total files, 0 missing files
virtualbox: 342 total files, 0 missing files
virtualbox-ext-vnc: 19 total files, 0 missing files
virtualbox-guest-iso: 5 total files, 0 missing files
vlc: 349 total files, 0 missing files
vlc-cli: 11 total files, 0 missing files
vlc-gui-qt: 8 total files, 0 missing files
vlc-plugin-a52dec: 6 total files, 0 missing files
vlc-plugin-aalib: 6 total files, 0 missing files
vlc-plugin-alsa: 8 total files, 0 missing files
vlc-plugin-aom: 6 total files, 0 missing files
vlc-plugin-archive: 6 total files, 0 missing files
vlc-plugin-aribb24: 6 total files, 0 missing files
vlc-plugin-aribb25: 6 total files, 0 missing files
vlc-plugin-ass: 6 total files, 0 missing files
vlc-plugin-avahi: 6 total files, 0 missing files
vlc-plugin-bluray: 6 total files, 0 missing files
vlc-plugin-caca: 6 total files, 0 missing files
vlc-plugin-cddb: 6 total files, 0 missing files
vlc-plugin-chromecast: 6 total files, 0 missing files
vlc-plugin-dav1d: 6 total files, 0 missing files
vlc-plugin-dbus: 6 total files, 0 missing files
vlc-plugin-dbus-screensaver: 6 total files, 0 missing files
vlc-plugin-dca: 6 total files, 0 missing files
vlc-plugin-dvb: 10 total files, 0 missing files
vlc-plugin-dvd: 7 total files, 0 missing files
vlc-plugin-faad2: 6 total files, 0 missing files
vlc-plugin-ffmpeg: 18 total files, 0 missing files
vlc-plugin-firewire: 7 total files, 0 missing files
vlc-plugin-flac: 6 total files, 0 missing files
vlc-plugin-fluidsynth: 6 total files, 0 missing files
vlc-plugin-freetype: 6 total files, 0 missing files
vlc-plugin-gme: 6 total files, 0 missing files
vlc-plugin-gnutls: 6 total files, 0 missing files
vlc-plugin-gstreamer: 6 total files, 0 missing files
vlc-plugin-inflate: 6 total files, 0 missing files
vlc-plugin-jack: 8 total files, 0 missing files
vlc-plugin-journal: 6 total files, 0 missing files
vlc-plugin-jpeg: 6 total files, 0 missing files
vlc-plugin-kate: 6 total files, 0 missing files
vlc-plugin-libsecret: 6 total files, 0 missing files
vlc-plugin-lirc: 6 total files, 0 missing files
vlc-plugin-live555: 6 total files, 0 missing files
vlc-plugin-lua: 152 total files, 0 missing files
vlc-plugin-mad: 6 total files, 0 missing files
vlc-plugin-matroska: 6 total files, 0 missing files
vlc-plugin-mdns: 6 total files, 0 missing files
vlc-plugin-modplug: 6 total files, 0 missing files
vlc-plugin-mpeg2: 6 total files, 0 missing files
vlc-plugin-mpg123: 6 total files, 0 missing files
vlc-plugin-mtp: 8 total files, 0 missing files
vlc-plugin-musepack: 6 total files, 0 missing files
vlc-plugin-nfs: 6 total files, 0 missing files
vlc-plugin-notify: 6 total files, 0 missing files
vlc-plugin-ogg: 8 total files, 0 missing files
vlc-plugin-opus: 6 total files, 0 missing files
vlc-plugin-png: 6 total files, 0 missing files
vlc-plugin-pulse: 13 total files, 0 missing files
vlc-plugin-samplerate: 6 total files, 0 missing files
vlc-plugin-sdl: 6 total files, 0 missing files
vlc-plugin-sftp: 6 total files, 0 missing files
vlc-plugin-shout: 6 total files, 0 missing files
vlc-plugin-smb: 6 total files, 0 missing files
vlc-plugin-soxr: 6 total files, 0 missing files
vlc-plugin-speex: 8 total files, 0 missing files
vlc-plugin-srt: 8 total files, 0 missing files
vlc-plugin-svg: 8 total files, 0 missing files
vlc-plugin-tag: 6 total files, 0 missing files
vlc-plugin-theora: 6 total files, 0 missing files
vlc-plugin-twolame: 6 total files, 0 missing files
vlc-plugin-udev: 6 total files, 0 missing files
vlc-plugin-upnp: 6 total files, 0 missing files
vlc-plugin-vorbis: 6 total files, 0 missing files
vlc-plugin-vpx: 6 total files, 0 missing files
vlc-plugin-x264: 7 total files, 0 missing files
vlc-plugin-x265: 6 total files, 0 missing files
vlc-plugin-xml: 6 total files, 0 missing files
vlc-plugin-zvbi: 9 total files, 0 missing files
vlc-plugins-all: 0 total files, 0 missing files
vlc-plugins-base: 290 total files, 0 missing files
vlc-plugins-extra: 7 total files, 0 missing files
vlc-plugins-video-output: 42 total files, 0 missing files
vlc-plugins-visualization: 9 total files, 0 missing files
vmaf: 255 total files, 0 missing files
volume_key: 126 total files, 0 missing files
vpnc: 30 total files, 0 missing files
vte-common: 319 total files, 0 missing files
vte3: 42 total files, 0 missing files
vulkan-icd-loader: 12 total files, 0 missing files
vulkan-tools: 5 total files, 0 missing files
wavpack: 33 total files, 0 missing files
wayland: 46 total files, 0 missing files
wayland-utils: 10 total files, 0 missing files
webkit2gtk-4.1: 416 total files, 0 missing files
webkitgtk-6.0: 291 total files, 0 missing files
webrtc-audio-processing: 53 total files, 0 missing files
webrtc-audio-processing-1: 54 total files, 0 missing files
wget: 176 total files, 0 missing files
wildmidi: 46 total files, 0 missing files
wine: 4191 total files, 0 missing files
wireless-regdb: 25 total files, 0 missing files
wireplumber: 326 total files, 0 missing files
woff2: 25 total files, 0 missing files
wolfssl: 223 total files, 0 missing files
wpa_supplicant: 36 total files, 0 missing files
wxmp3val-git: 53 total files, 0 missing files
wxwidgets-common: 995 total files, 0 missing files
wxwidgets-gtk3: 63 total files, 0 missing files
x264: 15 total files, 0 missing files
x265: 13 total files, 0 missing files
xapian-core: 110 total files, 0 missing files
xapp: 389 total files, 0 missing files
xapp-symbolic-icons: 676 total files, 0 missing files
xcb-proto: 74 total files, 0 missing files
xcb-util: 20 total files, 0 missing files
xcb-util-cursor: 14 total files, 0 missing files
xcb-util-image: 16 total files, 0 missing files
xcb-util-keysyms: 14 total files, 0 missing files
xcb-util-renderutil: 14 total files, 0 missing files
xcb-util-wm: 19 total files, 0 missing files
xdg-dbus-proxy: 7 total files, 0 missing files
xdg-desktop-portal: 198 total files, 0 missing files
xdg-desktop-portal-gtk: 119 total files, 0 missing files
xdg-desktop-portal-kde: 182 total files, 0 missing files
xdg-user-dirs: 264 total files, 0 missing files
xdg-utils: 25 total files, 0 missing files
xf86-input-elographics: 13 total files, 0 missing files
xf86-input-evdev: 21 total files, 0 missing files
xf86-input-libinput: 21 total files, 0 missing files
xf86-input-void: 13 total files, 0 missing files
xf86-video-amdgpu: 16 total files, 0 missing files
xf86-video-ati: 18 total files, 0 missing files
xf86-video-intel: 26 total files, 0 missing files
xf86-video-nouveau: 13 total files, 0 missing files
xfsprogs: 167 total files, 0 missing files
xkeyboard-config: 520 total files, 0 missing files
xl2tpd: 27 total files, 0 missing files
xmlsec: 193 total files, 0 missing files
xorg-fonts-encodings: 60 total files, 0 missing files
xorg-mkfontscale: 17 total files, 0 missing files
xorg-server: 48 total files, 0 missing files
xorg-server-common: 15 total files, 0 missing files
xorg-setxkbmap: 10 total files, 0 missing files
xorg-twm: 13 total files, 0 missing files
xorg-xauth: 10 total files, 0 missing files
xorg-xdpyinfo: 10 total files, 0 missing files
xorg-xhost: 10 total files, 0 missing files
xorg-xinit: 17 total files, 0 missing files
xorg-xkbcomp: 13 total files, 0 missing files
xorg-xkill: 10 total files, 0 missing files
xorg-xmessage: 14 total files, 0 missing files
xorg-xmodmap: 10 total files, 0 missing files
xorg-xprop: 10 total files, 0 missing files
xorg-xrdb: 10 total files, 0 missing files
xorg-xset: 10 total files, 0 missing files
xorg-xsetroot: 10 total files, 0 missing files
xorg-xwayland: 15 total files, 0 missing files
xorgproto: 211 total files, 0 missing files
xsettingsd: 16 total files, 0 missing files
xterm: 40 total files, 0 missing files
xvidcore: 7 total files, 0 missing files
xxhash: 27 total files, 0 missing files
xz: 486 total files, 0 missing files
yakuake: 370 total files, 0 missing files
yelp: 647 total files, 0 missing files
yelp-xsl: 104 total files, 0 missing files
youplay-base: 5 total files, 0 missing files
youplay-qt6: 6 total files, 0 missing files
yt-dlp: 3204 total files, 0 missing files
yt-dlp-ejs: 30 total files, 0 missing files
yyjson: 24 total files, 0 missing files
zam-plugins-lv2: 140 total files, 0 missing files
zbar: 64 total files, 0 missing files
zeromq: 184 total files, 0 missing files
zimg: 34 total files, 0 missing files
zint: 18 total files, 0 missing files
zita-convolver: 12 total files, 0 missing files
zix: 36 total files, 0 missing files
zlib: 17 total files, 0 missing files
zlib-ng: 24 total files, 0 missing files
zsh: 1233 total files, 0 missing files
zsh-autosuggestions: 14 total files, 0 missing files
zsh-completions: 189 total files, 0 missing files
zsh-history-substring-search: 12 total files, 0 missing files
zsh-syntax-highlighting: 42 total files, 0 missing files
zsh-theme-powerlevel10k: 54 total files, 0 missing files
zstd: 39 total files, 0 missing files
zvbi: 55 total files, 0 missing files
zxing-cpp: 41 total files, 0 missing files
zziplib: 76 total files, 0 missing files
You stated that you had timeshift installed so if your booted on the Manjaro iso open timeshift or install it on the usb your booted on and restore it back to a time before the issue started.
Thank you @soundofthunder and @straycat , I asked for advice for Timeshift.
Problem could be solved using TimeShift, ref. here.
Thanks @all.
While that’s great to hear.
A valid solution for this thread would have involved solutions being found for the discovered problems that contributed to the original “freezing” that you reported.
Restoring your system from a backup (or reinstalling from scratch) would have been a workaround only, which doesn’t provide useful information for others wishing to solve the same or a similar problem.
Marking the solution post is like saying “This is the solution to the issue in the title and first post”, which obviously it isn’t for everyone.
With so many issues discovered along the way, it’s simpler to close the thread (without a marked solution, in this case).
Glad you’re up and running.
Well, restoring means at some point he will try to update again, and then we might revisit this again. So far the best theory i had was “out of space”. The op freed 10+ gig now, so we will see if that was it.
P.s. i just read my PM. He did do the update successfully, so it seems to have been that.
