System shuts down after waking from sleep
Hey guys, i recently reinstalled manjaro and noticed when booting up or shutting down i get a message on screen “dev/sda clean blocks etc”
The main problem i’m facing is after longer periods in sleep state when my laptop wakes up from sleep the same “dev/sda clean” message shows up and the system shuts down. Can anybody help me solve this problem?
Inxi Output:
System: Host: hami-latitudee6440 Kernel: 5.14.10-1-MANJARO x86_64 bits: 64
Desktop: KDE Plasma 5.22.5 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Latitude E6440 v: 00 serial:
Mobo: Dell model: 0YX2X3 v: A00 serial: UEFI: Dell v: A24
date: 06/13/2019
Battery: ID-1: BAT0 charge: 42.2 Wh (73.4%) condition: 57.5/71.3 Wh (80.6%)
CPU: Info: Dual Core model: Intel Core i7-4600M bits: 64 type: MT MCP cache: L2: 4 MiB
Speed: 2894 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 2894 2: 2876 3: 1302
4: 1018
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915 v: kernel
Device-2: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X/.Org 1.20.13 driver: loaded: modesetting
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.2.3
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Ethernet I217-LM driver: e1000e
IF: eno1 state: down mac: ec:f4:bb:17:2c:ae
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi
IF: wlp3s0 state: up mac: c4:d9:87:64:eb:fa
Bluetooth: Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb
Drives: Local Storage: total: 709.83 GiB used: 178.32 GiB (25.1%)
ID-1: /dev/sda vendor: Lexar model: 512GB SSD size: 476.94 GiB
ID-2: /dev/sdb vendor: Samsung model: HM251HI size: 232.89 GiB
Partition: ID-1: / size: 294.79 GiB used: 178.29 GiB (60.5%) fs: ext4 dev: /dev/sda1
ID-2: /boot/efi size: 96 MiB used: 26.1 MiB (27.2%) fs: vfat dev: /dev/sda4
Swap: ID-1: swap-1 type: file size: 256 MiB used: 0 KiB (0.0%)
file: /var/lib/systemd-swap/swapfc/1
Sensors: System Temperatures: cpu: 59.0 C mobo: 56.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3321
Info: Processes: 237 Uptime: 17m Memory: 7.67 GiB used: 5.34 GiB (69.6%) Shell: Zsh
inxi: 3.3.07
Hello,
You should update the BIOS https://www.dell.com/support/home/en-en/product-support/product/latitude-e6440-laptop/drivers
not sure if that is ok …
Maybe try hibernate instead of suspend Power management/Suspend and hibernate - ArchWiki
thanks for replying, Bios is up to date, hibernation is more cumbersome than sleep and i’m fine with using just sleep mode. I didn’t have any problems with it before and i’m not sure why i’m experiencing them now. Can you tell me what this “dev/sda clean” msg is about?
The fsck runs at startup, and that message is only informing you have a clean file system.
More about it at fsck - ArchWiki
Try a different kernel. You could go with the LTS 5.10 for instance and see if the issue persists.
