Pinebook Pro installation of "microsoft-edge-stable-bin" stops with error
Hallo,
on my Pinebook Pro any try to install/build (via pamac) of “microsoft-edge-beta-bin” stops with error message:
==> ERROR: microsoft-edge-beta-bin is not available for the 'aarch64' architecture.==> ERROR: microsoft-edge-beta-bin is not available for the 'aarch64' architecture.
Same with microsoft-edge-stable-bin.
Anything done wrong by me?? For me to understand: if a package is listed in the repositories it is supposed to work on that architecture, right?
Edge don’t exist from arm64 yet Arm64 linux support? · Issue #697 · MicrosoftEdge/Status · GitHub
If it is builded from AUR it isn’t the same things, can’t see that in a mirror (just checked last updated one Index of /manjaro/arm-stable/community/aarch64/) so I guess you tried to build from AUR, not your fault
In the AUR pkgbuild of microsoft-edge-beta-bin (made by @bittin ) there are some things to change, like for binary sources it should use source_x86_64=() instead of source=()
