System Restart on Startup
Removed orphaned package last night and The system won’t even boot neither show grub screen,
It restart as soon as it start and enter the UEFI setting,.
I have windows installed alongside manjaro and can enter it by changing boot order(pressing F11)
Edit: Pressing Esc while booting show grub but it have only UEFI firmware setting
boot into manjaro live usb, make sure you are connected to internet, open terminal and chroot:
manjaro-chroot -a
and then check for pacman logs:
cat /var/log/pacman.log | grep removed | tail -100
and install the removed orphans back…
Looks like linux kernel was removed
Thanks to @brahma Installed all the package
still grub was giving error that failed to load pointer or something similar
installed refind instead of grub and it’s working smoothly
