System repair issues
yes uninstall the 5.9 click on entfernen , then reboot, try installing nvidia drivers again, if the install went ok, reboot and check if you can boot normally
yes it is a problem, it says there nicht unterstutzt … it can cause all kind of problems keeping it, like not to be able to install drivers
Everything is working.
Thanks for the support!
so uninstalling the kernel went ok? installing nvidia went ok? booting normally went ok? if so, youre welcome
Yes, everything is fine.
