System read-only
but sometimes after reboot the system is available
Tell me, how many years of experience do yo have? How many different distributions have you used? And please, give us uneducated plebs sources so that we can enlighten ourselves.
Yes, and I’m guessing it’s getting worse with time? That is a classic sign of hard disc failure.
How would you know - because you told us
This topic is going nowhere - I am on the verge of closing this nonsense topic - and I will if it continue on the pattern.
If I look to your inxi output compared to mine I see a difference in the boot parameter. At your place it is β€˜rw quiet’ and at mine it is only β€˜ro’.
fsck should only performed on a read-only fs. So you could try to change this.
In the file β€˜/etc/default/grub’ you should uncomment the β€˜GRUB_ROOT_FS_RO=true’ option’.
In my β€˜/etc/default/grub’ it looks like:
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically
GRUB_ENABLE_CRYPTODISK=y
After changing that you still have to reinstall grub by
sudo update-grub
But I dont know if this is the cause of the problem so change it on own risk.
It won’t be the first time, either.
I’m new to linux but not an idiot, if I have root then I can do whatever I want with the system
thank you! i will try it now
Except when the kernel mounts you hard drive as read-only. In which case, there is a good bad reason for it happening. Usually hard drive failure.
If you really want to break your system all is already mentioned above, read some post wich erxplains how give you all permissions in your root, nobody can prevent an obstinate suicide tendency
I’m also a noob, but i’ve already understood don’t play with permissions when you don’t know the consequences and exactly what you do, even not on a single system file…so in the whole / lol it’s just suicide, less an hour before your system is completely dead
it was a new ssd from amd which I bought a couple of months ago(
Your chosen username implies differently
Yes you can - but you have to su or login as root - then you do as you please - but not as a normal user unless the user is is assigned elevated privileges.
You will on Manjaro too.
Welp, I guess that can fail as well…anything is possible, aster all.
β”‚ File: /etc/default/grub
1   β”‚ GRUB_DEFAULT=saved
2   β”‚ GRUB_TIMEOUT=5
3   β”‚ GRUB_TIMEOUT_STYLE=hidden
4   β”‚ GRUB_DISTRIBUTOR="Manjaro"
5   β”‚ GRUB_CMDLINE_LINUX_DEFAULT="quiet cryptdevice=UUID=***************************92b root=/dev/mapper/luks-**********************************92b apparmor=1 security=appar
β”‚ mor udev.log_priority=3"
6   β”‚ GRUB_CMDLINE_LINUX=""
7   β”‚
8   β”‚ # If you want to enable the save default function, uncomment the following
9   β”‚ # line, and set GRUB_DEFAULT to saved.
10   β”‚ GRUB_SAVEDEFAULT=true
11   β”‚
12   β”‚ # Preload both GPT and MBR modules so that they are not missed
13   β”‚ GRUB_PRELOAD_MODULES="part_gpt part_msdos"
14   β”‚
15   β”‚ # Uncomment to enable booting from LUKS encrypted devices
16   β”‚ #GRUB_ENABLE_CRYPTODISK=y
17   β”‚
18   β”‚ # Uncomment to use basic console
19   β”‚ GRUB_TERMINAL_INPUT=console
20   β”‚
21   β”‚ # Uncomment to disable graphical terminal
22   β”‚ #GRUB_TERMINAL_OUTPUT=console
23   β”‚
24   β”‚ # The resolution used on graphical terminal
25   β”‚ # note that you can use only modes which your graphic card supports via VBE
26   β”‚ # you can see them in real GRUB with the command 'videoinfo'
27   β”‚ GRUB_GFXMODE=auto
28   β”‚
29   β”‚ # Uncomment to allow the kernel use the same resolution used by grub
30   β”‚ GRUB_GFXPAYLOAD_LINUX=keep
31   β”‚
32   β”‚ # Uncomment if you want GRUB to pass to the Linux kernel the old parameter
33   β”‚ # format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
34   β”‚ #GRUB_DISABLE_LINUX_UUID=true
35   β”‚
36   β”‚ # Uncomment to disable generation of recovery mode menu entries
37   β”‚ GRUB_DISABLE_RECOVERY=true
38   β”‚
39   β”‚ # Uncomment this option to enable os-prober execution in the grub-mkconfig command
40   β”‚ GRUB_DISABLE_OS_PROBER=false
41   β”‚
42   β”‚ # Uncomment and set to the desired menu colors.  Used by normal and wallpaper
43   β”‚ # modes only.  Entries specified as foreground/background.
44   β”‚ GRUB_COLOR_NORMAL="light-gray/black"
45   β”‚ GRUB_COLOR_HIGHLIGHT="green/black"
46   β”‚
47   β”‚ # Uncomment one of them for the gfx desired, a image background or a gfxtheme
48   β”‚ #GRUB_BACKGROUND="/usr/share/grub/background.png"
49   β”‚ GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
50   β”‚
51   β”‚ # Uncomment to get a beep at GRUB start
52   β”‚ #GRUB_INIT_TUNE="480 440 1"
53   β”‚
54   β”‚ # Uncomment to ensure that the root filesystem is mounted read-only so that
55   β”‚ # systemd-fsck can run the check automatically. We use 'fsck' by default, which
56   β”‚ # needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
57   β”‚ # removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
58   β”‚ # See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
59   β”‚ #GRUB_ROOT_FS_RO=true
60   β”‚ GRUB_ENABLE_CRYPTODISK=y
this is my conf, now I will add your parameter
Hey,
Can you provide output of these commands? β€œsudo dmesg --level err -L” and β€œjournalctl -b 0 --priority=3”
also trying β€œsmartctl -t long <insert_disk_path_here>” could be useful
[29041.292684] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.292698] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.292710] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.292723] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.292736] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29041.292748] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.292760] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.765182] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29041.775201] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29041.785178] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29041.811811] ata6.00: exception Emask 0x11 SAct 0xff8000 SErr 0x400000 action 0x6 frozen
[29041.811820] ata6.00: irq_stat 0x48000008, interface fatal error
[29041.811822] ata6: SError: { Handshk }
[29041.811826] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811828] ata6.00: cmd 61/38:78:90:c3:f0/00:00:02:00:00/40 tag 15 ncq dma 28672 out
res 40/00:bc:d0:c3:f0/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29041.811836] ata6.00: status: { DRDY }
[29041.811838] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811840] ata6.00: cmd 61/08:80:50:9b:fb/00:00:02:00:00/40 tag 16 ncq dma 4096 out
[29041.811846] ata6.00: status: { DRDY }
[29041.811848] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811849] ata6.00: cmd 61/10:88:d8:98:fb/00:00:02:00:00/40 tag 17 ncq dma 8192 out
[29041.811856] ata6.00: status: { DRDY }
[29041.811858] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811859] ata6.00: cmd 61/08:90:58:8f:fb/00:00:02:00:00/40 tag 18 ncq dma 4096 out
[29041.811865] ata6.00: status: { DRDY }
[29041.811867] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811868] ata6.00: cmd 61/08:98:d8:a6:fb/00:00:02:00:00/40 tag 19 ncq dma 4096 out
[29041.811874] ata6.00: status: { DRDY }
[29041.811876] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811878] ata6.00: cmd 61/08:a0:20:9b:fb/00:00:02:00:00/40 tag 20 ncq dma 4096 out
[29041.811884] ata6.00: status: { DRDY }
[29041.811886] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811887] ata6.00: cmd 61/08:a8:c8:98:fb/00:00:02:00:00/40 tag 21 ncq dma 4096 out
[29041.811893] ata6.00: status: { DRDY }
[29041.811894] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811896] ata6.00: cmd 61/90:b0:68:c6:f0/00:00:02:00:00/40 tag 22 ncq dma 73728 out
[29041.811901] ata6.00: status: { DRDY }
[29041.811902] ata6.00: failed command: WRITE FPDMA QUEUED
[29041.811904] ata6.00: cmd 61/08:b8:d0:c3:f0/00:00:02:00:00/40 tag 23 ncq dma 4096 out
[29041.811909] ata6.00: status: { DRDY }
[29041.815129] systemd-journald[351]: Failed to write entry (9 items, 293 bytes), ignoring: Read-only file system
[29041.815150] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29041.815179] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29041.815186] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29041.816915] systemd-journald[351]: Failed to write entry (9 items, 243 bytes) despite vacuuming, ignoring: Bad message
[29041.816943] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.816959] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29041.816973] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.816987] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817002] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817015] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817029] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817043] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817056] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817070] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817084] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817097] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817110] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817125] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817140] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817154] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817168] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817181] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817197] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817212] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817225] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817238] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817252] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29041.817265] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817280] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29041.817296] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29041.817309] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29041.817322] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.287991] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29042.298021] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29042.307972] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29042.337878] ata6.00: exception Emask 0x11 SAct 0x7fc00 SErr 0x400000 action 0x6 frozen
[29042.337886] ata6.00: irq_stat 0x48000008, interface fatal error
[29042.337888] ata6: SError: { Handshk }
[29042.337892] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337894] ata6.00: cmd 61/08:50:d0:c3:f0/00:00:02:00:00/40 tag 10 ncq dma 4096 out
res 40/00:54:d0:c3:f0/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29042.337901] ata6.00: status: { DRDY }
[29042.337903] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337905] ata6.00: cmd 61/90:58:68:c6:f0/00:00:02:00:00/40 tag 11 ncq dma 73728 out
[29042.337911] ata6.00: status: { DRDY }
[29042.337913] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337915] ata6.00: cmd 61/08:60:c8:98:fb/00:00:02:00:00/40 tag 12 ncq dma 4096 out
[29042.337920] ata6.00: status: { DRDY }
[29042.337922] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337924] ata6.00: cmd 61/08:68:20:9b:fb/00:00:02:00:00/40 tag 13 ncq dma 4096 out
[29042.337929] ata6.00: status: { DRDY }
[29042.337931] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337933] ata6.00: cmd 61/08:70:d8:a6:fb/00:00:02:00:00/40 tag 14 ncq dma 4096 out
[29042.337938] ata6.00: status: { DRDY }
[29042.337940] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337941] ata6.00: cmd 61/08:78:58:8f:fb/00:00:02:00:00/40 tag 15 ncq dma 4096 out
[29042.337947] ata6.00: status: { DRDY }
[29042.337949] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337950] ata6.00: cmd 61/10:80:d8:98:fb/00:00:02:00:00/40 tag 16 ncq dma 8192 out
[29042.337955] ata6.00: status: { DRDY }
[29042.337957] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337958] ata6.00: cmd 61/08:88:50:9b:fb/00:00:02:00:00/40 tag 17 ncq dma 4096 out
[29042.337964] ata6.00: status: { DRDY }
[29042.337965] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.337967] ata6.00: cmd 61/38:90:90:c3:f0/00:00:02:00:00/40 tag 18 ncq dma 28672 out
[29042.337972] ata6.00: status: { DRDY }
[29042.341283] systemd-journald[351]: Failed to write entry (9 items, 292 bytes), ignoring: Read-only file system
[29042.341306] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29042.341320] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341333] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341348] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341361] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341373] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341387] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29042.341403] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341418] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341437] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341454] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341466] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341479] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341492] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341505] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341518] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341531] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341553] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341573] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341592] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341608] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341629] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341647] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341664] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341683] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.341700] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341718] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.341732] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29042.341745] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.341758] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.814147] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29042.824138] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29042.834135] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29042.850738] ata6.00: exception Emask 0x11 SAct 0xff80 SErr 0x400000 action 0x6 frozen
[29042.850747] ata6.00: irq_stat 0x48000008, interface fatal error
[29042.850749] ata6: SError: { Handshk }
[29042.850753] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850755] ata6.00: cmd 61/38:38:90:c3:f0/00:00:02:00:00/40 tag 7 ncq dma 28672 out
res 40/00:3c:90:c3:f0/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29042.850764] ata6.00: status: { DRDY }
[29042.850766] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850768] ata6.00: cmd 61/08:40:50:9b:fb/00:00:02:00:00/40 tag 8 ncq dma 4096 out
[29042.850775] ata6.00: status: { DRDY }
[29042.850778] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850780] ata6.00: cmd 61/10:48:d8:98:fb/00:00:02:00:00/40 tag 9 ncq dma 8192 out
[29042.850787] ata6.00: status: { DRDY }
[29042.850789] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850790] ata6.00: cmd 61/08:50:58:8f:fb/00:00:02:00:00/40 tag 10 ncq dma 4096 out
[29042.850797] ata6.00: status: { DRDY }
[29042.850799] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850800] ata6.00: cmd 61/08:58:d8:a6:fb/00:00:02:00:00/40 tag 11 ncq dma 4096 out
[29042.850807] ata6.00: status: { DRDY }
[29042.850809] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850810] ata6.00: cmd 61/08:60:20:9b:fb/00:00:02:00:00/40 tag 12 ncq dma 4096 out
[29042.850817] ata6.00: status: { DRDY }
[29042.850818] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850820] ata6.00: cmd 61/08:68:c8:98:fb/00:00:02:00:00/40 tag 13 ncq dma 4096 out
[29042.850826] ata6.00: status: { DRDY }
[29042.850828] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850830] ata6.00: cmd 61/90:70:68:c6:f0/00:00:02:00:00/40 tag 14 ncq dma 73728 out
[29042.850836] ata6.00: status: { DRDY }
[29042.850838] ata6.00: failed command: WRITE FPDMA QUEUED
[29042.850840] ata6.00: cmd 61/08:78:d0:c3:f0/00:00:02:00:00/40 tag 15 ncq dma 4096 out
[29042.850846] ata6.00: status: { DRDY }
[29042.854108] systemd-journald[351]: Failed to write entry (9 items, 291 bytes), ignoring: Read-only file system
[29042.854128] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29042.854143] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854155] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854168] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.854180] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854192] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854205] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29042.854216] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854228] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854240] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29042.854251] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854262] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854274] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.854284] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854295] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854306] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.854317] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854328] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854339] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.854350] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854360] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854371] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.854382] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854394] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854405] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29042.854417] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29042.854429] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29042.854440] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29042.854463] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29042.854469] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29042.856353] systemd-journald[351]: Failed to write entry (9 items, 243 bytes) despite vacuuming, ignoring: Bad message
[29042.856376] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.323779] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29043.333628] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29043.343630] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29043.493417] ata6.00: exception Emask 0x11 SAct 0xff00000 SErr 0x400000 action 0x6 frozen
[29043.493425] ata6.00: irq_stat 0x48000008, interface fatal error
[29043.493428] ata6: SError: { Handshk }
[29043.493432] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493434] ata6.00: cmd 61/90:a0:68:c6:f0/00:00:02:00:00/40 tag 20 ncq dma 73728 out
res 40/00:a4:68:c6:f0/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29043.493442] ata6.00: status: { DRDY }
[29043.493444] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493445] ata6.00: cmd 61/08:a8:c8:98:fb/00:00:02:00:00/40 tag 21 ncq dma 4096 out
[29043.493451] ata6.00: status: { DRDY }
[29043.493453] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493454] ata6.00: cmd 61/08:b0:20:9b:fb/00:00:02:00:00/40 tag 22 ncq dma 4096 out
[29043.493459] ata6.00: status: { DRDY }
[29043.493461] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493462] ata6.00: cmd 61/08:b8:d8:a6:fb/00:00:02:00:00/40 tag 23 ncq dma 4096 out
[29043.493467] ata6.00: status: { DRDY }
[29043.493469] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493470] ata6.00: cmd 61/08:c0:58:8f:fb/00:00:02:00:00/40 tag 24 ncq dma 4096 out
[29043.493475] ata6.00: status: { DRDY }
[29043.493477] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493478] ata6.00: cmd 61/10:c8:d8:98:fb/00:00:02:00:00/40 tag 25 ncq dma 8192 out
[29043.493483] ata6.00: status: { DRDY }
[29043.493484] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493485] ata6.00: cmd 61/08:d0:50:9b:fb/00:00:02:00:00/40 tag 26 ncq dma 4096 out
[29043.493490] ata6.00: status: { DRDY }
[29043.493492] ata6.00: failed command: WRITE FPDMA QUEUED
[29043.493493] ata6.00: cmd 61/38:d8:90:c3:f0/00:00:02:00:00/40 tag 27 ncq dma 28672 out
[29043.493497] ata6.00: status: { DRDY }
[29043.496868] systemd-journald[351]: Failed to write entry (9 items, 294 bytes), ignoring: Read-only file system
[29043.496889] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29043.496903] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.496916] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.496930] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29043.496942] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.496954] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.497170] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29043.497178] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29043.499044] systemd-journald[351]: Failed to write entry (9 items, 366 bytes) despite vacuuming, ignoring: Bad message
[29043.499080] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499093] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.499107] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29043.499118] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499129] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.499141] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29043.499152] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499164] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.499176] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29043.499187] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499199] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.499212] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29043.499223] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499234] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.499247] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29043.499258] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499270] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29043.499281] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29043.499293] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.499304] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29043.969696] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29043.979699] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29043.979709] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29043.981733] systemd-journald[351]: Failed to write entry (9 items, 249 bytes) despite vacuuming, ignoring: Bad message
[29047.001301] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[29047.001335] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[29047.002671] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[29047.002694] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[29047.003070] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[29047.003294] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29047.003433] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[29047.251177] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[29047.251268] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[29047.251312] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[29047.251334] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29047.252752] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[29047.253182] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29047.253222] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29047.304487] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[29081.012076] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29081.012084] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29081.013904] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29109.769681] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29109.769689] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29109.771333] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29109.771624] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29109.771631] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29109.773196] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29137.434441] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[29210.149472] systemd-journald[351]: Failed to write entry (22 items, 840 bytes), ignoring: Read-only file system
[29210.151955] systemd-journald[351]: Failed to write entry (13 items, 324 bytes), ignoring: Read-only file system
[29210.152038] systemd-journald[351]: Failed to write entry (13 items, 324 bytes), ignoring: Read-only file system
[29210.152075] systemd-journald[351]: Failed to write entry (13 items, 324 bytes), ignoring: Read-only file system
[29210.152145] systemd-journald[351]: Failed to write entry (9 items, 280 bytes), ignoring: Read-only file system
[29210.152163] systemd-journald[351]: Failed to write entry (9 items, 280 bytes), ignoring: Read-only file system
[29210.152183] systemd-journald[351]: Failed to write entry (9 items, 280 bytes), ignoring: Read-only file system
[29210.153155] systemd-journald[351]: Failed to write entry (28 items, 645 bytes), ignoring: Read-only file system
[29210.222782] systemd-journald[351]: Failed to write entry (22 items, 689 bytes), ignoring: Read-only file system
[29210.222859] systemd-journald[351]: Failed to write entry (29 items, 656 bytes), ignoring: Read-only file system
[29210.223017] systemd-journald[351]: Failed to write entry (23 items, 728 bytes), ignoring: Read-only file system
[29210.225637] systemd-journald[351]: Failed to write entry (9 items, 435 bytes), ignoring: Read-only file system
[29210.225702] systemd-journald[351]: Failed to write entry (22 items, 828 bytes), ignoring: Read-only file system
[29210.228471] systemd-journald[351]: Failed to write entry (28 items, 647 bytes), ignoring: Read-only file system
[29210.237053] systemd-journald[351]: Failed to write entry (20 items, 689 bytes), ignoring: Read-only file system
[29210.237126] systemd-journald[351]: Failed to write entry (22 items, 690 bytes), ignoring: Read-only file system
[29210.238800] systemd-journald[351]: Failed to write entry (23 items, 728 bytes), ignoring: Read-only file system
[29210.238844] systemd-journald[351]: Failed to write entry (9 items, 435 bytes), ignoring: Read-only file system
[29210.238860] systemd-journald[351]: Failed to write entry (9 items, 435 bytes), ignoring: Read-only file system
[29210.238899] systemd-journald[351]: Failed to write entry (23 items, 726 bytes), ignoring: Read-only file system
[29210.238932] systemd-journald[351]: Failed to write entry (29 items, 658 bytes), ignoring: Read-only file system
[29210.239012] systemd-journald[351]: Failed to write entry (26 items, 639 bytes), ignoring: Read-only file system
[29210.239953] systemd-journald[351]: Failed to write entry (22 items, 828 bytes), ignoring: Read-only file system
[29210.243070] systemd-journald[351]: Failed to write entry (28 items, 647 bytes), ignoring: Read-only file system
[29210.250333] systemd-journald[351]: Failed to write entry (20 items, 689 bytes), ignoring: Read-only file system
[29210.250386] systemd-journald[351]: Failed to write entry (22 items, 690 bytes), ignoring: Read-only file system
[29210.252165] systemd-journald[351]: Failed to write entry (23 items, 728 bytes), ignoring: Read-only file system
[29210.252220] systemd-journald[351]: Failed to write entry (9 items, 435 bytes), ignoring: Read-only file system
[29210.252245] systemd-journald[351]: Failed to write entry (9 items, 435 bytes), ignoring: Read-only file system
[29210.252309] systemd-journald[351]: Failed to write entry (23 items, 726 bytes), ignoring: Read-only file system
[29210.252399] systemd-journald[351]: Failed to write entry (29 items, 658 bytes), ignoring: Read-only file system
[29210.252433] systemd-journald[351]: Failed to write entry (26 items, 639 bytes), ignoring: Read-only file system
[29227.633353] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[29227.633384] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[29227.635541] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[29227.635584] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[29227.635845] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[29227.636054] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29227.639028] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[29227.883222] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[29227.883369] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[29227.883408] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[29227.883431] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29227.885022] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[29227.885199] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29227.885226] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29227.903765] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[29240.223852] systemd-journald[351]: Failed to write entry (26 items, 639 bytes), ignoring: Read-only file system
[29240.226228] systemd-journald[351]: Failed to write entry (23 items, 726 bytes), ignoring: Read-only file system
[29240.226275] systemd-journald[351]: Failed to write entry (9 items, 435 bytes), ignoring: Read-only file system
[29240.299593] systemd-journald[351]: Failed to write entry (13 items, 328 bytes), ignoring: Read-only file system
[29240.299621] systemd-journald[351]: Failed to write entry (13 items, 328 bytes), ignoring: Read-only file system
[29240.299640] systemd-journald[351]: Failed to write entry (13 items, 328 bytes), ignoring: Read-only file system
[29240.302845] systemd-journald[351]: Failed to write entry (9 items, 282 bytes), ignoring: Read-only file system
[29240.302872] systemd-journald[351]: Failed to write entry (9 items, 282 bytes), ignoring: Read-only file system
[29240.302894] systemd-journald[351]: Failed to write entry (9 items, 282 bytes), ignoring: Read-only file system
[29247.826898] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29247.826906] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29247.828701] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29252.541260] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.541269] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.543238] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29252.543640] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.543649] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.545399] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29252.545765] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.545772] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.547357] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29252.547649] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.547658] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.549262] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29252.549602] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.549609] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.551431] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29252.551779] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.551787] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.553643] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29252.553987] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.553994] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.555543] systemd-journald[351]: Failed to write entry (28 items, 807 bytes) despite vacuuming, ignoring: Bad message
[29252.555808] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.555814] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.557412] systemd-journald[351]: Failed to write entry (28 items, 806 bytes) despite vacuuming, ignoring: Bad message
[29252.557748] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.557754] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.559276] systemd-journald[351]: Failed to write entry (28 items, 815 bytes) despite vacuuming, ignoring: Bad message
[29252.559499] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29252.559505] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29252.560903] systemd-journald[351]: Failed to write entry (28 items, 805 bytes) despite vacuuming, ignoring: Bad message
[29316.382495] ata6.00: exception Emask 0x11 SAct 0x7f800000 SErr 0x400000 action 0x6 frozen
[29316.382502] ata6.00: irq_stat 0x48000008, interface fatal error
[29316.382503] ata6: SError: { Handshk }
[29316.382506] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382507] ata6.00: cmd 61/10:b8:18:51:3c/00:00:02:00:00/40 tag 23 ncq dma 8192 out
res 40/00:c4:28:51:3c/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29316.382512] ata6.00: status: { DRDY }
[29316.382514] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382515] ata6.00: cmd 61/08:c0:28:51:3c/00:00:02:00:00/40 tag 24 ncq dma 4096 out
[29316.382519] ata6.00: status: { DRDY }
[29316.382520] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382521] ata6.00: cmd 61/08:c8:30:51:3c/00:00:02:00:00/40 tag 25 ncq dma 4096 out
[29316.382525] ata6.00: status: { DRDY }
[29316.382526] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382527] ata6.00: cmd 61/08:d0:38:51:3c/00:00:02:00:00/40 tag 26 ncq dma 4096 out
[29316.382531] ata6.00: status: { DRDY }
[29316.382532] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382533] ata6.00: cmd 61/08:d8:40:51:3c/00:00:02:00:00/40 tag 27 ncq dma 4096 out
[29316.382536] ata6.00: status: { DRDY }
[29316.382538] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382538] ata6.00: cmd 61/08:e0:48:51:3c/00:00:02:00:00/40 tag 28 ncq dma 4096 out
[29316.382542] ata6.00: status: { DRDY }
[29316.382543] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382544] ata6.00: cmd 61/08:e8:50:51:3c/00:00:02:00:00/40 tag 29 ncq dma 4096 out
[29316.382547] ata6.00: status: { DRDY }
[29316.382549] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.382549] ata6.00: cmd 61/08:f0:58:51:3c/00:00:02:00:00/40 tag 30 ncq dma 4096 out
[29316.382553] ata6.00: status: { DRDY }
[29316.385905] systemd-journald[351]: Failed to write entry (9 items, 295 bytes), ignoring: Read-only file system
[29316.385928] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29316.385957] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.385972] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.385987] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.385999] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386012] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386025] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386038] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386050] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386062] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386082] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386096] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386109] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386120] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386132] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386151] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386164] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386177] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386189] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386201] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386213] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386225] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386237] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386249] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.386261] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.386273] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.386285] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.858828] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29316.868832] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29316.878842] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29316.925481] ata6.00: exception Emask 0x11 SAct 0xfff SErr 0x400000 action 0x6 frozen
[29316.925489] ata6.00: irq_stat 0x48000008, interface fatal error
[29316.925492] ata6: SError: { Handshk }
[29316.925496] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925498] ata6.00: cmd 61/28:00:00:54:3c/00:00:02:00:00/40 tag 0 ncq dma 20480 out
res 40/00:04:00:54:3c/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29316.925506] ata6.00: status: { DRDY }
[29316.925509] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925511] ata6.00: cmd 61/18:08:38:54:3c/00:00:02:00:00/40 tag 1 ncq dma 12288 out
[29316.925518] ata6.00: status: { DRDY }
[29316.925520] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925522] ata6.00: cmd 61/10:10:20:55:3c/00:00:02:00:00/40 tag 2 ncq dma 8192 out
[29316.925528] ata6.00: status: { DRDY }
[29316.925530] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925531] ata6.00: cmd 61/08:18:18:56:3c/00:00:02:00:00/40 tag 3 ncq dma 4096 out
[29316.925538] ata6.00: status: { DRDY }
[29316.925540] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925541] ata6.00: cmd 61/08:20:38:56:3c/00:00:02:00:00/40 tag 4 ncq dma 4096 out
[29316.925548] ata6.00: status: { DRDY }
[29316.925550] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925551] ata6.00: cmd 61/08:28:60:56:3c/00:00:02:00:00/40 tag 5 ncq dma 4096 out
[29316.925557] ata6.00: status: { DRDY }
[29316.925560] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925562] ata6.00: cmd 61/08:30:f0:56:3c/00:00:02:00:00/40 tag 6 ncq dma 4096 out
[29316.925568] ata6.00: status: { DRDY }
[29316.925569] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925571] ata6.00: cmd 61/08:38:10:57:3c/00:00:02:00:00/40 tag 7 ncq dma 4096 out
[29316.925577] ata6.00: status: { DRDY }
[29316.925579] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925580] ata6.00: cmd 61/08:40:10:59:3c/00:00:02:00:00/40 tag 8 ncq dma 4096 out
[29316.925586] ata6.00: status: { DRDY }
[29316.925588] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925590] ata6.00: cmd 61/10:48:40:5a:3c/00:00:02:00:00/40 tag 9 ncq dma 8192 out
[29316.925596] ata6.00: status: { DRDY }
[29316.925598] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925599] ata6.00: cmd 61/08:50:60:5a:3c/00:00:02:00:00/40 tag 10 ncq dma 4096 out
[29316.925606] ata6.00: status: { DRDY }
[29316.925607] ata6.00: failed command: WRITE FPDMA QUEUED
[29316.925609] ata6.00: cmd 61/08:58:88:5a:3c/00:00:02:00:00/40 tag 11 ncq dma 4096 out
[29316.925621] ata6.00: status: { DRDY }
[29316.928757] systemd-journald[351]: Failed to write entry (9 items, 290 bytes), ignoring: Read-only file system
[29316.928779] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29316.928795] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.928809] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.928825] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.928840] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.928858] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.928873] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.928886] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.928899] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.928912] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.928926] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.928938] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.928951] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.928964] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.928977] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.928990] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.929007] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929025] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929045] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.929062] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929081] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929105] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.929128] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929152] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929177] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.929200] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929224] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929249] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.929272] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929296] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929321] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29316.929345] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929370] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929396] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.929420] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929443] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29316.929468] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29316.929488] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29316.929504] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.401743] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29317.411703] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29317.421693] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29317.438296] ata6.00: exception Emask 0x11 SAct 0x80e000ff SErr 0x400000 action 0x6 frozen
[29317.438304] ata6.00: irq_stat 0x48000008, interface fatal error
[29317.438306] ata6: SError: { Handshk }
[29317.438310] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438312] ata6.00: cmd 61/08:00:10:57:3c/00:00:02:00:00/40 tag 0 ncq dma 4096 out
res 40/00:ac:88:5a:3c/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29317.438318] ata6.00: status: { DRDY }
[29317.438320] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438321] ata6.00: cmd 61/08:08:f0:56:3c/00:00:02:00:00/40 tag 1 ncq dma 4096 out
[29317.438326] ata6.00: status: { DRDY }
[29317.438328] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438329] ata6.00: cmd 61/08:10:60:56:3c/00:00:02:00:00/40 tag 2 ncq dma 4096 out
[29317.438334] ata6.00: status: { DRDY }
[29317.438335] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438336] ata6.00: cmd 61/08:18:38:56:3c/00:00:02:00:00/40 tag 3 ncq dma 4096 out
[29317.438341] ata6.00: status: { DRDY }
[29317.438343] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438344] ata6.00: cmd 61/08:20:18:56:3c/00:00:02:00:00/40 tag 4 ncq dma 4096 out
[29317.438348] ata6.00: status: { DRDY }
[29317.438350] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438351] ata6.00: cmd 61/10:28:20:55:3c/00:00:02:00:00/40 tag 5 ncq dma 8192 out
[29317.438355] ata6.00: status: { DRDY }
[29317.438357] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438358] ata6.00: cmd 61/18:30:38:54:3c/00:00:02:00:00/40 tag 6 ncq dma 12288 out
[29317.438362] ata6.00: status: { DRDY }
[29317.438364] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438365] ata6.00: cmd 61/28:38:00:54:3c/00:00:02:00:00/40 tag 7 ncq dma 20480 out
[29317.438369] ata6.00: status: { DRDY }
[29317.438371] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438372] ata6.00: cmd 61/08:a8:88:5a:3c/00:00:02:00:00/40 tag 21 ncq dma 4096 out
[29317.438376] ata6.00: status: { DRDY }
[29317.438378] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438379] ata6.00: cmd 61/08:b0:60:5a:3c/00:00:02:00:00/40 tag 22 ncq dma 4096 out
[29317.438383] ata6.00: status: { DRDY }
[29317.438384] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438385] ata6.00: cmd 61/10:b8:40:5a:3c/00:00:02:00:00/40 tag 23 ncq dma 8192 out
[29317.438390] ata6.00: status: { DRDY }
[29317.438391] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.438392] ata6.00: cmd 61/08:f8:10:59:3c/00:00:02:00:00/40 tag 31 ncq dma 4096 out
[29317.438397] ata6.00: status: { DRDY }
[29317.441685] systemd-journald[351]: Failed to write entry (9 items, 295 bytes), ignoring: Read-only file system
[29317.441725] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29317.441748] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.441769] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.441796] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.441823] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.441849] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.441869] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.441888] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.441903] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.441919] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.441934] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.441948] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.441962] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.441975] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.441989] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442003] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.442018] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442037] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442057] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.442074] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442089] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442107] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.442125] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442141] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442158] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.442176] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442191] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442208] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.442222] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442235] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442249] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.442262] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442276] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442291] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.442310] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442330] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.442349] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.442362] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.442377] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.911281] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29317.921276] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29317.931232] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29317.954687] ata6.00: exception Emask 0x11 SAct 0x7fc00007 SErr 0x400000 action 0x6 frozen
[29317.954694] ata6.00: irq_stat 0x48000008, interface fatal error
[29317.954697] ata6: SError: { Handshk }
[29317.954700] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954702] ata6.00: cmd 61/08:00:60:56:3c/00:00:02:00:00/40 tag 0 ncq dma 4096 out
res 40/00:b4:10:59:3c/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29317.954710] ata6.00: status: { DRDY }
[29317.954712] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954713] ata6.00: cmd 61/08:08:f0:56:3c/00:00:02:00:00/40 tag 1 ncq dma 4096 out
[29317.954720] ata6.00: status: { DRDY }
[29317.954722] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954723] ata6.00: cmd 61/08:10:10:57:3c/00:00:02:00:00/40 tag 2 ncq dma 4096 out
[29317.954730] ata6.00: status: { DRDY }
[29317.954732] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954733] ata6.00: cmd 61/08:b0:10:59:3c/00:00:02:00:00/40 tag 22 ncq dma 4096 out
[29317.954740] ata6.00: status: { DRDY }
[29317.954741] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954743] ata6.00: cmd 61/10:b8:40:5a:3c/00:00:02:00:00/40 tag 23 ncq dma 8192 out
[29317.954749] ata6.00: status: { DRDY }
[29317.954751] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954752] ata6.00: cmd 61/08:c0:60:5a:3c/00:00:02:00:00/40 tag 24 ncq dma 4096 out
[29317.954758] ata6.00: status: { DRDY }
[29317.954759] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954761] ata6.00: cmd 61/08:c8:88:5a:3c/00:00:02:00:00/40 tag 25 ncq dma 4096 out
[29317.954767] ata6.00: status: { DRDY }
[29317.954769] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954770] ata6.00: cmd 61/28:d0:00:54:3c/00:00:02:00:00/40 tag 26 ncq dma 20480 out
[29317.954776] ata6.00: status: { DRDY }
[29317.954778] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954779] ata6.00: cmd 61/18:d8:38:54:3c/00:00:02:00:00/40 tag 27 ncq dma 12288 out
[29317.954784] ata6.00: status: { DRDY }
[29317.954786] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954787] ata6.00: cmd 61/10:e0:20:55:3c/00:00:02:00:00/40 tag 28 ncq dma 8192 out
[29317.954792] ata6.00: status: { DRDY }
[29317.954794] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954795] ata6.00: cmd 61/08:e8:18:56:3c/00:00:02:00:00/40 tag 29 ncq dma 4096 out
[29317.954801] ata6.00: status: { DRDY }
[29317.954803] ata6.00: failed command: WRITE FPDMA QUEUED
[29317.954804] ata6.00: cmd 61/08:f0:38:56:3c/00:00:02:00:00/40 tag 30 ncq dma 4096 out
[29317.954809] ata6.00: status: { DRDY }
[29317.957887] systemd-journald[351]: Failed to write entry (9 items, 295 bytes), ignoring: Read-only file system
[29317.957907] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29317.957921] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.957935] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.957948] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.957958] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.957969] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.957980] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.957990] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958000] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958011] systemd-journald[351]: Failed to write entry (9 items, 365 bytes), ignoring: Read-only file system
[29317.958021] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958031] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958042] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958052] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958063] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958074] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958084] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958094] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958105] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958116] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958125] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958137] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958147] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958157] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958168] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29317.958179] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958189] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958200] systemd-journald[351]: Failed to write entry (9 items, 367 bytes), ignoring: Read-only file system
[29317.958211] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958221] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958232] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958242] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958252] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958264] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958275] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958287] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29317.958300] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29317.958313] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29317.958326] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29318.019132] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[29318.427496] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29318.437498] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29318.447486] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29318.479131] ata6.00: exception Emask 0x11 SAct 0x800 SErr 0x400000 action 0x6 frozen
[29318.479139] ata6.00: irq_stat 0x48000008, interface fatal error
[29318.479141] ata6: SError: { Handshk }
[29318.479145] ata6.00: failed command: WRITE FPDMA QUEUED
[29318.479146] ata6.00: cmd 61/08:58:b0:5a:3c/00:00:02:00:00/40 tag 11 ncq dma 4096 out
res 40/00:5c:b0:5a:3c/00:00:02:00:00/40 Emask 0x10 (ATA bus error)
[29318.479153] ata6.00: status: { DRDY }
[29318.480808] systemd-journald[351]: Failed to write entry (9 items, 290 bytes), ignoring: Read-only file system
[29318.480828] systemd-journald[351]: Failed to write entry (9 items, 269 bytes), ignoring: Read-only file system
[29318.480841] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29318.480853] systemd-journald[351]: Failed to write entry (9 items, 261 bytes), ignoring: Read-only file system
[29318.480871] systemd-journald[351]: Failed to write entry (9 items, 366 bytes), ignoring: Read-only file system
[29318.480888] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29318.480903] systemd-journald[351]: Failed to write entry (9 items, 243 bytes), ignoring: Read-only file system
[29318.953754] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29318.963695] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29318.973694] systemd-journald[351]: Failed to write entry (9 items, 235 bytes), ignoring: Read-only file system
[29364.677988] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29364.677996] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29364.679795] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29369.465829] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.465837] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.467378] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29369.467666] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.467672] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.469085] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29369.469303] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.469310] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.470718] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29369.470968] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.470974] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.472357] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29369.472582] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.472588] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.474017] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29369.474267] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.474273] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.475667] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[29369.475888] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.475894] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.477301] systemd-journald[351]: Failed to write entry (28 items, 807 bytes) despite vacuuming, ignoring: Bad message
[29369.477626] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.477633] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.479192] systemd-journald[351]: Failed to write entry (28 items, 806 bytes) despite vacuuming, ignoring: Bad message
[29369.479427] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.479432] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.480670] systemd-journald[351]: Failed to write entry (28 items, 815 bytes) despite vacuuming, ignoring: Bad message
[29369.480926] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29369.480931] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29369.482208] systemd-journald[351]: Failed to write entry (28 items, 805 bytes) despite vacuuming, ignoring: Bad message
[29408.207420] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[29408.207476] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[29408.208762] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[29408.208797] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[29408.209019] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[29408.209198] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29408.209365] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[29408.457165] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[29408.457238] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[29408.457284] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[29408.457304] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29408.458866] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[29408.459249] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29408.459268] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29408.541663] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[29440.775201] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29440.775211] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29440.777122] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29445.493775] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29445.493783] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29445.495487] systemd-journald[351]: Failed to write entry (28 items, 804 bytes) despite vacuuming, ignoring: Bad message
[29461.823750] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29461.823761] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29461.825398] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29466.377364] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29466.377376] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29466.379079] systemd-journald[351]: Failed to write entry (28 items, 804 bytes) despite vacuuming, ignoring: Bad message
[29479.502989] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29479.502997] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29479.504619] systemd-journald[351]: Failed to write entry (28 items, 706 bytes) despite vacuuming, ignoring: Bad message
[29495.668716] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29495.668724] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29495.670546] systemd-journald[351]: Failed to write entry (28 items, 719 bytes) despite vacuuming, ignoring: Bad message
[29498.638264] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[29507.061171] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29507.061180] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29507.063149] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29511.739924] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29511.739931] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29511.741204] systemd-journald[351]: Failed to write entry (28 items, 804 bytes) despite vacuuming, ignoring: Bad message
[29588.788328] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[29588.788369] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[29588.789974] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[29588.790006] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[29588.790254] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[29588.790461] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29588.793740] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[29589.038287] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[29589.038425] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[29589.038467] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[29589.038488] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29589.040092] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[29589.040160] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29589.040185] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29589.055450] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[29598.412722] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29598.412738] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29598.414854] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29657.457182] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29657.457191] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29657.458946] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29657.459254] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29657.459260] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29657.460691] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29657.460920] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29657.460926] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29657.462226] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29679.229804] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[29681.677214] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[29681.687179] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[29703.330087] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29703.330095] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29703.331881] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29703.332260] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29703.332267] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29703.333761] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29769.396843] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[29769.396885] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[29769.398422] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[29769.398459] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[29769.398762] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[29769.398963] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[29769.399023] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29769.646717] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[29769.646819] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[29769.646866] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[29769.646893] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29769.648766] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29769.648785] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29769.648838] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[29769.662556] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[29776.438365] systemd-journald[351]: Failed to write entry (24 items, 735 bytes), ignoring: Read-only file system
[29776.438392] systemd-journald[351]: Failed to write entry (24 items, 725 bytes), ignoring: Read-only file system
[29776.438657] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29776.438664] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29776.440559] systemd-journald[351]: Failed to write entry (26 items, 802 bytes) despite vacuuming, ignoring: Bad message
[29776.440601] systemd-journald[351]: Failed to write entry (9 items, 438 bytes), ignoring: Read-only file system
[29776.440617] systemd-journald[351]: Failed to write entry (9 items, 432 bytes), ignoring: Read-only file system
[29833.715906] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29833.715913] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29833.717494] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29838.001805] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29838.001813] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29838.003658] systemd-journald[351]: Failed to write entry (28 items, 804 bytes) despite vacuuming, ignoring: Bad message
[29847.261398] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29847.261407] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29847.263118] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29859.808501] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[29873.566567] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29873.566575] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29873.568395] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29873.568695] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29873.568701] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29873.570126] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29904.221151] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29904.221161] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29904.222996] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[29908.566567] systemd-journald[351]: Failed to write entry (28 items, 803 bytes), ignoring: Cannot assign requested address
[29914.387307] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29914.387314] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29914.388787] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29914.389046] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29914.389051] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29914.390220] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29914.390405] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[29914.390410] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[29914.391556] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[29950.003060] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[29950.003105] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[29950.005199] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[29950.005241] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[29950.005270] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[29950.005420] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29950.008371] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[29950.253060] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[29950.253225] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[29950.253254] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[29950.253290] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[29950.254686] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[29950.254845] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29950.254876] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[29950.270019] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[30040.409291] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[30052.213792] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30052.213803] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30052.215598] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[30056.519244] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.519251] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.521253] systemd-journald[351]: Failed to write entry (28 items, 809 bytes) despite vacuuming, ignoring: Bad message
[30056.521640] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.521649] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.523667] systemd-journald[351]: Failed to write entry (28 items, 809 bytes) despite vacuuming, ignoring: Bad message
[30056.524044] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.524053] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.526078] systemd-journald[351]: Failed to write entry (28 items, 809 bytes) despite vacuuming, ignoring: Bad message
[30056.526470] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.526479] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.528459] systemd-journald[351]: Failed to write entry (28 items, 809 bytes) despite vacuuming, ignoring: Bad message
[30056.528782] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.528789] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.530280] systemd-journald[351]: Failed to write entry (28 items, 809 bytes) despite vacuuming, ignoring: Bad message
[30056.530526] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.530532] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.532050] systemd-journald[351]: Failed to write entry (28 items, 809 bytes) despite vacuuming, ignoring: Bad message
[30056.532319] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.532327] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.534200] systemd-journald[351]: Failed to write entry (28 items, 808 bytes) despite vacuuming, ignoring: Bad message
[30056.534640] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.534648] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.536503] systemd-journald[351]: Failed to write entry (28 items, 807 bytes) despite vacuuming, ignoring: Bad message
[30056.536817] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.536824] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.538694] systemd-journald[351]: Failed to write entry (28 items, 816 bytes) despite vacuuming, ignoring: Bad message
[30056.539075] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30056.539084] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30056.541588] systemd-journald[351]: Failed to write entry (28 items, 806 bytes) despite vacuuming, ignoring: Bad message
[30130.579613] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[30130.579649] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[30130.581065] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[30130.581106] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[30130.581349] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[30130.581520] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[30130.581628] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[30130.829618] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[30130.829718] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[30130.829759] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[30130.829777] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[30130.831207] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[30130.831461] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[30130.831481] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[30130.846900] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[30164.244093] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30164.244100] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30164.245635] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[30164.245872] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30164.245879] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30164.247343] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[30164.247619] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30164.247626] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30164.248959] systemd-journald[351]: Failed to write entry (28 items, 718 bytes) despite vacuuming, ignoring: Bad message
[30190.704861] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[30190.714839] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[30221.026045] systemd-journald[351]: Failed to write entry (25 items, 599 bytes), ignoring: Read-only file system
[30223.586680] systemd-journald[351]: Failed to write entry (9 items, 272 bytes), ignoring: Read-only file system
[30223.596670] systemd-journald[351]: Failed to write entry (9 items, 249 bytes), ignoring: Read-only file system
[30311.173875] systemd-journald[351]: Failed to write entry (25 items, 600 bytes), ignoring: Read-only file system
[30311.173906] systemd-journald[351]: Failed to write entry (25 items, 593 bytes), ignoring: Read-only file system
[30311.175212] systemd-journald[351]: Failed to write entry (29 items, 692 bytes), ignoring: Read-only file system
[30311.175237] systemd-journald[351]: Failed to write entry (27 items, 642 bytes), ignoring: Read-only file system
[30311.175512] systemd-journald[351]: Failed to write entry (29 items, 653 bytes), ignoring: Read-only file system
[30311.175768] systemd-journald[351]: Failed to write entry (9 items, 424 bytes), ignoring: Read-only file system
[30311.175820] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[30311.423635] systemd-journald[351]: Failed to write entry (27 items, 665 bytes), ignoring: Read-only file system
[30311.423743] systemd-journald[351]: Failed to write entry (29 items, 645 bytes), ignoring: Read-only file system
[30311.423781] systemd-journald[351]: Failed to write entry (23 items, 708 bytes), ignoring: Read-only file system
[30311.423803] systemd-journald[351]: Failed to write entry (23 items, 706 bytes), ignoring: Read-only file system
[30311.425231] systemd-journald[351]: Failed to write entry (28 items, 632 bytes), ignoring: Read-only file system
[30311.425444] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[30311.425460] systemd-journald[351]: Failed to write entry (9 items, 425 bytes), ignoring: Read-only file system
[30311.445872] systemd-journald[351]: Failed to write entry (20 items, 574 bytes), ignoring: Read-only file system
[30321.724214] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30321.724222] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30321.726087] systemd-journald[351]: Failed to write entry (28 items, 821 bytes) despite vacuuming, ignoring: Bad message
[30321.756176] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30321.756184] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30321.757872] systemd-journald[351]: Failed to write entry (28 items, 923 bytes) despite vacuuming, ignoring: Bad message
[30326.087844] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30326.087856] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30326.089896] systemd-journald[351]: Failed to write entry (28 items, 804 bytes) despite vacuuming, ignoring: Bad message
[30355.624063] systemd-journald[351]: Failed to write entry (24 items, 797 bytes), ignoring: Read-only file system
[30355.625182] systemd-journald[351]: Failed to write entry (22 items, 809 bytes), ignoring: Read-only file system
[30355.625416] systemd-journald[351]: Failed to write entry (9 items, 468 bytes), ignoring: Read-only file system
[30355.625509] systemd-journald[351]: Failed to write entry (22 items, 760 bytes), ignoring: Read-only file system
[30355.625960] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30355.625968] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30355.627549] systemd-journald[351]: Failed to write entry (26 items, 895 bytes) despite vacuuming, ignoring: Bad message
[30355.627602] systemd-journald[351]: Failed to write entry (24 items, 773 bytes), ignoring: Read-only file system
[30355.627625] systemd-journald[351]: Failed to write entry (24 items, 785 bytes), ignoring: Read-only file system
[30355.627646] systemd-journald[351]: Failed to write entry (24 items, 785 bytes), ignoring: Read-only file system
[30355.627905] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30355.627912] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30355.629448] systemd-journald[351]: Failed to write entry (26 items, 860 bytes) despite vacuuming, ignoring: Bad message
[30355.629508] systemd-journald[351]: Failed to write entry (9 items, 456 bytes), ignoring: Read-only file system
[30355.629523] systemd-journald[351]: Failed to write entry (9 items, 462 bytes), ignoring: Read-only file system
[30355.629537] systemd-journald[351]: Failed to write entry (9 items, 461 bytes), ignoring: Read-only file system
[30355.630008] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/system.journal: Read-only fm
[30355.630015] systemd-journald[351]: Failed to rotate /var/log/journal/b45dd0ca12de410987e312d208af63e4/user-1000.journal: Read-onlm
[30355.631830] systemd-journald[351]: Failed to write entry (26 items, 851 bytes) despite vacuuming, ignoring: Bad message
β””[~]> sudo smartctl -t long /dev/sdb2
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.13.19-2-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 10 minutes for test to complete.
Test will complete after Sat Nov  6 16:43:48 2021 MSK
Use smartctl -X to abort test.
I will wait
You should keep that as is
because in /etc/mkinitcpio.conf you should have something like this:
HOOKS="base udev autodetect modconf block keyboard keymap consolefont encrypt filesystems fsck"
so fsck is there by default
but then in fstab you have:
and you should have it as
/ ext4 defaults,noatime 0 1
But then you have this
Check the cable for that SSD
maybe you need to make use of libata.force=noncq
but this
is a sign of hardware failure …
So far it looks like some defective ssd as said above or maybe even the SATA cable that is connected with, maybe even port on the motherboard etc…
After that smartctl test ends I would for sure try to make sure the cables are connected properly and stuff
If you will keep having problems after checking the cables and such are okay the ssd is very likely dead
Edit:
As last resort you could wipe the disk clean someway lol
i have it bc someone it chat say that i must add β€œrw”
where i must add " libata.force=noncq"?
