provide FORMATTED output from: mhwd -l && mhwd -li find /etc/X11/ -name "*.conf"
try switching kernels
and when it happens again enter into tty: ctrl+alt+f2 or f1-f6, enter your username/password, and type: startx
if it doesnt work it creates a log in your home directory and post FORMATTED output from that log
the output looks ok…
so switch kernels - 5.18, 5.10 and try with them, try first with the 5.18, if it happens again try with the 5.10, if it also happens with it, hard reboot, and provide logs from the failed boot with: journalctl -b-1 -p4 --no-pager
I’ve changed kernel to 5.10, because 5.18 broke my multimedia keys
июл 23 16:44:51 hp kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
июл 23 16:44:51 hp kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
июл 23 16:44:51 hp kernel: #5 #6 #7
июл 23 16:44:51 hp kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
июл 23 16:44:51 hp kernel: [Firmware Bug]: Invalid critical threshold (0)
июл 23 16:44:51 hp kernel: hpet_acpi_add: no address or irqs in _CRS
июл 23 16:44:51 hp kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
июл 23 16:44:51 hp kernel: usb: port power management may be unreliable
июл 23 16:44:51 hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20200925/psargs-330)
июл 23 16:44:51 hp kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
июл 23 16:44:51 hp kernel: wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
июл 23 16:44:51 hp kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
июл 23 16:44:51 hp kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
июл 23 16:44:51 hp kernel: wmi_bus wmi_bus-PNP0C14:05: WQBJ data block query control method not found
июл 23 16:44:52 hp kernel: i2c_hid i2c-ELAN0710:01: supply vdd not found, using dummy regulator
июл 23 16:44:52 hp kernel: i2c_hid i2c-ELAN0710:01: supply vddl not found, using dummy regulator
июл 23 16:44:52 hp kernel: r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
июл 23 16:44:52 hp kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
июл 23 16:44:52 hp kernel: nvidia: loading out-of-tree module taints kernel.
июл 23 16:44:52 hp kernel: nvidia: module license 'NVIDIA' taints kernel.
июл 23 16:44:52 hp kernel: Disabling lock debugging due to kernel taint
июл 23 16:44:52 hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.57 Wed Jun 22 22:44:07 UTC 2022
июл 23 16:44:52 hp kernel: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
июл 23 16:44:52 hp kernel: thermal thermal_zone9: failed to read out thermal zone (-61)
июл 23 16:44:53 hp kernel: hp_wmi: query 0x4c returned error 0x6
июл 23 16:44:54 hp kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
июл 23 16:44:57 hp kernel: kauditd_printk_skb: 26 callbacks suppressed
июл 23 16:45:24 hp kernel: ACPI Error: Aborting method \_SB.PCI0.RTEN due to previous error (AE_AML_LOOP_TIMEOUT) (20200925/psparse-529)
июл 23 16:45:24 hp kernel: ACPI Error: Aborting method \_SB.PCI0.PGON due to previous error (AE_AML_LOOP_TIMEOUT) (20200925/psparse-529)
июл 23 16:45:24 hp kernel: ACPI Error: Aborting method \_SB.PCI0.PEG0.PG00._ON due to previous error (AE_AML_LOOP_TIMEOUT) (20200925/psparse-529)
июл 23 16:45:24 hp kernel: acpi device:00: Failed to change power state to D0
июл 23 16:45:25 hp kernel: video LNXVIDEO:00: Cannot transition to power state D0 for parent in (unknown)
июл 23 16:45:25 hp kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
июл 23 16:45:26 hp kernel: snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
I reload my leptop about 20 times in a row and it happens again.
open this file: kate /etc/default/grub
and in this line GRUB_CMDLINE_LINUX_DEFAULT inside the quotes"" add this parameter: pcie_aspm=off
add it to existing ones, dont remove anything from there, then save the file and run this: sudo update-grub
reboot and test
июл 23 17:02:20 hp kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
июл 23 17:02:20 hp kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
июл 23 17:02:20 hp kernel: #5 #6 #7
июл 23 17:02:20 hp kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
июл 23 17:02:20 hp kernel: [Firmware Bug]: Invalid critical threshold (0)
июл 23 17:02:20 hp kernel: hpet_acpi_add: no address or irqs in _CRS
июл 23 17:02:20 hp kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
июл 23 17:02:20 hp kernel: usb: port power management may be unreliable
июл 23 17:02:20 hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20200925/psargs-330)
июл 23 17:02:20 hp kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
июл 23 17:02:20 hp kernel: wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
июл 23 17:02:20 hp kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
июл 23 17:02:20 hp kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
июл 23 17:02:20 hp kernel: wmi_bus wmi_bus-PNP0C14:05: WQBJ data block query control method not found
июл 23 17:02:20 hp kernel: i2c_hid i2c-ELAN0710:01: supply vdd not found, using dummy regulator
июл 23 17:02:20 hp kernel: i2c_hid i2c-ELAN0710:01: supply vddl not found, using dummy regulator
июл 23 17:02:21 hp kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
июл 23 17:02:21 hp kernel: nvidia: loading out-of-tree module taints kernel.
июл 23 17:02:21 hp kernel: nvidia: module license 'NVIDIA' taints kernel.
июл 23 17:02:21 hp kernel: Disabling lock debugging due to kernel taint
июл 23 17:02:21 hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.57 Wed Jun 22 22:44:07 UTC 2022
июл 23 17:02:21 hp kernel: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
июл 23 17:02:21 hp kernel: thermal thermal_zone9: failed to read out thermal zone (-61)
июл 23 17:02:22 hp kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
июл 23 17:02:22 hp kernel: hp_wmi: query 0x4c returned error 0x6
июл 23 17:02:26 hp kernel: kauditd_printk_skb: 26 callbacks suppressed
This time it hangs up after “Started Hostname Service”, it thinking about 10 seconds then die
