Hello, just installed manjaro on my new laptop, in dual-boot with windows 10 on the same SSD. Half the times i try to login it freezes on the login page and responds to nothing. Sometimes i have to hard shut down and sometimes it shuts down itself after 1-2 minutes. I have seen a lot of similar threads but none of them helped me.
Here is info about my system:
inxi -Fxz ✔ 8s
System: Kernel: 5.15.2-1-rt19-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.23.3
Machine: Type: Laptop System: Dell product: Inspiron 5593 v: N/A serial: <superuser required>
Mobo: Dell model: 0HFDR0 v: A00 serial: <superuser required> UEFI: Dell v: 1.18.0 date: 10/06/2021
Battery: ID-1: BAT0 charge: 23.3 Wh (66.2%) condition: 35.2/42.0 Wh (83.8%) volts: 11.8 min: 11.4
model: LGC-LGC3.65 DELL FDRHM05 status: Discharging
CPU: Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache: L2: 2 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23961
Speed: 1235 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1199 2: 1252 3: 1211 4: 1208 5: 1172 6: 1296 7: 1197
8: 1264
Graphics: Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-6:4
Display: x11 server: X.Org 1.21.1.1 driver: loaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.2-1-rt19-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
bus-ID: 02:00.0
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 16.7 GiB (3.5%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB temp: 27.9 C
Partition: ID-1: / size: 117.07 GiB used: 16.7 GiB (14.3%) fs: ext4 dev: /dev/nvme0n1p9
ID-2: /boot/efi size: 511 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p8
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p7
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 288 Uptime: 1h 17m Memory: 15.41 GiB used: 2.43 GiB (15.8%) Init: systemd Compilers: gcc: 11.1.0
Packages: 1236 Shell: Zsh v: 5.8 inxi: 3.3.09
Also i saw the logs after a successful login, there seems to be a problem with resolving host api.snapcraft.io:
journalctl --boot -1 --no-pager | grep error ✔
Δεκ 02 22:45:33 manjaro kernel: pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Δεκ 02 22:45:33 manjaro kernel: pcieport 0000:00:1d.4: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Δεκ 02 22:45:34 manjaro snapd[399]: stateengine.go:149: state ensure error: Get "https://api.snapcraft.io/api/v1/snaps/sections": dial tcp: lookup api.snapcraft.io: no such host
Same problem apperars sometimes even when i boot from usb.
When system freezes the caps-lock led starts blinking, which i read is a sign of kernel panic.
If i complete a successful login everything works fine.
Can anyone help?
UPDATE: After i tested the behavior out a bit more i found out that it freezes 100% of the times if i wait a bit more. What i mean is that the freezing will always happen somewhere after grub and before logging in. So if i don’t login fast enough it will freeze 100% of the times.
Also if i put my computer to sleep i can never return cause after sleep it returns to a black screen with the cursor somewhere on it, but you cannot move the cursor and it does not respond to anything.
I tried kernels 5.13 and 5.10 but nothing changed. Then i tried kernel 5.4 with which the freeze on startup seems to be resolved, but not the freeze after sleep.
