System monitor sensor widget - very small font size
I mean that before the update this morning, the text of the widget was at scale with the height of the panel, and now it’s very small, too small for my eyes at least.
This is what is reported in the summary of the issue 488816 – On a horizontal panel, "Text Only" system monitor sensor widgets have dramatically reduced text size compared to 6.0, and are top-aligned
I see - never doubted you have an issue - I have just struggled to understand :t_rex:
I could be that it is just one of those improvements the plasma devs cannot live without :slight_smile:
I literally cannot live without those text widgets :slight_smile:
I find it more suitable than conkys, because it’s there in the panel, always visible.
