Hello!
My Manjaro keeps logging out and I’m not sure why. It always happens when downloading updates with pacman while keeping Firefox open, or minutes after starting PyCharm.
Adding /var/log/Xorg.0.log.old:
[ 41.925]
X.Org X Server 1.21.1.4
[ 41.925] Current Operating System: Linux SHARKBAIT 5.10.133-1-MANJARO #1 SMP PREEMPT Mon Jul 25 20:12:34 UTC 2022 x86_64
[ 41.925] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=5cb7906f-8fbb-4888-b646-123ea5c489e9 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 41.926]
[ 41.926] Current version of pixman: 0.40.0
[ 41.926] Before reporting problems, check http://wiki.x.org
[ 41.926] Markers: (--) probed, (**) from config file, (==) default setting,
[ 41.926] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul 29 15:40:38 2022
[ 42.184] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 42.184] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 42.365] (==) No Layout section. Using the first Screen section.
[ 42.365] (==) No screen section available. Using defaults.
[ 42.365] (**) |-->Screen "Default Screen Section" (0)
[ 42.365] (**) | |-->Monitor "<default monitor>"
[ 42.366] (==) No monitor specified for screen "Default Screen Section".
[ 42.366] (==) Automatically adding devices
[ 42.366] (==) Automatically enabling devices
[ 42.366] (==) Automatically adding GPU devices
[ 42.366] (==) Automatically binding GPU devices
[ 42.366] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 42.563] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 42.563] Entry deleted from font path.
[ 42.563] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 42.563] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 42.563] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 42.563] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 42.563] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 42.563] (II) The server relies on udev to provide the list of input devices.
[ 42.563] (II) Module ABI versions:
[ 42.563] X.Org ANSI C Emulation: 0.4
[ 42.563] X.Org Video Driver: 25.2
[ 42.563] X.Org XInput driver : 24.4
[ 42.563] X.Org Server Extension : 10.0
[ 42.565] (++) using VT number 7
[ 42.565] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 42.567] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 42.567] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 42.583] (--) PCI:*(0@0:2:0) 8086:0166:17aa:3977 rev 9, Mem @ 0xe0000000/4194304, 0xd0000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 42.583] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 42.583] (II) LoadModule: "glx"
[ 42.717] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 43.013] (II) Module glx: vendor="X.Org Foundation"
[ 43.013] compiled for 1.21.1.4, module version = 1.0.0
[ 43.013] ABI class: X.Org Server Extension, version 10.0
[ 43.013] (==) Matched modesetting as autoconfigured driver 0
[ 43.013] (==) Matched fbdev as autoconfigured driver 1
[ 43.013] (==) Matched vesa as autoconfigured driver 2
[ 43.013] (==) Assigned the driver to the xf86ConfigLayout
[ 43.013] (II) LoadModule: "modesetting"
[ 43.013] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 43.082] (II) Module modesetting: vendor="X.Org Foundation"
[ 43.082] compiled for 1.21.1.4, module version = 1.21.1
[ 43.082] Module class: X.Org Video Driver
[ 43.082] ABI class: X.Org Video Driver, version 25.2
[ 43.083] (II) LoadModule: "fbdev"
[ 43.107] (WW) Warning, couldn't open module fbdev
[ 43.107] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 43.107] (II) LoadModule: "vesa"
[ 43.107] (WW) Warning, couldn't open module vesa
[ 43.107] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 43.107] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 43.127] (II) modeset(0): using drv /dev/dri/card0
[ 43.127] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 43.127] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 43.127] (==) modeset(0): RGB weight 888
[ 43.127] (==) modeset(0): Default visual is TrueColor
[ 43.127] (II) Loading sub module "glamoregl"
[ 43.127] (II) LoadModule: "glamoregl"
[ 43.127] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 43.210] (II) Module glamoregl: vendor="X.Org Foundation"
[ 43.210] compiled for 1.21.1.4, module version = 1.0.1
[ 43.210] ABI class: X.Org ANSI C Emulation, version 0.4
[ 53.846] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 4000 (IVB GT2)
[ 53.846] (II) modeset(0): glamor initialized
[ 53.846] (==) modeset(0): VariableRefresh: disabled
[ 53.846] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 53.847] (II) modeset(0): Output LVDS-1 has no monitor section
[ 53.848] (II) modeset(0): Output VGA-1 has no monitor section
[ 53.850] (II) modeset(0): Output HDMI-1 has no monitor section
[ 53.850] (II) modeset(0): Output DP-1 has no monitor section
[ 53.851] (II) modeset(0): EDID for output LVDS-1
[ 53.851] (II) modeset(0): Manufacturer: BOE Model: 5b1 Serial#: 0
[ 53.851] (II) modeset(0): Year: 2011 Week: 1
[ 53.851] (II) modeset(0): EDID Version: 1.3
[ 53.851] (II) modeset(0): Digital Display Input
[ 53.851] (II) modeset(0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 53.851] (II) modeset(0): Gamma: 2.20
[ 53.851] (II) modeset(0): No DPMS capabilities specified
[ 53.851] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 53.851] (II) modeset(0): First detailed timing is preferred mode
[ 53.851] (II) modeset(0): redX: 0.592 redY: 0.347 greenX: 0.328 greenY: 0.570
[ 53.851] (II) modeset(0): blueX: 0.150 blueY: 0.114 whiteX: 0.312 whiteY: 0.328
[ 53.851] (II) modeset(0): Manufacturer's mask: 0
[ 53.851] (II) modeset(0): Supported detailed timing:
[ 53.851] (II) modeset(0): clock: 67.5 MHz Image Size: 309 x 173 mm
[ 53.851] (II) modeset(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1446 h_border: 0
[ 53.851] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 778 v_border: 0
[ 53.851] (II) modeset(0): BOE HF
[ 53.851] (II) modeset(0): HB140WX1-100
[ 53.851] (II) modeset(0): EDID (in hex):
[ 53.851] (II) modeset(0): 00ffffffffffff0009e5b10500000000
[ 53.851] (II) modeset(0): 01150103801f11780ab0909758549226
[ 53.851] (II) modeset(0): 1d505400000001010101010101010101
[ 53.851] (II) modeset(0): 0101010101015e1a565050000a303020
[ 53.851] (II) modeset(0): 360035ad1000001a5e1a565050000a30
[ 53.851] (II) modeset(0): 3020360035ad1000001a000000fe0042
[ 53.851] (II) modeset(0): 4f452048460a202020202020000000fe
[ 53.851] (II) modeset(0): 0048423134305758312d3130300a0085
[ 53.852] (II) modeset(0): Printing probed modes for output LVDS-1
[ 53.852] (II) modeset(0): Modeline "1366x768"x60.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 53.852] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 53.852] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 53.852] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 53.852] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 53.852] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 53.852] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 53.852] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 53.852] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 53.852] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 53.852] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 53.852] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 53.852] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 53.852] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 53.852] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 53.852] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 53.852] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 53.852] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 53.852] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 53.852] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 53.852] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 53.852] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 53.852] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 53.852] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 53.853] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 53.853] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 53.853] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 53.853] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 53.853] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 53.853] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 53.853] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 53.853] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 53.853] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 53.853] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 53.853] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 53.853] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 53.853] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 53.853] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 53.853] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 53.853] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 53.853] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 53.853] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 53.853] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 53.853] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 53.853] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 53.854] (II) modeset(0): EDID for output VGA-1
[ 53.856] (II) modeset(0): EDID for output HDMI-1
[ 53.856] (II) modeset(0): EDID for output DP-1
[ 53.856] (II) modeset(0): Output LVDS-1 connected
[ 53.856] (II) modeset(0): Output VGA-1 disconnected
[ 53.856] (II) modeset(0): Output HDMI-1 disconnected
[ 53.856] (II) modeset(0): Output DP-1 disconnected
[ 53.856] (II) modeset(0): Using exact sizes for initial modes
[ 53.856] (II) modeset(0): Output LVDS-1 using initial mode 1366x768 +0+0
[ 53.856] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 53.856] (==) modeset(0): DPI set to (96, 96)
[ 53.856] (II) Loading sub module "fb"
[ 53.856] (II) LoadModule: "fb"
[ 53.856] (II) Module "fb" already built-in
[ 54.469] (==) modeset(0): Backing store enabled
[ 54.469] (==) modeset(0): Silken mouse enabled
[ 54.511] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 54.511] (==) modeset(0): DPMS enabled
[ 54.511] (II) modeset(0): [DRI2] Setup complete
[ 54.511] (II) modeset(0): [DRI2] DRI driver: crocus
[ 54.511] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 54.511] (II) Initializing extension Generic Event Extension
[ 54.512] (II) Initializing extension SHAPE
[ 54.512] (II) Initializing extension MIT-SHM
[ 54.512] (II) Initializing extension XInputExtension
[ 54.512] (II) Initializing extension XTEST
[ 54.513] (II) Initializing extension BIG-REQUESTS
[ 54.513] (II) Initializing extension SYNC
[ 54.513] (II) Initializing extension XKEYBOARD
[ 54.514] (II) Initializing extension XC-MISC
[ 54.514] (II) Initializing extension SECURITY
[ 54.514] (II) Initializing extension XFIXES
[ 54.514] (II) Initializing extension RENDER
[ 54.514] (II) Initializing extension RANDR
[ 54.515] (II) Initializing extension COMPOSITE
[ 54.515] (II) Initializing extension DAMAGE
[ 54.515] (II) Initializing extension MIT-SCREEN-SAVER
[ 54.516] (II) Initializing extension DOUBLE-BUFFER
[ 54.516] (II) Initializing extension RECORD
[ 54.516] (II) Initializing extension DPMS
[ 54.516] (II) Initializing extension Present
[ 54.517] (II) Initializing extension DRI3
[ 54.517] (II) Initializing extension X-Resource
[ 54.517] (II) Initializing extension XVideo
[ 54.517] (II) Initializing extension XVideo-MotionCompensation
[ 54.517] (II) Initializing extension GLX
[ 54.525] (II) AIGLX: Loaded and initialized crocus
[ 54.525] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 54.525] (II) Initializing extension XFree86-VidModeExtension
[ 54.525] (II) Initializing extension XFree86-DGA
[ 54.525] (II) Initializing extension XFree86-DRI
[ 54.525] (II) Initializing extension DRI2
[ 54.526] (II) modeset(0): Damage tracking initialized
[ 54.526] (II) modeset(0): Setting screen physical size to 361 x 203
[ 55.046] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 55.046] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 55.046] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 55.046] (**) Power Button: Applying InputClass "system-keyboard"
[ 55.046] (II) LoadModule: "libinput"
[ 55.046] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 55.092] (II) Module libinput: vendor="X.Org Foundation"
[ 55.092] compiled for 1.21.1.3, module version = 1.2.1
[ 55.092] Module class: X.Org XInput Driver
[ 55.092] ABI class: X.Org XInput driver, version 24.4
[ 55.092] (II) Using input driver 'libinput' for 'Power Button'
[ 55.092] (**) Power Button: always reports core events
[ 55.092] (**) Option "Device" "/dev/input/event3"
[ 55.242] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 55.242] (II) event3 - Power Button: device is a keyboard
[ 55.242] (II) event3 - Power Button: device removed
[ 55.253] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 55.253] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 55.253] (**) Option "xkb_layout" "latam"
[ 55.253] (**) Option "xkb_variant" "deadtilde"
[ 55.322] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 55.322] (II) event3 - Power Button: device is a keyboard
[ 55.324] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 55.324] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 55.324] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 55.324] (**) Video Bus: Applying InputClass "system-keyboard"
[ 55.324] (II) Using input driver 'libinput' for 'Video Bus'
[ 55.324] (**) Video Bus: always reports core events
[ 55.324] (**) Option "Device" "/dev/input/event7"
[ 55.326] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 55.326] (II) event7 - Video Bus: device is a keyboard
[ 55.326] (II) event7 - Video Bus: device removed
[ 55.380] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:02/input/input9/event7"
[ 55.380] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 55.380] (**) Option "xkb_layout" "latam"
[ 55.380] (**) Option "xkb_variant" "deadtilde"
[ 55.383] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 55.383] (II) event7 - Video Bus: device is a keyboard
[ 55.385] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 55.385] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 55.385] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 55.385] (**) Power Button: Applying InputClass "system-keyboard"
[ 55.385] (II) Using input driver 'libinput' for 'Power Button'
[ 55.385] (**) Power Button: always reports core events
[ 55.385] (**) Option "Device" "/dev/input/event0"
[ 55.387] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 55.387] (II) event0 - Power Button: device is a keyboard
[ 55.388] (II) event0 - Power Button: device removed
[ 55.440] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input0/event0"
[ 55.440] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 55.440] (**) Option "xkb_layout" "latam"
[ 55.440] (**) Option "xkb_variant" "deadtilde"
[ 55.443] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 55.443] (II) event0 - Power Button: device is a keyboard
[ 55.444] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 55.444] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 55.444] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 55.444] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 55.444] (II) Using input driver 'libinput' for 'Sleep Button'
[ 55.444] (**) Sleep Button: always reports core events
[ 55.444] (**) Option "Device" "/dev/input/event1"
[ 55.445] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 55.445] (II) event1 - Sleep Button: device is a keyboard
[ 55.446] (II) event1 - Sleep Button: device removed
[ 55.463] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input1/event1"
[ 55.463] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 55.463] (**) Option "xkb_layout" "latam"
[ 55.463] (**) Option "xkb_variant" "deadtilde"
[ 55.466] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 55.467] (II) event1 - Sleep Button: device is a keyboard
[ 55.468] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 55.468] (II) No input driver specified, ignoring this device.
[ 55.468] (II) This device may have been added with another device file.
[ 55.470] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[ 55.470] (II) No input driver specified, ignoring this device.
[ 55.470] (II) This device may have been added with another device file.
[ 55.471] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event10)
[ 55.471] (II) No input driver specified, ignoring this device.
[ 55.471] (II) This device may have been added with another device file.
[ 55.472] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[ 55.472] (II) No input driver specified, ignoring this device.
[ 55.472] (II) This device may have been added with another device file.
[ 55.474] (II) config/udev: Adding input device Lenovo EasyCamera: Lenovo EasyC (/dev/input/event12)
[ 55.474] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "evdev keyboard catchall"
[ 55.474] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "libinput keyboard catchall"
[ 55.474] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "system-keyboard"
[ 55.474] (II) Using input driver 'libinput' for 'Lenovo EasyCamera: Lenovo EasyC'
[ 55.474] (**) Lenovo EasyCamera: Lenovo EasyC: always reports core events
[ 55.474] (**) Option "Device" "/dev/input/event12"
[ 55.477] (II) event12 - Lenovo EasyCamera: Lenovo EasyC: is tagged by udev as: Keyboard
[ 55.477] (II) event12 - Lenovo EasyCamera: Lenovo EasyC: device is a keyboard
[ 55.477] (II) event12 - Lenovo EasyCamera: Lenovo EasyC: device removed
[ 55.530] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/input/input13/event12"
[ 55.530] (II) XINPUT: Adding extended input device "Lenovo EasyCamera: Lenovo EasyC" (type: KEYBOARD, id 10)
[ 55.530] (**) Option "xkb_layout" "latam"
[ 55.530] (**) Option "xkb_variant" "deadtilde"
[ 55.534] (II) event12 - Lenovo EasyCamera: Lenovo EasyC: is tagged by udev as: Keyboard
[ 55.534] (II) event12 - Lenovo EasyCamera: Lenovo EasyC: device is a keyboard
[ 55.535] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event6)
[ 55.536] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[ 55.536] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 55.536] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 55.536] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 55.536] (**) Ideapad extra buttons: always reports core events
[ 55.536] (**) Option "Device" "/dev/input/event6"
[ 55.538] (II) event6 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 55.538] (II) event6 - Ideapad extra buttons: device is a keyboard
[ 55.538] (II) event6 - Ideapad extra buttons: device removed
[ 55.596] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input8/event6"
[ 55.597] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 11)
[ 55.597] (**) Option "xkb_layout" "latam"
[ 55.597] (**) Option "xkb_variant" "deadtilde"
[ 55.599] (II) event6 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 55.600] (II) event6 - Ideapad extra buttons: device is a keyboard
[ 55.601] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 55.601] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 55.601] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 55.601] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 55.601] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 55.601] (**) AT Translated Set 2 keyboard: always reports core events
[ 55.601] (**) Option "Device" "/dev/input/event4"
[ 55.603] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 55.604] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 55.605] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 55.640] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 55.640] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 55.640] (**) Option "xkb_layout" "latam"
[ 55.640] (**) Option "xkb_variant" "deadtilde"
[ 55.641] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 55.641] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 55.643] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event8)
[ 55.643] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 55.643] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 55.643] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 55.643] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 55.643] (**) Option "Device" "/dev/input/event8"
[ 55.645] (II) event8 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 55.648] (II) event8 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 55.648] (II) event8 - SynPS/2 Synaptics TouchPad: device removed
[ 55.693] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event8"
[ 55.694] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[ 55.694] (**) Option "AccelerationScheme" "none"
[ 55.694] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 55.694] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 55.694] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 55.695] (II) event8 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 55.697] (II) event8 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 55.699] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 55.699] (II) No input driver specified, ignoring this device.
[ 55.699] (II) This device may have been added with another device file.
[ 55.700] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 55.700] (II) No input driver specified, ignoring this device.
[ 55.700] (II) This device may have been added with another device file.
[ 74.618] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 74.618] (II) modeset(0): Printing DDC gathered Modelines:
[ 74.618] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 82.439] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 82.439] (II) modeset(0): Printing DDC gathered Modelines:
[ 82.439] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 85.722] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 85.722] (II) modeset(0): Printing DDC gathered Modelines:
[ 85.722] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 97.449] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 97.449] (II) modeset(0): Printing DDC gathered Modelines:
[ 97.449] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 122.417] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 122.417] (II) modeset(0): Printing DDC gathered Modelines:
[ 122.417] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 198.952] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 198.953] (II) modeset(0): Printing DDC gathered Modelines:
[ 198.953] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 277.646] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 277.646] (II) modeset(0): Printing DDC gathered Modelines:
[ 277.646] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 277.679] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 277.679] (II) modeset(0): Printing DDC gathered Modelines:
[ 277.679] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 301.743] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 301.743] (II) modeset(0): Printing DDC gathered Modelines:
[ 301.743] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 301.776] (II) modeset(0): EDID vendor "BOE", prod id 1457
[ 301.776] (II) modeset(0): Printing DDC gathered Modelines:
[ 301.776] (II) modeset(0): Modeline "1366x768"x0.0 67.50 1366 1414 1446 1446 768 771 777 778 +hsync -vsync (46.7 kHz eP)
[ 365.708] (EE)
[ 365.708] (EE) Backtrace:
[ 365.716] (EE) 0: /usr/lib/Xorg (dri3_send_open_reply+0xdd) [0x5622f2864bed]
[ 365.717] (EE) 1: /usr/lib/libc.so.6 (__sigaction+0x50) [0x7f65752dd8e0]
[ 365.718] (EE) 2: /usr/lib/libc.so.6 (pthread_key_delete+0x15c) [0x7f657532d36c]
[ 365.720] (EE) 3: /usr/lib/libc.so.6 (raise+0x18) [0x7f65752dd838]
[ 365.721] (EE) 4: /usr/lib/libc.so.6 (abort+0xcf) [0x7f65752c7535]
[ 365.739] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 365.739] (EE) 5: /usr/lib/dri/crocus_dri.so (?+0x0) [0x7f6572ae4283]
[ 365.740] (EE) 6: /usr/lib/dri/crocus_dri.so (nouveau_drm_screen_create+0x6d92cf) [0x7f65739db14f]
[ 365.746] (EE) 7: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0x507316) [0x7f65730012e6]
[ 365.747] (EE) 8: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0x4e6b79) [0x7f6572fe0b49]
[ 365.748] (EE) 9: /usr/lib/dri/crocus_dri.so (nouveau_drm_screen_create+0x77a366) [0x7f6573a7c1e6]
[ 365.749] (EE) 10: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0x50664c) [0x7f657300061c]
[ 365.751] (EE) 11: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0xc9307) [0x7f6572bc32d7]
[ 365.752] (EE) 12: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0x9109d) [0x7f6572b8b06d]
[ 365.753] (EE) 13: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0x93f60) [0x7f6572b8df30]
[ 365.754] (EE) 14: /usr/lib/dri/crocus_dri.so (__driDriverGetExtensions_d3d12+0x9404c) [0x7f6572b8e01c]
[ 365.755] (EE) 15: /usr/lib/xorg/modules/libglamoregl.so (glamor_pixmap_exchange_fbos+0x3c92) [0x7f65745d5762]
[ 365.756] (EE) 16: /usr/lib/xorg/modules/libglamoregl.so (glamor_finish+0x1379) [0x7f65745bcfb9]
[ 365.756] (EE) 17: /usr/lib/Xorg (RRXineramaExtensionInit+0x169d) [0x5622f27d59cd]
[ 365.756] (EE) 18: /usr/lib/Xorg (UpdateCurrentTime+0x29b5) [0x5622f277dd25]
[ 365.757] (EE) 19: /usr/lib/Xorg (SProcXkbDispatch+0x280c) [0x5622f2745097]
[ 365.758] (EE) 20: /usr/lib/libc.so.6 (__libc_init_first+0x90) [0x7f65752c8290]
[ 365.759] (EE) 21: /usr/lib/libc.so.6 (__libc_start_main+0x8a) [0x7f65752c834a]
[ 365.760] (EE) 22: /usr/lib/Xorg (_start+0x25) [0x5622f27454b5]
[ 365.760] (EE)
[ 365.760] (EE)
Fatal server error:
[ 365.760] (EE) Caught signal 6 (Aborted). Server aborting
[ 365.760] (EE)
[ 365.760] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 365.760] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 365.760] (EE)
[ 365.760] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 365.831] (EE) Server terminated with error (1). Closing log file.
Thank you in advance!
