After a recent system upgrade, the system somehow does not remember the Wifi password and keeps asking me to insert it every time it returns from suspend mode.
The system also asks for the password when I log on.
This is my inxi -Fxzc0
output:
Kernel: 6.1.141-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
Desktop: KDE Plasma v: 6.3.5 Distro: Manjaro base: Arch Linux
Type: Laptop System: SAMSUNG product: 370E4K v: P06RCX
serial: <superuser required>
Mobo: SAMSUNG model: NP370E4K-KW2BR
v: SGL8663A03-C01-G001-S0001+10.0.10586 serial: <superuser required>
UEFI: American Megatrends v: P06RCX.075.160311.JJ date: 03/11/2016
ID-1: BAT1 charge: 9.1 Wh (41.0%) condition: 22.2/48.8 Wh (45.5%)
volts: 11.4 min: 11.1 model: SAMSUNG Electronics SR Real Battery
status: charging
Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2195 min/max: 500/2700 cores: 1: 2195 2: 2195 3: 2195
4: 2195 bogomips: 17565
Device-1: Intel HD Graphics 5500 vendor: Samsung Co driver: i915 v: kernel
arch: Gen-8 bus-ID: 00:02.0
Device-2: Silicon Motion ATIV VGA Camera driver: uvcvideo type: USB
bus-ID: 1-5:3
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8 driver: X:
loaded: intel dri: iris gpu: i915 resolution: 1366x768~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW
GT2)
API: Vulkan v: 1.4.313 drivers: intel surfaces: N/A devices: 1
de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
xdpyinfo, xprop, xrandr
Device-1: Intel Broadwell-U Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus-ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.1.141-1-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.4.5 status: active (process)
Server-4: PulseAudio v: 17.0-43-g3e2bb status: off
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Samsung Co driver: ath9k v: kernel bus-ID: 01:00.0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Samsung Co
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 driver: btusb v: 0.8
type: USB bus-ID: 1-4:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 323.44 GiB (34.7%)
ID-1: /dev/sda vendor: Samsung model: ST1000LM024 HN-M101MBB
ID-1: / size: 450.76 GiB used: 323.4 GiB (71.7%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 96 MiB used: 42.5 MiB (44.3%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.66 GiB used: 5.83 GiB (76.0%)
Processes: 236 Uptime: 2d 6h 42m Init: systemd
Packages: 2385 Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Bash v: 5.2.37
inxi: 3.3.38
This is my rfkill
list all output
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
This is my dmesg -l emerg,alert,crit,err,warn
output:
[ 0.153420] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.153420] #3
[ 0.156768] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.673293] ata1.00: LPM support broken, forcing max_power
[ 0.680737] ata1.00: LPM support broken, forcing max_power
[ 11.518775] systemd[1]: /usr/lib/systemd/system/plymouth-start.service:13: Unit uses KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update the service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 14.887229] vboxdrv: loading out-of-tree module taints kernel.
[ 15.057615] VBoxNetAdp: Successfully started.
[ 15.287325] VBoxNetFlt: Successfully started.
[ 25.329483] at24 8-0050: supply vcc not found, using dummy regulator
[ 25.339920] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 25.964686] spi-nor: probe of spi0.0 failed with error -22
[ 753.483715] ata1.00: LPM support broken, forcing max_power
[ 753.490345] ata1.00: LPM support broken, forcing max_power
[ 1150.875244] ata1.00: LPM support broken, forcing max_power
[ 1150.881780] ata1.00: LPM support broken, forcing max_power
[ 1447.220131] ata1.00: LPM support broken, forcing max_power
[ 1447.226717] ata1.00: LPM support broken, forcing max_power
[ 1803.198252] ata1.00: LPM support broken, forcing max_power
[ 1803.204880] ata1.00: LPM support broken, forcing max_power
[ 2166.651879] ata1.00: LPM support broken, forcing max_power
[ 2166.658251] ata1.00: LPM support broken, forcing max_power
[ 2881.015852] ata1.00: LPM support broken, forcing max_power
[ 2881.022413] ata1.00: LPM support broken, forcing max_power
[ 3086.976713] ata1.00: LPM support broken, forcing max_power
[ 3086.983189] ata1.00: LPM support broken, forcing max_power
[ 3319.241776] ata1.00: LPM support broken, forcing max_power
[ 3319.248887] ata1.00: LPM support broken, forcing max_power
[ 3470.341954] ata1.00: LPM support broken, forcing max_power
[ 3470.348372] ata1.00: LPM support broken, forcing max_power
[ 4010.144747] ata1.00: LPM support broken, forcing max_power
[ 4010.151181] ata1.00: LPM support broken, forcing max_power
[ 4193.743540] ata1.00: LPM support broken, forcing max_power
[ 4193.750015] ata1.00: LPM support broken, forcing max_power
[ 4500.822682] ata1.00: LPM support broken, forcing max_power
[ 4500.829312] ata1.00: LPM support broken, forcing max_power
[ 4506.800312] ata1.00: LPM support broken, forcing max_power
[ 4506.806844] ata1.00: LPM support broken, forcing max_power
[ 4988.969353] ata1.00: LPM support broken, forcing max_power
[ 4988.975700] ata1.00: LPM support broken, forcing max_power
This is my journalctl --follow
output after the lid was closed (I open it again arount 16:50:34):
jul 02 16:50:18 tardis systemd-logind[664]: Lid closed.
jul 02 16:50:18 tardis systemd-logind[664]: The system will suspend now!
jul 02 16:50:18 tardis ModemManager[695]: <msg> [sleep-monitor-systemd] system is about to suspend
jul 02 16:50:18 tardis NetworkManager[660]: <info> [1751485818.8828] manager: sleep: sleep requested (sleeping: no enabled: yes)
jul 02 16:50:18 tardis NetworkManager[660]: <info> [1751485818.8829] device (enp2s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
jul 02 16:50:18 tardis NetworkManager[660]: <info> [1751485818.8859] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
jul 02 16:50:18 tardis NetworkManager[660]: <info> [1751485818.8861] manager: NetworkManager state is now ASLEEP
jul 02 16:50:18 tardis NetworkManager[660]: <info> [1751485818.8864] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
jul 02 16:50:18 tardis systemd[1]: Starting Network Manager Script Dispatcher Service...
jul 02 16:50:18 tardis systemd[1]: Started Network Manager Script Dispatcher Service.
jul 02 16:50:19 tardis kernel: wlp1s0: deauthenticating from 3c:84:6a:22:1a:70 by local choice (Reason: 3=DEAUTH_LEAVING)
jul 02 16:50:19 tardis wpa_supplicant[767]: nl80211: send_event_marker failed: Source based routing not supported
jul 02 16:50:19 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=3c:84:6a:22:1a:70 reason=3 locally_generated=1
jul 02 16:50:19 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2617] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
jul 02 16:50:19 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2621] dhcp4 (wlp1s0): canceled DHCP transaction
jul 02 16:50:19 tardis avahi-daemon[662]: Withdrawing address record for 2804:4b0:1221:9c00:9408:c7b1:dd98:2 on wlp1s0.
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2621] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
jul 02 16:50:19 tardis avahi-daemon[662]: Withdrawing address record for 2804:4b0:1221:9c00:a876:1902:fe98:ab26 on wlp1s0.
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2621] dhcp4 (wlp1s0): state changed no lease
jul 02 16:50:19 tardis avahi-daemon[662]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address 2804:4b0:1221:9c00:a876:1902:fe98:ab26.
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2623] dhcp6 (wlp1s0): canceled DHCP transaction
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2623] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2623] dhcp6 (wlp1s0): state changed no lease
jul 02 16:50:19 tardis avahi-daemon[662]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::12e:a4de:f5d4:b9ec.
jul 02 16:50:19 tardis avahi-daemon[662]: Registering new address record for fe80::12e:a4de:f5d4:b9ec on wlp1s0.*.
jul 02 16:50:19 tardis avahi-daemon[662]: Withdrawing address record for fe80::12e:a4de:f5d4:b9ec on wlp1s0.
jul 02 16:50:19 tardis avahi-daemon[662]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::12e:a4de:f5d4:b9ec.
jul 02 16:50:19 tardis avahi-daemon[662]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
jul 02 16:50:19 tardis avahi-daemon[662]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
jul 02 16:50:19 tardis avahi-daemon[662]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.3.16.
jul 02 16:50:19 tardis avahi-daemon[662]: Withdrawing address record for 192.168.3.16 on wlp1s0.
jul 02 16:50:19 tardis NetworkManager[660]: <info> [1751485819.2926] device (wlp1s0): set-hw-addr: set MAC address to 1E:3E:36:E6:98:BB (scanning)
jul 02 16:50:19 tardis kscreenlocker_greet[20737]: kf.svg: The theme "Nordic" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
jul 02 16:50:19 tardis avahi-daemon[662]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.3.16.
jul 02 16:50:19 tardis kscreenlocker_greet[20737]: kf.plasma.core: The theme "Nordic" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
jul 02 16:50:19 tardis avahi-daemon[662]: New relevant interface wlp1s0.IPv4 for mDNS.
jul 02 16:50:19 tardis avahi-daemon[662]: Registering new address record for 192.168.3.16 on wlp1s0.IPv4.
jul 02 16:50:20 tardis NetworkManager[660]: <info> [1751485820.0913] device (wlp1s0): supplicant interface state: completed -> disconnected
jul 02 16:50:20 tardis NetworkManager[660]: <info> [1751485820.0918] device (wlp1s0): supplicant interface state: disconnected -> interface_disabled
jul 02 16:50:20 tardis NetworkManager[660]: <info> [1751485820.0920] device (wlp1s0): supplicant interface state: interface_disabled -> disconnected
jul 02 16:50:20 tardis NetworkManager[660]: <info> [1751485820.0928] device (wlp1s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
jul 02 16:50:20 tardis NetworkManager[660]: <info> [1751485820.1582] device (wlp1s0): set-hw-addr: reset MAC address to 98:83:89:5F:0E:83 (unmanage)
jul 02 16:50:20 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
jul 02 16:50:20 tardis wpa_supplicant[767]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
jul 02 16:50:21 tardis systemd[1]: Reached target Sleep.
jul 02 16:50:21 tardis systemd[1]: Starting System Suspend...
jul 02 16:50:21 tardis kscreenlocker_greet[20737]: kf.svg: The theme "Nordic" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
jul 02 16:50:21 tardis systemd[1]: session-2.scope: Unit now frozen-by-parent.
jul 02 16:50:21 tardis systemd[1]: user.slice: Unit now frozen.
jul 02 16:50:21 tardis systemd[1]: user-1000.slice: Unit now frozen-by-parent.
jul 02 16:50:21 tardis systemd[1]: user@1000.service: Unit now frozen-by-parent.
jul 02 16:50:21 tardis systemd-sleep[20771]: Successfully froze unit 'user.slice'.
jul 02 16:50:21 tardis systemd-sleep[20771]: Performing sleep operation 'suspend'...
jul 02 16:50:21 tardis kernel: PM: suspend entry (deep)
jul 02 16:50:31 tardis kernel: Filesystems sync: 1.617 seconds
jul 02 16:50:31 tardis kernel: Freezing user space processes
jul 02 16:50:31 tardis kernel: Freezing user space processes completed (elapsed 0.001 seconds)
jul 02 16:50:31 tardis kernel: OOM killer disabled.
jul 02 16:50:31 tardis kernel: Freezing remaining freezable tasks
jul 02 16:50:31 tardis kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
jul 02 16:50:31 tardis kernel: printk: Suspending console(s) (use no_console_suspend to debug)
jul 02 16:50:31 tardis kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
jul 02 16:50:31 tardis kernel: ata1.00: Entering standby power mode
jul 02 16:50:31 tardis kernel: ACPI: EC: interrupt blocked
jul 02 16:50:31 tardis kernel: ACPI: PM: Preparing to enter system sleep state S3
jul 02 16:50:31 tardis kernel: ACPI: EC: event blocked
jul 02 16:50:31 tardis kernel: ACPI: EC: EC stopped
jul 02 16:50:31 tardis kernel: ACPI: PM: Saving platform NVS memory
jul 02 16:50:31 tardis kernel: Disabling non-boot CPUs ...
jul 02 16:50:31 tardis kernel: smpboot: CPU 1 is now offline
jul 02 16:50:31 tardis kernel: smpboot: CPU 2 is now offline
jul 02 16:50:31 tardis kernel: smpboot: CPU 3 is now offline
jul 02 16:50:31 tardis kernel: ACPI: PM: Low-level resume complete
jul 02 16:50:31 tardis kernel: ACPI: EC: EC started
jul 02 16:50:31 tardis kernel: ACPI: PM: Restoring platform NVS memory
jul 02 16:50:31 tardis kernel: Enabling non-boot CPUs ...
jul 02 16:50:31 tardis kernel: x86: Booting SMP configuration:
jul 02 16:50:31 tardis kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
jul 02 16:50:31 tardis kernel: CPU1 is up
jul 02 16:50:31 tardis kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
jul 02 16:50:31 tardis kernel: CPU2 is up
jul 02 16:50:31 tardis kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
jul 02 16:50:31 tardis kernel: CPU3 is up
jul 02 16:50:31 tardis kernel: ACPI: PM: Waking up from system sleep state S3
jul 02 16:50:31 tardis kernel: ACPI: EC: interrupt unblocked
jul 02 16:50:31 tardis kernel: ACPI: EC: event unblocked
jul 02 16:50:31 tardis kernel: ACPI: EC: 0 stale EC events cleared
jul 02 16:50:31 tardis kernel: ath: phy0: ASPM enabled: 0x42
jul 02 16:50:31 tardis kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
jul 02 16:50:31 tardis kernel: ata2.00: configured for UDMA/100
jul 02 16:50:31 tardis kernel: usb 1-8: reset high-speed USB device number 4 using xhci_hcd
jul 02 16:50:31 tardis kernel: usb 1-5: reset high-speed USB device number 3 using xhci_hcd
jul 02 16:50:31 tardis kernel: OOM killer enabled.
jul 02 16:50:31 tardis systemd-logind[664]: Lid opened.
jul 02 16:50:31 tardis kernel: Restarting tasks ... done.
jul 02 16:50:31 tardis kernel: random: crng reseeded on system resumption
jul 02 16:50:32 tardis systemd-sleep[20771]: System returned from sleep operation 'suspend'.
jul 02 16:50:32 tardis kernel: PM: suspend exit
jul 02 16:50:33 tardis kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jul 02 16:50:33 tardis kernel: ata1.00: Entering active power mode
jul 02 16:50:33 tardis kernel: ata1.00: LPM support broken, forcing max_power
jul 02 16:50:33 tardis kernel: ata1.00: configured for UDMA/133
jul 02 16:50:33 tardis systemd[1]: user.slice: Unit now thawed.
jul 02 16:50:33 tardis systemd[1]: user-1000.slice: Unit now thawed.
jul 02 16:50:33 tardis systemd[1]: user@1000.service: Unit now thawed.
jul 02 16:50:33 tardis systemd[1]: session-2.scope: Unit now thawed.
jul 02 16:50:33 tardis systemd-sleep[20771]: Successfully thawed unit 'user.slice'.
jul 02 16:50:33 tardis systemd[1]: systemd-suspend.service: Deactivated successfully.
jul 02 16:50:33 tardis systemd[1]: Finished System Suspend.
jul 02 16:50:33 tardis systemd[1]: Stopped target Sleep.
jul 02 16:50:33 tardis systemd[1]: Reached target Suspend.
jul 02 16:50:33 tardis systemd-logind[664]: Operation 'suspend' finished.
jul 02 16:50:33 tardis ModemManager[695]: <msg> [sleep-monitor-systemd] system is resuming
jul 02 16:50:33 tardis systemd[1]: Stopped target Suspend.
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.6625] manager: sleep: wake requested (sleeping: yes enabled: yes)
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.6627] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
jul 02 16:50:33 tardis kernel: RTL8208 Fast Ethernet r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
jul 02 16:50:33 tardis ModemManager[695]: <wrn> [plugin-manager] task 22: port context already being processed
jul 02 16:50:33 tardis ModemManager[695]: <wrn> [plugin-manager] task 23: port context already being processed
jul 02 16:50:33 tardis kscreenlocker_greet[20737]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "pt_BR". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
jul 02 16:50:33 tardis kernel: r8169 0000:02:00.0 enp2s0: Link is Down
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9613] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9650] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9662] manager: NetworkManager state is now DISCONNECTED
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9901] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9913] device (p2p-dev-wlp1s0): state change: unavailable -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9933] Wi-Fi P2P device controlled by interface wlp1s0 created
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9941] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/22)
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9951] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
jul 02 16:50:33 tardis NetworkManager[660]: <info> [1751485833.9971] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', managed-type: 'full')
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.0010] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9832] policy: auto-activating connection 'Matias2' (ad956440-d8a4-45ae-a1d0-4042bf56a3f5)
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9837] device (wlp1s0): Activation: starting connection 'Matias2' (ad956440-d8a4-45ae-a1d0-4042bf56a3f5)
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9839] device (wlp1s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9845] manager: NetworkManager state is now CONNECTING
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9848] device (wlp1s0): state change: prepare -> config (reason 'none', managed-type: 'full')
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9851] device (wlp1s0): Activation: (wifi) access point 'Matias2' has security, but secrets are required.
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9852] device (wlp1s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9853] sup-iface[a9333e449392dafe,19,wlp1s0]: wps: type pbc start...
jul 02 16:50:34 tardis wpa_supplicant[767]: wlp1s0: WPS-PBC-ACTIVE
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9936] device (wlp1s0): supplicant interface state: disconnected -> scanning
jul 02 16:50:34 tardis NetworkManager[660]: <info> [1751485834.9938] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@469.service.
jul 02 16:50:35 tardis kwalletd6[21106]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@469.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@469.service: Failed with result 'exit-code'.
jul 02 16:50:35 tardis kded6[1229]: Couldn't start kwalletd: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "Could not activate remote peer 'org.kde.kwalletd6': unit failed")
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@470.service.
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@470.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@470.service: Failed with result 'exit-code'.
jul 02 16:50:36 tardis kwalletd6[21110]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:36 tardis kwalletd6[21112]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@471.service.
jul 02 16:50:37 tardis kwalletd6[21113]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@471.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:37 tardis kwalletd6[21114]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@471.service: Failed with result 'exit-code'.
jul 02 16:50:37 tardis kwalletd6[21115]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:37 tardis kwalletd6[21116]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@472.service.
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@472.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@472.service: Failed with result 'exit-code'.
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@473.service.
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@473.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@473.service: Failed with result 'exit-code'.
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@474.service.
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@474.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@474.service: Failed with result 'exit-code'.
jul 02 16:50:35 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@475.service.
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@475.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:35 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@475.service: Failed with result 'exit-code'.
jul 02 16:50:35 tardis kded6[1229]: org.kde.plasma.nm.kded: Error opening kwallet.
jul 02 16:50:39 tardis systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4067] device (wlp1s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4080] device (wlp1s0): state change: prepare -> config (reason 'none', managed-type: 'full')
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: WPS-CANCEL
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4118] device (wlp1s0): Activation: (wifi) connection 'Matias2' has security, and secrets exist. No new secrets needed.
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4119] Config: added 'ssid' value 'Matias2'
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4119] Config: added 'scan_ssid' value '1'
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4119] Config: added 'bgscan' value 'simple:30:-70:86400'
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4120] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4120] Config: added 'auth_alg' value 'OPEN'
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4120] Config: added 'psk' value '<hidden>'
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@476.service.
jul 02 16:50:50 tardis ksnip[14669]: Warning: "O objeto não existe no caminho “/org/freedesktop/NetworkManager/ActiveConnection/22”"
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: SME: Trying to authenticate with 3c:84:6a:22:1a:70 (SSID='Matias2' freq=2452 MHz)
jul 02 16:50:50 tardis kernel: wlp1s0: authenticate with 3c:84:6a:22:1a:70
jul 02 16:50:50 tardis kernel: wlp1s0: 80 MHz not supported, disabling VHT
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4398] device (wlp1s0): supplicant interface state: scanning -> authenticating
jul 02 16:50:50 tardis kernel: wlp1s0: send auth to 3c:84:6a:22:1a:70 (try 1/3)
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4398] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> authenticating
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: Trying to associate with 3c:84:6a:22:1a:70 (SSID='Matias2' freq=2452 MHz)
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4421] device (wlp1s0): supplicant interface state: authenticating -> associating
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4422] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
jul 02 16:50:50 tardis kernel: wlp1s0: authenticated
jul 02 16:50:50 tardis kernel: wlp1s0: associate with 3c:84:6a:22:1a:70 (try 1/3)
jul 02 16:50:50 tardis kernel: wlp1s0: RX AssocResp from 3c:84:6a:22:1a:70 (capab=0x411 status=0 aid=4)
jul 02 16:50:50 tardis kernel: wlp1s0: associated
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: Associated with 3c:84:6a:22:1a:70
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
jul 02 16:50:50 tardis kwalletd6[21144]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@476.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@476.service: Failed with result 'exit-code'.
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4556] device (wlp1s0): supplicant interface state: associating -> associated
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.4558] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
jul 02 16:50:50 tardis kded6[1229]: Couldn't start kwalletd: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "Could not activate remote peer 'org.kde.kwalletd6': unit failed")
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@477.service.
jul 02 16:50:51 tardis kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@477.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: WPA: Key negotiation completed with 3c:84:6a:22:1a:70 [PTK=CCMP GTK=CCMP]
jul 02 16:50:51 tardis kwalletd6[21148]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@477.service: Failed with result 'exit-code'.
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-CONNECTED - Connection to 3c:84:6a:22:1a:70 completed [id=0 id_str=]
jul 02 16:50:51 tardis kwalletd6[21149]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis avahi-daemon[662]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::12e:a4de:f5d4:b9ec.
jul 02 16:50:52 tardis kwalletd6[21150]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@478.service.
jul 02 16:50:50 tardis avahi-daemon[662]: New relevant interface wlp1s0.IPv6 for mDNS.
jul 02 16:50:52 tardis kwalletd6[21164]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@478.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:50 tardis avahi-daemon[662]: Registering new address record for fe80::12e:a4de:f5d4:b9ec on wlp1s0.*.
jul 02 16:50:52 tardis kwalletd6[21165]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@478.service: Failed with result 'exit-code'.
jul 02 16:50:50 tardis avahi-daemon[662]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.3.16.
jul 02 16:50:52 tardis kwalletd6[21166]: /usr/bin/kwalletd6: error while loading shared libraries: libgpgmepp.so.7: cannot open shared object file: No such file or directory
jul 02 16:50:50 tardis avahi-daemon[662]: New relevant interface wlp1s0.IPv4 for mDNS.
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@479.service.
jul 02 16:50:50 tardis avahi-daemon[662]: Registering new address record for 192.168.3.16 on wlp1s0.IPv4.
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.5049] device (wlp1s0): supplicant interface state: associated -> completed
jul 02 16:50:50 tardis wpa_supplicant[767]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-45 noise=-83 txrate=72200
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.5049] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Matias2"
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.5049] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> completed
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.5051] device (wlp1s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.5059] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@479.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@479.service: Failed with result 'exit-code'.
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.5150] dhcp4 (wlp1s0): state changed new lease, address=192.168.3.16, acd pending
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@480.service.
jul 02 16:50:53 tardis avahi-daemon[662]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::12e:a4de:f5d4:b9ec.
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@480.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:53 tardis avahi-daemon[662]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address 2804:4b0:1221:9c00:a876:1902:fe98:ab26.
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@480.service: Failed with result 'exit-code'.
jul 02 16:50:53 tardis avahi-daemon[662]: Registering new address record for 2804:4b0:1221:9c00:a876:1902:fe98:ab26 on wlp1s0.*.
jul 02 16:50:53 tardis avahi-daemon[662]: Withdrawing address record for fe80::12e:a4de:f5d4:b9ec on wlp1s0.
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@481.service.
jul 02 16:50:53 tardis rtkit-daemon[1259]: Supervising 14 threads of 10 processes of 1 users.
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@481.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@481.service: Failed with result 'exit-code'.
jul 02 16:50:54 tardis avahi-daemon[662]: Registering new address record for 2804:4b0:1221:9c00:9408:c7b1:dd98:2 on wlp1s0.*.
jul 02 16:50:55 tardis rtkit-daemon[1259]: Supervising 14 threads of 10 processes of 1 users.
jul 02 16:50:50 tardis systemd[1004]: Started dbus-:1.2-org.kde.kwalletd6@482.service.
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@482.service: Main process exited, code=exited, status=127/n/a
jul 02 16:50:50 tardis systemd[1004]: dbus-:1.2-org.kde.kwalletd6@482.service: Failed with result 'exit-code'.
jul 02 16:50:50 tardis kded6[1229]: org.kde.plasma.nm.kded: Error opening kwallet.
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.6634] dhcp4 (wlp1s0): state changed new lease, address=192.168.3.16
jul 02 16:50:50 tardis NetworkManager[660]: <info> [1751485850.6647] policy: set 'Matias2' (wlp1s0) as default for IPv4 routing and DNS
jul 02 16:50:52 tardis NetworkManager[660]: <info> [1751485852.3182] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
jul 02 16:50:52 tardis systemd[1]: Starting Network Manager Script Dispatcher Service...
jul 02 16:50:52 tardis systemd[1]: Started Network Manager Script Dispatcher Service.
jul 02 16:50:52 tardis NetworkManager[660]: <info> [1751485852.3882] device (wlp1s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
jul 02 16:50:52 tardis NetworkManager[660]: <info> [1751485852.3884] device (wlp1s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
jul 02 16:50:52 tardis NetworkManager[660]: <info> [1751485852.3888] manager: NetworkManager state is now CONNECTED_SITE
jul 02 16:50:52 tardis NetworkManager[660]: <info> [1751485852.3895] device (wlp1s0): Activation: successful, device activated.
jul 02 16:50:53 tardis NetworkManager[660]: <info> [1751485853.4010] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
jul 02 16:50:53 tardis NetworkManager[660]: <info> [1751485853.4038] policy: set 'Matias2' (wlp1s0) as default for IPv6 routing and DNS
jul 02 16:50:54 tardis NetworkManager[660]: <info> [1751485854.4551] dhcp6 (wlp1s0): state changed new lease, address=2804:4b0:1221:9c00:9408:c7b1:dd98:2
jul 02 16:50:54 tardis NetworkManager[660]: <info> [1751485854.6591] manager: NetworkManager state is now CONNECTED_GLOBAL
