RejZoR
April 7, 2023, 1:23pm
1
I’ve reinstalled Manjaro KDE clean yesterday after trying GNOME version of it for a while and now system won’t sleep properly, won’t even hibernate and hybrid sleep doesn’t work at all. I’ve used Manjaro KDE on same system and sleep worked great several months in the past if we look back from this point. So it has to be some sort of recent change.
When I press “Sleep” button in “Start” menu, image just freezes and nothing happens. When I start slapping it on keyboard, it seems like it wakes up, but it hasn’t really even gone to sleep properly.
When set on the sleep timer, I’ve set sleep to happen after 1 minute of waiting an in this case, image goes black, but I can still see mouse cursor. And that’s it. Slapping keyboard wakes it up from what wasn’t even actual sleep. What’s going in?
AMD Ryzen 5 2500U, 8GB RAM, 256GB NVMe SSD, it’s laptop from HP.
brahma
April 7, 2023, 5:29pm
2
post full system info:
inxi -zav7
cat /sys/power/mem_sleep
RejZoR
April 7, 2023, 7:57pm
3
brahma:
inxi -zav7
Kernel: 6.2.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=ba91c4b9-5007-4cfb-ac39-d633fd6ef6ef rw quiet splash
resume=UUID=13b40e6c-2d7a-455a-825c-2eb53e8e8038 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 17-ca0xxx v: N/A
Mobo: HP model: 84D2 v: 91.30 serial: <superuser required> UEFI: AMI
v: F.62 date: 05/06/2022
ID-1: BAT0 charge: 30.7 Wh (100.0%) condition: 30.7/30.7 Wh (100.0%)
volts: 12.8 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235
status: discharging
RAM: total: 6.73 GiB used: 2.37 GiB (35.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1594 high: 2000 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1254 2: 2000
3: 1600 4: 1502 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31948
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 46.0 C
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 2-2.1:4 chip-ID: 04f2:b65d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x219e built: 2015
res: 1600x900 hz: 60 dpi: 106 gamma: 1.2 size: 382x214mm (15.04x8.43")
diag: 438mm (17.2") ratio: 16:9 modes: max: 1600x900 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.2.9-1-MANJARO) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.2.9-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 2-2.2:6 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 704.24 GiB used: 293.9 GiB (41.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC501 HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 80003C00 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: JMicron Tech model: N/A
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 1201 scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 15.73 GiB (7.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ba91c4b9-5007-4cfb-ac39-d633fd6ef6ef
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: A4D2-6071
ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 2 TiB
used: 278.18 GiB (13.6%) fs: fuse source: ERR-102
ID-1: swap-1 type: partition size: 8.8 GiB used: 460 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 13b40e6c-2d7a-455a-825c-2eb53e8e8038
ID-1: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: ORICO
uuid: 705A76465A7608DC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 2-1:2 info: Compal STD-USB3.1 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 04b7:0100 class-ID: 0806 serial: <filter>
Hub-3: 2-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 2-2.1:4 info: Chicony HP TrueVision HD Camera type: Video
Device-2: 2-2.2:6 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 3-2:2 info: JMicron / USA Gen1 SATA 6Gb/s Bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 896mA chip-ID: 152d:0576 class-ID: 0806 serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 245 Uptime: 6h 18m wakeups: 22 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1126 libs: 326 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Sleep status:
s2idle [deep]
Odd thing is, when I left it for like 3 hours and it went into sleep after display went out in 30 minutes and sleep in 60 minutes, it seemed to work fine. But if I manually initiated it, it didn’t go into Sleep correctly. Is it possible that sleep is broken if display is active, but works fine if it’s off prior system going into sleep?
brahma
April 8, 2023, 6:53am
4
edit your post, and use formatting for the outputs, click this icon in editor </>
and copy the output there;
or use:
your output here
maybe there is some setting in your display?
also you are running the 6.2 kernel, does it happens with the 6.1 and 5.15 kernels too?
also boot into live usb of manjaro, and test sleep there…
