when i restart system, it boots with black screen and mouse pointer
what can i do now ?
Can you switch to console ?
CTRL+ALT+F2
can enter tty
HI @siyuan,
The case is, it is known that the manjaro does not use bootsplash by default.
So I ask, doesn’t it reach the login screen? (ssdm; lightdm, gdm)
T+ = So long
can not reach the login screen
I will show you another alternative.
I’m always one that breaks systems easily he he, so when you turn on the PC as soon as you start, repeatedly press the two “Shift” keys on your keyboard to show the Grub menu.
Navigate to the advanced option and choose fallback mode
T+ = So long
choose fallback mode still black screen
