Context: Switched from Wayland to Xorg recently due to screen sharing issues on apps like Zoom and Teams.
After around 3 or 4 hours, my system randomly freezes, and today I noticed the consistent behaviour:
If I’m moving the mouse, everything works just fine. The moment I press any character on the keyboard to input data anywhere, everything freezes for around 4 seconds. If Audio does not freeze, only video.
After that, same thing: I can’t alt + tab because that brings the mouse pointer to the foreground, but I can type as long as I want, navigate within the same app. But, the moment I move the mouse pointer, it freezes again for the same amount of time.
$ inxi -Fazy
Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=789272d4-c6d4-45f4-888c-3f1b8d5e5d61 rw rootflags=subvol=@ quiet
cryptdevice=UUID=0945f6d4-da68-4ed5-8fc6-2bf02b8f7b1a:luks-0945f6d4-da68-4ed5-8fc6-2bf02b8f7b1a
root=/dev/mapper/luks-0945f6d4-da68-4ed5-8fc6-2bf02b8f7b1a splash
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: B550M AORUS ELITE v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B550M AORUS ELITE v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F19
date: 03/22/2024
ID-1: hidpp_battery_2 charge: 31% condition: N/A volts: 3.8 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3634 high: 3693 min/max: N/A cores: 1: 3586 2: 3405
3: 3693 4: 3693 5: 3580 6: 3693 7: 3693 8: 3693 9: 3693 10: 3693 11: 3693
12: 3693 13: 2997 14: 3693 15: 3693 16: 3693 17: 3592 18: 3693 19: 3591
20: 3693 21: 3693 22: 3693 23: 3693 24: 3693 bogomips: 177359
affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 09:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3.2:39
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) TV SSCR2 serial: <filter>
built: 2021 res: 3840x2160 dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43")
diag: 1836mm (72.3") ratio: 16:9 modes: max: 3840x2160 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
navi22 LLVM 17.0.6 DRM 3.54 6.6.34-1-MANJARO) device-ID: 1002:73df
memory: 11.72 GiB unified: no
When I move the mouse after using the keyboard, the following message appears on journalctl
jul 17 10:20:31 william-desktop /usr/lib/gdm-x-session[2185]: (II) event21 - Logitech G703 LS: SYN_DROPPED event - some input events have been lost.
Same thing the other way around
jul 17 10:21:29 william-desktop /usr/lib/gdm-x-session[2185]: (II) event2 - Razer Razer Huntsman Tournament Edition: SYN_DROPPED event - some input events have been lost.
Typically, I have a picture-in-picture video open in firefox. That may be connected.
The only thing that currently works is logging out. But, after a while, it starts happening again.
