System hangs on network activation
Hi, I just installed Manjaro as bare CLI and the system hung after I activated network connection. Kernels 5.4 and 5.6 (from Architect) work fine, in 5.9, 5.10, 5.11 and 5.12rc5 the issue occurs and I can’t event reboot the system and some other commands hang too. I was able to find an email on lkml about the issue - about cfg80211 getting deadlocked and it got fixed in June 2020. Is there a way how I can get it to work?
[  245.353452] INFO: task kworker/u64:7:236 blocked for more than 122 seconds.
[  245.353455]       Not tainted 5.9.16-1-MANJARO #1
[  245.353456] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[  245.353458] task:kworker/u64:7   state:D stack:    0 pid:  236 ppid:     2 flags:0x00004000
[  245.353482] Workqueue: events_power_efficient reg_check_chans_work [cfg80211]
[  245.353483] Call Trace:
[  245.353489]  __schedule+0x292/0x830
[  245.353493]  schedule+0x46/0xf0
[  245.353495]  schedule_preempt_disabled+0x14/0x20
[  245.353497]  __mutex_lock.constprop.0+0x180/0x530
[  245.353499]  ? _raw_spin_lock+0x13/0x30
[  245.353517]  reg_check_chans_work+0x2d/0x3f0 [cfg80211]
[  245.353522]  process_one_work+0x1da/0x3d0
[  245.353524]  worker_thread+0x4d/0x3d0
[  245.353526]  ? rescuer_thread+0x410/0x410
[  245.353528]  kthread+0x142/0x160
[  245.353530]  ? __kthread_bind_mask+0x60/0x60
[  245.353533]  ret_from_fork+0x22/0x30
[  245.353551] INFO: task ip:1317 blocked for more than 122 seconds.
[  245.353552]       Not tainted 5.9.16-1-MANJARO #1
[  245.353552] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[  245.353553] task:ip              state:D stack:    0 pid: 1317 ppid:  1304 flags:0x00004080
[  245.353555] Call Trace:
[  245.353557]  __schedule+0x292/0x830
[  245.353560]  schedule+0x46/0xf0
[  245.353562]  schedule_preempt_disabled+0x14/0x20
[  245.353563]  __mutex_lock.constprop.0+0x180/0x530
[  245.353571]  igb_resume+0xff/0x1d0 [igb]
[  245.353576]  pci_pm_runtime_resume+0xaa/0xc0
[  245.353578]  ? pci_pm_freeze_noirq+0x110/0x110
[  245.353581]  __rpm_callback+0xc5/0x170
[  245.353584]  rpm_callback+0x4f/0x70
[  245.353585]  ? pci_pm_freeze_noirq+0x110/0x110
[  245.353587]  rpm_resume+0x5d7/0x820
[  245.353590]  __pm_runtime_resume+0x3b/0x60
[  245.353593]  __dev_open+0x63/0x1b0
[  245.353596]  __dev_change_flags+0x1a5/0x210
[  245.353598]  dev_change_flags+0x21/0x60
[  245.353601]  do_setlink+0x2bc/0x1160
[  245.353607]  ? __nla_validate_parse+0x5f/0x910
[  245.353610]  __rtnl_newlink+0x65f/0x9e0
[  245.353620]  rtnl_newlink+0x44/0x70
[  245.353622]  rtnetlink_rcv_msg+0x13e/0x390
[  245.353625]  ? rtnl_calcit.isra.0+0x120/0x120
[  245.353627]  netlink_rcv_skb+0x75/0x140
[  245.353630]  netlink_unicast+0x242/0x340
[  245.353632]  netlink_sendmsg+0x243/0x480
[  245.353636]  sock_sendmsg+0x5e/0x60
[  245.353638]  ____sys_sendmsg+0x25a/0x2a0
[  245.353640]  ? copy_msghdr_from_user+0x6e/0xa0
[  245.353642]  ___sys_sendmsg+0x97/0xe0
[  245.353646]  __sys_sendmsg+0x81/0xd0
[  245.353649]  do_syscall_64+0x33/0x40
[  245.353651]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[  245.353654] RIP: 0033:0x7f54dfc31737
[  245.353655] RSP: 002b:00007ffe8adaa928 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
[  245.353656] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f54dfc31737
[  245.353657] RDX: 0000000000000000 RSI: 00007ffe8adaa990 RDI: 0000000000000003
[  245.353658] RBP: 00000000607c3ca8 R08: 0000000000000001 R09: 00007f54dfcf2a60
[  245.353659] R10: 0000000000000230 R11: 0000000000000246 R12: 0000000000000001
[  245.353659] R13: 00007ffe8adaaa60 R14: 0000000000000000 R15: 000055722d3b8020
System info:
  Kernel: 5.4.108-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=/dev/mapper/manjaro-system rw
  cryptdevice=UUID=c862b0da-751c-4bbc-bd7c-fde691941c26:cryptroot quiet
  udev.log_priority=3
  Console: tty 1 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: ROG CROSSHAIR VII HERO v: Rev 1.xx serial: <filter>
  UEFI: American Megatrends v: 4301 date: 03/04/2021
  RAM: total: 62.77 GiB used: 1.01 GiB (1.6%)
  RAM Report:
  missing: Required tool dmidecode not installed. Check --recommends
  Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
  family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
  bogomips: 118225
  Speed: 2415 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
  1: 2415 2: 1714 3: 2087 4: 2067 5: 2194 6: 2190 7: 2187 8: 2191 9: 1718
  10: 1922 11: 1974 12: 1886 13: 1886 14: 1960 15: 3723 16: 2085
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
  sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
  tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  disabled, RSB filling
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k
  port: e000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> scope: link
  Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: e000
  bus-ID: 07:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
  v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0025 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
  rfk-block: hardware: no software: no address: see --recommends
have you computer on resume before ?
Thanks for the pointers. I connected the dots and the cause was Windows 10 and its fast boot…and disconnected computer from power for 10 seconds to clear stuff and new kernels work now.
Not sure if it counts as a regression or not.
You will run into this problem again in the future and it’s called a side-effect and the solution is:
  • When rebooting from Windows to Linux, cold boot the system (I.E.: Power off in Windopws, press the power button again to boot to Linux.)
  • When booting from Linux to Windows, you can still warm boot.
Why, oh why?
Because Windows has a monopoly, they don’t care that their network drivers mess up the UEFI system as they re-init said system in their drivers, whereas Linux expects a clean system.
:sob:
