From time to time my system becomes irresponsive specially when I use google meetings:
[sudo] senha para vfbsilva:
– Logs begin at Mon 2020-06-08 07:39:48 -03, end at Tue 2020-10-06 17:54:01 -03. –
out 06 17:51:16 rohan kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
out 06 17:51:16 rohan kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
out 06 17:51:16 rohan kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
inxi -Fza System: Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=b841b317-5f27-4086-9390-595dff39a5c8 rw quiet apparmor=1 security=apparmor udev.log_priority=3 Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux Machine: Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.80 date: 12/25/2019 CPU: Topology: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158) stepping: C (12) microcode: D6 L2 cache: 9216 KiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44412 Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf status: Not affected Type: mds mitigation: Clear CPU buffers; SMT disabled Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling Type: srbds mitigation: Microcode Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2070] driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f02 Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia display ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5") s-diag: 693mm (27.3") Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27") OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66 direct render: Yes Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348 Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9 Device-3: Logitech Logitech Webcam C925e type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-2:7 chip ID: 046d:085b serial: <filter> Sound Server: ALSA v: k5.7.19-2-MANJARO Network: Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter> IF-ID-1: br-232fd21ea23b state: down mac: <filter> IF-ID-2: br-5d01cbb2628b state: down mac: <filter> IF-ID-3: docker0 state: down mac: <filter> Drives: Local Storage: total: 912.89 GiB used: 105.32 GiB (11.5%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: DB6Q scheme: GPT ID-2: /dev/sdb vendor: Kingston model: SA400S37480G size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0102 scheme: GPT Partition: ID-1: / raw size: 154.16 GiB size: 150.74 GiB (97.78%) used: 105.28 GiB (69.8%) fs: ext4 dev: /dev/sdb1 Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default) ID-1: swap-1 type: file size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile Sensors: System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 31 C Fan Speeds (RPM): N/A gpu: nvidia fan: 45% Info: Processes: 239 Uptime: 14m Memory: 15.58 GiB used: 4.12 GiB (26.4%) Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 Packages: 1533 pacman: 1531 lib: 410 flatpak: 0 snap: 2 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
I wonder if this is somehow related: 206653 – i2c_nvidia_gpu takes too long time and makes system suspend & resume failed with NVIDIA GTX 1660 card
