well i did grab a priority 4 log, and as far as i can tell its just the way linux is, there is always errors and warnings even in a brand-new system
But yes, the topmost hardware errors are still there but as i say, they are, and have always been there.
~ journalctl -p 4 ✔
Jun 30 09:44:22 manjaro kernel: DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000008d000000-0x000000008f7fffff], contact BIOS vendor for fixes
Jun 30 09:44:22 manjaro kernel: DMAR: [Firmware Bug]: Your BIOS is broken; bad RMRR [0x000000008d000000-0x000000008f7fffff]
BIOS vendor: Dell Inc.; Ver: 1.5.0; Product Version:
Jun 30 09:44:22 manjaro kernel: x86/cpu: SGX disabled by BIOS.
Jun 30 09:44:22 manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jun 30 09:44:22 manjaro kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Jun 30 09:44:22 manjaro kernel: #3
Jun 30 09:44:22 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jun 30 09:44:22 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
Jun 30 09:44:22 manjaro kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee0000000040110a
Jun 30 09:44:22 manjaro kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ce80 MISC 43880014086
Jun 30 09:44:22 manjaro kernel: mce: [Hardware Error]: PROCESSOR 0:806e9 TIME 1656582254 SOCKET 0 APIC 0 microcode f0
Jun 30 09:44:22 manjaro kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ee0000000040110a
Jun 30 09:44:22 manjaro kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ce40 MISC 7880014086
Jun 30 09:44:22 manjaro kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
Jun 30 09:44:22 manjaro kernel: i8042: Warning: Keylock active
Jun 30 09:44:22 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
Jun 30 09:44:23 manjaro systemd-udevd[339]: Configuration file /usr/lib/udev/rules.d/77-mm-fibocom-port-types.rules is marked executable. Please remove executable permission bits. Proceeding anyway.
Jun 30 09:44:23 manjaro kernel: ACPI Warning: \_SB.IETM._TRT: Return Package has no elements (empty) (20210730/nsprepkg-94)
Jun 30 09:44:23 manjaro kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Jun 30 09:44:24 manjaro systemd-udevd[359]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Jun 30 09:44:25 manjaro kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
Jun 30 09:44:25 manjaro systemd-udevd[358]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Jun 30 09:44:28 manjaro kernel: kauditd_printk_skb: 21 callbacks suppressed
Jun 30 09:44:30 manjaro systemd-xdg-autostart-generator[786]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proceeding >
Jun 30 09:44:30 manjaro systemd-xdg-autostart-generator[786]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceeding an>
Jun 30 09:44:30 manjaro systemd-xdg-autostart-generator[786]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceeding an>
Jun 30 09:44:31 manjaro startplasma-x11[796]: QIODevice::read (QFile, "/home/manjaro/.config/kdedefaults/package"): device not open
Jun 30 09:44:31 manjaro startplasma-x11[796]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.config/kdedefaults/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigCha>
Jun 30 09:44:31 manjaro startplasma-x11[796]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.config/kdedefaults/kcminputrc" interface "org.kde.kconfig.notify" member "ConfigCha>
Jun 30 09:44:31 manjaro startplasma-x11[796]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.config/kdedefaults/kwinrc" interface "org.kde.kconfig.notify" member "ConfigChanged>
Jun 30 09:44:31 manjaro ksplashqml[804]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jun 30 09:44:31 manjaro ksplashqml[804]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Jun 30 09:44:31 manjaro startplasma-x11[796]: QPixmap: QGuiApplication must be created before calling defaultDepth().
Jun 30 09:44:31 manjaro startplasma-x11[796]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChan>
Jun 30 09:44:32 manjaro klauncher[934]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 30 09:44:32 manjaro kcminit_startup[978]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChan>
Jun 30 09:44:32 manjaro kwin_x11[1089]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jun 30 09:44:32 manjaro kwin_x11[1089]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jun 30 09:44:32 manjaro kwin_x11[1089]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jun 30 09:44:33 manjaro ksmserver[1135]: Qt: Session management error: networkIdsList argument is NULL
Jun 30 09:44:33 manjaro kernel: kauditd_printk_skb: 32 callbacks suppressed
Jun 30 09:44:33 manjaro breath2tobreath[1160]: QApplication::qAppName: Please instantiate the QApplication object first
Jun 30 09:44:33 manjaro breath2tobreath[1160]: QSocketNotifier: Can only be used with threads started with QThread
Jun 30 09:44:33 manjaro breath2tobreath[1160]: QCoreApplication::arguments: Please instantiate the QApplication object first
Jun 30 09:44:34 manjaro kwin_x11[1089]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 757, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Jun 30 09:44:34 manjaro kwin_x11[1089]: kwin_core: XCB error: 10 (BadAccess), sequence: 820, resource id: 1945, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Jun 30 09:44:34 manjaro gst-plugin-scan[1226]: type name '-a-png-encoder-pred' contains invalid characters
Jun 30 09:44:34 manjaro gst-plugin-scan[1226]: g_type_set_qdata: assertion 'node != NULL' failed
Jun 30 09:44:34 manjaro org_kde_powerdevil[1143]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 30 09:44:35 manjaro org_kde_powerdevil[1143]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 30 09:44:35 manjaro org_kde_powerdevil[1143]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 30 09:44:35 manjaro baloo_file[1149]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.43'
Jun 30 09:44:35 manjaro pulseaudio[1170]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 30 09:44:35 manjaro kded5[1038]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.11'
Jun 30 09:44:36 manjaro plasmashell[1145]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jun 30 09:44:36 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea: Binding loop detected for property "spacingAtMinSize"
Jun 30 09:44:36 manjaro plasmashell[1145]: <Unknown File>: QML QQuickAnchors: Binding loop detected for property "leftMargin"
Jun 30 09:44:36 manjaro plasmashell[1145]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jun 30 09:44:36 manjaro plasmashell[1145]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55c618fe52b0)
Jun 30 09:44:36 manjaro plasmashell[1145]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55c618fe50f0)
Jun 30 09:44:36 manjaro plasmashell[1145]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55c618fe50a0)
Jun 30 09:44:36 manjaro plasmashell[1145]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": I>
Jun 30 09:44:36 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jun 30 09:44:36 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jun 30 09:44:36 manjaro plasmashell[1145]: Activity added twice "47f063cc-56eb-4f25-b0c0-a48dadbd831c"
Jun 30 09:44:37 manjaro plasmashell[1145]: org.kde.klipper: Failed to load history resource. Clipboard history cannot be read. : History file does not exist
Jun 30 09:44:37 manjaro plasmashell[1145]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmo>
Jun 30 09:44:37 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for proper>
Jun 30 09:44:37 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jun 30 09:44:37 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jun 30 09:44:37 manjaro plasmashell[1145]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Jun 30 09:44:37 manjaro plasmashell[1145]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55c6194ff970)
Jun 30 09:44:37 manjaro plasmashell[1145]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55c6195007f0)
Jun 30 09:44:37 manjaro plasmashell[1145]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55c6194ff9c0)
Jun 30 09:44:37 manjaro plasmashell[1145]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55c619500840)
Jun 30 09:44:37 manjaro plasmashell[1145]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55c619ae6c50)
Jun 30 09:44:37 manjaro plasmashell[1145]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55c619b325c0)
Jun 30 09:44:37 manjaro plasmashell[1145]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 30 09:44:38 manjaro kwin_x11[1089]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3361, resource id: 4194357, major code: 18 (ChangeProperty), minor code: 0
Jun 30 09:44:38 manjaro kernel: psmouse serio1: Failed to deactivate mouse on isa0060/serio1: -5
Jun 30 09:44:40 manjaro plasmashell[1145]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jun 30 09:44:40 manjaro kwin_x11[1089]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3737, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
Jun 30 09:44:40 manjaro plasmashell[1145]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jun 30 09:44:42 manjaro plasmashell[1145]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jun 30 09:44:42 manjaro plasmashell[1145]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jun 30 09:44:42 manjaro kwin_x11[1089]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4080, resource id: 54525962, major code: 15 (QueryTree), minor code: 0
Jun 30 09:44:43 manjaro kernel: psmouse serio1: Failed to enable mouse on isa0060/serio1
Jun 30 09:44:43 manjaro kwin_x11[1089]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4295, resource id: 4194309, major code: 18 (ChangeProperty), minor code: 0
Jun 30 09:44:48 manjaro plasmashell[1145]: trying to show an empty dialog
Jun 30 09:44:55 manjaro kernel: kauditd_printk_skb: 6 callbacks suppressed
