Hello,
after the last update, my system hangs when it wakes from suspend or hibernate.
The keyboard is unresponsive and I am always forced to do hard reboot.
Sometimes the mouse pointer appears on the bottom right of the screen, but it is also unresponsive.
In my ‘journalctl -r’ I noticed that after the suspend, no entries are logged until the reboot starts, i.e. the wake up process loggs nothing. Observe between timestamps
09:03:56 and 09:06:06. That was when I tried to wake the system.
Δεκ 09 09:06:06 HEX kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=1b7c73b4-63d5-4ca9-919a-0b0934556445 rw quiet resume=UUID=1dd39edf-2f7b-415e-9113-2d2842978c70 udev.log_priority=3 sysrq_>
Δεκ 09 09:06:06 HEX kernel: Linux version 6.12.1-4-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Mon, 25 Nov 2024 05:36:03 +0000
-- Boot 5f4f83888ab34046949c02dfd1cdcac3 --
Δεκ 09 09:03:56 HEX kernel: Filesystems sync: 0.018 seconds
Δεκ 09 09:03:56 HEX kernel: PM: suspend entry (deep)
Δεκ 09 09:03:56 HEX systemd-sleep[3363]: Performing sleep operation 'suspend'...
Δεκ 09 09:03:56 HEX systemd-sleep[3363]: Successfully froze unit 'user.slice'.
Δεκ 09 09:03:56 HEX systemd[1]: Starting System Suspend...
Δεκ 09 09:03:56 HEX systemd[1]: Reached target Sleep.
Δεκ 09 09:03:55 HEX kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.9600] device (enp7s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Δεκ 09 09:03:55 HEX mullvad-daemon[871]: [mullvad_api::availability][DEBUG] Pausing API requests due to being offline
Δεκ 09 09:03:55 HEX mullvad-daemon[871]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Status { ipv4: false, ipv6: false }
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8143] dhcp6 (enp7s0): state changed no lease
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8143] dhcp6 (enp7s0): activation: beginning transaction (timeout in 45 seconds)
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8143] dhcp6 (enp7s0): canceled DHCP transaction
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8141] dhcp4 (enp7s0): state changed no lease
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8141] dhcp4 (enp7s0): activation: beginning transaction (timeout in 45 seconds)
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8141] dhcp4 (enp7s0): canceled DHCP transaction
Δεκ 09 09:03:55 HEX mullvad-daemon[871]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Status { ipv4: true, ipv6: false }
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.8137] device (enp7s0): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
Δεκ 09 09:03:55 HEX systemd[1]: Started Network Manager Script Dispatcher Service.
Δεκ 09 09:03:55 HEX kded6[2060]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Δεκ 09 09:03:55 HEX systemd[1]: Starting Network Manager Script Dispatcher Service...
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.7732] device (enp7s0): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.7731] manager: NetworkManager state is now ASLEEP
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.7728] device (wlp6s0): set-hw-addr: reset MAC address to 34:6F:24:DA:C9:79 (unmanage)
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.7725] device (wlp6s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Δεκ 09 09:03:55 HEX ModemManager[801]: <msg> [sleep-monitor-systemd] system is about to suspend
Δεκ 09 09:03:55 HEX NetworkManager[731]: <info> [1733731435.7723] manager: sleep: sleep requested (sleeping: no enabled: yes)
Δεκ 09 09:03:55 HEX systemd-logind[736]: The system will suspend now!
My system specs are:
Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
sysrq_always_enabled=1
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_wayland tools:
avail: xfce4-screensaver dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
serial: <filter> part-nu: SKU uuid: cc8431dd-2d3c-f758-4fa6-c87f540603c2
UEFI: American Megatrends v: 2803 date: 04/27/2022
System RAM: total: 32 GiB available: 31.23 GiB used: 3.81 GiB (12.2%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK16GX4M2D3000C16 serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
children: 1: 08:00.0 class-ID: 0604 type: bridge children: 1: 09:00.0
class-ID: 0604 type: bridge children: 1: 0a:00.0 class-ID: 0300
type: display 2: 0a:00.1 class-ID: 0403 type: audio
Slot: 1 type: PCIe status: available length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 2 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 4 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1f.7
Info: model: AMD Ryzen 5 3600X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 550 min/max: 550/4409 boost: enabled
base/boost: 3800/4400 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 550 2: 550 3: 550 4: 550 5: 550
6: 550 7: 550 8: 550 9: 550 10: 550 11: 550 12: 550 bogomips: 91064
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Gigabyte driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:73df
class-ID: 0300
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 6460x3840 s-dpi: 96 s-size: 1709x1016mm (67.28x40.00")
s-diag: 1988mm (78.28")
Monitor-1: DP-1 pos: top-right model: Dell P2723QE serial: <filter>
built: 2023 res: 2160x3840 hz: 60 dpi: 163 gamma: 1.2 chroma: red: x: 0.659
y: 0.329 green: x: 0.306 y: 0.647 blue: x: 0.149 y: 0.059 white: x: 0.314
y: 0.329 size: 336x597mm (13.23x23.5") diag: 685mm (27") ratio: 16:9
modes: 3840x2160, 2560x1440, 2048x1280, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 93
Monitor-2: DP-2 pos: primary,bottom-l model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2023 res: 4300x1800 hz: 144 dpi: 137 gamma: 1.2
chroma: red: x: 0.686 y: 0.306 green: x: 0.259 y: 0.671 blue: x: 0.149
y: 0.055 white: x: 0.314 y: 0.329 size: 800x335mm (31.5x13.19")
diag: 867mm (34.1") modes: 3440x1440, 1920x1200, 1920x1080, 1600x1200,
EDID-Warnings: 1: parse_edid: unknown tag 112
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 18.1.8 DRM 3.59 6.12.1-4-MANJARO) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.2.8-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 0a:00.1 chip-ID: 1002:ab28 class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 13d3:3563
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 4.55 TiB used: 1.73 TiB (38.1%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 105d 9h cycles: 2,165
read-units: 9,087,212 [4.65 TB] written-units: 8,992,346 [4.60 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 201d 3h cycles: 2,441
read-units: 9,743,179 [4.98 TB] written-units: 35,015,767 [17.9 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 21 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 319d 0h cycles: 923
written: 1.29 TiB
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20NMVW-11AV3S0 family: Elements / My Passport (USB, AF)
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 sata: 3.0 speed: 3.0 Gb/s
tech: HDD rpm: 5200 serial: <filter> fw-rev: 1022 drive-rev: 01.01A01
temp: 33 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 5y 83d 20h cycles: 739
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: ST1000LM025 HN-M101ABB
size: 931.5 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 3 scheme: MBR
ID-1: / raw-size: 431.08 GiB size: 423.25 GiB (98.18%)
used: 305.16 GiB (72.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:5 label: N/A uuid: 1b7c73b4-63d5-4ca9-919a-0b0934556445
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 28.7 MiB (9.7%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:2 label: N/A uuid: 32A8-B232
ID-3: /mnt/elements raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 743.63 GiB (39.9%) fs: ntfs block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: Elements uuid: 16DEA95BDEA93441
ID-4: /mnt/storage raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 725.68 GiB (79.2%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: hex-storage uuid: b96f3c3c-db76-4491-a1c5-7e1a34e3f816
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:7 label: swap
uuid: 1dd39edf-2f7b-415e-9113-2d2842978c70
ID-1: /dev/nvme0n1p1 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:4 size: 464.94 GiB fs: ntfs label: N/A
uuid: EE0616300615FA73
ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 821 MiB fs: ntfs label: N/A
uuid: 627C78E57C78B57F
ID-4: /dev/sdc1 maj-min: 8:33 size: 931.5 GiB fs: ntfs label: SAMSUNG
uuid: A814FE8714FE5830
Device-1: 1-5:2 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-7.2:5 info: NZXT Smart Device V2 type: HID
driver: nzxt-smart2,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2006 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: SINOWEALTH Game Mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 256mA chip-ID: 258a:1007 class-ID: 0301
Device-2: 3-4:3 info: Logitech G413 Gaming Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 046d:c33a class-ID: 0300
serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-1:2 info: Western Digital Elements Portable (WDBU6Y)
type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 1058:1048 class-ID: 0806 serial: <filter>
Device-2: 4-2:3 info: Samsung S2 Portable 3 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 8mA chip-ID: 04e8:60a8 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 41.0 C mobo: 40.0 C gpu: amdgpu temp: 56.0 C
mem: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1820 libs: 494 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
3: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 329
1: cpu: 8.4% command: firefox pid: 2020 mem: 648.3 MiB (2.0%)
2: cpu: 5.7% command: firefox pid: 2489 mem: 326.1 MiB (1.0%)
3: cpu: 2.6% command: kwin_wayland pid: 1302 mem: 332.6 MiB (1.0%)
4: cpu: 0.7% command: konsole pid: 2133 mem: 149.9 MiB (0.4%)
5: cpu: 0.6% command: firefox pid: 2401 mem: 282.6 MiB (0.8%)
Memory top: 5 of 329
1: mem: 711.4 MiB (2.2%) command: plasmashell pid: 1558 cpu: 0.4%
2: mem: 648.3 MiB (2.0%) command: firefox pid: 2020 cpu: 8.4%
3: mem: 332.6 MiB (1.0%) command: kwin_wayland pid: 1302 cpu: 2.6%
4: mem: 326.1 MiB (1.0%) command: firefox pid: 2489 cpu: 5.7%
5: mem: 282.6 MiB (0.8%) command: firefox pid: 2401 cpu: 0.6%
Processes: 329 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
Thank you in advance.
Georgios
