so i have
Version : 21.0.3-2
The version that alledgedly integrates corrections is 21.0.3-1 so i’m up to date on this.
Today i got 2 freeze in a row after 2 days of no problemo. The one thing that might have made a difference is that i put the comp on standby a couple times but not sure if that can impact.
May 04 18:27:05 systemd[1407]: tracker-extract-3.service: Succeeded.
May 04 18:27:14 kernel: [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
May 04 18:27:14 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=1606824, emitted seq=1606825
May 04 18:27:14 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset begin!
May 04 18:27:14 kernel: [drm] free PSP TMR buffer
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: MODE2 reset
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset succeeded, trying to resume
May 04 18:27:14 kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
May 04 18:27:14 kernel: [drm] PSP is resuming...
May 04 18:27:14 kernel: [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
May 04 18:27:14 kernel: [drm] kiq ring mec 2 pipe 1 q 0
May 04 18:27:14 kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: recover vram bo from shadow start
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: recover vram bo from shadow done
May 04 18:27:14 kernel: [drm] Skip scheduling IBs!
May 04 18:27:14 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset(1) succeeded!
May 04 18:27:15 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-BEACON-LOSS
May 04 18:27:16 kernel: sched: RT throttling activated
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119b802e0 flags=0x0070]
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119b80300 flags=0x0070]
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119bc0000 flags=0x0070]
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119b80320 flags=0x0070]
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119b80340 flags=0x0070]
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119b80360 flags=0x0070]
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x119b80380 flags=0x0070]
May 04 18:27:24 kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=05:00.0 domain=0x0000 address=0x119bc0000 flags=0x0070]
May 04 18:27:24 kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=05:00.0 domain=0x0000 address=0x119b803a0 flags=0x0070]
May 04 18:27:24 kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=05:00.0 domain=0x0000 address=0x119b803c0 flags=0x0070]
May 04 18:27:24 kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=05:00.0 domain=0x0000 address=0x119b803e0 flags=0x0070]
May 04 18:27:24 kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=05:00.0 domain=0x0000 address=0x119b80400 flags=0x0070]
May 04 18:27:24 kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=05:00.0 domain=0x0000 address=0x119b80420 flags=0x0070]
May 04 18:27:24 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=5852587, emitted seq=5852590
May 04 18:27:24 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xwayland pid 1531 thread Xwayland:cs0 pid 1908
May 04 18:27:24 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset begin!
May 04 18:27:25 kernel: [drm] free PSP TMR buffer
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: MODE2 reset
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset succeeded, trying to resume
May 04 18:27:25 kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
May 04 18:27:25 kernel: [drm] PSP is resuming...
May 04 18:27:25 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=ac:f8:cc:07:dc:b2 reason=4 locally_generated=1
May 04 18:27:25 kernel: rtw_8822be 0000:04:00.0: sta ac:f8:cc:07:dc:b2 with macid 0 left
May 04 18:27:25 kernel: [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
May 04 18:27:25 kernel: [drm] kiq ring mec 2 pipe 1 q 0
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring sdma0 test failed (-110)
May 04 18:27:25 kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <sdma_v4_0> failed -110
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset(3) failed
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: couldn't schedule ib on ring <sdma0>
May 04 18:27:25 kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset end with ret = -110
May 04 18:27:25 kernel: [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
May 04 18:27:25 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
May 04 18:27:25 NetworkManager[542]: <info> [1620145645.6914] device (wlp4s0): supplicant interface state: completed -> scanning
May 04 18:27:27 audit[10228]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=10228 comm="GpuWatchdog" exe="/app/extra/share/skypeforlinux/skypeforlinux" sig=11 res=1
May 04 18:27:27 systemd[1]: Created slice system-systemd\x2dcoredump.slice.
May 04 18:27:27 audit: BPF prog-id=35 op=LOAD
May 04 18:27:27 audit: BPF prog-id=36 op=LOAD
May 04 18:27:27 systemd[1]: Started Process Core Dump (PID 33633/UID 0).
May 04 18:27:27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-33633-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 04 18:27:32 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
May 04 18:27:35 wpa_supplicant[686]: wlp4s0: SME: Trying to authenticate with ac:f8:cc:07:dc:b2 (SSID='V&T' freq=5500 MHz)
May 04 18:27:35 kernel: wlp4s0: authenticate with ac:f8:cc:07:dc:b2
May 04 18:27:35 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
May 04 18:27:35 NetworkManager[542]: <info> [1620145655.9486] device (wlp4s0): supplicant interface state: scanning -> authenticating
May 04 18:27:35 kernel: wlp4s0: send auth to ac:f8:cc:07:dc:b2 (try 1/3)
May 04 18:27:35 wpa_supplicant[686]: wlp4s0: Trying to associate with ac:f8:cc:07:dc:b2 (SSID='V&T' freq=5500 MHz)
May 04 18:27:35 kernel: wlp4s0: authenticated
May 04 18:27:35 kernel: wlp4s0: associate with ac:f8:cc:07:dc:b2 (try 1/3)
May 04 18:27:35 NetworkManager[542]: <info> [1620145655.9670] device (wlp4s0): supplicant interface state: authenticating -> associating
May 04 18:27:36 wpa_supplicant[686]: wlp4s0: Associated with ac:f8:cc:07:dc:b2
May 04 18:27:36 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
May 04 18:27:36 kernel: wlp4s0: RX AssocResp from ac:f8:cc:07:dc:b2 (capab=0x11 status=0 aid=5)
May 04 18:27:36 kernel: rtw_8822be 0000:04:00.0: sta ac:f8:cc:07:dc:b2 joined with macid 0
May 04 18:27:36 kernel: wlp4s0: associated
May 04 18:27:36 NetworkManager[542]: <info> [1620145656.0204] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
May 04 18:27:36 NetworkManager[542]: <info> [1620145656.0205] device (wlp4s0): DHCPv4 lease renewal requested
May 04 18:27:36 NetworkManager[542]: <info> [1620145656.0206] dhcp4 (wlp4s0): canceled DHCP transaction
May 04 18:27:36 NetworkManager[542]: <info> [1620145656.0206] dhcp4 (wlp4s0): state changed extended -> terminated
May 04 18:27:36 NetworkManager[542]: <info> [1620145656.0213] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
May 04 18:27:36 wpa_supplicant[686]: wlp4s0: WPA: Key negotiation completed with ac:f8:cc:07:dc:b2 [PTK=CCMP GTK=CCMP]
May 04 18:27:36 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to ac:f8:cc:07:dc:b2 completed [id=0 id_str=]
May 04 18:27:36 NetworkManager[542]: <info> [1620145656.0607] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
May 04 18:27:36 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-45 noise=9999 txrate=585000
May 04 18:27:38 NetworkManager[542]: <info> [1620145658.0661] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.1.50
May 04 18:27:38 dbus-daemon[541]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=542 comm="/usr/bin/NetworkManager --no-daemon ")
May 04 18:27:38 systemd[1]: Starting Network Manager Script Dispatcher Service...
May 04 18:27:39 geoclue[1602]: Failed to query location: Error resolving “location.services.mozilla.com”: Name or service not known
May 04 18:27:39 wpa_supplicant[686]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
May 04 18:27:45 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
May 04 18:28:00 audit[33645]: USER_AUTH pid=33645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 kernel: kauditd_printk_skb: 156 callbacks suppressed
May 04 18:28:00 kernel: audit: type=1100 audit(1620145680.567:378): pid=33645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 dbus-daemon[541]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.384' (uid=0 pid=33645 comm="sshd: gh0st [priv] ")
May 04 18:28:00 dbus-daemon[541]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 04 18:28:00 sshd[33645]: pam_systemd_home(sshd:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 04 18:28:00 audit[33645]: USER_ACCT pid=33645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 sshd[33645]: Accepted password for gh0st from 192.168.1.201 port 44582 ssh2
May 04 18:28:00 audit[33645]: CRED_ACQ pid=33645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 audit[33645]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffcf36e2010 a2=4 a3=3e8 items=0 ppid=568 pid=33645 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="sshd" exe="/usr/bin/sshd" subj==unconfined key=(null)
May 04 18:28:00 audit: PROCTITLE proctitle=737368643A206768307374205B707269765D
May 04 18:28:00 sshd[33645]: pam_unix(sshd:session): session opened for user gh0st(uid=1000) by (uid=0)
May 04 18:28:00 kernel: audit: type=1101 audit(1620145680.577:379): pid=33645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 kernel: audit: type=1103 audit(1620145680.577:380): pid=33645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 kernel: audit: type=1006 audit(1620145680.577:381): pid=33645 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=5 res=1
May 04 18:28:00 kernel: audit: type=1300 audit(1620145680.577:381): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffcf36e2010 a2=4 a3=3e8 items=0 ppid=568 pid=33645 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="sshd" exe="/usr/bin/sshd" subj==unconfined key=(null)
May 04 18:28:00 kernel: audit: type=1327 audit(1620145680.577:381): proctitle=737368643A206768307374205B707269765D
May 04 18:28:00 systemd-logind[546]: New session 5 of user gh0st.
May 04 18:28:00 systemd[1]: Started Session 5 of user gh0st.
May 04 18:28:00 sshd[33645]: pam_env(sshd:session): deprecated reading of user environment enabled
May 04 18:28:00 audit[33645]: USER_START pid=33645 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 audit[33647]: CRED_ACQ pid=33647 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 kernel: audit: type=1105 audit(1620145680.593:382): pid=33645 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:00 kernel: audit: type=1103 audit(1620145680.593:383): pid=33647 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gh0st" exe="/usr/bin/sshd" hostname=192.168.1.201 addr=192.168.1.201 terminal=ssh res=success'
May 04 18:28:03 dbus-daemon[541]: [system] Failed to activate service 'org.freedesktop.nm_dispatcher': timed out (service_start_timeout=25000ms)
