Yes, now that I checked.
Apr 18 15:21:16 fakefred kernel: audit: type=1334 audit(1618730476.763:9): prog-id=5 op=LOAD
Apr 18 15:21:16 fakefred kernel: audit: type=1334 audit(1618730476.763:10): prog-id=6 op=LOAD
Apr 18 15:21:16 fakefred kernel: usb 3-2: New USB device found, idVendor=13d3, idProduct=56a6, bcdDevice=17.11
Apr 18 15:21:16 fakefred kernel: usb 3-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Apr 18 15:21:16 fakefred kernel: usb 3-2: Product: Integrated Camera
Apr 18 15:21:16 fakefred kernel: usb 3-2: Manufacturer: Azurewave
Apr 18 15:21:16 fakefred kernel: usb 3-2: SerialNumber: 0001
Apr 18 15:21:16 fakefred kernel: acpi_cpufreq: overriding BIOS provided _PSD data
Apr 18 15:21:16 fakefred kernel: r8168: loading out-of-tree module taints kernel.
Apr 18 15:21:17 fakefred kernel: ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
Apr 18 15:21:17 fakefred kernel: acpi device:08: registered as cooling_device8
Apr 18 15:21:17 fakefred kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:07/LNXVIDEO:00/input/input6
Apr 18 15:21:17 fakefred kernel: r8168: module verification failed: signature and/or required key missing - tainting kernel
Apr 18 15:21:17 fakefred kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Apr 18 15:21:17 fakefred kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Apr 18 15:21:17 fakefred kernel: r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
Apr 18 15:21:17 fakefred kernel: piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
Apr 18 15:21:17 fakefred kernel: piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
Apr 18 15:21:17 fakefred kernel: piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
Apr 18 15:21:17 fakefred kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
Apr 18 15:21:17 fakefred kernel: sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
Apr 18 15:21:17 fakefred kernel: sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
Apr 18 15:21:17 fakefred kernel: r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
Apr 18 15:21:17 fakefred kernel: r8168 Copyright (C) 2020 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
Apr 18 15:21:17 fakefred kernel: random: mktemp: uninitialized urandom read (6 bytes read)
Apr 18 15:21:17 fakefred kernel: Adding 9227464k swap on /dev/nvme0n1p3. Priority:-2 extents:1 across:9227464k SSFS
Apr 18 15:21:17 fakefred kernel: ccp 0000:05:00.2: enabling device (0000 -> 0002)
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: ThinkPad ACPI Extras v0.26
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: http://ibm-acpi.sf.net/
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: ThinkPad BIOS R0UET65W (1.45 ), EC R0UHT65W
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: Lenovo ThinkPad E485, model 20KUA001CD
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: radio switch found; radios are enabled
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
Apr 18 15:21:17 fakefred kernel: ccp 0000:05:00.2: ccp enabled
Apr 18 15:21:17 fakefred kernel: ccp 0000:05:00.2: psp: unable to access the device: you might be running a broken BIOS.
Apr 18 15:21:17 fakefred kernel: input: PC Speaker as /devices/platform/pcspkr/input/input8
Apr 18 15:21:17 fakefred kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
Apr 18 15:21:17 fakefred kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Apr 18 15:21:17 fakefred kernel: cryptd: max_cpu_qlen set to 1000
Apr 18 15:21:17 fakefred kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Apr 18 15:21:17 fakefred kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Apr 18 15:21:17 fakefred kernel: AVX2 version of gcm_enc/dec engaged.
Apr 18 15:21:17 fakefred kernel: AES CTR mode by8 optimization enabled
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
Apr 18 15:21:17 fakefred kernel: r8168 0000:02:00.0 enp2s0: renamed from eth0
Apr 18 15:21:17 fakefred kernel: thinkpad_acpi: battery 1 registered (start 95, stop 100)
Apr 18 15:21:17 fakefred kernel: battery: new extension: ThinkPad Battery Extension
Apr 18 15:21:17 fakefred kernel: input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input7
Apr 18 15:21:17 fakefred kernel: kvm: Nested Virtualization enabled
Apr 18 15:21:17 fakefred kernel: SVM: kvm: Nested Paging enabled
Apr 18 15:21:17 fakefred kernel: SVM: Virtual VMLOAD VMSAVE supported
Apr 18 15:21:17 fakefred kernel: SVM: Virtual GIF supported
Apr 18 15:21:17 fakefred kernel: MCE: In-kernel MCE decoding enabled.
Apr 18 15:21:17 fakefred kernel: EDAC amd64: F17h_M10h detected (node 0).
Apr 18 15:21:17 fakefred kernel: EDAC amd64: Node 0: DRAM ECC disabled.
Apr 18 15:21:17 fakefred kernel: snd_hda_intel 0000:05:00.1: enabling device (0000 -> 0002)
Apr 18 15:21:17 fakefred kernel: snd_hda_intel 0000:05:00.1: Handle vga_switcheroo audio client
Apr 18 15:21:17 fakefred kernel: snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
Apr 18 15:21:17 fakefred kernel: input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:05:00.1/sound/card0/input10
Apr 18 15:21:17 fakefred kernel: input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:05:00.1/sound/card0/input11
Apr 18 15:21:17 fakefred kernel: input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:05:00.1/sound/card0/input12
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: CX20753/4: BIOS auto-probing.
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20753/4: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: mono: mono_out=0x0
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: inputs:
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: Internal Mic=0x1a
Apr 18 15:21:17 fakefred kernel: snd_hda_codec_conexant hdaudioC1D0: Mic=0x19
Apr 18 15:21:17 fakefred kernel: intel_rapl_common: Found RAPL domain package
Apr 18 15:21:17 fakefred kernel: intel_rapl_common: Found RAPL domain core
Apr 18 15:21:17 fakefred kernel: input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input13
Apr 18 15:21:17 fakefred kernel: input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input14
Apr 18 15:21:17 fakefred kernel: ath10k_pci 0000:04:00.0: enabling device (0000 -> 0002)
Apr 18 15:21:17 fakefred kernel: ath10k_pci 0000:04:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Apr 18 15:21:17 fakefred kernel: [drm] amdgpu kernel modesetting enabled.
Apr 18 15:21:17 fakefred kernel: amdgpu: Topology: Add APU node [0x0:0x0]
Apr 18 15:21:17 fakefred kernel: checking generic (b0000000 7f0000) vs hw (b0000000 10000000)
Apr 18 15:21:17 fakefred kernel: fb0: switching to amdgpudrmfb from EFI VGA
Apr 18 15:21:17 fakefred kernel: Console: switching to colour dummy device 80x25
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: vgaarb: deactivate vga console
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: enabling device (0006 -> 0007)
Apr 18 15:21:17 fakefred kernel: [drm] initializing kernel modesetting (RAVEN 0x1002:0x15DD 0x17AA:0x506F 0xC4).
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Apr 18 15:21:17 fakefred kernel: [drm] register mmio base: 0xC0800000
Apr 18 15:21:17 fakefred kernel: [drm] register mmio size: 524288
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 0 <soc15_common>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 1 <gmc_v9_0>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 2 <vega10_ih>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 3 <psp>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 4 <gfx_v9_0>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 5 <sdma_v4_0>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 6 <powerplay>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 7 <dm>
Apr 18 15:21:17 fakefred kernel: [drm] add ip block number 8 <vcn_v1_0>
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Fetched VBIOS from VFCT
Apr 18 15:21:17 fakefred kernel: amdgpu: ATOM BIOS: 113-RAVEN-106
Apr 18 15:21:17 fakefred kernel: [drm] VCN decode is enabled in VM mode
Apr 18 15:21:17 fakefred kernel: [drm] VCN encode is enabled in VM mode
Apr 18 15:21:17 fakefred kernel: [drm] JPEG decode is enabled in VM mode
Apr 18 15:21:17 fakefred kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VRAM: 256M 0x000000F400000000 - 0x000000F40FFFFFFF (256M used)
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Apr 18 15:21:17 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Apr 18 15:21:17 fakefred kernel: [drm] Detected VRAM RAM=256M, BAR=256M
Apr 18 15:21:17 fakefred kernel: [drm] RAM width 128bits DDR4
Apr 18 15:21:17 fakefred kernel: [TTM] Zone kernel: Available graphics memory: 3880308 KiB
Apr 18 15:21:17 fakefred kernel: [TTM] Zone dma32: Available graphics memory: 2097152 KiB
Apr 18 15:21:17 fakefred kernel: [drm] amdgpu: 256M of VRAM memory ready
Apr 18 15:21:17 fakefred kernel: [drm] amdgpu: 3072M of GTT memory ready.
Apr 18 15:21:17 fakefred kernel: [drm] GART: num cpu pages 262144, num gpu pages 262144
Apr 18 15:21:17 fakefred kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Apr 18 15:21:17 fakefred kernel: tun: Universal TUN/TAP device driver, 1.6
Apr 18 15:21:17 fakefred kernel: amdgpu: hwmgr_sw_init smu backed is smu10_smu
Apr 18 15:21:17 fakefred kernel: [drm] Found VCN firmware Version ENC: 1.12 DEC: 2 VEP: 0 Revision: 5
Apr 18 15:21:17 fakefred kernel: [drm] PSP loading VCN firmware
Apr 18 15:21:17 fakefred kernel: [drm] reserve 0x400000 from 0xf40fc00000 for PSP TMR
Apr 18 15:21:17 fakefred kernel: random: crng init done
Apr 18 15:21:17 fakefred kernel: random: 6 urandom warning(s) missed due to ratelimiting
Apr 18 15:21:17 fakefred kernel: pcieport 0000:00:01.6: AER: Multiple Corrected error received: 0000:00:01.0
Apr 18 15:21:17 fakefred kernel: pcieport 0000:00:01.6: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
Apr 18 15:21:17 fakefred kernel: pcieport 0000:00:01.6: device [1022:15d3] error status/mask=00000040/00006000
Apr 18 15:21:17 fakefred kernel: pcieport 0000:00:01.6: [ 6] BadTLP
Apr 18 15:21:17 fakefred kernel: enp2s0: 0xffffa2bac02c1000, e8:6a:64:4a:8d:7d, IRQ 64
Apr 18 15:21:17 fakefred kernel: ath10k_pci 0000:04:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
Apr 18 15:21:17 fakefred kernel: ath10k_pci 0000:04:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
Apr 18 15:21:17 fakefred kernel: ath10k_pci 0000:04:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
Apr 18 15:21:18 fakefred kernel: ath10k_pci 0000:04:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
Apr 18 15:21:18 fakefred kernel: psmouse serio1: synaptics: queried max coordinates: x [..5676], y [..4690]
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
Apr 18 15:21:18 fakefred kernel: ath10k_pci 0000:04:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
Apr 18 15:21:18 fakefred kernel: [drm] kiq ring mec 2 pipe 1 q 0
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: values for F clock
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 400000 in kHz, 3174 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 933000 in kHz, 3724 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 1067000 in kHz, 3924 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 1200000 in kHz, 4074 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: values for DCF clock
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 300000 in kHz, 3174 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 600000 in kHz, 3724 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 626000 in kHz, 3924 in mV
Apr 18 15:21:18 fakefred kernel: [drm] DM_PPLIB: 654000 in kHz, 4074 in mV
Apr 18 15:21:18 fakefred kernel: [drm] Display Core initialized with v3.2.116!
Apr 18 15:21:18 fakefred kernel: psmouse serio1: synaptics: queried min coordinates: x [1266..], y [1162..]
Apr 18 15:21:18 fakefred kernel: psmouse serio1: synaptics: Your touchpad (PNP: LEN2060 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
Apr 18 15:21:18 fakefred kernel: snd_hda_intel 0000:05:00.1: bound 0000:05:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Apr 18 15:21:18 fakefred kernel: ath: EEPROM regdomain: 0x6c
Apr 18 15:21:18 fakefred kernel: ath: EEPROM indicates we should expect a direct regpair map
Apr 18 15:21:18 fakefred kernel: ath: Country alpha2 being used: 00
Apr 18 15:21:18 fakefred kernel: ath: Regpair used: 0x6c
Apr 18 15:21:18 fakefred kernel: psmouse serio1: synaptics: Touchpad model: 1, fw: 8.16, id: 0x1e2b1, caps: 0xf016a3/0x940300/0x12e800/0x400000, board id: 3383, fw id: 2731746
Apr 18 15:21:18 fakefred kernel: psmouse serio1: synaptics: serio: Synaptics pass-through port at isa0060/serio1/input0
Apr 18 15:21:18 fakefred kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
Apr 18 15:21:18 fakefred kernel: EDAC amd64: F17h_M10h detected (node 0).
Apr 18 15:21:18 fakefred kernel: EDAC amd64: Node 0: DRAM ECC disabled.
Apr 18 15:21:18 fakefred kernel: kfd kfd: Allocated 3969056 bytes on gart
Apr 18 15:21:18 fakefred kernel: kfd kfd: error getting iommu info. is the iommu enabled?
Apr 18 15:21:18 fakefred kernel: kfd kfd: Error initializing iommuv2
Apr 18 15:21:18 fakefred kernel: kfd kfd: device 1002:15dd NOT added due to errors
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 11, active_cu_number 8
Apr 18 15:21:18 fakefred kernel: [drm] fb mappable at 0xA0BCA000
Apr 18 15:21:18 fakefred kernel: [drm] vram apper at 0xA0000000
Apr 18 15:21:18 fakefred kernel: [drm] size 8294400
Apr 18 15:21:18 fakefred kernel: [drm] fb depth is 24
Apr 18 15:21:18 fakefred kernel: [drm] pitch is 7680
Apr 18 15:21:18 fakefred kernel: fbcon: amdgpudrmfb (fb0) is primary device
Apr 18 15:21:18 fakefred kernel: ath10k_pci 0000:04:00.0 wlp4s0: renamed from wlan0
Apr 18 15:21:18 fakefred kernel: Console: switching to colour frame buffer device 240x67
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: AER: Corrected error received: 0000:00:01.0
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: device [1022:15d3] error status/mask=00000040/00006000
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: [ 6] BadTLP
Apr 18 15:21:18 fakefred kernel: mc: Linux media interface: v0.10
Apr 18 15:21:18 fakefred kernel: input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input9
Apr 18 15:21:18 fakefred kernel: input: Lenovo Laser Wireless Mouse as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4:1.0/0003:17EF:6039.0001/input/input16
Apr 18 15:21:18 fakefred kernel: hid-generic 0003:17EF:6039.0001: input,hidraw0: USB HID v1.11 Mouse [Lenovo Laser Wireless Mouse] on usb-0000:05:00.3-4/input0
Apr 18 15:21:18 fakefred kernel: usbcore: registered new interface driver usbhid
Apr 18 15:21:18 fakefred kernel: usbhid: USB HID core driver
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Apr 18 15:21:18 fakefred kernel: mousedev: PS/2 mouse device common for all mice
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: AER: Multiple Corrected error received: 0000:00:01.0
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: device [1022:15d3] error status/mask=00000080/00006000
Apr 18 15:21:18 fakefred kernel: pcieport 0000:00:01.6: [ 7] BadDLLP
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Apr 18 15:21:18 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Apr 18 15:21:18 fakefred kernel: videodev: Linux video capture interface: v2.00
Apr 18 15:21:18 fakefred kernel: Bluetooth: Core ver 2.22
Apr 18 15:21:18 fakefred kernel: NET: Registered protocol family 31
Apr 18 15:21:18 fakefred kernel: Bluetooth: HCI device and connection manager initialized
Apr 18 15:21:18 fakefred kernel: Bluetooth: HCI socket layer initialized
Apr 18 15:21:18 fakefred kernel: Bluetooth: L2CAP socket layer initialized
Apr 18 15:21:18 fakefred kernel: Bluetooth: SCO socket layer initialized
Apr 18 15:21:18 fakefred kernel: [drm] Initialized amdgpu 3.40.0 20150101 for 0000:05:00.0 on minor 0
Apr 18 15:21:18 fakefred kernel: usbcore: registered new interface driver btusb
Apr 18 15:21:18 fakefred kernel: uvcvideo: Found UVC 1.00 device Integrated Camera (13d3:56a6)
Apr 18 15:21:18 fakefred kernel: input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-2/3-2:1.0/input/input17
Apr 18 15:21:18 fakefred kernel: usbcore: registered new interface driver uvcvideo
Apr 18 15:21:18 fakefred kernel: USB Video Class driver (1.1.1)
Apr 18 15:21:18 fakefred kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Apr 18 15:21:18 fakefred kernel: Bluetooth: BNEP filters: protocol multicast
Apr 18 15:21:18 fakefred kernel: Bluetooth: BNEP socket layer initialized
Apr 18 15:21:18 fakefred kernel: NET: Registered protocol family 38
Apr 18 15:21:18 fakefred kernel: psmouse serio2: trackpoint: Elan TrackPoint firmware: 0x11, buttons: 3/3
Apr 18 15:21:19 fakefred kernel: input: TPPS/2 Elan TrackPoint as /devices/platform/i8042/serio1/serio2/input/input15
Apr 18 15:21:20 fakefred kernel: kauditd_printk_skb: 38 callbacks suppressed
Apr 18 15:21:20 fakefred kernel: audit: type=1100 audit(1618730480.463:49): pid=1170 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:20 fakefred kernel: audit: type=1101 audit(1618730480.463:50): pid=1170 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:20 fakefred kernel: audit: type=1103 audit(1618730480.463:51): pid=1170 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:20 fakefred kernel: audit: type=1130 audit(1618730480.493:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:20 fakefred kernel: audit: type=1101 audit(1618730480.503:53): pid=1180 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:20 fakefred kernel: audit: type=1103 audit(1618730480.503:54): pid=1180 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 18 15:21:20 fakefred kernel: audit: type=1006 audit(1618730480.503:55): pid=1180 uid=0 old-auid=4294967295 auid=973 tty=(none) old-ses=4294967295 ses=1 res=1
Apr 18 15:21:20 fakefred kernel: audit: type=1300 audit(1618730480.503:55): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fff4cc0df90 a2=3 a3=3cd items=0 ppid=1 pid=1180 auid=973 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
Apr 18 15:21:20 fakefred kernel: audit: type=1327 audit(1618730480.503:55): proctitle="(systemd)"
Apr 18 15:21:20 fakefred kernel: audit: type=1105 audit(1618730480.506:56): pid=1180 uid=0 auid=973 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:25 fakefred kernel: kauditd_printk_skb: 30 callbacks suppressed
Apr 18 15:21:25 fakefred kernel: audit: type=1130 audit(1618730485.466:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:25 fakefred kernel: audit: type=1105 audit(1618730485.533:80): pid=1942 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="fakefred" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Apr 18 15:21:27 fakefred kernel: audit: type=1130 audit(1618730487.679:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:28 fakefred kernel: audit: type=1131 audit(1618730488.039:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:28 fakefred kernel: Bluetooth: RFCOMM TTY layer initialized
Apr 18 15:21:28 fakefred kernel: Bluetooth: RFCOMM socket layer initialized
Apr 18 15:21:28 fakefred kernel: Bluetooth: RFCOMM ver 1.11
Apr 18 15:21:33 fakefred kernel: wlp4s0: authenticate with d8:32:14:ff:5e:61
Apr 18 15:21:33 fakefred kernel: wlp4s0: send auth to d8:32:14:ff:5e:61 (try 1/3)
Apr 18 15:21:33 fakefred kernel: wlp4s0: authenticated
Apr 18 15:21:33 fakefred kernel: wlp4s0: associate with d8:32:14:ff:5e:61 (try 1/3)
Apr 18 15:21:33 fakefred kernel: wlp4s0: RX AssocResp from d8:32:14:ff:5e:61 (capab=0x411 status=0 aid=5)
Apr 18 15:21:33 fakefred kernel: wlp4s0: associated
Apr 18 15:21:33 fakefred kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
Apr 18 15:21:33 fakefred kernel: audit: type=1130 audit(1618730493.953:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:35 fakefred kernel: audit: type=1131 audit(1618730495.659:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:35 fakefred kernel: audit: type=1131 audit(1618730495.679:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:44 fakefred kernel: audit: type=1131 audit(1618730504.036:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:48 fakefred kernel: audit: type=1131 audit(1618730508.463:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:21:48 fakefred kernel: audit: type=1334 audit(1618730508.586:88): prog-id=10 op=UNLOAD
Apr 18 15:21:48 fakefred kernel: audit: type=1334 audit(1618730508.586:89): prog-id=9 op=UNLOAD
Apr 18 15:23:54 fakefred kernel: audit: type=1130 audit(1618730634.499:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:24:01 fakefred kernel: usb 1-2: new high-speed USB device number 3 using xhci_hcd
Apr 18 15:24:02 fakefred kernel: usb 1-2: New USB device found, idVendor=2717, idProduct=ff40, bcdDevice= 4.04
Apr 18 15:24:02 fakefred kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 18 15:24:02 fakefred kernel: usb 1-2: Product: MI 6
Apr 18 15:24:02 fakefred kernel: usb 1-2: Manufacturer: Xiaomi
Apr 18 15:24:02 fakefred kernel: usb 1-2: SerialNumber: 639335a0
Apr 18 15:24:02 fakefred kernel: usb 1-2: USB disconnect, device number 3
Apr 18 15:24:03 fakefred kernel: usb 1-2: new high-speed USB device number 4 using xhci_hcd
Apr 18 15:24:03 fakefred kernel: usb 1-2: New USB device found, idVendor=2717, idProduct=ff80, bcdDevice= 4.04
Apr 18 15:24:03 fakefred kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 18 15:24:03 fakefred kernel: usb 1-2: Product: MI 6
Apr 18 15:24:03 fakefred kernel: usb 1-2: Manufacturer: Xiaomi
Apr 18 15:24:03 fakefred kernel: usb 1-2: SerialNumber: 639335a0
Apr 18 15:24:04 fakefred kernel: usbcore: registered new interface driver cdc_ether
Apr 18 15:24:04 fakefred kernel: rndis_host 1-2:1.0 usb0: register 'rndis_host' at usb-0000:05:00.3-2, RNDIS device, ba:c3:34:09:2e:17
Apr 18 15:24:04 fakefred kernel: usbcore: registered new interface driver rndis_host
Apr 18 15:24:04 fakefred kernel: rndis_host 1-2:1.0 enp5s0f3u2: renamed from usb0
Apr 18 15:24:04 fakefred kernel: audit: type=1130 audit(1618730644.129:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:24:10 fakefred kernel: audit: type=1131 audit(1618730650.328:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:24:14 fakefred kernel: audit: type=1131 audit(1618730654.042:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 18 15:24:37 fakefred kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
Apr 18 15:24:38 fakefred kernel: sched: RT throttling activated
Apr 18 15:24:38 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32776, for process minetest pid 30628 thread minetest:cs0 pid 30652)
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108301000 from client 27
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Faulty UTCL2 client ID: TCP (0x8)
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MORE_FAULTS: 0x1
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: WALKER_ERROR: 0x0
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: PERMISSION_FAULTS: 0x5
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MAPPING_ERROR: 0x0
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RW: 0x1
Apr 18 15:24:39 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32776, for process minetest pid 30628 thread minetest:cs0 pid 30652)
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108300000 from client 27
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x004C0071
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Faulty UTCL2 client ID: CB (0x0)
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MORE_FAULTS: 0x1
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: WALKER_ERROR: 0x0
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: PERMISSION_FAULTS: 0x7
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MAPPING_ERROR: 0x0
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RW: 0x1
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32776, for process minetest pid 30628 thread minetest:cs0 pid 30652)
Apr 18 15:24:40 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108305000 from client 27
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108304000 from client 27
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x004C0071
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Faulty UTCL2 client ID: CB (0x0)
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MORE_FAULTS: 0x1
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: WALKER_ERROR: 0x0
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: PERMISSION_FAULTS: 0x7
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MAPPING_ERROR: 0x0
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RW: 0x1
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32776, for process minetest pid 30628 thread minetest:cs0 pid 30652)
Apr 18 15:24:41 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108307000 from client 27
Apr 18 15:24:42 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x004C0071
Apr 18 15:24:42 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Faulty UTCL2 client ID: CB (0x0)
Apr 18 15:24:43 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MORE_FAULTS: 0x1
Apr 18 15:24:43 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: WALKER_ERROR: 0x0
Apr 18 15:24:44 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: PERMISSION_FAULTS: 0x7
Apr 18 15:24:44 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MAPPING_ERROR: 0x0
Apr 18 15:24:44 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RW: 0x1
Apr 18 15:24:46 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32776, for process minetest pid 30628 thread minetest:cs0 pid 30652)
Apr 18 15:24:46 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108303000 from client 27
Apr 18 15:24:46 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x004C0071
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: Faulty UTCL2 client ID: CB (0x0)
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MORE_FAULTS: 0x1
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: WALKER_ERROR: 0x0
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: PERMISSION_FAULTS: 0x7
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: MAPPING_ERROR: 0x0
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RW: 0x1
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32776, for process minetest pid 30628 thread minetest:cs0 pid 30652)
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108306000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x004C0071
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108302000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108309000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x800108308000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x80010830d000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x80010830c000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x80010830f000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x80010830b000 from client 27
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: in page starting at address 0x80010830e000 from client 27
Apr 18 15:24:47 fakefred kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=17440, emitted seq=17443
Apr 18 15:24:47 fakefred kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process minetest pid 30628 thread minetest:cs0 pid 30652
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset begin!
Apr 18 15:24:47 fakefred kernel: [drm] free PSP TMR buffer
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset succeeded, trying to resume
Apr 18 15:24:47 fakefred kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Apr 18 15:24:47 fakefred kernel: [drm] PSP is resuming...
Apr 18 15:24:47 fakefred kernel: [drm] reserve 0x400000 from 0xf40fc00000 for PSP TMR
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
Apr 18 15:24:47 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
Apr 18 15:24:48 fakefred kernel: [drm] kiq ring mec 2 pipe 1 q 0
Apr 18 15:24:48 fakefred kernel: amdgpu 0000:05:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
Apr 18 15:24:48 fakefred kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v9_0> failed -110
Apr 18 15:24:48 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset(3) failed
Apr 18 15:24:48 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset end with ret = -110
Apr 18 15:24:58 fakefred kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
Apr 18 15:24:58 fakefred kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=1305, emitted seq=1307
Apr 18 15:24:58 fakefred kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0
Apr 18 15:24:58 fakefred kernel: amdgpu 0000:05:00.0: amdgpu: GPU reset begin!
Looks like there has been a failed GPU reset, at the end of the log?
