System freezes for around 1 minute while playing a video on Kaffeine
or vlc media player
Output of the below command:
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=06d7363a-23c3-4c3d-97e3-3bc65484e084 ro quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513IA_KM513IA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X513IA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X513IA.300 date: 06/05/2020
ID-1: BAT0 charge: 6.0 Wh (16.6%) condition: 36.2/42.1 Wh (86.1%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 363
RAM: total: 7.26 GiB used: 4.06 GiB (55.9%)
Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 cache: L2: 4 MiB bogomips: 31952
Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1400 8: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.68-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.2 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 85.07 GiB (7.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM256GDJTNG-8310A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 80001C00 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-80Z10T2
type: HDD rpm: 5400 serial: <filter> rev: 1A04 scheme: GPT
ID-1: / raw-size: 52.2 GiB size: 51.13 GiB (97.95%) used: 33.32 GiB (65.2%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 06d7363a-23c3-4c3d-97e3-3bc65484e084
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 66.8 MiB (26.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: DA44-C033
ID-3: /home raw-size: 34.8 GiB size: 34 GiB (97.71%) used: 22.34 GiB (65.7%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 941c21f5-3c1e-45ab-8989-ce9c68b0c218
ID-4: /run/timeshift/backup raw-size: 30 GiB size: 29.36 GiB (97.86%)
used: 29.34 GiB (99.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
label: Manjaro-recovery uuid: ab4be4b9-eb3d-43ea-a32c-8763e70be217
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 150.18 GiB fs: ntfs label: OS
uuid: DC20475720473832
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.03 GiB fs: ntfs label: RECOVERY
uuid: E6BAAD46BAAD13D9
ID-4: /dev/sda1 maj-min: 8:1 size: 901.51 GiB fs: ntfs label: New Volume
uuid: 800C3F790C3F6974
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-4:2 info: No brand USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 2188:0ae1 class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 3-3:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): cpu: 0
Processes: 270 Uptime: 1d 14h 9m wakeups: 35 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1391 lib: 390
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
