Ok, so as the title suggests, my Laptop absolutely FREEZES!! while playing DOTA2. The background music keeps on playing but that’s it. No keyboard, no touchpad gestures nothing. And there’s no stuttering or lagging before( the thermals are good too) it just goes kaput. I thought Manjaro was meant to be a ‘gaming-friendly’ distro. Each time I’ve had to REISUB. What’s the underlying issue?
My inxi -Fazy
Kernel: 5.11.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=76839173-ded3-47ed-b743-7d503298909d rw quiet apparmor=1
security=apparmor resume=UUID=0eb2fb6f-7b97-4079-afe0-7595022800e5
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8575 v: 21.16 serial: <filter> UEFI: AMI v: F.21
date: 11/13/2020
ID-1: BAT0 charge: 45.7 Wh (100.0%) condition: 45.7/45.7 Wh (100.0%)
volts: 13.1 min: 11.6 model: HP Primary type: Li-ion serial: N/A
status: Full
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 12 MiB
bogomips: 62431
Speed: 799 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 799 2: 4156
3: 3577 4: 1405 5: 2848 6: 2223 7: 1453 8: 1026 9: 800 10: 800 11: 800
12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 460.80
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.11.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Local Storage: total: 1.14 TiB used: 58.45 GiB (5.0%)
model: PC SN720 SDAPNTW-256G-1006 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 10112006 temp: 55.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
rotation: 7200 rpm serial: <filter> rev: A3T0 scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.12 GiB (97.80%) used: 14.97 GiB (38.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 82.2 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 196.95 GiB size: 192.86 GiB (97.92%)
used: 43.4 GiB (22.5%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 81.0 C mobo: N/A
Processes: 282 Uptime: 6m wakeups: 1 Memory: 7.58 GiB used: 2.23 GiB (29.3%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 Packages:
pacman: 1361 lib: 421 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
Tell me if you need any more info!
Thanks!
