My system consistently freezes when I open certain games, so far the games this happens on are Hearts of Iron 4 and Superhot, other games work just fine. Both open up then freeze, the mouse and keyboard input nothing and the only way to get out of it is doing ctrl+alt+backspace to shut down the X server. I have tried switching kernels and drivers aswell as changing to the unstable branch and even reinstalling Manjaro but nothing has fixed this. I’d appreciate any help on this as I have no idea why this is happening
Output of inxi -Fazy:
Kernel: 5.13.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=29f7dd24-e2ce-41ba-97c4-9b2cd2a783ef rw
resume=UUID=387435ef-d4c8-4771-82a1-746d4e103605 udev.log_priority=3
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 1 dm: LightDM 1.30.0
Type: Desktop System: Dell product: G5 5090 v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Dell model: 0DXJD9 v: A00 serial: <filter> UEFI: Dell v: 1.4.0
date: 10/20/2020
Info: 6-Core model: Intel Core i5-9400 bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: D (13) microcode: EA
cache: L2: 9 MiB
bogomips: 34814
Speed: 801 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 801 2: 800
3: 1597 4: 900 5: 840 6: 864
Type: srbds mitigation: TSX disabled
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Dell driver: nvidia
v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f82 class-ID: 0300
Display: server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
diag: 584mm (23")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.42.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.13.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Device-1: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:2502 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 3000 bus-ID: 04:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 3.19 TiB used: 352.23 GiB (10.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 10410104 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LM015-2E8174
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: HP model: x900w
size: 231.6 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: PMAP scheme: MBR
ID-1: / raw-size: 230.09 GiB size: 225.42 GiB (97.97%) used: 10.6 GiB (4.7%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 953 MiB size: 951.1 MiB (99.80%)
used: 296 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 26.51 GiB (2.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-aa82af9d-e24b-4334-9919-b20959c49550
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 266 Uptime: 10m wakeups: 0 Memory: 23.34 GiB
used: 2.95 GiB (12.6%) Init: systemd v: 249 target: multi-user.target
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1169 lib: 400
flatpak: 0 Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.05 ```
