System freezes on the lock screen
I am using manjaro gnome version. when I lock my laptop after a while my external keyboard and mouse get disconnected and the lock screen freezes, sometimes I can move the mouse using my laptop touchpad. not sure what is causing this. Any suggestions?
here’s the output of inxi -Fza command
System:    Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           root=UUID=eb93c9c9-c612-4b08-a708-9198142f89ee rw quiet splash apparmor=1
           security=apparmor resume=UUID=e9c0b66d-4db4-4e24-9c93-de101f94754a udev.log_priority=3
           Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Manjaro Linux
           base: Arch Linux
Machine:   Type: Laptop System: Hewlett-Packard product: HP EliteBook 8570w v: A1029D110C
           serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Hewlett-Packard model: 176B v: KBC Version 50.1F serial: <filter>
           UEFI: Hewlett-Packard v: 68IAV Ver. F.71 date: 04/19/2019
Battery:   ID-1: BAT0 charge: 39.8 Wh (100.0%) condition: 39.8/39.8 Wh (100.0%) volts: 16.2
           min: 14.8 model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
CPU:       Info: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge
           family: 6 model-id: 3A (58) stepping: 9 microcode: 21 cache: L2: 6 MiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38334
           Speed: 1209 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1209 2: 1271 3: 1260
           4: 1404 5: 2143 6: 1866 7: 1534 8: 1220
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
           Type: srbds status: Vulnerable: No microcode
Graphics:  Device-1: NVIDIA GK107GLM [Quadro K1000M] vendor: Hewlett-Packard driver: nvidia
           v: 390.144 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:0ffc
           class-ID: 0300
           Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
           bus-ID: 1-1.2:4 chip-ID: 046d:082d class-ID: 0102 serial: <filter>
           Device-3: Primax HP HD Webcam [Fixed] type: USB driver: uvcvideo bus-ID: 1-1.3:5
           chip-ID: 0461:4dfe class-ID: 0e02 serial: <filter>
           Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver: loaded: nvidia
           OpenGL: renderer: Quadro K1000M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
           Device-2: NVIDIA GK107 HDMI Audio vendor: Hewlett-Packard driver: snd_hda_intel
           v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
           Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
           Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.38 running: yes
Network:   Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard driver: e1000e
           v: kernel port: 5040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
           IF: enp0s25 state: down mac: <filter>
           Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel bus-ID: 25:00.0
           chip-ID: 8086:422b class-ID: 0280
Bluetooth: Device-1: Broadcom HP Portable SoftSailing type: USB driver: btusb v: 0.8
           bus-ID: 2-1.6:3 chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 18 GiB (7.5%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAK256MBF-1AN15ABHA
           size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
           serial: <filter> rev: M6T3 scheme: GPT
Partition: ID-1: / raw-size: 73.24 GiB size: 71.54 GiB (97.68%) used: 13.77 GiB (19.3%) fs: ext4
           dev: /dev/sda2 maj-min: 8:2
           ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat
           dev: /dev/sda1 maj-min: 8:1
           ID-3: /home raw-size: 20.11 GiB size: 19.62 GiB (97.59%) used: 4.23 GiB (21.5%)
           fs: ext4 dev: /dev/sda3 maj-min: 8:3
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 7.91 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/sda4 maj-min: 8:4
Sensors:   System Temperatures: cpu: 65.0 C mobo: 63.0 C gpu: nvidia temp: 61 C
Info:      Processes: 285 Uptime: 6m wakeups: 2 Memory: 7.7 GiB used: 3.45 GiB (44.8%)
           Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1201
           pacman: 1196 lib: 309 flatpak: 5 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.08
