I came across 7 or 8 freezes today but I had no idea why it happend and how to fix it. Please, can anyone help?
Here is the log during the freeze (hard reboot at 21:55:32): paste
I see lots of log entries like Can’t update stage views actor… not sure whether it’s relevant or not.
Here’s some other information about my computer by inxi -Fz
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 Desktop: GNOME 40.4 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.00 date: 06/04/2020
CPU: Info: 6-Core model: AMD Ryzen 5 PRO 4400G with Radeon Graphics bits: 64 type: MT MCP cache: L2: 3 MiB
Speed: 2598 MHz min/max: 1400/3700 MHz Core speeds (MHz): 1: 2598 2: 4300 3: 1333 4: 1333 5: 1911 6: 2999 7: 1333
8: 1369 9: 1976 10: 4289 11: 1908 12: 2823
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.2
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.35 running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb
Drives: Local Storage: total: 1.38 TiB used: 168.64 GiB (12.0%)
ID-1: /dev/nvme0n1 vendor: Colorful model: CN600 512GB size: 476.94 GiB
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB
Partition: ID-1: / size: 78.24 GiB used: 50.12 GiB (64.1%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 511 MiB used: 27.2 MiB (5.3%) fs: vfat dev: /dev/nvme0n1p9
ID-3: /home size: 97.93 GiB used: 79.19 GiB (80.9%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 7.63 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p11
Sensors: System Temperatures: cpu: 45.8 C mobo: N/A gpu: amdgpu temp: 32.0 C
Info: Processes: 375 Uptime: 12m Memory: 14.57 GiB used: 6.74 GiB (46.3%) Shell: Zsh inxi: 3.3.06
Here’s the neofetch
result:
██████████████████ ████████ z@z-matrix
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: MS-7C95 1.0
████████ ████████ Kernel: 5.13.19-2-MANJARO
████████ ████████ ████████ Uptime: 15 mins
████████ ████████ ████████ Packages: 1881 (pacman), 10 (flatpak), 6 (snap)
████████ ████████ ████████ Shell: zsh 5.8
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: GNOME 40.4
████████ ████████ ████████ WM: Mutter
████████ ████████ ████████ WM Theme: Adwaita
████████ ████████ ████████ Theme: Adwaita [GTK2/3]
████████ ████████ ████████ Icons: ePapirus [GTK2/3]
Terminal: guake
CPU: AMD Ryzen 5 PRO 4400G with Radeon Graphics (12) @ 3.700GHz
GPU: AMD ATI 30:00.0 Renoir
Memory: 6255MiB / 14919MiB
