Hello,
I switched from Kernel 5.9 to 5.10 (because the latter has LTS) and since then my system freezes from time to time when I am e.g. using Chrome and, what is really annoying, every time a couple of seconds after entering a Zoom meeting. The sound keeps playing (so it could be worse) but everything else is frozen. I tried all kernels with LTS and also increased my SWAP partition but the problem persists.
My inxi output:
Kernel: 4.19.189-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=66d75c2d-755b-4b7b-a0bf-f1d712c4597c rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop Mobo: ASUSTeK model: P8B75-M LX PLUS v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 0501 date: 10/10/2012
RAM: total: 7.66 GiB used: 1.62 GiB (21.2%)
Info: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB bogomips: 23945
Speed: 2743 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 2743 2: 2746
3: 2750 4: 2612
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: ASUSTeK P8H77-I driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0152 class-ID: 0380
Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Gigabyte driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:11c6 class-ID: 0300
Device-3: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 4-1.6:4 chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: NVE6 v: 4.3 Mesa 21.0.3 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GK106 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
Sound Server-1: ALSA v: k4.19.189-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
driver: rtl8192ce v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8178
class-ID: 0280
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: c000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 66.33 GiB (7.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010DLE630
rotation: 7200 rpm serial: <filter> rev: A650 scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-S203B rev: SB00
dev-links: cdrom
ID-1: / raw-size: 48.83 GiB size: 47.81 GiB (97.92%) used: 29.16 GiB (61.0%)
fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: 66d75c2d-755b-4b7b-a0bf-f1d712c4597c
used: 324 KiB (0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: C279-385A
ID-3: /home raw-size: 50.63 GiB size: 49.59 GiB (97.94%)
used: 37.17 GiB (75.0%) fs: ext4 dev: /dev/sda10 maj-min: 8:10 label: N/A
uuid: 7976b5e6-39be-4a5b-a650-f56773265bdc
ID-1: swap-1 type: partition size: 15.96 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: d671cdcc-21fa-44ba-b230-f1a1f61a6bcf
ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Wiederherstellung
uuid: A838697B38694A00
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 786B-D832
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 194.24 GiB fs: ntfs label: Programme
uuid: 9A087C53087C2FFD
ID-5: /dev/sda5 maj-min: 8:5 size: 527 MiB fs: ntfs label: N/A
uuid: 9AD2E141D2E121ED
ID-6: /dev/sda6 maj-min: 8:6 size: 594.24 GiB fs: ntfs label: Daten
uuid: 6E8005C2800591AF
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 2-3:2 info: Logitech M90/M100 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c05a class-ID: 0301
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 4-1.5:3 info: Logitech Corded Keyboard K280e type: Keyboard,HID
power: 98mA chip-ID: 046d:c328 class-ID: 0300
Device-2: 4-1.6:4 info: Microdia Webcam Vitade AF type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 29.0 C
Fan Speeds (RPM): cpu: 0 gpu: nouveau fan: 1320
Processes: 201 Uptime: 16m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: 1595 pacman: 1589 lib: 431 rpm: 0
flatpak: 0 snap: 6 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
What could I try to solve that problem?
