I installed a fresh manjaro gnome iso at the old hardware of my father.
The system is running fine if he use only fileexplorer or a browser like google-chrome from AUR.
But if he opens a application like thunderbird or libreoffice the system freeze randomly after a short time.
The mouse could be moved, but the system is not responding on any key/mouse action.
Here you can see the output of inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ff14c7b4-46ae-40ac-912e-0a48b2e99268 rw quiet splash apparmor=1
security=apparmor resume=UUID=a6a88c0c-bf6a-47c5-9b0e-e941363f8e5a
udev.log_priority=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop Mobo: ASRock model: G41C-GS serial: <filter>
BIOS: American Megatrends v: P1.20 date: 06/01/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
RAM: total: 3.83 GiB used: 1.62 GiB (42.4%)
Array-1: capacity: 4 GiB slots: 2 EC: None max-module-size: 4 GiB
Device-1: DIMM0 info: double-bank type: SDRAM detail: synchronous
size: 2 GiB speed: N/A volts: N/A width (bits): data: 64 total: 64
manufacturer: N/A part-no: N/A serial: N/A
Device-2: DIMM1 info: double-bank type: SDRAM detail: synchronous
Info: model: Intel Core2 Quad Q6600 bits: 64 type: MCP arch: Core Merom
family: 6 model-id: 0xF (15) stepping: 0xB (11) microcode: 0xBA
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2394 min/max: N/A base/boost: 2400/2400 volts: 1.3 V
ext-clock: 267 MHz cores: 1: 2394 2: 2394 3: 2394 4: 2394 bogomips: 19158
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep sse sse2 ssse3 syscall tm tm2 tpr_shadow
tsc vme vmx vnmi vpid xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: NVIDIA G96 [GeForce 9500 GS] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 340.xx status: legacy (EOL, try --nv)
arch: Tesla pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-1
empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 10de:0644 class-ID: 0300
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: nouveau display-ID: :1 screens: 1
Screen-1: 0 s-res: 1680x1050 s-size: <missing: xdpyinfo>
Monitor-1: DVI-I-1 model: LG (GoldStar) W2042 serial: <filter> built: 2008
res: 1680x1050 hz: 60 dpi: 98 gamma: 1.2 size: 434x270mm (17.09x10.63")
diag: 511mm (20.1") ratio: 16:10 modes: max: 1680x1050 min: 720x400
OpenGL: renderer: NV96 v: 3.3 Mesa 22.0.4 direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:27d8
class-ID: 0403
Device-2: Philips s SAA7131/SAA7133/SAA7135 Video Broadcast Decoder
vendor: Creatix Polymedia GmbH driver: saa7134 v: 0, 2, 17 bus-ID: 03:02.0
chip-ID: 1131:7133 class-ID: 0480
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d800 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 232.89 GiB used: 36.4 GiB (15.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B
speed: <unknown> type: SSD serial: <filter> rev: 043 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH20NS10 rev: EL00
dev-links: cdrom
ID-1: / raw-size: 224.46 GiB size: 219.87 GiB (97.96%)
used: 36.4 GiB (16.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: ff14c7b4-46ae-40ac-912e-0a48b2e99268
ID-1: swap-1 type: partition size: 8.43 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: a6a88c0c-bf6a-47c5-9b0e-e941363f8e5a
Hub-1: 1-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-3: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 3-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 56.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 225 Uptime: 13m wakeups: 1890 Init: systemd v: 250
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1365
lib: 339 flatpak: 0 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.16
Do you need any further logs?
