If it helps:
# inxi -zv8
Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
root=UUID=e606c908-01e8-11f1-bbaf-4da1686e5bf4 rw udev.log_priority=3
lsm=landlock,lockdown,yama,integrity,apparmor,bpf
Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Dell product: Inspiron 16 5625 v: 1.28.1
serial: <filter> Chassis: type: 10 v: 1.28.1 serial: <filter>
Mobo: Dell model: 0J9C2M v: A00 serial: <filter> part-nu: 0B47
uuid: 4c4c4544-0059-3210-8053-b9c04f445833 Firmware: UEFI vendor: Dell
v: 1.28.1 date: 05/12/2026
ID-1: BAT0 charge: 54 Wh (100%) condition: 54/54 Wh (100%) volts: 16.38
min: 15 model: SMP-COS3.66 DELL XDY9K35 type: Li-poly serial: <filter>
charging: status: full cycles: N/A
System RAM: total: 16 GiB available: 14.97 GiB used: 6.73 GiB (44.9%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: 80AD000080AD
part-no: HMAA1GS6CJR6N-XN firmware: HMAA1GS6CJR6N-XN serial: <filter>
Slot: 2 type: PCIe status: available info: J10 length: short volts: 3.3
bus-ID: 0200:00:02.2
Slot: 3 type: PCIe status: available info: J3600 length: short volts: 3.3
Slot: 3 type: PCIe status: available info: J3707 length: short volts: 3.3
Slot: 3 type: PCIe status: available info: J3700 length: short volts: 3.3
Slot: 3 type: PCIe status: available info: J3702 length: short volts: 3.3
Slot: 3 type: PCIe status: available info: J3703 length: short volts: 3.3
Slot: N/A type: N/A status: available info: J3701 length: short volts: 3.3
bus-ID: 0200:00:02.5
Info: model: AMD Ryzen 7 5825U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500014
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 411 min/max: 411/2000 boost: enabled
base/boost: 2000/4550 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 411 2: 411 3: 411 4: 411 5: 411
6: 411 7: 411 8: 411 9: 411 10: 411 11: 411 12: 411 13: 411 14: 411
15: 411 16: 411 bogomips: 63885
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Dell
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7 class-ID: 0300
temp: 42.0 C
Device-2: Microdia Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0c45:6739
class-ID: 0e02
Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x0a34 built: 2021 res: 1920x1200
dpi: 141 gamma: 1.2 chroma: red: x: 0.580 y: 0.365 green: x: 0.345 y: 0.580
blue: x: 0.165 y: 0.129 white: x: 0.314 y: 0.329
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x800, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM
3.64 7.2.3-2-MANJARO) device-ID: 1002:15e7 memory: 500 MiB unified: yes
API: Vulkan v: 1.4.357 layers: 2 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.2.2-arch1.1
device-ID: 1002:15e7 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Dell
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.6.8 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: MEDIATEK MT7921 802.11ax PCIe Wireless Network Adapter [Filogic
330] vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Info: services: NetworkManager, sshd, wpa_supplicant
Device-1: Foxconn / Hon Hai MediaTek MT7921 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
chip-ID: 0489:e0c8 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 931.51 GiB used: 300.83 GiB (32.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P310SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: VACR001 temp: 32.9 C
scheme: GPT
SMART: yes health: PASSED on: 17d 13h cycles: 491
read-units: 17,850,313 [9.13 TB] written-units: 4,287,331 [2.19 TB]
ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.74%) used: 43.17 GiB (55.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10 maj-min: 259:10
label: Manjaro uuid: e606c908-01e8-11f1-bbaf-4da1686e5bf4
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 99.1 MiB (50.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: ESP uuid: 90DC-4AF6
ID-3: /home raw-size: 150 GiB size: 146.59 GiB (97.72%)
used: 110.22 GiB (75.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p11
maj-min: 259:11 label: Home uuid: 5a96eae4-6622-40a3-8e1f-d7b55719287c
ID-4: /local-backups raw-size: 224.57 GiB size: 219.99 GiB (97.96%)
used: 147.45 GiB (67.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p12
maj-min: 259:12 label: Local_Backups
uuid: 86895c4c-cbdd-4bbc-8fea-da1213d5b3de
ID-1: swap-1 type: partition size: 28.13 GiB used: 0 KiB (0.0%)
priority: -1 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 222db0df-e653-4309-8a12-64df0fc3f2ae
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 180.72 GiB fs: ntfs label: OS
uuid: 9656F3A756F385F1
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 220 GiB fs: ext4 label: N/A
uuid: 53b68390-ec6d-4d9c-a340-89ca70d563da
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 27.07 GiB fs: ext4 label: N/A
uuid: b5d4ddac-bf44-4034-a2da-88aaea57e09e
ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: 6CB81D12B81CDC80
ID-6: /dev/nvme0n1p8 maj-min: 259:8 size: 18.29 GiB fs: ntfs label: Image
uuid: 6AA81D45A81D10E5
ID-7: /dev/nvme0n1p9 maj-min: 259:9 size: 1.45 GiB fs: ntfs
label: DELLSUPPORT uuid: B090CAD090CA9BEA
Device-1: 1-2:2 info: Dell Universal Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 413c:2514 class-ID: 0300
Device-2: 1-4:3 info: Microdia Integrated_Webcam_FHD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6739 class-ID: 0e02
Device-1: 3-3:2 info: Foxconn / Hon Hai MediaTek MT7921 Bluetooth
type: bluetooth driver: btusb interfaces: 3 rev: 2.1
Device-2: 3-4:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:639c class-ID: ef00 serial: <filter>
System Temperatures: cpu: 44.9 C mobo: 36.0 C sodimm: 40.0 C gpu: amdgpu
temp: 43.0 C
Fan Speeds (rpm): cpu: 0
Packages: 2236 pm: pacman pkgs: 2221 libs: 392 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 15
1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
2: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
3: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
4: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
6: https://mirror.informatik.tu-freiberg.de/manjaro/stable/$repo/$arch
7: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
8: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 364
1: cpu: 100% command: ps pid: 5316 mem: 3.83 MiB (0.0%)
2: cpu: 11.5% command: qemu-system-x86_64 pid: 1140
mem: 3169.0 MiB (20.6%)
3: cpu: 5.9% command: firefox pid: 3569 mem: 477.4 MiB (3.1%)
4: cpu: 2.1% command: firefox pid: 3997 mem: 274.1 MiB (1.7%)
5: cpu: 1.9% command: kwin_wayland pid: 1423 mem: 280.4 MiB (1.8%)
Memory top: 5 of 364
1: mem: 3169.0 MiB (20.6%) command: qemu-system-x86_64 pid: 1140
cpu: 11.5%
2: mem: 961.5 MiB (6.2%) command: clamd pid: 603 cpu: 0.5%
3: mem: 477.4 MiB (3.1%) command: firefox pid: 3569 cpu: 5.9%
4: mem: 383.4 MiB (2.5%) command: plasmashell pid: 1561 cpu: 0.8%
5: mem: 365.2 MiB (2.3%) command: plasma-discover pid: 3324 cpu: 1.1%
Processes: 364 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
image: 5.91 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 261 default: graphical tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Bash (sudo) v: 5.3.15
running-in: konsole inxi: 3.3.41
By the way, efivars usage has climbed back up to 80% in the meantime. That is presumably because I ran updates using fwupdmgr.
