I set my laptop to hibernate (suspend/sleep) for some 30 ~ 40 min. After turning it back on I waited a while on login screen, then typed my password and waited a while longer. Then I tried opening my browser and it took too long not opening until the mouse pointer lost the loading sign. I tried opening other programs shortly after and even shut it down. But it just froze.
Kernel: 5.18.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=d490644f-c0c6-4cd2-a1b8-3399f98ade5c rw quiet
resume=UUID=f8aae6e5-5e27-4d69-8332-16701ccef143 apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3584 v: N/A
Mobo: Dell model: 05RCHV v: A00 serial: <superuser required> UEFI: Dell
v: 1.17.0 date: 03/24/2022
ID-1: BAT0 charge: 2.6 Wh (22.6%) condition: 11.5/42.0 Wh (27.4%)
volts: 12.2 min: 11.4 model: BYD DELL FW8KR96 type: Li-ion serial: <filter>
status: charging
RAM: total: 3.73 GiB used: 3.07 GiB (82.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i3-7020U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check gen: core 7 built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1153 high: 1209 min/max: 400/2300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1209 2: 1200 3: 1103
4: 1100 bogomips: 18406
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: Intel vendor: Dell driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5921
class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: N/A
bus-ID: 1-5:3 chip-ID: 0bda:5520 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x71ec built: 2016 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.18.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:5
chip-ID: 0cf3:e009 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 96.98 GiB (10.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-75Z10T2 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A03 scheme: GPT
ID-1: / raw-size: 38 GiB size: 37.11 GiB (97.65%) used: 19.36 GiB (52.2%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: d490644f-c0c6-4cd2-a1b8-3399f98ade5c
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 292 KiB
(0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7 label: NO_LABEL
uuid: F9C1-B0CE
ID-3: /home raw-size: 121.02 GiB size: 118.56 GiB (97.97%) used: 75.15
GiB (63.4%) fs: ext4 dev: /dev/sda10 maj-min: 8:10 label: N/A
uuid: 3989e7da-996f-4a8c-9b06-6d3d52e37b63
ID-4: /mnt/veracrypt8 raw-size: 5.09 GiB size: 4.93 GiB (96.81%) used: 2.06
GiB (41.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0 mapped: veracrypt8
label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 4 GiB used: 418.2 MiB (10.2%)
priority: -2 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: f8aae6e5-5e27-4d69-8332-16701ccef143
ID-1: /dev/sda1 maj-min: 8:1 size: 650 MiB fs: vfat label: ESP
uuid: D211-7C1A
ID-2: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
ID-3: /dev/sda3 maj-min: 8:3 size: 752.71 GiB fs: ntfs label: OS
uuid: 8868568F68567BBE
ID-4: /dev/sda4 maj-min: 8:4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 2E66E97566E93DE9
ID-5: /dev/sda5 maj-min: 8:5 size: 12.33 GiB fs: ntfs label: Image
uuid: 1AC8EA5AC8EA33A3
ID-6: /dev/sda6 maj-min: 8:6 size: 1.22 GiB fs: ntfs label: DELLSUPPORT
uuid: 8C98D3C298D3A8CA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: MosArt Wireless Mouse 2.4G type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4106 class-ID: 0301
Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
driver: N/A interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 1-7:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C pch: 44.5 C mobo: 43.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 224 Uptime: 30m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1380 lib: 354 flatpak: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.20
Journalctl:
ago 02 21:11:41 ***-pc kernel: Linux version 5.18.15-1-MANJARO (builduser@fv-az39-418) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38>
ago 02 21:11:41 ***-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=d490644f-c0c6-4cd2-a1b8-3399f98ade5c rw >
ago 02 21:11:41 ***-pc kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
ago 02 21:11:41 ***-pc kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
ago 02 21:11:41 ***-pc kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
ago 02 21:11:41 ***-pc kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
ago 02 21:11:41 ***-pc kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
ago 02 21:11:41 ***-pc kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
ago 02 21:11:41 ***-pc kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
ago 02 21:11:41 ***-pc kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
ago 02 21:11:41 ***-pc kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
ago 02 21:11:41 ***-pc kernel: signal: max sigframe size: 2032
ago 02 21:11:41 ***-pc kernel: BIOS-provided physical RAM map:
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000079c70fff] usable
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000079c71000-0x0000000079c71fff] ACPI NVS
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000079c72000-0x0000000079c72fff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000079c73000-0x000000008a169fff] usable
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008a16a000-0x000000008a4e5fff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008a4e6000-0x000000008a529fff] ACPI data
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008a52a000-0x000000008ae25fff] ACPI NVS
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008ae26000-0x000000008b52ffff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008b530000-0x000000008b5fdfff] type 20
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008b5fe000-0x000000008b5fefff] usable
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x000000008b5ff000-0x000000008f7fffff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
ago 02 21:11:41 ***-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x000000016f7fffff] usable
ago 02 21:11:41 ***-pc kernel: NX (Execute Disable) protection: active
ago 02 21:11:41 ***-pc kernel: efi: EFI v2.40 by American Megatrends
ago 02 21:11:41 ***-pc kernel: efi: ACPI=0x8a4f3000 ACPI 2.0=0x8a4f3000 SMBIOS=0xf0000 SMBIOS 3.0=0xf0020 TPMFinalLog=0x8adc7000 ESR>
ago 02 21:11:41 ***-pc kernel: SMBIOS 3.1.1 present.
ago 02 21:11:41 ***-pc kernel: DMI: Dell Inc. Inspiron 3584/05RCHV, BIOS 1.17.0 03/24/2022
ago 02 21:11:41 ***-pc kernel: tsc: Detected 2300.000 MHz processor
ago 02 21:11:41 ***-pc kernel: tsc: Detected 2299.968 MHz TSC
ago 02 21:11:41 ***-pc kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
ago 02 21:11:41 ***-pc kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
ago 02 21:11:41 ***-pc kernel: last_pfn = 0x16f800 max_arch_pfn = 0x400000000
ago 02 21:11:41 ***-pc kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
ago 02 21:11:41 ***-pc kernel: last_pfn = 0x8b5ff max_arch_pfn = 0x400000000
ago 02 21:11:41 ***-pc kernel: esrt: Reserving ESRT space from 0x000000008b23b698 to 0x000000008b23b6d0.
ago 02 21:11:41 ***-pc kernel: Using GB pages for direct mapping
ago 02 21:11:41 ***-pc kernel: Secure boot disabled
ago 02 21:11:41 ***-pc kernel: RAMDISK: [mem 0x3655b000-0x372a4fff]
ago 02 21:11:41 ***-pc kernel: ACPI: Early table checksum verification disabled
ago 02 21:11:41 ***-pc kernel: ACPI: RSDP 0x000000008A4F3000 000024 (v02 DELL )
ago 02 21:11:41 ***-pc kernel: ACPI: XSDT 0x000000008A4F30D0 000124 (v01 DELL CBX3 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: FACP 0x000000008A518618 00010C (v05 DELL CBX3 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: DSDT 0x000000008A4F3288 02538A (v02 DELL CBX3 01072009 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: FACS 0x000000008AE23180 000040
ago 02 21:11:41 ***-pc kernel: ACPI: UEFI 0x000000008A519000 00063A (v01 INTEL RstSataE 00000000 ?? 00000000)
ago 02 21:11:41 ***-pc kernel: ACPI: APIC 0x000000008A519640 000084 (v03 DELL CBX3 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: FPDT 0x000000008A5196C8 000044 (v01 DELL CBX3 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: FIDT 0x000000008A519710 0000AC (v01 DELL CBX3 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: MCFG 0x000000008A5197C0 00003C (v01 DELL CBX3 01072009 MSFT 00000097)
ago 02 21:11:41 ***-pc kernel: ACPI: HPET 0x000000008A519800 000038 (v01 DELL CBX3 01072009 AMI. 0005000B)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A519838 000359 (v01 SataRe SataTabl 00001000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: BOOT 0x000000008A519B98 000028 (v01 DELL CBX3 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A519BC0 0012E0 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: HPET 0x000000008A51AEA0 000038 (v01 INTEL KBL-ULT 00000001 MSFT 0000005F)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A51AED8 000760 (v02 INTEL xh_OEMBD 00000000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: UEFI 0x000000008A51B638 000042 (v01 00000000 00000000)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A51B680 0017AE (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: LPIT 0x000000008A51CE30 000094 (v01 INTEL KBL-ULT 00000000 MSFT 0000005F)
ago 02 21:11:41 ***-pc kernel: ACPI: WSMT 0x000000008A51CEC8 000028 (v01 DELL CBX3 00000000 MSFT 0000005F)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A51CEF0 000161 (v02 INTEL HdaDsp 00000000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A51D058 00029F (v02 INTEL sensrhub 00000000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A51D2F8 003002 (v02 INTEL PtidDevc 00001000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A520300 000517 (v02 INTEL TbtTypeC 00000000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A520818 0002E9 (v02 INTEL Wwan 00000001 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: DBGP 0x000000008A520B08 000034 (v01 INTEL 00000002 MSFT 0000005F)
ago 02 21:11:41 ***-pc kernel: ACPI: DBG2 0x000000008A520B40 000054 (v00 INTEL 00000002 MSFT 0000005F)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A520B98 0007DD (v02 INTEL UsbCTabl 00001000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0x000000008A521378 007F51 (v02 DptfTa DptfTabl 00001000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: MSDM 0x000000008A5292D0 000055 (v03 DELL CBX3 06222004 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: SLIC 0x000000008A529328 000176 (v03 DELL CBX3 01072009 MSFT 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: NHLT 0x000000008A5294A0 00002D (v00 INTEL EDK2 00000002 01000013)
ago 02 21:11:41 ***-pc kernel: ACPI: UEFI 0x000000008A5294D0 00005C (v01 INTEL RstSataV 00000000 ?? 00000000)
ago 02 21:11:41 ***-pc kernel: ACPI: TPM2 0x000000008A529530 000034 (v04 DELL CBX3 00000001 AMI 00000000)
ago 02 21:11:41 ***-pc kernel: ACPI: DMAR 0x000000008A529568 0000CC (v01 INTEL EDK2 00000001 INTL 00000001)
ago 02 21:11:41 ***-pc kernel: ACPI: BGRT 0x000000008A529638 000038 (v00 01072009 AMI 00010013)
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving FACP table memory at [mem 0x8a518618-0x8a518723]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving DSDT table memory at [mem 0x8a4f3288-0x8a518611]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving FACS table memory at [mem 0x8ae23180-0x8ae231bf]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving UEFI table memory at [mem 0x8a519000-0x8a519639]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving APIC table memory at [mem 0x8a519640-0x8a5196c3]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving FPDT table memory at [mem 0x8a5196c8-0x8a51970b]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving FIDT table memory at [mem 0x8a519710-0x8a5197bb]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving MCFG table memory at [mem 0x8a5197c0-0x8a5197fb]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving HPET table memory at [mem 0x8a519800-0x8a519837]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a519838-0x8a519b90]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving BOOT table memory at [mem 0x8a519b98-0x8a519bbf]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a519bc0-0x8a51ae9f]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving HPET table memory at [mem 0x8a51aea0-0x8a51aed7]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a51aed8-0x8a51b637]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving UEFI table memory at [mem 0x8a51b638-0x8a51b679]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a51b680-0x8a51ce2d]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving LPIT table memory at [mem 0x8a51ce30-0x8a51cec3]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving WSMT table memory at [mem 0x8a51cec8-0x8a51ceef]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a51cef0-0x8a51d050]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a51d058-0x8a51d2f6]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a51d2f8-0x8a5202f9]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a520300-0x8a520816]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a520818-0x8a520b00]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving DBGP table memory at [mem 0x8a520b08-0x8a520b3b]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving DBG2 table memory at [mem 0x8a520b40-0x8a520b93]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a520b98-0x8a521374]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x8a521378-0x8a5292c8]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving MSDM table memory at [mem 0x8a5292d0-0x8a529324]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving SLIC table memory at [mem 0x8a529328-0x8a52949d]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving NHLT table memory at [mem 0x8a5294a0-0x8a5294cc]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving UEFI table memory at [mem 0x8a5294d0-0x8a52952b]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving TPM2 table memory at [mem 0x8a529530-0x8a529563]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving DMAR table memory at [mem 0x8a529568-0x8a529633]
ago 02 21:11:41 ***-pc kernel: ACPI: Reserving BGRT table memory at [mem 0x8a529638-0x8a52966f]
ago 02 21:11:41 ***-pc kernel: No NUMA configuration found
ago 02 21:11:41 ***-pc kernel: Faking a node at [mem 0x0000000000000000-0x000000016f7fffff]
ago 02 21:11:41 ***-pc kernel: NODE_DATA(0) allocated [mem 0x16f7fc000-0x16f7fffff]
ago 02 21:11:41 ***-pc kernel: Zone ranges:
ago 02 21:11:41 ***-pc kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
ago 02 21:11:41 ***-pc kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
ago 02 21:11:41 ***-pc kernel: Normal [mem 0x0000000100000000-0x000000016f7fffff]
ago 02 21:11:41 ***-pc kernel: Device empty
ago 02 21:11:41 ***-pc kernel: Movable zone start for each node
ago 02 21:11:41 ***-pc kernel: Early memory node ranges
ago 02 21:11:41 ***-pc kernel: node 0: [mem 0x0000000000001000-0x0000000000057fff]
ago 02 21:11:41 ***-pc kernel: node 0: [mem 0x0000000000059000-0x000000000009dfff]
ago 02 21:11:41 ***-pc kernel: node 0: [mem 0x0000000000100000-0x0000000079c70fff]
ago 02 21:11:41 ***-pc kernel: node 0: [mem 0x0000000079c73000-0x000000008a169fff]
ago 02 21:11:41 ***-pc kernel: node 0: [mem 0x000000008b5fe000-0x000000008b5fefff]
ago 02 21:11:41 ***-pc kernel: node 0: [mem 0x0000000100000000-0x000000016f7fffff]
ago 02 21:11:41 ***-pc kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000016f7fffff]
ago 02 21:11:41 ***-pc kernel: On node 0, zone DMA: 1 pages in unavailable ranges
ago 02 21:11:41 ***-pc kernel: On node 0, zone DMA: 98 pages in unavailable ranges
ago 02 21:11:41 ***-pc kernel: On node 0, zone DMA32: 2 pages in unavailable ranges
ago 02 21:11:41 ***-pc kernel: On node 0, zone DMA32: 5268 pages in unavailable ranges
ago 02 21:11:41 ***-pc kernel: On node 0, zone Normal: 18945 pages in unavailable ranges
ago 02 21:11:41 ***-pc kernel: On node 0, zone Normal: 2048 pages in unavailable ranges
ago 02 21:11:41 ***-pc kernel: Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
ago 02 21:11:41 ***-pc kernel: ACPI: PM-Timer IO Port: 0x1808
ago 02 21:11:41 ***-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ago 02 21:11:41 ***-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
ago 02 21:11:41 ***-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
ago 02 21:11:41 ***-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
ago 02 21:11:41 ***-pc kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
ago 02 21:11:41 ***-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ago 02 21:11:41 ***-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ago 02 21:11:41 ***-pc kernel: ACPI: Using ACPI (MADT) for SMP configuration information
ago 02 21:11:41 ***-pc kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
ago 02 21:11:41 ***-pc kernel: e820: update [mem 0x86de7000-0x86e2bfff] usable ==> reserved
ago 02 21:11:41 ***-pc kernel: TSC deadline timer available
ago 02 21:11:41 ***-pc kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x79c71000-0x79c71fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x79c72000-0x79c72fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x86de7000-0x86e2bfff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8a16a000-0x8a4e5fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8a4e6000-0x8a529fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8a52a000-0x8ae25fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8ae26000-0x8b52ffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8b530000-0x8b5fdfff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8b5ff000-0x8f7fffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
ago 02 21:11:41 ***-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
ago 02 21:11:41 ***-pc kernel: [mem 0x8f800000-0xdfffffff] available for PCI devices
ago 02 21:11:41 ***-pc kernel: Booting paravirtualized kernel on bare hardware
ago 02 21:11:41 ***-pc kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 >
ago 02 21:11:41 ***-pc kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
ago 02 21:11:41 ***-pc kernel: percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u524288
ago 02 21:11:41 ***-pc kernel: pcpu-alloc: s221184 r8192 d28672 u524288 alloc=1*2097152
ago 02 21:11:41 ***-pc kernel: pcpu-alloc: [0] 0 1 2 3
ago 02 21:11:41 ***-pc kernel: Fallback order for Node 0: 0
ago 02 21:11:41 ***-pc kernel: Built 1 zonelists, mobility grouping on. Total pages: 1006083
ago 02 21:11:41 ***-pc kernel: Policy zone: Normal
ago 02 21:11:41 ***-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=d490644f-c0c6-4cd2-a1b8-3399f98ad>
ago 02 21:11:41 ***-pc kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64", will be passed to user>
ago 02 21:11:41 ***-pc kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
ago 02 21:11:41 ***-pc kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
ago 02 21:11:41 ***-pc kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
ago 02 21:11:41 ***-pc kernel: Memory: 3849480K/4088852K available (14343K kernel code, 2124K rwdata, 11072K rodata, 1868K init, 380>
ago 02 21:11:41 ***-pc kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
ago 02 21:11:41 ***-pc kernel: Kernel/User page tables isolation: enabled
ago 02 21:11:41 ***-pc kernel: ftrace: allocating 45086 entries in 177 pages
ago 02 21:11:41 ***-pc kernel: ftrace: allocated 177 pages with 4 groups
ago 02 21:11:41 ***-pc kernel: Dynamic Preempt: full
ago 02 21:11:41 ***-pc kernel: rcu: Preemptible hierarchical RCU implementation.
ago 02 21:11:41 ***-pc kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
ago 02 21:11:41 ***-pc kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
ago 02 21:11:41 ***-pc kernel: Trampoline variant of Tasks RCU enabled.
ago 02 21:11:41 ***-pc kernel: Rude variant of Tasks RCU enabled.
ago 02 21:11:41 ***-pc kernel: Tracing variant of Tasks RCU enabled.
ago 02 21:11:41 ***-pc kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
ago 02 21:11:41 ***-pc kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
ago 02 21:11:41 ***-pc kernel: NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
ago 02 21:11:41 ***-pc kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
ago 02 21:11:41 ***-pc kernel: random: crng init done
ago 02 21:11:41 ***-pc kernel: Console: colour dummy device 80x25
ago 02 21:11:41 ***-pc kernel: printk: console [tty0] enabled
ago 02 21:11:41 ***-pc kernel: ACPI: Core revision 20211217
ago 02 21:11:41 ***-pc kernel: hpet: HPET dysfunctional in PC10. Force disabled.
ago 02 21:11:41 ***-pc kernel: APIC: Switch to symmetric I/O mode setup
ago 02 21:11:41 ***-pc kernel: DMAR: Host address width 39
ago 02 21:11:41 ***-pc kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
ago 02 21:11:41 ***-pc kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
ago 02 21:11:41 ***-pc kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
ago 02 21:11:41 ***-pc kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
ago 02 21:11:41 ***-pc kernel: DMAR: RMRR base: 0x0000008a239000 end: 0x0000008a258fff
ago 02 21:11:41 ***-pc kernel: DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
ago 02 21:11:41 ***-pc kernel: DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
ago 02 21:11:41 ***-pc kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
ago 02 21:11:41 ***-pc kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
ago 02 21:11:41 ***-pc kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
ago 02 21:11:41 ***-pc kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
ago 02 21:11:41 ***-pc kernel: x2apic enabled
ago 02 21:11:41 ***-pc kernel: Switched APIC routing to cluster x2apic.
ago 02 21:11:41 ***-pc kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x212717146a7, max_idle_ns: 440795291431>
ago 02 21:11:41 ***-pc kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4601.60 BogoMIPS (lpj=7666>
ago 02 21:11:41 ***-pc kernel: pid_max: default: 32768 minimum: 301
ago 02 21:11:41 ***-pc kernel: LSM: Security Framework initializing
ago 02 21:11:41 ***-pc kernel: landlock: Up and running.
ago 02 21:11:41 ***-pc kernel: Yama: becoming mindful.
ago 02 21:11:41 ***-pc kernel: LSM support for eBPF active
ago 02 21:11:41 ***-pc kernel: AppArmor: AppArmor initialized
ago 02 21:11:41 ***-pc kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
ago 02 21:11:41 ***-pc kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
ago 02 21:11:41 ***-pc kernel: x86/cpu: SGX disabled by BIOS.
ago 02 21:11:41 ***-pc kernel: CPU0: Thermal monitoring enabled (TM1)
ago 02 21:11:41 ***-pc kernel: process: using mwait in idle threads
ago 02 21:11:41 ***-pc kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
ago 02 21:11:41 ***-pc kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
ago 02 21:11:41 ***-pc kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
ago 02 21:11:41 ***-pc kernel: Spectre V2 : Mitigation: IBRS
ago 02 21:11:41 ***-pc kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
ago 02 21:11:41 ***-pc kernel: RETBleed: Mitigation: IBRS
ago 02 21:11:41 ***-pc kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
ago 02 21:11:41 ***-pc kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
ago 02 21:11:41 ***-pc kernel: MDS: Mitigation: Clear CPU buffers
ago 02 21:11:41 ***-pc kernel: MMIO Stale Data: Mitigation: Clear CPU buffers
ago 02 21:11:41 ***-pc kernel: SRBDS: Mitigation: Microcode
ago 02 21:11:41 ***-pc kernel: Freeing SMP alternatives memory: 36K
ago 02 21:11:41 ***-pc kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1024
ago 02 21:11:41 ***-pc kernel: smpboot: CPU0: Intel(R) Core(TM) i3-7020U CPU @ 2.30GHz (family: 0x6, model: 0x8e, stepping: 0x9)
ago 02 21:11:41 ***-pc kernel: cblist_init_generic: Setting adjustable number of callback queues.
ago 02 21:11:41 ***-pc kernel: cblist_init_generic: Setting shift to 2 and lim to 1.
ago 02 21:11:41 ***-pc kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
ago 02 21:11:41 ***-pc kernel: ... version: 4
ago 02 21:11:41 ***-pc kernel: ... bit width: 48
ago 02 21:11:41 ***-pc kernel: ... generic registers: 4
ago 02 21:11:41 ***-pc kernel: ... value mask: 0000ffffffffffff
ago 02 21:11:41 ***-pc kernel: ... max period: 00007fffffffffff
ago 02 21:11:41 ***-pc kernel: ... fixed-purpose events: 3
ago 02 21:11:41 ***-pc kernel: ... event mask: 000000070000000f
ago 02 21:11:41 ***-pc kernel: rcu: Hierarchical SRCU implementation.
ago 02 21:11:41 ***-pc kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
ago 02 21:11:41 ***-pc kernel: smp: Bringing up secondary CPUs ...
ago 02 21:11:41 ***-pc kernel: x86: Booting SMP configuration:
ago 02 21:11:41 ***-pc kernel: .... node #0, CPUs: #1 #2
ago 02 21:11:41 ***-pc kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin->
ago 02 21:11:41 ***-pc kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/l>
ago 02 21:11:41 ***-pc kernel: #3
ago 02 21:11:41 ***-pc kernel: smp: Brought up 1 node, 4 CPUs
ago 02 21:11:41 ***-pc kernel: smpboot: Max logical packages: 1
ago 02 21:11:41 ***-pc kernel: smpboot: Total of 4 processors activated (18407.40 BogoMIPS)
ago 02 21:11:41 ***-pc kernel: devtmpfs: initialized
ago 02 21:11:41 ***-pc kernel: x86/mm: Memory block size: 128MB
ago 02 21:11:41 ***-pc kernel: ACPI: PM: Registering ACPI NVS region [mem 0x79c71000-0x79c71fff] (4096 bytes)
ago 02 21:11:41 ***-pc kernel: ACPI: PM: Registering ACPI NVS region [mem 0x8a52a000-0x8ae25fff] (9420800 bytes)
ago 02 21:11:41 ***-pc kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
ago 02 21:11:41 ***-pc kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
ago 02 21:11:41 ***-pc kernel: pinctrl core: initialized pinctrl subsystem
ago 02 21:11:41 ***-pc kernel: PM: RTC time: 00:11:23, date: 2022-08-03
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
ago 02 21:11:41 ***-pc kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
ago 02 21:11:41 ***-pc kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
ago 02 21:11:41 ***-pc kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
ago 02 21:11:41 ***-pc kernel: audit: initializing netlink subsys (disabled)
ago 02 21:11:41 ***-pc kernel: audit: type=2000 audit(1659485483.009:1): state=initialized audit_enabled=0 res=1
ago 02 21:11:41 ***-pc kernel: thermal_sys: Registered thermal governor 'fair_share'
ago 02 21:11:41 ***-pc kernel: thermal_sys: Registered thermal governor 'bang_bang'
ago 02 21:11:41 ***-pc kernel: thermal_sys: Registered thermal governor 'step_wise'
ago 02 21:11:41 ***-pc kernel: thermal_sys: Registered thermal governor 'user_space'
ago 02 21:11:41 ***-pc kernel: thermal_sys: Registered thermal governor 'power_allocator'
ago 02 21:11:41 ***-pc kernel: cpuidle: using governor ladder
ago 02 21:11:41 ***-pc kernel: cpuidle: using governor menu
ago 02 21:11:41 ***-pc kernel: Simple Boot Flag at 0x47 set to 0x80
ago 02 21:11:41 ***-pc kernel: HugeTLB: can free 4095 vmemmap pages for hugepages-1048576kB
ago 02 21:11:41 ***-pc kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
ago 02 21:11:41 ***-pc kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
ago 02 21:11:41 ***-pc kernel: PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
ago 02 21:11:41 ***-pc kernel: PCI: Using configuration type 1 for base access
ago 02 21:11:41 ***-pc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
ago 02 21:11:41 ***-pc kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
ago 02 21:11:41 ***-pc kernel: HugeTLB: can free 7 vmemmap pages for hugepages-2048kB
ago 02 21:11:41 ***-pc kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
ago 02 21:11:41 ***-pc kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(Module Device)
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(Processor Device)
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(Processor Aggregator Device)
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(Linux-Dell-Video)
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
ago 02 21:11:41 ***-pc kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
ago 02 21:11:41 ***-pc kernel: ACPI: 12 ACPI AML tables successfully acquired and loaded
ago 02 21:11:41 ***-pc kernel: ACPI Error: No pointer back to namespace node in package 000000005acefb1d (20211217/dsargs-301)
ago 02 21:11:41 ***-pc kernel: ACPI Error: No pointer back to namespace node in package 00000000ff94bb4f (20211217/dsargs-301)
ago 02 21:11:41 ***-pc kernel: ACPI Error: No pointer back to namespace node in package 000000000738414c (20211217/dsargs-301)
ago 02 21:11:41 ***-pc kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
ago 02 21:11:41 ***-pc kernel: ACPI: Dynamic OEM Table Load:
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0xFFFF923BC100A800 00060F (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0xFFFF923BC100B000 000424 (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0xFFFF923BC012E000 000D14 (v02 PmRef ApIst 00003000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0xFFFF923BC0D29400 000317 (v02 PmRef ApHwp 00003000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: SSDT 0xFFFF923BC0D2A400 00030A (v02 PmRef ApCst 00003000 INTL 20160422)
ago 02 21:11:41 ***-pc kernel: ACPI: EC: EC started
ago 02 21:11:41 ***-pc kernel: ACPI: EC: interrupt blocked
ago 02 21:11:41 ***-pc kernel: ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
ago 02 21:11:41 ***-pc kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
ago 02 21:11:41 ***-pc kernel: ACPI: Interpreter enabled
ago 02 21:11:41 ***-pc kernel: ACPI: PM: (supports S0 S3 S4 S5)
ago 02 21:11:41 ***-pc kernel: ACPI: Using IOAPIC for interrupt routing
ago 02 21:11:41 ***-pc kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ago 02 21:11:41 ***-pc kernel: ACPI: Enabled 7 GPEs in block 00 to 7F
ago 02 21:11:41 ***-pc kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
ago 02 21:11:41 ***-pc kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
ago 02 21:11:41 ***-pc kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
ago 02 21:11:41 ***-pc kernel: PCI host bridge to bus 0000:00
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:00.0: [8086:5904] type 00 class 0x060000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: [8086:5921] type 00 class 0x030000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: reg 0x10: [mem 0xd0000000-0xd0ffffff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:04.0: reg 0x10: [mem 0xd1320000-0xd1327fff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
ago 02 21:11:41 ***-pc kernel: pci 0000:00:14.0: reg 0x10: [mem 0xd1310000-0xd131ffff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
ago 02 21:11:41 ***-pc kernel: pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:14.2: reg 0x10: [mem 0xd1337000-0xd1337fff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:15.0: reg 0x10: [mem 0xd1336000-0xd1336fff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:16.0: reg 0x10: [mem 0xd1335000-0xd1335fff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:16.0: PME# supported from D3hot
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: [8086:282a] type 00 class 0x010400
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: reg 0x10: [mem 0xd1330000-0xd1331fff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: reg 0x14: [mem 0xd1334000-0xd13340ff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: reg 0x18: [io 0xf090-0xf097]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: reg 0x1c: [io 0xf080-0xf083]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: reg 0x20: [io 0xf060-0xf07f]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: reg 0x24: [mem 0xd1333000-0xd13337ff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:17.0: PME# supported from D3hot
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.0: [8086:9d14] type 01 class 0x060400
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.5: [8086:9d15] type 01 class 0x060400
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.0: [8086:9d4e] type 00 class 0x060100
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.2: reg 0x10: [mem 0xd132c000-0xd132ffff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040380
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xd1328000-0xd132bfff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.3: reg 0x20: [mem 0xd1300000-0xd130ffff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.4: reg 0x10: [mem 0xd1332000-0xd13320ff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1f.4: reg 0x20: [io 0xf040-0xf05f]
ago 02 21:11:41 ***-pc kernel: pci 0000:01:00.0: [10ec:8136] type 00 class 0x020000
ago 02 21:11:41 ***-pc kernel: pci 0000:01:00.0: reg 0x10: [io 0xe000-0xe0ff]
ago 02 21:11:41 ***-pc kernel: pci 0000:01:00.0: reg 0x18: [mem 0xd1204000-0xd1204fff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:01:00.0: reg 0x20: [mem 0xd1200000-0xd1203fff 64bit pref]
ago 02 21:11:41 ***-pc kernel: pci 0000:01:00.0: supports D1 D2
ago 02 21:11:41 ***-pc kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.0: bridge window [mem 0xd1200000-0xd12fffff]
ago 02 21:11:41 ***-pc kernel: pci 0000:02:00.0: [168c:0042] type 00 class 0x028000
ago 02 21:11:41 ***-pc kernel: pci 0000:02:00.0: reg 0x10: [mem 0xd1000000-0xd11fffff 64bit]
ago 02 21:11:41 ***-pc kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.5: PCI bridge to [bus 02]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:1c.5: bridge window [mem 0xd1000000-0xd11fffff]
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 10
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 11
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 11
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 11
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 11
ago 02 21:11:41 ***-pc kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 11
ago 02 21:11:41 ***-pc kernel: ACPI: EC: interrupt unblocked
ago 02 21:11:41 ***-pc kernel: ACPI: EC: event unblocked
ago 02 21:11:41 ***-pc kernel: ACPI: EC: GPE=0x6e
ago 02 21:11:41 ***-pc kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
ago 02 21:11:41 ***-pc kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
ago 02 21:11:41 ***-pc kernel: iommu: Default domain type: Translated
ago 02 21:11:41 ***-pc kernel: iommu: DMA domain TLB invalidation policy: lazy mode
ago 02 21:11:41 ***-pc kernel: SCSI subsystem initialized
ago 02 21:11:41 ***-pc kernel: libata version 3.00 loaded.
ago 02 21:11:41 ***-pc kernel: ACPI: bus type USB registered
ago 02 21:11:41 ***-pc kernel: usbcore: registered new interface driver usbfs
ago 02 21:11:41 ***-pc kernel: usbcore: registered new interface driver hub
ago 02 21:11:41 ***-pc kernel: usbcore: registered new device driver usb
ago 02 21:11:41 ***-pc kernel: pps_core: LinuxPPS API ver. 1 registered
ago 02 21:11:41 ***-pc kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
ago 02 21:11:41 ***-pc kernel: PTP clock support registered
ago 02 21:11:41 ***-pc kernel: EDAC MC: Ver: 3.0.0
ago 02 21:11:41 ***-pc kernel: Registered efivars operations
ago 02 21:11:41 ***-pc kernel: NetLabel: Initializing
ago 02 21:11:41 ***-pc kernel: NetLabel: domain hash size = 128
ago 02 21:11:41 ***-pc kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
ago 02 21:11:41 ***-pc kernel: NetLabel: unlabeled traffic allowed by default
ago 02 21:11:41 ***-pc kernel: mctp: management component transport protocol core
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_MCTP protocol family
ago 02 21:11:41 ***-pc kernel: PCI: Using ACPI for IRQ routing
ago 02 21:11:41 ***-pc kernel: PCI: pci_cache_line_size set to 64 bytes
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x79c71000-0x7bffffff]
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x86de7000-0x87ffffff]
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x8a16a000-0x8bffffff]
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x8b5ff000-0x8bffffff]
ago 02 21:11:41 ***-pc kernel: e820: reserve RAM buffer [mem 0x16f800000-0x16fffffff]
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: vgaarb: bridge control possible
ago 02 21:11:41 ***-pc kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
ago 02 21:11:41 ***-pc kernel: vgaarb: loaded
ago 02 21:11:41 ***-pc kernel: clocksource: Switched to clocksource tsc-early
ago 02 21:11:41 ***-pc kernel: VFS: Disk quotas dquot_6.6.0
ago 02 21:11:41 ***-pc kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
ago 02 21:11:41 ***-pc kernel: AppArmor: AppArmor Filesystem Enabled
ago 02 21:11:41 ***-pc kernel: pnp: PnP ACPI init
ago 02 21:11:41 ***-pc kernel: system 00:00: [io 0x0680-0x069f] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:00: [io 0xffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:00: [io 0x1800-0x18fe] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:00: [io 0x164e-0x164f] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:02: [io 0x1854-0x1857] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xff000000-0xffffffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
ago 02 21:11:41 ***-pc kernel: system 00:05: [mem 0xdffe0000-0xdfffffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfd000000-0xfdabffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfdad0000-0xfdadffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfdb00000-0xfdffffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfe036000-0xfe03bfff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfe03d000-0xfe3fffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:06: [mem 0xfe410000-0xfe7fffff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:07: [io 0xff00-0xfffe] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:08: [mem 0xfe029000-0xfe029fff] has been reserved
ago 02 21:11:41 ***-pc kernel: system 00:08: [mem 0xfe028000-0xfe028fff] has been reserved
ago 02 21:11:41 ***-pc kernel: pnp: PnP ACPI: found 9 devices
ago 02 21:11:41 ***-pc kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_INET protocol family
ago 02 21:11:41 ***-pc kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
ago 02 21:11:41 ***-pc kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
ago 02 21:11:41 ***-pc kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
ago 02 21:11:41 ***-pc kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
ago 02 21:11:41 ***-pc kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
ago 02 21:11:41 ***-pc kernel: TCP: Hash tables configured (established 32768 bind 32768)
ago 02 21:11:41 ***-pc kernel: MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
ago 02 21:11:41 ***-pc kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
ago 02 21:11:41 ***-pc kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_XDP protocol family
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000dffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: resource 7 [mem 0x8f800000-0xdfffffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:01: resource 1 [mem 0xd1200000-0xd12fffff]
ago 02 21:11:41 ***-pc kernel: pci_bus 0000:02: resource 1 [mem 0xd1000000-0xd11fffff]
ago 02 21:11:41 ***-pc kernel: PCI: CLS 0 bytes, default 64
ago 02 21:11:41 ***-pc kernel: DMAR: ACPI device "device:6a" under DMAR at fed91000 as 00:15.0
ago 02 21:11:41 ***-pc kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
ago 02 21:11:41 ***-pc kernel: software IO TLB: mapped [mem 0x0000000082de7000-0x0000000086de7000] (64MB)
ago 02 21:11:41 ***-pc kernel: Trying to unpack rootfs image as initramfs...
ago 02 21:11:41 ***-pc kernel: Initialise system trusted keyrings
ago 02 21:11:41 ***-pc kernel: Key type blacklist registered
ago 02 21:11:41 ***-pc kernel: workingset: timestamp_bits=41 max_order=20 bucket_order=0
ago 02 21:11:41 ***-pc kernel: zbud: loaded
ago 02 21:11:41 ***-pc kernel: Key type asymmetric registered
ago 02 21:11:41 ***-pc kernel: Asymmetric key parser 'x509' registered
ago 02 21:11:41 ***-pc kernel: Freeing initrd memory: 13608K
ago 02 21:11:41 ***-pc kernel: alg: self-tests for CTR-KDF (hmac(sha256)) passed
ago 02 21:11:41 ***-pc kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
ago 02 21:11:41 ***-pc kernel: io scheduler mq-deadline registered
ago 02 21:11:41 ***-pc kernel: io scheduler kyber registered
ago 02 21:11:41 ***-pc kernel: io scheduler bfq registered
ago 02 21:11:41 ***-pc kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
ago 02 21:11:41 ***-pc kernel: pcieport 0000:00:1c.0: AER: enabled with IRQ 122
ago 02 21:11:41 ***-pc kernel: pcieport 0000:00:1c.5: PME: Signaling with IRQ 123
ago 02 21:11:41 ***-pc kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
ago 02 21:11:41 ***-pc kernel: ACPI: AC: AC Adapter [AC] (off-line)
ago 02 21:11:41 ***-pc kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
ago 02 21:11:41 ***-pc kernel: ACPI: button: Lid Switch [LID0]
ago 02 21:11:41 ***-pc kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
ago 02 21:11:41 ***-pc kernel: ACPI: button: Power Button [PBTN]
ago 02 21:11:41 ***-pc kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
ago 02 21:11:41 ***-pc kernel: ACPI: button: Sleep Button [SBTN]
ago 02 21:11:41 ***-pc kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
ago 02 21:11:41 ***-pc kernel: ACPI: button: Power Button [PWRF]
ago 02 21:11:41 ***-pc kernel: thermal LNXTHERM:00: registered as thermal_zone0
ago 02 21:11:41 ***-pc kernel: ACPI: thermal: Thermal Zone [THM] (25 C)
ago 02 21:11:41 ***-pc kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
ago 02 21:11:41 ***-pc kernel: hpet_acpi_add: no address or irqs in _CRS
ago 02 21:11:41 ***-pc kernel: Non-volatile memory driver v1.3
ago 02 21:11:41 ***-pc kernel: Linux agpgart interface v0.103
ago 02 21:11:41 ***-pc kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
ago 02 21:11:41 ***-pc kernel: ACPI: bus type drm_connector registered
ago 02 21:11:41 ***-pc kernel: ahci 0000:00:17.0: version 3.0
ago 02 21:11:41 ***-pc kernel: ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
ago 02 21:11:41 ***-pc kernel: ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl RAID mode
ago 02 21:11:41 ***-pc kernel: ahci 0000:00:17.0: flags: 64bit ncq stag pm led clo only pio slum part deso sadm sds apst
ago 02 21:11:41 ***-pc kernel: scsi host0: ahci
ago 02 21:11:41 ***-pc kernel: scsi host1: ahci
ago 02 21:11:41 ***-pc kernel: ata1: SATA max UDMA/133 abar m2048@0xd1333000 port 0xd1333100 irq 124
ago 02 21:11:41 ***-pc kernel: ata2: SATA max UDMA/133 abar m2048@0xd1333000 port 0xd1333180 irq 124
ago 02 21:11:41 ***-pc kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ago 02 21:11:41 ***-pc kernel: ehci-pci: EHCI PCI platform driver
ago 02 21:11:41 ***-pc kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ago 02 21:11:41 ***-pc kernel: ohci-pci: OHCI PCI platform driver
ago 02 21:11:41 ***-pc kernel: uhci_hcd: USB Universal Host Controller Interface driver
ago 02 21:11:41 ***-pc kernel: usbcore: registered new interface driver usbserial_generic
ago 02 21:11:41 ***-pc kernel: usbserial: USB Serial support registered for generic
ago 02 21:11:41 ***-pc kernel: rtc_cmos 00:01: RTC can wake from S4
ago 02 21:11:41 ***-pc kernel: rtc_cmos 00:01: registered as rtc0
ago 02 21:11:41 ***-pc kernel: rtc_cmos 00:01: setting system clock to 2022-08-03T00:11:23 UTC (1659485483)
ago 02 21:11:41 ***-pc kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
ago 02 21:11:41 ***-pc kernel: intel_pstate: Intel P-state driver initializing
ago 02 21:11:41 ***-pc kernel: intel_pstate: HWP enabled
ago 02 21:11:41 ***-pc kernel: ledtrig-cpu: registered to indicate activity on CPUs
ago 02 21:11:41 ***-pc kernel: efifb: probing for efifb
ago 02 21:11:41 ***-pc kernel: efifb: showing boot graphics
ago 02 21:11:41 ***-pc kernel: efifb: framebuffer at 0xc0000000, using 4160k, total 4160k
ago 02 21:11:41 ***-pc kernel: efifb: mode is 1366x768x32, linelength=5504, pages=1
ago 02 21:11:41 ***-pc kernel: efifb: scrolling: redraw
ago 02 21:11:41 ***-pc kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
ago 02 21:11:41 ***-pc kernel: fbcon: Deferring console take-over
ago 02 21:11:41 ***-pc kernel: fb0: EFI VGA frame buffer device
ago 02 21:11:41 ***-pc kernel: hid: raw HID events driver (C) Jiri Kosina
ago 02 21:11:41 ***-pc kernel: intel_pmc_core INT33A1:00: initialized
ago 02 21:11:41 ***-pc kernel: drop_monitor: Initializing network drop monitor service
ago 02 21:11:41 ***-pc kernel: Initializing XFRM netlink socket
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_INET6 protocol family
ago 02 21:11:41 ***-pc kernel: Segment Routing with IPv6
ago 02 21:11:41 ***-pc kernel: RPL Segment Routing with IPv6
ago 02 21:11:41 ***-pc kernel: In-situ OAM (IOAM) with IPv6
ago 02 21:11:41 ***-pc kernel: NET: Registered PF_PACKET protocol family
ago 02 21:11:41 ***-pc kernel: microcode: sig=0x806e9, pf=0x40, revision=0xf0
ago 02 21:11:41 ***-pc kernel: microcode: Microcode Update Driver: v2.2.
ago 02 21:11:41 ***-pc kernel: IPI shorthand broadcast: enabled
ago 02 21:11:41 ***-pc kernel: sched_clock: Marking stable (588404626, 6644033)->(617790216, -22741557)
ago 02 21:11:41 ***-pc kernel: registered taskstats version 1
ago 02 21:11:41 ***-pc kernel: Loading compiled-in X.509 certificates
ago 02 21:11:41 ***-pc kernel: ACPI: battery: Slot [BAT0] (battery present)
ago 02 21:11:41 ***-pc kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 6341fee0c9711b4126df5989f9ac70b7ad9305b5'
ago 02 21:11:41 ***-pc kernel: zswap: loaded using pool zstd/z3fold
ago 02 21:11:41 ***-pc kernel: Key type ._fscrypt registered
ago 02 21:11:41 ***-pc kernel: Key type .fscrypt registered
ago 02 21:11:41 ***-pc kernel: Key type fscrypt-provisioning registered
ago 02 21:11:41 ***-pc kernel: AppArmor: AppArmor sha1 policy hashing enabled
ago 02 21:11:41 ***-pc kernel: PM: Magic number: 2:848:151
ago 02 21:11:41 ***-pc kernel: RAS: Correctable Errors collector initialized.
ago 02 21:11:41 ***-pc kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ago 02 21:11:41 ***-pc kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
ago 02 21:11:41 ***-pc kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
ago 02 21:11:41 ***-pc kernel: ata1.00: ATA-10: WDC WD10SPZX-75Z10T2, 03.01A03, max UDMA/133
ago 02 21:11:41 ***-pc kernel: ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
ago 02 21:11:41 ***-pc kernel: ata1.00: Features: NCQ-prio
ago 02 21:11:41 ***-pc kernel: ata1.00: configured for UDMA/133
ago 02 21:11:41 ***-pc kernel: scsi 0:0:0:0: Direct-Access ATA WDC WD10SPZX-75Z 1A03 PQ: 0 ANSI: 5
ago 02 21:11:41 ***-pc kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
ago 02 21:11:41 ***-pc kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
ago 02 21:11:41 ***-pc kernel: sd 0:0:0:0: [sda] Write Protect is off
ago 02 21:11:41 ***-pc kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
ago 02 21:11:41 ***-pc kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
ago 02 21:11:41 ***-pc kernel: sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10
ago 02 21:11:41 ***-pc kernel: sd 0:0:0:0: [sda] Attached SCSI disk
ago 02 21:11:41 ***-pc kernel: ata2: SATA link down (SStatus 4 SControl 300)
ago 02 21:11:41 ***-pc kernel: Freeing unused decrypted memory: 2036K
ago 02 21:11:41 ***-pc kernel: Freeing unused kernel image (initmem) memory: 1868K
ago 02 21:11:41 ***-pc kernel: Write protecting the kernel read-only data: 28672k
ago 02 21:11:41 ***-pc kernel: Freeing unused kernel image (text/rodata gap) memory: 2040K
ago 02 21:11:41 ***-pc kernel: Freeing unused kernel image (rodata/data gap) memory: 1216K
ago 02 21:11:41 ***-pc kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
ago 02 21:11:41 ***-pc kernel: rodata_test: all tests were successful
ago 02 21:11:41 ***-pc kernel: x86/mm: Checking user space page tables
ago 02 21:11:41 ***-pc kernel: Run /init as init process
ago 02 21:11:41 ***-pc kernel: with arguments:
ago 02 21:11:41 ***-pc kernel: /init
ago 02 21:11:41 ***-pc kernel: with environment:
ago 02 21:11:41 ***-pc kernel: HOME=/
ago 02 21:11:41 ***-pc kernel: TERM=linux
ago 02 21:11:41 ***-pc kernel: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
ago 02 21:11:41 ***-pc kernel: tsc: Refined TSC clocksource calibration: 2304.000 MHz
ago 02 21:11:41 ***-pc kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
ago 02 21:11:41 ***-pc kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
ago 02 21:11:41 ***-pc kernel: i8042: Warning: Keylock active
ago 02 21:11:41 ***-pc kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
ago 02 21:11:41 ***-pc kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
ago 02 21:11:41 ***-pc kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
ago 02 21:11:41 ***-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
ago 02 21:11:41 ***-pc kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
ago 02 21:11:41 ***-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
ago 02 21:11:41 ***-pc kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
ago 02 21:11:41 ***-pc kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
ago 02 21:11:41 ***-pc kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
ago 02 21:11:41 ***-pc kernel: usb usb1: Product: xHCI Host Controller
ago 02 21:11:41 ***-pc kernel: usb usb1: Manufacturer: Linux 5.18.15-1-MANJARO xhci-hcd
ago 02 21:11:41 ***-pc kernel: usb usb1: SerialNumber: 0000:00:14.0
ago 02 21:11:41 ***-pc kernel: hub 1-0:1.0: USB hub found
ago 02 21:11:41 ***-pc kernel: hub 1-0:1.0: 12 ports detected
ago 02 21:11:41 ***-pc kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
ago 02 21:11:41 ***-pc kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
ago 02 21:11:41 ***-pc kernel: usb usb2: Product: xHCI Host Controller
ago 02 21:11:41 ***-pc kernel: usb usb2: Manufacturer: Linux 5.18.15-1-MANJARO xhci-hcd
ago 02 21:11:41 ***-pc kernel: usb usb2: SerialNumber: 0000:00:14.0
ago 02 21:11:41 ***-pc kernel: hub 2-0:1.0: USB hub found
ago 02 21:11:41 ***-pc kernel: hub 2-0:1.0: 6 ports detected
ago 02 21:11:41 ***-pc kernel: usb: port power management may be unreliable
ago 02 21:11:41 ***-pc kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
ago 02 21:11:41 ***-pc kernel: usb 1-3: new full-speed USB device number 2 using xhci_hcd
ago 02 21:11:41 ***-pc kernel: usb 1-3: New USB device found, idVendor=062a, idProduct=4106, bcdDevice= 1.00
ago 02 21:11:41 ***-pc kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
ago 02 21:11:41 ***-pc kernel: usb 1-3: Product: 2.4G Wireless Mouse
ago 02 21:11:41 ***-pc kernel: usb 1-3: Manufacturer: MOSART Semi.
ago 02 21:11:41 ***-pc kernel: input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:062>
ago 02 21:11:41 ***-pc kernel: hid-generic 0003:062A:4106.0001: input,hiddev96,hidraw0: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wirel>
ago 02 21:11:41 ***-pc kernel: usbcore: registered new interface driver usbhid
ago 02 21:11:41 ***-pc kernel: usbhid: USB HID core driver
ago 02 21:11:41 ***-pc kernel: usb 1-5: new high-speed USB device number 3 using xhci_hcd
ago 02 21:11:41 ***-pc kernel: usb 1-5: New USB device found, idVendor=0bda, idProduct=5520, bcdDevice=85.11
ago 02 21:11:41 ***-pc kernel: usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
ago 02 21:11:41 ***-pc kernel: usb 1-5: Product: Integrated_Webcam_HD
ago 02 21:11:41 ***-pc kernel: usb 1-5: Manufacturer: CNFHH46P0454004BBC40
ago 02 21:11:41 ***-pc kernel: usb 1-5: SerialNumber: 200901010001
ago 02 21:11:41 ***-pc kernel: usb 1-6: new high-speed USB device number 4 using xhci_hcd
ago 02 21:11:41 ***-pc kernel: usb 1-6: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
ago 02 21:11:41 ***-pc kernel: usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
ago 02 21:11:41 ***-pc kernel: usb 1-6: Product: USB2.0-CRW
ago 02 21:11:41 ***-pc kernel: usb 1-6: Manufacturer: Generic
ago 02 21:11:41 ***-pc kernel: usb 1-6: SerialNumber: 20100201396000000
ago 02 21:11:41 ***-pc kernel: usbcore: registered new interface driver rtsx_usb
ago 02 21:11:41 ***-pc kernel: usb 1-7: new full-speed USB device number 5 using xhci_hcd
ago 02 21:11:41 ***-pc kernel: usb 1-7: New USB device found, idVendor=0cf3, idProduct=e009, bcdDevice= 0.01
ago 02 21:11:41 ***-pc kernel: usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
ago 02 21:11:41 ***-pc kernel: PM: Image not found (code -22)
ago 02 21:11:41 ***-pc kernel: fbcon: Taking over console
ago 02 21:11:41 ***-pc kernel: Console: switching to colour frame buffer device 170x48
ago 02 21:11:41 ***-pc kernel: EXT4-fs (sda8): mounted filesystem with ordered data mode. Quota mode: none.
ago 02 21:11:41 ***-pc systemd[1]: systemd 251.3-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCO>
ago 02 21:11:41 ***-pc systemd[1]: Detected architecture x86-64.
ago 02 21:11:41 ***-pc systemd[1]: Hostname set to <***-pc>.
ago 02 21:11:41 ***-pc systemd[1]: Queued start job for default target Graphical Interface.
ago 02 21:11:41 ***-pc systemd[1]: Created slice Slice /system/getty.
ago 02 21:11:41 ***-pc systemd[1]: Created slice Slice /system/modprobe.
ago 02 21:11:41 ***-pc systemd[1]: Created slice Slice /system/systemd-fsck.
ago 02 21:11:41 ***-pc systemd[1]: Created slice User and Session Slice.
ago 02 21:11:41 ***-pc systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
ago 02 21:11:41 ***-pc systemd[1]: Started Forward Password Requests to Wall Directory Watch.
ago 02 21:11:41 ***-pc systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Local Encrypted Volumes.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Login Prompts.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Local Integrity Protected Volumes.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Path Units.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Remote File Systems.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Slice Units.
ago 02 21:11:41 ***-pc systemd[1]: Reached target Local Verity Protected Volumes.
ago 02 21:11:41 ***-pc systemd[1]: Listening on Device-mapper event daemon FIFOs.
ago 02 21:11:41 ***-pc systemd[1]: Listening on LVM2 poll daemon socket.
ago 02 21:11:41 ***-pc systemd[1]: Listening on Process Core Dump Socket.
ago 02 21:11:41 ***-pc systemd[1]: Listening on Journal Audit Socket.
ago 02 21:11:41 ***-pc systemd[1]: Listening on Journal Socket (/dev/log).
ago 02 21:11:41 ***-pc systemd[1]: Listening on Journal Socket.
ago 02 21:11:41 ***-pc systemd[1]: Listening on udev Control Socket.
ago 02 21:11:41 ***-pc systemd[1]: Listening on udev Kernel Socket.
ago 02 21:11:41 ***-pc systemd[1]: Mounting Huge Pages File System...
ago 02 21:11:41 ***-pc systemd[1]: Mounting POSIX Message Queue File System...
ago 02 21:11:41 ***-pc systemd[1]: Mounting Kernel Debug File System...
ago 02 21:11:41 ***-pc systemd[1]: Mounting Kernel Trace File System...
ago 02 21:11:41 ***-pc systemd[1]: Starting Load AppArmor profiles...
ago 02 21:11:41 ***-pc systemd[1]: Starting Create List of Static Device Nodes...
ago 02 21:11:41 ***-pc systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
ago 02 21:11:41 ***-pc systemd[1]: Starting Load Kernel Module configfs...
ago 02 21:11:41 ***-pc systemd[1]: Starting Load Kernel Module drm...
ago 02 21:11:41 ***-pc systemd[1]: Starting Load Kernel Module fuse...
ago 02 21:11:41 ***-pc systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIs>
ago 02 21:11:41 ***-pc systemd[1]: Starting Load Kernel Modules...
ago 02 21:11:41 ***-pc systemd[1]: Starting Remount Root and Kernel File Systems...
ago 02 21:11:41 ***-pc systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
ago 02 21:11:41 ***-pc systemd[1]: Starting Coldplug All udev Devices...
ago 02 21:11:41 ***-pc systemd[1]: Mounted Huge Pages File System.
ago 02 21:11:41 ***-pc systemd[1]: Mounted POSIX Message Queue File System.
ago 02 21:11:41 ***-pc systemd[1]: Mounted Kernel Debug File System.
ago 02 21:11:41 ***-pc systemd[1]: Mounted Kernel Trace File System.
ago 02 21:11:41 ***-pc systemd[1]: Finished Create List of Static Device Nodes.
ago 02 21:11:41 ***-pc systemd[1]: modprobe@configfs.service: Deactivated successfully.
ago 02 21:11:41 ***-pc systemd[1]: Finished Load Kernel Module configfs.
ago 02 21:11:41 ***-pc systemd[1]: modprobe@drm.service: Deactivated successfully.
ago 02 21:11:41 ***-pc systemd[1]: Finished Load Kernel Module drm.
ago 02 21:11:41 ***-pc systemd[1]: Mounting Kernel Configuration File System...
ago 02 21:11:41 ***-pc systemd[1]: Mounted Kernel Configuration File System.
ago 02 21:11:41 ***-pc kernel: fuse: init (API version 7.36)
ago 02 21:11:41 ***-pc systemd[1]: modprobe@fuse.service: Deactivated successfully.
ago 02 21:11:41 ***-pc systemd[1]: Finished Load Kernel Module fuse.
ago 02 21:11:41 ***-pc systemd[1]: Mounting FUSE Control File System...
ago 02 21:11:41 ***-pc systemd[1]: Mounted FUSE Control File System.
ago 02 21:11:41 ***-pc kernel: EXT4-fs (sda8): re-mounted. Quota mode: none.
ago 02 21:11:41 ***-pc systemd[1]: Finished Remount Root and Kernel File Systems.
ago 02 21:11:41 ***-pc systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
ago 02 21:11:41 ***-pc systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/>
ago 02 21:11:41 ***-pc systemd[1]: Starting Load/Save Random Seed...
ago 02 21:11:41 ***-pc systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
ago 02 21:11:41 ***-pc systemd[1]: Starting Create Static Device Nodes in /dev...
ago 02 21:11:41 ***-pc systemd[1]: Finished Coldplug All udev Devices.
ago 02 21:11:41 ***-pc kernel: vboxdrv: loading out-of-tree module taints kernel.
ago 02 21:11:41 ***-pc kernel: vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
ago 02 21:11:41 ***-pc kernel: vboxdrv: Found 4 processor cores
ago 02 21:11:41 ***-pc kernel: vboxdrv: TSC mode is Invariant, tentative frequency 2303998928 Hz
ago 02 21:11:41 ***-pc kernel: vboxdrv: Successfully loaded version 6.1.36 r152435 (interface 0x00320000)
ago 02 21:11:41 ***-pc kernel: VBoxNetAdp: Successfully started.
ago 02 21:11:41 ***-pc kernel: VBoxNetFlt: Successfully started.
ago 02 21:11:41 ***-pc systemd[1]: Finished Load/Save Random Seed.
ago 02 21:11:41 ***-pc systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485499.772:2): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc kernel: device-mapper: uevent: version 1.0.3
ago 02 21:11:41 ***-pc kernel: device-mapper: ioctl: 4.46.0-ioctl (2022-02-22) initialised: dm-devel@redhat.com
ago 02 21:11:41 ***-pc systemd[1]: Finished Load Kernel Modules.
ago 02 21:11:41 ***-pc systemd[1]: Starting Apply Kernel Variables...
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485499.985:3): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485500.058:4): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485500.138:5): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485500.142:6): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485500.188:7): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc kernel: audit: type=1400 audit(1659485500.192:8): apparmor="STATUS" operation="profile_load" profile="unconfi>
ago 02 21:11:41 ***-pc systemd[1]: Finished Apply Kernel Variables.
ago 02 21:11:41 ***-pc systemd[1]: Starting CLI Netfilter Manager...
