System doesn't suspend properly
Hi,
My system doesn’t suspend properly after using it a while. For the first, second or even fourth or whatever works without problem but a random attempt (close lid) doesn’t suspend system properly. Hard disk led stays on, fan works loudly and if I open lid, screen doesn’t came up. So I have to press power button long to force it to close.
Don’t take account of zen kernel, I’ve four kernel ( zen 6.4, kernel 6.3, kernel 6.1 and 5.15 ) on system and the issue were triggered after update system to kernel 6.x. Suspend works properly at kernel 5.15 even at ten or more when I try close lid.
I always check journalctl after reboot but it doesn’t give a meaningfull clue about what’s going on. The last entry on the log always is “PM: suspend entry (deep)”. How can I debug this problem?
  Kernel: 6.4.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
    root=UUID=5779ac9e-ba54-447e-a069-a626d8d45fa5 rw quiet
    cryptdevice=UUID=a11091e0-2731-4754-b6ec-30df0d377dfb:luks-a11091e0-2731-4754-b6ec-30df0d377dfb
    root=/dev/mapper/luks-a11091e0-2731-4754-b6ec-30df0d377dfb
    resume=/dev/mapper/luks-a11091e0-2731-4754-b6ec-30df0d377dfb apparmor=1
    lsm=landlock,lockdown,yama,apparmor,bpf mem_sleep_default=deep
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: UX310UQK v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX310UQK v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: UX310UQK.311 date: 04/18/2019
  ID-1: BAT0 charge: 46.0 Wh (100.0%) condition: 46.0/44.5 Wh (103.4%)
    volts: 11.4 min: 11.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 21
  System RAM: available: 15.51 GiB used: 7.13 GiB (46.0%)
  Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF2
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 770 high: 800 min/max: 400/3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 681 2: 800 3: 799 4: 800
    bogomips: 23199
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia
    v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
    class-ID: 0302
  Device-3: Realtek USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0bda:58d2
  Display: x11 server: X.org v: 1.21.1.8 compositor: xfwm v: 4.18.0 driver:
    X: loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3200x1800 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: Samsung 0x374a built: 2014 res: 3200x1800 hz: 60
    dpi: 277 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
    ratio: 16:9 modes: 3200x1800
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel HD Graphics 620 (KBL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.4.0-zen1-1-zen status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.70 status: off with: 1: pipewire-media-session
    status: off 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-jack
    type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 8087:0a2b
    class-ID: e001
  Device-1: luks-a11091e0-2731-4754-b6ec-30df0d377dfb maj-min: 254:0
    type: LUKS dm: dm-0 size: 322.18 GiB
  Components:
  p-1: sda5 maj-min: 8:5 size: 322.18 GiB
  Device-2: luks-47ad7c79-701b-430a-80df-8d7bac4a33f9 maj-min: 254:1
    type: LUKS dm: dm-1 size: 45.54 GiB
  Components:
  p-1: sdb2 maj-min: 8:18 size: 45.54 GiB
  Local Storage: total: 592.63 GiB used: 327.78 GiB (55.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS512G39TND-N210A
    size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra Fit
    size: 115.69 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 322.18 GiB size: 304.24 GiB (94.43%)
    used: 274.08 GiB (90.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-a11091e0-2731-4754-b6ec-30df0d377dfb label: N/A
    uuid: 5779ac9e-ba54-447e-a069-a626d8d45fa5
  ID-2: /run/media/hoobastank/Linux raw-size: 45.54 GiB
    size: 44.52 GiB (97.77%) used: 27.14 GiB (61.0%) fs: ext4 dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-47ad7c79-701b-430a-80df-8d7bac4a33f9
    label: LinuxYedek uuid: 2e0e4e12-4163-4cdc-a920-b26c1ef6b1bb
  ID-3: /run/media/hoobastank/NTFS raw-size: 70.12 GiB
    size: 70.12 GiB (100.00%) used: 26.56 GiB (37.9%) fs: ntfs dev: /dev/sdb1
    maj-min: 8:17 label: NTFSYedek uuid: 1808A1696F69902D
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda6 maj-min: 8:6 label: swap
    uuid: 04224dbe-e601-45ca-bf0b-5ccd9aedd9cb
  ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: EC18-BA0B
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 150 GiB fs: ntfs label: OS
    uuid: 98741F9F741F7EE6
  ID-4: /dev/sda4 maj-min: 8:4 size: 499 MiB fs: ntfs label: RECOVERY
    uuid: 7EA63776A6372DD1
  ID-5: /dev/sdb3 maj-min: 8:19 size: 33 MiB fs: vfat label: N/A
    uuid: AF2B-2249
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Realtek USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0bda:58d2 class-ID: 0e02 serial: <filter>
  Device-2: 1-8:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Device-1: 2-1:2 info: SanDisk Ultra Fit type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 62.0 C pch: 51.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 3500
  Processes: 256 Uptime: 28m wakeups: 2 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 2078 libs: 513 tools: pacaur,pamac,yay Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.27
$ pacman -Q | grep nvidia
lib32-nvidia-utils 535.54.03-2
mhwd-nvidia 530.41.03-4
mhwd-nvidia-304xx 1:304.137-1
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.157-6
mhwd-nvidia-470xx 470.182.03-2
nvidia-dkms 535.54.03-1
nvidia-prime 1.0-4
nvidia-utils 535.54.03-1
nvidia-xrun 0.3-0
mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
Jul 03 00:16:18 hoobastank systemd-logind[475]: Lid closed.
Jul 03 00:16:18 hoobastank systemd-logind[475]: Suspending...
Jul 03 00:16:18 hoobastank ModemManager[502]: <info>  [sleep-monitor-systemd] system is about to suspend
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2204] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2207] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reas>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2217] device (48:E2:44:5F:28:4C): state change: disconnected -> unmanaged (r>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2226] device (BC:54:51:FD:7A:3F): state change: disconnected -> unmanaged (r>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2236] device (A8:76:50:E1:D2:6B): state change: disconnected -> unmanaged (r>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2262] manager: NetworkManager state is now ASLEEP
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.2267] device (wlp2s0): state change: activated -> deactivating (reason 'slee>
Jul 03 00:16:18 hoobastank dbus-daemon[470]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freede>
Jul 03 00:16:18 hoobastank systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 03 00:16:18 hoobastank dbus-daemon[470]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 03 00:16:18 hoobastank systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 03 00:16:18 hoobastank kernel: wlp2s0: deauthenticating from 50:ff:20:29:b7:f6 by local choice (Reason: 3=DEAUTH_LEAVING)
Jul 03 00:16:18 hoobastank wpa_supplicant[851]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=50:ff:20:29:b7:f6 reason=3 locally_generated=1
Jul 03 00:16:18 hoobastank wpa_supplicant[851]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3383] device (wlp2s0): state change: deactivating -> disconnected (reason 's>
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Withdrawing address record for fe80::47:e041:8146:8dbb on wlp2s0.
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::47:e041:8146:8dbb.
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3390] dhcp4 (wlp2s0): canceled DHCP transaction
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3390] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 secon>
Jul 03 00:16:18 hoobastank wpa_supplicant[851]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-9999 noise=9999 txrate=0
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3390] dhcp4 (wlp2s0): state changed no lease
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.46.
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Withdrawing address record for 192.168.1.46 on wlp2s0.
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3538] device (wlp2s0): set-hw-addr: set MAC address to C2:08:DB:EB:06:F5 (sc>
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.46.
Jul 03 00:16:18 hoobastank avahi-daemon[468]: New relevant interface wlp2s0.IPv4 for mDNS.
Jul 03 00:16:18 hoobastank avahi-daemon[468]: Registering new address record for 192.168.1.46 on wlp2s0.IPv4.
Jul 03 00:16:18 hoobastank systemd-resolved[333]: wlp2s0: Bus client set default route setting: no
Jul 03 00:16:18 hoobastank systemd-resolved[333]: wlp2s0: Bus client reset DNS server list.
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3739] device (wlp2s0): supplicant interface state: completed -> disconnected
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3743] device (wlp2s0): supplicant interface state: disconnected -> interface>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3745] device (wlp2s0): supplicant interface state: interface_disabled -> dis>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.3757] device (wlp2s0): state change: disconnected -> unmanaged (reason 'slee>
Jul 03 00:16:18 hoobastank NetworkManager[499]: <info>  [1688332578.4952] device (wlp2s0): set-hw-addr: reset MAC address to 28:16:AD:C8:21:75 (>
Jul 03 00:16:18 hoobastank wpa_supplicant[851]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jul 03 00:16:18 hoobastank wpa_supplicant[851]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Jul 03 00:16:18 hoobastank systemd[1]: Reached target Sleep.
Jul 03 00:16:18 hoobastank systemd[1]: Starting NVIDIA system suspend actions...
Jul 03 00:16:18 hoobastank suspend[43277]: nvidia-suspend.service
Jul 03 00:16:18 hoobastank logger[43277]: <13>Jul  3 00:16:18 suspend: nvidia-suspend.service
Jul 03 00:16:18 hoobastank wpa_supplicant[851]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jul 03 00:16:18 hoobastank systemd[1]: nvidia-suspend.service: Deactivated successfully.
Jul 03 00:16:18 hoobastank systemd[1]: Finished NVIDIA system suspend actions.
Jul 03 00:16:18 hoobastank systemd[1]: Starting System Suspend...
Jul 03 00:16:18 hoobastank systemd-sleep[43286]: Entering sleep state 'suspend'...
Jul 03 00:16:18 hoobastank kernel: PM: suspend entry (deep)
Please clarify
  • suspend - does not require swap - all in ram
or
  • hibernate - requires swap to write memory to disk
There is a newer BIOS version for your model …
I think all those model from Asus need this in order to wake up from suspend, as this model ASUS Zenbook UX31E - ArchWiki
On the other hand, you might have to do some changes, so please read this Power management/Suspend and hibernate - ArchWiki
suspend which doesn’t require swap.
Are you sure that there is newer BIOS version for my model?
Here is ASUS support page:
https://www.asus.com/supportonly/ux310uq/helpdesk_bios/
There are two models which are UX310UQ and UX310UQK. In fact my model is UX310UQ according to label on PC but I’d used BIOS file of UX310UQK 3 years ago, thought that it was newer and probably there is no difference between two models.
If you select UX310UQ you see Version 305 (2019/06/05) and if you select UX310UQK you see Version 311 (2019/06/05), different versions, but they’ve same date. They probably are same BIOS with different name. It doesn’t matter which one is true does matter? I’ve been using Version 311 (2019/06/05) for 3 years, it didn’t cause any problem up to now. Problem was arisen after kernel update 6.x.
Your model is
the BIOS is
AFAIK the
will not change because i think is part of the model tag.
Do not flash a different BIOS than the one recommended for your exact model.
The one with the red pointer is what your laptop has now
Even tho you might have downloaded it at a latter date.
So BIOS seems uptodate according to ASUS support. As I said before the issue has arisen after kernel update from 5.x to 6.x
I can’t debug the problem because when I close lid system isn’t suspended properly and fan works loudly and I have to force it to shut down. After reboot, journalctl doesn’t give a meaningfull clue.
You can have multiple kernels installed as you know already, so, booting from any of the 5.x LTS kernel is making your laptop to perform as expected?
Yes. Whenever I close lid, system suspends while using kernel 5.x
So, is there any way to debug this issue on kernel 6.x? I can’t even speculate about the issue without any log or footprint. Debug this issue isn’t very easy without right log. Do you have any suggestion?
