The grub boot instruction got corrupted too but thankfully I can still boot grub itself if I load the drive manually, I’ve seen threads that mention a potential fix for that but they always require chroot. I originally tried the
su -
in a normal terminal (of live usb) and then followed the instructions I’d found but fell short at the
chroot /mnt/lbl/@ /bin/bash
I tried many variations thereof but no luck so I then went to the actual directory, opened it as root and then opened it in terminal then finally tried the chroot variations again but instead used variations of . ./bin/bash, unfortunatly all I get is messages like this:
chroot: failed to run command ‘./bin/bash’: Input/output error
I checked in the relevant directories and they ARE there so I’m now at an impass, someone please help me
Yeah I’ve tried manjaro-chroot too, didn’t work, switched to chroot afterwards to see if anything changed but as you can see I’m here
Edit: Btw when I tried the -a command it keeps going for the wrong drive so I gave up on that
Edit 2: to be exact it chucks this at me:
grub-probe: error: cannot find a GRUB drive for /dev/sde1. Check your device.map.
==> ERROR: No Linux partitions detected!
Had to sleep so attribute a few hours of the wait to that, I’ve somewhat restored grub I think as the instructions were about a generic system boot fix from livecd/liveusb. Unfortunately I still can’t get the system to boot as the kernels appear to be corrupted. The files still exist, I tried xnu_kernel & xnu_kernel64 on the file in /@/boot but they report Mach 0 is not setup for 32/64bit. I tried the linux command on those same files but it reports premature end. I don’t actually know what those commands do but I figured they look suitable, honestly I think the system is confused by the /@ that should be prepended to the root but I don’t see it when it says it can’t find the kernel files from the grub menu
I didn’t see it mentioned, but …
you did try to chroot into your system via booting from USB (or similar) ?
From the syntax you used I suspect your system is on BTRFS ?
… which might … complicate things
oh well - it’s done with now …
