After each update that consists of a kernel update (not necessarily an upgrade, but upgrade as well), i.e. any update that requires a restart, the system would work fine until I go AFK for a while and the screen lock \ monitor standby kick in.
After that AFK period, when I get back, I find my system frozen with the screen showing the BIOS logo (more recently just a black screen with a very rapidly blinking cursor).
Sometimes I’m able to restart it with rapid use of ctrl+alt+delete, sometimes even this fails. TTY switching doesn’t work either.
After a restart the system works fine.
It seems as if the system going to lock screen \ monitor standby causes the system to try and reload the nvidia driver, which fails.
Since the system works properly before this AFK period, I suspect it’d be easy to disable this reload and keep the system working until restart.
As I’m reporting this, I’ve just updated the system - so this can easily be reproduced right now.
So if there’s any missing information, any additional log files (or higher logging verbosity) needed, now is the time to mention it, so I can set it to log before letting my system freeze.
Here are the logs from last week, when it last happened:
/var/log/Xorg.1.log:
[1383800.788]
X.Org X Server 1.20.11
[1383800.788] Build Operating System: Linux Manjaro Linux
[1383800.788] Current Operating System: Linux feature-precision3630tower 5.10.36-2-MANJARO #1 SMP PREEMPT Tue May 11 19:38:44 UTC 2021 x86_64
[1383800.788] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=14840702-a1f4-45f2-ac1d-bf20549068fa rw quiet apparmor=1 security=apparmor udev.log_priority=3 mitigations=off
[1383800.788] Build Date: 13 April 2021 04:11:08PM
[1383800.788]
[1383800.788] Current version of pixman: 0.40.0
[1383800.788] Before reporting problems, check http://wiki.x.org
[1383800.788] Markers: (--) probed, (**) from config file, (==) default setting,
[1383800.788] (==) Log file: "/var/log/Xorg.1.log", Time: Tue Jun 8 08:43:21 2021
[1383800.789] (==) Using config directory: "/etc/X11/xorg.conf.d"
[1383800.789] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[1383800.789] (==) ServerLayout "layout"
[1383800.789] (**) |-->Screen "Screen0" (0)
[1383800.789] (**) | |-->Monitor "Monitor0"
[1383800.789] (**) | |-->Device "Device0"
[1383800.789] (==) Automatically adding devices
[1383800.789] (==) Automatically enabling devices
[1383800.789] (==) Automatically adding GPU devices
[1383800.789] (==) Automatically binding GPU devices
[1383800.789] (==) Max clients allowed: 256, resource mask: 0x1fffff
[1383800.789] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[1383800.789] Entry deleted from font path.
[1383800.789] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[1383800.789] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[1383800.789] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[1383800.789] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[1383800.789] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[1383800.789] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[1383800.789] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[1383800.789] (==) FontPath set to:
[1383800.789] (==) ModulePath set to "/usr/lib/xorg/modules"
[1383800.789] (**) Extension "COMPOSITE" is enabled
[1383800.789] (II) The server relies on udev to provide the list of input devices.
[1383800.789] (II) Module ABI versions:
[1383800.789] X.Org ANSI C Emulation: 0.4
[1383800.789] X.Org Video Driver: 24.1
[1383800.789] X.Org XInput driver : 24.1
[1383800.789] X.Org Server Extension : 10.0
[1383800.792] (++) using VT number 8
[1383800.792] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[1383800.793] (II) xfree86: Adding drm device (/dev/dri/card0)
[1383800.793] (II) xfree86: Adding drm device (/dev/dri/card1)
[1383800.794] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[1383800.794] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[1383800.795] (--) PCI: (0@0:2:0) 8086:3e92:1028:0871 rev 0, Mem @ 0xa2000000/16777216, 0x80000000/268435456, I/O @ 0x00004000/64
[1383800.795] (--) PCI:*(1@0:0:0) 10de:1b80:1028:3366 rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[1383800.795] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[1383800.795] (II) LoadModule: "glx"
[1383800.795] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[1383800.796] (II) Module glx: vendor="X.Org Foundation"
[1383800.796] compiled for 1.20.11, module version = 1.0.0
[1383800.796] ABI class: X.Org Server Extension, version 10.0
[1383800.796] (II) LoadModule: "nvidia"
[1383800.797] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[1383800.797] (II) Module nvidia: vendor="NVIDIA Corporation"
[1383800.797] compiled for 1.6.99.901, module version = 1.0.0
[1383800.797] Module class: X.Org Video Driver
[1383800.797] (II) NVIDIA dlloader X Driver 465.31 Thu May 13 22:19:15 UTC 2021
[1383800.797] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[1383800.797] (II) Loading sub module "fb"
[1383800.797] (II) LoadModule: "fb"
[1383800.797] (II) Loading /usr/lib/xorg/modules/libfb.so
[1383800.797] (II) Module fb: vendor="X.Org Foundation"
[1383800.797] compiled for 1.20.11, module version = 1.0.0
[1383800.797] ABI class: X.Org ANSI C Emulation, version 0.4
[1383800.797] (II) Loading sub module "wfb"
[1383800.797] (II) LoadModule: "wfb"
[1383800.797] (II) Loading /usr/lib/xorg/modules/libwfb.so
[1383800.797] (II) Module wfb: vendor="X.Org Foundation"
[1383800.797] (II) Loading sub module "ramdac"
[1383800.797] (II) LoadModule: "ramdac"
[1383800.797] (II) Module "ramdac" already built-in
[1383800.798] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[1383800.798] (EE) NVIDIA: system's kernel log for additional error messages and
[1383800.798] (EE) NVIDIA: consult the NVIDIA README for details.
[1383800.799] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[1383800.799] (EE) NVIDIA: system's kernel log for additional error messages and
[1383800.799] (EE) NVIDIA: consult the NVIDIA README for details.
[1383800.799] (EE) No devices detected.
[1383800.799] (EE)
Fatal server error:
[1383800.799] (EE) no screens found(EE)
[1383800.799] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[1383800.799] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[1383800.799] (EE)
[1383800.803] (EE) Server terminated with error (1). Closing log file.
System details:
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop System: Dell product: Precision 3630 Tower v: N/A
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: Dell model: 0NNNCT v: A01 serial: <filter> UEFI: Dell v: 2.6.1
date: 07/01/2020
RAM: total: 31.2 GiB used: 4.11 GiB (13.2%)
Info: 6-Core model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
cache: L2: 12 MiB bogomips: 76831
Speed: 900 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Type: tsx_async_abort status: Vulnerable
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1080] vendor: Dell driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b80
class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5")
s-diag: 600mm (23.6")
Monitor-1: DP-4 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060
bus-ID: 00:17.0 chip-ID: 8086.2822 rev: 10 class-ID: 0104
Local Storage: total: 476.94 GiB used: 128.26 GiB (26.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 SATA 512GB
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: L022 scheme: GPT
Optical-1: /dev/sr0 vendor: TS8XDVDS model: TRANSCEND rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 210.08 GiB size: 205.78 GiB (97.95%)
used: 128.2 GiB (62.3%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 14840702-a1f4-45f2-ac1d-bf20549068fa
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 66.5 MiB (10.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: ESP
uuid: B040-598E
ID-1: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 265.12 GiB fs: ntfs label: OS
uuid: 426C78126C77FF4B
ID-3: /dev/sda4 maj-min: 8:4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: C26A19566A194895
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-9:2 info: Transcend Information Portable Super Multi Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 8564:8000 class-ID: 0802
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 2-8:2 info: Realtek USB3.0-CRW type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0328 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): cpu: 1543 fan-2: 821 gpu: nvidia fan: 27%
Processes: 270 Uptime: 17m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 11.1.0 Packages: pacman: 1465 lib: 435
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
