System collapsed suddenly in newest version on stable branch
Hi guys,
I just install Manjaro Gnome from the newest release on 2024.12.16 yesterday. I choose the open source installation so there is no stuff related to nvidia so far. However, I find that my system will collapse while using radomly for no reason. To be more specific, the situation is that everything would sudddenly freeze, with cursor not able to move either from the touchpad or mouse and keyboard disabled without response, so that I have to press power button to shutdown.
Here is my computers situation:
(base) [nuvole0217@Nuvole ~]$ uname -r
6.12.4-1-MANJARO
(base) [nuvole0217@Nuvole ~]$ inxi -Fazzz
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=775df364-690c-42e1-bf59-b2fdb4bdbf25 rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A14 FA401WV_FA401WV
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FA401WV v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: FA401WV.314
    date: 11/07/2024
  ID-1: BAT0 charge: 53.3 Wh (77.9%) condition: 68.4/73.0 Wh (93.6%)
    power: 10.4 W volts: 16.0 min: 15.9 model: AS3GYRE3KC GA40347 type: Unknown
    serial: <filter> status: discharging
  Info: model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64 type: MT MCP
    arch: N/A level: v4 note: check family: 0x1A (26) model-id: 0x24 (36)
    stepping: 0 microcode: 0xB204019
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 24 MiB desc: 1x16 MiB, 1x8 MiB
  Speed (MHz): avg: 2000 min/max: 599/4367 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2000 2: 2000 3: 2000
    4: 2000 5: 2000 6: 2000 7: 2000 8: 2000 9: 2000 10: 2000 11: 2000 12: 2000
    13: 2000 14: 2000 15: 2000 16: 2000 17: 2000 18: 2000 19: 2000 20: 2000
    21: 2000 22: 2000 23: 2000 24: 2000 bogomips: 96024
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
    driver: nouveau v: kernel non-free: 550.xx+ status: current (as of 2024-09)
    arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 8 ports: active: none
    empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 64:00.0 chip-ID: 10de:28e0
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Strix [Radeon 880M / 890M]
    vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
    DP-8, DP-9, Writeback-1 bus-ID: 65:00.0 chip-ID: 1002:150e class-ID: 0380
    temp: 34.0 C
  Device-3: Sonix ASUS FHD webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 3277:0018
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-2 model: BOE Display NE140QDM-NX7 built: 2023
    res: 2560x1600 dpi: 215 gamma: 1.2 size: 302x188mm (11.89x7.4")
    diag: 356mm (14") ratio: 16:10 modes: max: 2560x1600 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
    device: 0 drv: nouveau device: 1 drv: radeonsi device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: nouveau wayland: drv: radeonsi x11:
    drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa v: 24.2.8-arch1.1
    gfx1150 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:150e
    memory: 500 MiB unified: no display-ID: :0.0
  Device-1: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 64:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: ASUSTeK driver: snd_acp_pci v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_rpl_pci_acp6x,
    snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 65:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 65:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 63:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp99s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 0489:e0f6
  Local Storage: total: 953.87 GiB used: 15.18 GiB (1.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN560 SDDPNQE-1T00-1102 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 74114000 temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 217 GiB size: 212.53 GiB (97.94%) used: 15.08 GiB (7.1%)
    fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 98.4 MiB (38.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 35.9 C mobo: N/A gpu: amdgpu temp: 35.0 C
  Fan Speeds (rpm): cpu: 0
  Memory: total: 16 GiB note: est. available: 14.74 GiB used: 2.77 GiB (18.8%)
  Processes: 495 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
    image: 5.86 GiB services: gsd-power, power-profiles-daemon, upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1471 libs: 350 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash
    v: 5.2.37 running-in: ghostty inxi: 3.3.36
and here is what I find in journalctl
1月 08 18:59:20 Nuvole wpa_supplicant[1011]: wlp99s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=780000
1月 08 18:59:20 Nuvole touchegg.desktop[2022]: /usr/include/c++/14.1.1/bits/stl_vector.h:1130: std::vector<_Tp, _Alloc>::reference std::vector<_Tp, _Alloc>::operator[](size_type) [with _Tp = long unsigned int; _Alloc = std::allocator<long unsigned int>; >
1月 08 18:59:20 Nuvole systemd-coredump[2482]: Process 2022 (touchegg) of user 1000 terminated abnormally with signal 6/ABRT, processing...
1月 08 18:59:20 Nuvole systemd[1]: Created slice Slice /system/systemd-coredump.
1月 08 18:59:20 Nuvole systemd[1]: Started Process Core Dump (PID 2482/UID 0).
1月 08 18:59:20 Nuvole systemd-coredump[2483]: [🡕] Process 2022 (touchegg) of user 1000 dumped core.
                                                Stack trace of thread 2022:
                                                #0  0x0000797913ca53f4 n/a (libc.so.6 + 0x963f4)
                                                #1  0x0000797913c4c120 raise (libc.so.6 + 0x3d120)
                                                #2  0x0000797913c334c3 abort (libc.so.6 + 0x244c3)
                                                #3  0x0000797913ed3af0 _ZSt21__glibcxx_assert_failPKciS0_S0_ (libstdc++.so.6 + 0xd3af0)
                                                #4  0x00005de7add3caa0 _ZNK3X1118getDesktopWorkareaEv (touchegg + 0x3eaa0)
                                                #5  0x00005de7add1f895 _ZN19TileWindowAnimationC1ERK12WindowSystemRK7WindowT5ColorS6_b (touchegg + 0x21895)
                                                #6  0x00005de7add1f9a0 _ZN16AnimationFactory14buildAnimationE13AnimationTypeRK12WindowSystemRK7WindowT5ColorS7_ (touchegg + 0x219a0)
                                                #7  0x00005de7add20e21 _ZN10TileWindow14onGestureBeginERK7Gesture (touchegg + 0x22e21)
                                                #8  0x00005de7add18e16 _ZN12DaemonClient23sendToGestureControllerERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEP9_GVariant (touchegg + 0x1ae16)
                                                #9  0x00005de7add18f8b _ZN12DaemonClient12onNewMessageEP16_GDBusConnectionPKcS3_S3_S3_P9_GVariantPv (touchegg + 0x1af8b)
                                                #10 0x0000797914ccc9b9 n/a (libgio-2.0.so.0 + 0x1019b9)
                                                #11 0x0000797914df7559 n/a (libglib-2.0.so.0 + 0x5d559)
                                                #12 0x0000797914e5a257 n/a (libglib-2.0.so.0 + 0xc0257)
                                                #13 0x0000797914df8287 g_main_loop_run (libglib-2.0.so.0 + 0x5e287)
                                                #14 0x00005de7add13a0e main (touchegg + 0x15a0e)
                                                #15 0x0000797913c34e08 n/a (libc.so.6 + 0x25e08)
                                                #16 0x0000797913c34ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                #17 0x00005de7add13c05 _start (touchegg + 0x15c05)
                                                Stack trace of thread 2322:
                                                #0  0x0000797913d1abb0 ppoll (libc.so.6 + 0x10bbb0)
                                                #1  0x0000797914e5a327 n/a (libglib-2.0.so.0 + 0xc0327)
                                                #2  0x0000797914df6a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
                                                #3  0x0000797914df6ab2 n/a (libglib-2.0.so.0 + 0x5cab2)
                                                #4  0x0000797914e2cbe6 n/a (libglib-2.0.so.0 + 0x92be6)
                                                #5  0x0000797913ca339d n/a (libc.so.6 + 0x9439d)
                                                #6  0x0000797913d2849c n/a (libc.so.6 + 0x11949c)
                                                Stack trace of thread 2479:
                                                #3  0x000079791528b2fe n/a (libdconfsettings.so + 0x62fe)
                                                Stack trace of thread 2329:
                                                #2  0x0000797914df8287 g_main_loop_run (libglib-2.0.so.0 + 0x5e287)
                                                #3  0x0000797914cdebc4 n/a (libgio-2.0.so.0 + 0x113bc4)
                                                Stack trace of thread 2320:
                                                #0  0x0000797913d1ac5a read (libc.so.6 + 0x10bc5a)
                                                #1  0x00005de7add1d74a n/a (touchegg + 0x1f74a)
                                                #2  0x00005de7add1d7a1 n/a (touchegg + 0x1f7a1)
                                                #3  0x0000797913ee1c34 execute_native_thread_routine (libstdc++.so.6 + 0xe1c34)
                                                #4  0x0000797913ca339d n/a (libc.so.6 + 0x9439d)
                                                #5  0x0000797913d2849c n/a (libc.so.6 + 0x11949c)
                                                Stack trace of thread 2321:
                                                #0  0x0000797913d261fd syscall (libc.so.6 + 0x1171fd)
                                                #1  0x0000797914e28be0 g_cond_wait (libglib-2.0.so.0 + 0x8ebe0)
                                                #2  0x0000797914dbf98c n/a (libglib-2.0.so.0 + 0x2598c)
                                                #3  0x0000797914e2f237 n/a (libglib-2.0.so.0 + 0x95237)
                                                Stack trace of thread 2478:
                                                #1  0x0000797914e298f7 g_cond_wait_until (libglib-2.0.so.0 + 0x8f8f7)
                                                #2  0x0000797914dbf955 n/a (libglib-2.0.so.0 + 0x25955)
                                                #3  0x0000797914e2fcfb n/a (libglib-2.0.so.0 + 0x95cfb)
Anyone can help me solve this problem? I used to use manjaro and I stick to it is because it is really stable. But this problem is really bothering since I don’t know whether things would be down next moment :cry: So I really wish someone can help me with this :sob:
Without any comparable system it is impossible to suggest any meaningful response and the following is only thoughts.
The CPU is very new - likely you will have better support using linux 6.13 on unstable branch.
sudo pacman-mirrors -aS unstable
sudo pacman -Syu
mhwd-kernel -i linux613
Test by installing the laptop combo driver - I suggest using dkms and the latest nvidia 565
  • to check is whether you have any swap configured
  • to check your power settings
  • to check if any xf86- packages are installed - if any remove them
May I ask when will we have linux 6.13 on the stable branch? Maybe I can wait for a bit :thinking:
I have run swapon --show in my terminal and get nothing, so I guess it indicates that there is no swap enabled.
xf86 packages information:
(base) [nuvole0217@Nuvole ~]$ pacman -Q | grep xf86
libxxf86vm 1.1.5-2
xf86-input-elographics 1.4.4-1
xf86-input-evdev 2.11.0-1
xf86-input-libinput 1.5.0-1
xf86-input-void 1.4.2-2
xf86-input-wacom 1.2.2-1
xf86-video-amdgpu 23.0.0-2
xf86-video-ati 1:22.0.0-2
xf86-video-intel 1:2.99.917+923+gb74b67f0-2
xf86-video-nouveau 1.0.18-1
and here is the power setting situation:
[nuvole0217@Nuvole ~]$ powerprofilesctl list
  performance:
    CpuDriver:  amd_pstate
    PlatformDriver:     platform_profile
    Degraded:   no
* balanced:
  power-saver:
Besides, the reason why I choose to install at this time before waiting till next stable release is based on this, I can see that it is stable for my cpu chip, so maybe the discrepency is on my side? Not quite sure…
Is it not in the installation list?
I live in STABLE branch.
❱ pacman-mirrors -G
stable
❱ sudo mhwd-kernel -l
available kernels:
   * linux419
   * linux510
   * linux515
   * linux54
   * linux61
   * linux611
   * linux612
   * linux613 🌸
   * linux66
   * linux61-rt
   * linux611-rt
   * linux66-rt
❱ LC_ALL=C sudo mhwd-kernel -i linux613
Packages (3) linux613-6.13.0rc2-1  linux613-headers-6.13.0rc2-1  linux613-virtualbox-host-modules-7.1.4-0.6
Total Download Size:   175.18 MiB
Total Installed Size:  283.53 MiB
Thanks for let me know, I ll try switch to this situation first to see if things gets better!
(base) [nuvole0217@Nuvole ~]$ pacman-mirrors -G
stable
6.13.0-rc2-1-MANJARO
Update
Not working, still got a sudden freeze just now :cry:
In case the link is needed:
There’s 6.13.0rc5-1 on Testing.
Not sure about Gnome, but I’ve been very stable with Testing for a year now.
You can use Timeshift and get a snapshot before biting :wink:
If this is a hardware issue, you won’t get more stable than that.
    driver: nouveau
Why not install the proprietary Nvidia driver? I’d imagine that such a new card has issues using nouveau.
At least check if there’s an option to completely disable the Nvidia card in Bios, if that solves the issue (the AMD should work) you know that you’ll need the proprietary driver.
Have you updated your system already? If not:
sudo pacman -Syu
It is advisable as mentioned by @6x12 to install the proprietary Nvidia drivers:
sudo mhwd -a pci free 0300
Afterwards, reboot.
P.S.: How long have you waited before pressing the power button?
Guys, currently my choice is switch to unstable branch, and already running
sudo pacman -Syu
to update my computer to the newest status. Lets wait and see if problems solved. I am actually careful with nvidia, overall it is closed source…
Seems this pb persists :cry:
Oh, and I forgot to mentioned that actually at first I tried boot into proprietary when I try to install via usb boot. However I booted into black screen, so I didn’t choose that way, and reckon maybe not a better choice compared to current situation.
In your case I would think about using Plasma with X11 until the issues have been solved. Gnome + Wayland + Nvidia and fresh hardware could be a challenge.
in my case i didnt use Nvidia driver so far, is it an issue now? i ll try KDE Plasma bit later today.
btw, is it a big issue to be solved? how long may i wait for such pb to be solved
Nobody can tell you.
ok, thanks anyway :slight_smile:
probably still nvidia’s issue, after I switch to unstable and disable nvidia-backlight-wmi (It has error in my journalctl), the freeze situation only happens once in my one week usage, which is acceptable. I think the problem is now solved to some extent :thinking:
